Case Wheel Tractor 320 Operators Manual 9-231
Brand: Case
Type of Machine: Wheel Tractor
Model: Case 320 Tractor
Part Number: 9-231
Number of Pages: 180 Pages
Serial Plates
Introduction
SpecificationS
Lubrication
Tachometer
Engine Oil Body Recommendations
Engine Lubricating Oil Service Designations
Crankcase Lubrication
OilFilter
Air Cleaner & Crankcase Breather,
Speedometer 86 Tachometer,
Power Steering Pump & Reservoir
Steering Gear Housing
Checking Transmission & Final Drive
Eagle Hitch - Hydraulic System
Operating Instructions
Pre—Starting Check List
Service Access Openings
Operating Controls & Instruments
Ignition Key
Instruments
Run-In Procedure
Engine Starting Procedure
Stopping Engine
Shuttle Transmission
Shuttle Travel Speeds
Independent Differential Brakes
EasyRideSeat
Fenders & Platform
Tires & Operating Pressures
Front Wheel Toe-In
EagleHitch
Cold Weather Operation
Fuel Recommendations for Gasoline Tractors
Checks During Operation
Service Diagnosis
Service Suggestions
Automatic Voltage Regulator & Generator
Maintenance
Operating Temperature
Fan Belt Tension
Checking Thermostat '
Care Of Radiator
General Maintenance Of Cooling System
AirCleaner '
Breathers
Carburetor
Load or Power IetcAdjustment
Governor & Engine Speed
Valve Adjustment
Engine Compression
Engine Oil Pump
Ignition System
Front Wheel Bearings
Clutch
Differential Brake Adjustment
Tractor Storage
Introduction
Loader Specifications
Loader Serial Number Plate
Loader Lubrication
Recommended Lubricants
Pressure Fittings
Lubrication Points Drawing
Checking Hydraulic Oil Level in Tank
Tank Breather
Operation (General)
Loader Control Levers
Two-Way Seat Adjustment
Operating Wheel Loader
Loading the Bucket
Leveling or Digging
Prevent Accidents
Hydraulic Reservoir " Suction Line" Filter
Draining Hydraulic Oil
Filling the Reservoir
Maintenance Service Suggestions
Introduction
Backhoe Serial Number Plate
Backhoe Specifications
Backhoe Lubrication
Backhoe Pressure Fittings
Lubrication Chart 1
Backhoe Operating Controls
Operating the Backhoe
Preparation For IOb-to—Iob Travel
Removing Backhoe From Tractor
Reinstalling Backhoe
Bucket Teeth
Hydraulic Cylinders
Checking Hydraulic Pressures (Backhoe)
