Case Mini Track Loader TL100 Operators Manual 92187327 2023
Brand: Case
Type of Machine: Mini Track Loader
Model: Case TL100 Mini Track Loader
Engine: Kubota D1305 EU Stage V EPA Tier 4 Final
Part Number: 92187327
Publication Date: 2023
Number of Pages: 256 Pages
1 - Introduction
1.1 - Regarding This Manual
1.1.1 - Manual Consultation And Terminology
1.2 - Machine Identification Data
1.3 - Manufacturer
1.3.1 - Contact The After-Sales Network
1.3.2 - Spare Parts
1.4 - Information To The Owner Of The Machine
1.5 - Intended Use
1.6 - Prohibited Use
1.7 - Emissions Overview
2 - Safety
2.1 - Safety Symbol
2.2 - General Safety
2.2.1 - Manual Safety Sign Consultation
2.3 - Safety Signs And Operation Related Labels
2.4 - Machine Driver
2.4.1 - Personal Protective Equipment (Ppe)
2.5 - Work Area - Hazard Zone - No Entry Zone
2.6 - List Of Residual Risks
2.7 - Safety Procedures
2.8 - Safety Devices
2.8.1 - Control Cut-Out Button
2.8.2 - Parking Brake Button
3 - Technical Data
3.1 - General Data
3.2 - Engine
3.3 - Hydraulic System
3.4 - Performance
3.5 - Counterweight
3.6 - Undercarriage
3.7 - Fluid Capacities
3.8 - Electrical System
3.9 - Brakes
3.10 - Operating Load
3.10.1 - Bucket
3.10.2 - Pallet Forks
3.11 - Standard / Optional Equipment
3.12 - Overall Dimensions
Summary
4 - Transporting The Machine
4.1 - Transportation Dimensions
4.2 - Loading/Unloading Operations
4.3 - Securing The Machine On The Mean Of Transport
4.4 - Lifting The Machine
4.4.1 - Lifting Procedure
4.5 - Recovering And Towing The Machine
5 - Controls And Instrumentation
5.1 - Description Of Controls
5.2 - Description Of Control Levers
5.3 - Description Of Dashboard
5.4 - Roller Operation
5.5 - Auxiliary Power Socket On Console
5.6 - Control Panel
5.7 - Battery Isolator Switch
5.8 - Geo-Localisation System
6 - Using The Machine
6.1 - Commissioning
6.2 - Battery Isolator Switch
6.3 - Driver Seat
6.4 - Control Cut-Out Button
6.5 - Parking Brake Button
6.6 - Visibility
6.6.1 - Travel Position
6.7 - Starting The Engine
6.7.1 - Inspections Prior To Starting
6.7.2 - Procedure For Starting The Machine
6.8 - Engine Jump-Starting Procedure
6.8.1 - Connecting The Additional Cables
6.8.2 - Starting The Engine
6.8.3 - Removing The Additional Cables
6.9 - Horn
6.10 - Work Lights
6.11 - Operation At Low Temperatures Or During Winter
6.12 - Precautions During Operation
6.13 - Stopping And Parking The Machine
6.14 - Refuelling
6.15 - Throttle Lever
6.16 - Machine Movement
6.16.1 - Left Joystick
6.16.2 - Forward And Reverse Travel
6.16.3 - Turning While Moving Forward
6.16.4 - Rotation While Reversing
6.16.4.1 - Precautions During The Operation Of The Tracks
Summary
6.17 - Operating The Boom
6.17.1 - Right Joystick
6.17.2 - Boom Floating Control
6.18 - Using The Bucket
6.19 - Discharge Residual Pressure In The Hydraulic System
6.20 - Auxiliary Hydraulic Systems
6.20.1 - Connection Of Equipment To The Hydraulic Systems
6.20.2 - Aux1 Auxiliary Hydraulic System
6.20.2.1 - Hydraulic System Three-Way Switch Aux1
6.20.2.2 - Single-Acting Mode Aux1
6.20.2.3 - Double-Acting Mode Aux1
6.20.2.4 - Auxiliary Hydraulic System Aux1 Latch With Operator Not In The Driver’s Seat
6.20.3 - Drain Line (Direct To Tank - Optional)
6.21 - Electrical Auxiliary Systems (Optional)
6.21.1 - Connecting Equipment To Electrical Systems
6.21.2 - Operation Of Electrical Auxiliary Systems
6.22 - Emergency Boom Lowering Procedure
6.23 - Procedure For The Temporary Activation Of The Controls With The Operator Not
Detected In The Driver’s Seat
6.24 - Supplementary Counterweight Installation And Removal Procedure
6.25 - Daily Storage
7 - Recommended Optional Equipment
7.1 - Safety Precautions
7.2 - Specifications On Authorised Equipment
7.3 - Operating Capacity
7.4 - Quick-Coupling
7.5 - Bucket Teeth And Blade
7.6 - Precautions
8 - Maintenance
8.1 - Safety
8.1.1 - Putting The Machine Out Of Service For Maintenance
8.2 - Tools And Equipment For Maintenance
8.3 - Safety Devices
8.3.1 - Engine Hood
8.3.2 - Upper Compartment Cover (Cushion)
8.3.3 - Lower Compartment Cover
8.3.4 - Oil Tank Compartment Guard
8.4 - Locking The Boom For Maintenance
8.5 - Electrical System
8.6 - Tracks
8.7 - Refilling
8.7.1 - Refilling Quantity Table
8.7.2 - Products For Lubrication
8.7.3 - Fuel
8.7.4 - Engine Oil
Summary
8.7.5 - Cooling Liquid
8.7.6 - Hydraulic System Oils
8.7.6.1 - Requirements For Using Eco-Friendly Hydraulic Oil
8.7.6.2 - Scheduled Plan For Analysis And Control Of Ecological Hydraulic Oil
8.7.6.3 - Requirements For The Sampling Of Eco-Friendly Hydraulic Oil
8.8 - Battery
8.8.1 - Fitting And Removing The Battery
8.8.2 - Recharging The Battery
8.9 - Tightening Torque Tables
8.10 - Weights Of The Material In A Pile
8.11 - Regular Maintenance
8.11.1 - Performance Check
8.11.2 - Check Of Engine Oil Level
8.11.3 - Replacement Of Engine Oil
8.11.4 - Replacement Of Engine Oil Filter
8.11.5 - Check Of Cooling Liquid Level
8.11.6 - Replacement Of Cooling Liquid
8.11.7 - Check And Replacement Of Cooling Liquid Sleeves
8.11.8 - Cleaning The Radiator
8.11.9 - Check Of Hydraulic Oil Level
8.11.10 - Change Discharge Circuit Hydraulic Oil Filter
8.11.11 - Hydraulic System Oil Sampling/Replacement
8.11.12 - Replacement Of Intake Circuit Hydraulic Oil Filter
8.11.13 - Check Of Hydraulic Line Condition
8.11.14 - Check Of Drive Wheel/Roller Screw Tightness
8.11.15 - Track Service Position
8.11.16 - Check Of Track Tension
8.11.17 - Adjusting The Track Tension
8.11.18 - Check Of Tension And Replacement Of Alternator And Fan Belts
8.11.19 - Check And Replacement Of Air Filter
8.11.20 - Replacement Of Fuel Filter
8.11.21 - Draining The Fuel Tank
8.11.22 - Draining Water From The Fuel Circuit
8.11.23 - Cleaning The Filter On The Fuel Intake
8.11.24 - Bleeding Air From The Fuel Circuit
8.11.25 - Level Control And Replacement Of Geared Motors Translation Oil
8.12 - Lubrication Of Pins
8.13 - Long Inactivity Periods
8.14 - Long-Term Storage
9 - Electrical Components
9.1 - Fuses And Relays
9.1.1 - Control Box Fuses
9.1.2 - Control Unit Relays
9.1.3 - Engine Fuses And Relays
9.2 - Work Lights Replacement
Brand: Case
1 - Introduction
1.3 - Manufacturer
1.3.2 - Spare Parts
1.5 - Intended Use
2 - Safety
2.1 - Safety Symbol
3 - Technical Data
3.1 - General Data
3.2 - Engine
3.4 - Performance
3.5 - Counterweight
3.6 - Undercarriage
3.9 - Brakes
3.10.1 - Bucket
Summary
5.6 - Control Panel
6.1 - Commissioning
6.3 - Driver Seat
6.6 - Visibility
6.9 - Horn
6.10 - Work Lights
6.14 - Refuelling
Summary
7.6 - Precautions
8 - Maintenance
8.1 - Safety
8.3.1 - Engine Hood
8.6 - Tracks
8.7 - Refilling
8.7.3 - Fuel
8.7.4 - Engine Oil
Summary
8.8 - Battery
- CASE IH & NEW HOLLAND FAULT CODES
- Case MXM Series 120-190 Tractor Service Manual
- Case 845, 865, 885 Graders Service Manual
- CASE 85XT, 90XT, 95XT Complete Service Manual
- Case Loader 621D Service Manual
- Case IH PUMA 165-225 CVX Service manual
- Case STX Series Steiger Tractor Redefind Four-Wheel Drive Industry
- CASE Backhoe Loader Schematic for 580SR; 590SR; 695SR
- Case Backhoe Loaders 580T 580ST 590ST 695ST Service Manual
- CASE 580SM, 590SM Series 3 Loader Backhoe Electrical Schematic
- CAT 140H Motor Grader Parts Manual
- Case CX210 Crawler Excavator Shop Manual
- Case 845-865-885 Grader Service Manual
- Case Wheel Loader W18-W20 Service Manual
- CASE IH MX215-305 Electrical diagram
