Hyundai
86
176,834
Case Loader Backhoe 580 Super L Series 2 Parts Catalog
Brand: Case
Type of Machine: Loader Backhoe
Model: Case 580 Super L Series 2 Loader Backhoe
Part Number: Bur 7-3350
Number of Pages: 572 Pages
A
Accumulator, Ride Control
Air Cleaner
Air Cleaner Mounting
Air Conditioner
Air Filter - cab
Alarm - backup
Alarm - warning, engine oil pressure
Alarm - warning, engine water temp
Alarm - warning, parking brake
Allternator - electrical
Alternator Mounting
Antenna - radio
Antirollback - loader
Auxiliary Hydraulics
Axle - Front - four wheel drive
Axle - Front - two wheel drive
Axle - Rear Drive
B
Backhoe
Backhoe Auxiliary Hydraulics
Backup Alarm
Baffle Plates - front covers
Battery - with cold start
Battery - without cold start
Battery Box
Beacon - rotating
Bearings - front wheel
Belts - fan, alternator, and compressor
Belts - seat
Block - cylinder
Blower - air conditioner
Boom Latch
Boom Lock
Boots
Box - battery
Box - tool
Brake - differential, rear axle
Brake - parking, lever
Brake - parking, rear axle
Brake Alarm - parking
Brake Master Cylinder
Brake Pedals
Buckets - backhoe
Buckets - loader
C
Cables - battery
Camshaft - engine
Canopy - ROPS
Chaff Screen
Chassis - tractor
Cluster - instrument
Clutch Cutout
Coat Hook
Cold Start - dual battery
Cold Start System - ether
Column - steering
Compressor and Mounting - A/C
Controls
Control Tower and Covers - backhoe
Cooler - hydraulic oil
Cooling Systems
Core - evaporator, air conditioner
Counterweight - front
Coupler - backhoe bucket
Coupler - quick, loader hydraulic tool
Couplings - auxiliary hydraulics, hand held
Couplings - hydraulic line disconnect
Couplings - hydraulic pump to engine
Covers
Cylinder - brake master
Cylinders - hydraulic
D
Differential and Differential Lock - rear axle
Differential - front axle
Dipper
Dipper - extendable
Dipsticks
Dome Lamp
Drive Shaft
Drive Shaft Guards
E
Electrical Circuits and Components
Engine and Fuel Injection Components
Engine Mounting
Equipment Pump
Evaporator - core, air conditioner
Exhaust/Intake Manifolds
Exhaust System and Muffler
F
Fans
Fenders - cab
Fenders - ROPS canopy, rear
Filters
Floor Plates and Mats
Flywheel and Housing
Frame
Frost Point Assembly
Fuel Injection Nozzle
Fuel Injection Pump
Fuel Injection System
Fuel Level Sensor
Fuel Reservoir Lines
Fuses
G
Gaskets - engine
Gauges
Grille - chaff screen
Grille Unit
Guards
H
Hand Held Auxiliary Hydraulics
Harness - electrical
Head - cylinder and cover
Headliner - cab
Heater - cab
Heater - engine block
Heater - engine oil
Hood and Latch Release
Hook, Coat
Horn - electric
Hub - front wheel
Hydraulic Systems
I
Index - numerical
Injection Nozzle - fuel
Injection Pump - fuel
Injection System - fuel
Injector Nozzle - ether
Instrument Cluster
Instrument Panels and Covers
Intake/Exhaust Manifolds
K
Kits
L
Lamp - dome, cab
Lamps - tractor
Latch Release - hood
Levers - control (See Controls)
Loader
Louvers - cab
M
Manifold - intake/exhaust
Master Cylinder - brake and mounting
Mats and Floor Plates
Mirror - rear view
Motor - wiper
Mud Guard
Muffler - engine exhaust
N
Nozzle - ether injection, cold start
Nozzle - fuel injection
Nozzle - windshield washers
Numerical index
O
Oil Cooler - engine
Oil Cooler - hydraulic
Oil Filter - engine
Oil Filter - hydraulic
Oil Pump and Pan
Outlet - power plug
P
Pads - stabilizers
Pan - oil
Panel - cab control
Panel - closure, rear - canopy
Panel - engine side
Panel - instrument, front and side
Parking Brake - rear axle
Pedals
Pistons and Connecting Rods
Plate - pump guard
Plates - baffle, front covers
Plates - floor and mats
Plug - power outlet
Precleaner
Pulley
Pump
Pump Guard
R
Radiator - engine
Radiator Shroud
Radio Ready Package
Reflector - red
Relays
Reservoir
Reservoir Lines - fuel
Return-to-Dig
Ride Control
Roll Over Protective Structure
Rotating Beacon
S
Screen - Chaff
Seat - operators
Self-Leveling Control
Sender
Sensor - fuel level
Shift Lever - FNR - transmission
Shifter Mechanism - transmission
Shroud - radiator
Side Panels - engine
Slow Moving Vehicle Emblem
Solenoids
Speakers - radio and tape player
Spindles - front axle
Stabilizers
Starter - engine
Starter - mounting
Steering - two wheel drive
Steps
Stereo - radio
Sunvisor
Support Strut - loader lift frame
Switches
T
Tachometer - electric
Tank - fuel
Tank - hydraulic oil
Teeth - buckets
Thermostat - engine
Throttle - engine
Tires and Wheels
Tool Box
Tool Coupler - quick disconnect
Tool Tray
Tower - backhoe control and covers
Tower - swing
Turbocharger and System
Turn Signal Switch
V
Valve Mechanism - engine
Valves
Valve Stem - wheel
Vents - louvers, cab
Visor - sun
W
Washer - Windshield
Wheel - steering
Wheels and Tires
Wiper - cab window
