Case Loader Backhoe 580B Service Manual
Brand: Case
Type of Machine: Loader Backhoe
Type of Manual: Service Manual, Schematic Diagram
Model: Case 580B Loader Backhoe
Number of Pages: 649 Pages
Section 11 General Specifications 580B Tractors
Section 12 Detailed Specifications
Section 13 Lubrication 580B Hydrostatic Tractors
Section 13 Lubrication 580B Shuttle Tractors
Section 13 Maintenance and Lubrication for Loader and Backhoe
Section 22 Cylinder Head and Valves 188 Diesel Engines
Section 22 Cylinder Head and Valves 148, 159, 188, 201 Spark Ignition Engines
Section 23 Engine Block Assemblies 180D Diesel and 188G, 159G, 148G Spark Ignition Engines
Section 24 Air Cleaner, Restriction Indicator and Pre-Screener
Section 31 Fuel System and Filters
Section 32 Roosa Master Model DB Fuel Injection Pumps 188 Series Diesel Engines
Section 33 Roosa Master Fuel Injectors 188 Diesel Engines
Section 35 Model 267 Series Carburetor 188G, 159G Spark Ignition Engines
Section 42 Hyrdraulic System and Power Steering Oil Filters
Section 42 Hydraulic Diagrams Trouble Shooting Testing and Service
Section 43 Torque Converter Power Shuttle Hydraulic Pump
Section 43 Equipment Pump
Section 44 3 Point Hitch Cylinders
Section 44B Loader Control Valve
Section 44B Backhoe Control Valve
Section 44C Stabilizer Control Valve
Section 44D Three Point Hitch Control Valve
Section 45 Loader Cylinders
Section 45 Cylinder Removal and Installation
Section 46 Backhoe Cylinders
Section 47 Auxiliary Cylinders
Section 47 Hydra Guide Hydraulics Guidance System
Section 49 Boom Lockout System
Section 52 Power Steering Pump and Hand Pump
Section 53 Steering Control Valve
Section 54 Steering Cylinders and Adjustment
Section 55 Steering Axle and Wheel Bearings
Section 61 Torque Converter, Power Shuttle Counter Shaft, Control Valve and Adjustments
Section 62 Rockford Clutch Power Shuttle Clutch Pack
Section 63 Twin Disc Power Shuttle Clutch Pack
Section 64 Hydrostatic Drive, Gear Train and Control Linkage
Section 65 Four Speed Transmission and Final Drive
Section 66 Mechanical Shuttle
Section 67 Dual Range Assembly
Section 68 11 Inch Traction Clutch
Section 69 Independent Power Take Off
Section 74 Differential Brakes, Differential Lock and Parking Brake
Section 81 Wiring Diagram 580 Series B Diesel and Spark Ignition Tractors
Section 81 Wiring Diagram 580 Series B Diesel and Spark Ignition Forklift Tractors
Section 91 Miscellaneous Equipment
Section 92 Loader
Section 93 Backhoe
Section 97 Three Point Hitch
Section 101 Hydraulic Testing Torque Converter Power Shuttle
Section 151 How It Works Hydrostatic Power Steering
Section 162 How It Works Torque Converter
Section 163 How It Works Torque Converter With Twin Disc Power Shuttle
Section 164 How It Works Hydrostatic Transmission
Brand: Case
Section 92 Loader
Section 93 Backhoe
- CASE IH & NEW HOLLAND FAULT CODES
- Case MXM Series 120-190 Tractor Service Manual
- Case 845, 865, 885 Graders Service Manual
- CASE 85XT, 90XT, 95XT Complete Service Manual
- Case Loader 621D Service Manual
- Case IH PUMA 165-225 CVX Service manual
- Case STX Series Steiger Tractor Redefind Four-Wheel Drive Industry
- CASE Backhoe Loader Schematic for 580SR; 590SR; 695SR
- Case Backhoe Loaders 580T 580ST 590ST 695ST Service Manual
- CASE 580SM, 590SM Series 3 Loader Backhoe Electrical Schematic
- CAT 140H Motor Grader Parts Manual
- Case CX210 Crawler Excavator Shop Manual
- Case 845-865-885 Grader Service Manual
- Case Wheel Loader W18-W20 Service Manual
- CASE IH MX215-305 Electrical diagram
