Case Wheel Tractor 320 Operators Manual 9-231
Brand: Case
Type of Machine: Wheel Tractor
Model: Case 320 Wheel Tractor
Part Number: 9-231
Number of Pages: 180 Pages
Foreword
Table Of Contents
Serialplates
Introduction
Specifications
Lubrication
Tachometer
Engine Oil Body Recommendations
Engine Lubricating Oil Service Designations
Crankcase Lubrication
Oilfilter
Air Cleaner & Crankcase Breather
Speedometer &'~Tachometer
Power Steering Pump & Reservoir
Steering Gear Housing
Checking Transmission & Final Drive
Eagle Hitch - Hydraulic System
Operating Instructions
Pre-Starting Check List
Service Access Openings
Operating Controls & Instruments
Ignition Key
Instruments
Run-In Procedure
Engine Starting Procedure
Stopping Engine
Shuttle Transmission
Shuttle Travel Speeds
Independent Differential Brakes
Easy Ride Seat
Fenders & Platform
Tires & Operating Pressures
Front Wheel Toe-In
Eaglehitch
Cold Weather Operation
Fuel Recommendations For Gasoline Tractors
Checks During Operation
Service Diagnosis
Service Suggestions
Automatic Voltage Regulator & Generator
Maintenance
Operating Temperature
Fan Belt Tension
Checking Thermostat
Care Of Radiator
General Maintenance Of Cooling System
Aircleaner
Breathers
Carburetor
Load Or Power Ietcadjustment
Governor & Engine Speed
Valve Adjustment
Engine Compression
Engine Oil Pump
Ignition System
Front Wheel Bearings
Clutch
Differential Brake Adjustment
Tractor Storage
