Case IH Axial Rotary Combines AF9 AF10 Operators Manual 92677247 2025
Brand: Case IH
Type of Machine: Axial Rotary Combines
Model: Case IH AF9, AF10 Axial Rotary Combines
Part Number: 92677247
Publication Date: 2025
Number of Pages: 1030 Pages
GENERAL INFORMATION
Brand: Case IH
GENERAL INFORMATION
Note to the Owner
Intended use
Engine tampering
Electro-Magnetic Compatibility (EMC)
Cybersecurity declarations
Manual scope
Product identification
Operator's manual storage on the machine
SAFETY INFORMATIONSafety alert symbol and signal word definition
Safety signs – Overview
General safety rules
General maintenance safety rules
Wheel and tire safety
Transporting on public roads
Fire prevention
Fire extinguisher
Battery safety
Battery disconnect switch
Seat belt precautions
Instructional seat safety
Operator presence system
Safety rules
Warning lights
Air-conditioning system
Reverse alarm and light
Personal Protective Equipment (PPE)
Do Not Operate hang tag
Hazardous chemicals
Electrical storm safety
Utility safety
Mounting and dismounting precautions
Operating the machine
Connecting a header
Hydraulic system safety
Working at heights
Ecology and the environment
Illustrations
Lift cylinder lockout
Urgent stop button
Airborne noise emission
Vehicle vibration levels
Machine disposal
Safety signs – Right-hand side
Safety signs – Front
Safety signs – Left-hand side
Safety signs – Rear
Safety signs – Top
Road travel signs and decals
Informational decals
CONTROLS AND INSTRUMENTSAccess to operator's platform
Machine access
Rear platform access
Engine access
Rotary dust screen – access
Transmission access
Side shields – Open/Close
Service platforms and shielding
Handwash station
Rotor module – Access
Cleaning system – Access folding hitch/step
Grain tank – Covers
Grain tank access
Clean out doors
Grain tank – Clean out covers
Adjustable threshing cage – Access
Battery access
Access to operator’s platform
Cab mirrors – access
Folding ladder - If equipped
Cab layout
Emergency exit
Operator's seat
Operator's seat
Seat belt – Operator’s seat
Instructional seat
Instructional seat – Overview
Seat belt – Instructional seat
Under seat cooler
Forward controls
Steering column
Urgent stop button
Foot controls
Right-hand side controls
Threshing controls
Cleaning controls
Grain handling
Residue controls
Machine controls
Start console
Multi-Function Handle (MFH)
Unload tube
Pivoting unloading spout
Quick stop
Feedrate control
AFS Accuguide™
Automatic Header Height Control (AHHC)
Configurable header position control – MFH
Configurable reel position control
Configurable position control Setting
Feeder fore/aft tilt – In cab adjustment
Grain tank unloading drive
Shift button
Right-hand console
Drive engagement switches
Reel drive – Controls
Rotor speed – Switch
Module to rotor clearance – Controls
Rotor discharge deflector switch
Remote adjustable vanes – switch
Threshing short cut – shortcut switch
Cleaning fan speed control – Switch
Upper sieve – Switch
Lower sieve – Switch
Cleaning settings shortcut – switch
Gear selector
Throttle control
Light memory – switch
Road / Auto guide mode – switch
Grain tank covers – switch
Folding unload tube – switch
Chopper counter knife – Position switch
Spreader speed – Control switch
Spread distribution – switch
Residue spreader – shortcut switch
Automatic differential – switch
Parking brake
Variable Powered Rear Axle (VPRA) – Control
High/Low – Control
Header height control
Feeder – Controls
Vertical knife – Control
AFS Pro-1200
Armrest - Overview
Rearward controls
Rear window
Cab features – Storage and fuse access
Overhead controls
Overhead controls
Sun screens
Cab climate controls
Overhead storage
Cab radio
Cab radio - DEA730 radio
Phone app
Interior lamps
Communication equipment – Power connection and mounting
Exterior controls
Exterior switches – Rear frame control panel
Battery connect – operation
Display
AFS®Pro 1200 display
AFS® Pro 1200 display overview – Overview
Notification bar
Machine status area
Work switch status
Faults & Warnings
Global Navigation Satellite System (GNSS)
Connectivity
Applications
Help
Clock
User Profiles
Menu - Settings
Headers
Calibrations
Menu screens
System settings
Data settings
ISOBUS settings
Connectivity settings
Header settings
Combine settings
Header setup
FD2/D2 Header
Combine corn header – Set up
Grain header – Set up
Draper/Varifeed™ header – Set up
Pickup header – Set up
Procedures & Calibration
Yield & Moisture Monitor
GNSS & Guidance settings
Activations
Diagnostics
AFS® Pro 1200 diagnostics and troubleshooting
Header diagnostics
Combine diagnostics
Productivity
Automatic Crop Settings (ACS)
AFS Harvest Command™ – Overview
Camera - Overview
Procedures
Calibrations
Concave opening
Gear position
Inclination sensor(s)
Hydro-mechanical rotor
Side Shake Upper Shoe
Spreader Frame Position
Swath Door Position – Actuator
Side Shake Grain Pan
Sieves – Upper and lower sieves
Steering Angle
Suspended Tracks Height - Height
Folding unload tube
Feeder Hydro-mechanical
Zero Returns
Counter knives
Distance calibration
Unloading tube swing
Chopper gearbox
Rotor gearbox
Steering valve
Calibration error list
Procedure Overview
Kill stall
Sieves – Pressure sensor test
Automatic Deslug Feeder
Automatic Deslug Feeder + Rotor – System overview
Fluid level check
Rotor Loss Sensor – Test
ActiveTrac 4-Roller Track – Tension / Untension
Sieve Loss Sensor – Test
Cleanout control
Run screens
Overview
Sensitivity settings
Lighting and mirrors
Lighting controls
OPERATING INSTRUCTIONSCommissioning the unit
Before driving the combine
Track Transmission Unlock
Starting the unit
Daily start up procedure
Starting the engine – Cold weather
Stopping the unit
Stopping the engine
Stopping the engine
Engine idle speed
Moving the unit
Moving the machine
Road travel
ActiveTrac 4-Roller Track – Road travel
Parking brake – Manual release
Transmission – Manual shifting
TRANSPORT OPERATIONSPreparing for road transport
Jacking points – Locations
Transporting on a trailer – Tie downs for shipping
Lifting the machine
Transport latches
Operator's platform – Prepare for transport
Engine shield
Attaching a trailer
Speed and gradeability
Recovery transport
Towing the machine
WORKING OPERATIONSGeneral information
Introduction to harvesting
Initial crop settings
NO TITLENO TITLE
NO TITLE
NO TITLENO TITLE
NO TITLE
NO TITLENO TITLE
NO TITLE
Performance indicators
Change from grain to corn configuration
Losses
Kill-Stall diagnosis
Crop setup values – Crop condition adjustment
Header height control – Overview
Header status – Header Height Control Status Icons
Header height control – Manual mode
Header height control – Sensitivity
Header height control – Return To Cut (RTC) mode
Header height control – Auto Header Height Control (AHHC)
Header height control – Pressure float mode
Header height control – Lateral tilt
Feedrate control
Feedrate control
ACS Automatic Crop Settings
AFS Harvest Command™ – Activation
AFS Harvest Command™ – Run screen
AFS Harvest Command™ – Basic tab
AFS Harvest Command™ – Advanced tab
AFS Harvest Command™ – Sensitivities tab
AFS Harvest Command™ – Headland tab
AFS Harvest Command™ – Status tab
AFS Harvest Command™ – Ranges tab
AFS Harvest Command™ – Information
AFS Harvest Command™ – Operation
AFS Harvest Command™ – Sensitivity adjustment
Automation – Residue control
Header connection
Connecting a header
Disconnecting a header
Feeding
Feeding
Synchronized Feed System (SFS) - Rock trap
Synchronized Feed System (SFS) – Reverser
Feeder drum – Adjust lower stop
Feeder chain – Adjustment
Feeder chain – Link removal
Reel speed
Feeder reverse system - Overview
Threshing
Rotor overview
Threshing concave – overview
Module Adjustment – Position overview
Concave - Remove
Concave - Install
Concave position – Minimum, maximum concave opening
Concave H-Frame – Leveling
Concave H-Frame – Side shift adjustment
Concave H–frame stop bolt adjustment
Threshing and separation
Suggested start up configurations for major crops
Rotor overview
Rotor deslug
Separation
Separator grates - Overview
Separator grates - Remove
Separator grates - Install
Beater / Chopper
Hood mounted chopper
Integrated chopper
Discharge beater
Discharge beater grate
Integrated chopper
Integrated chopper – Chopper grate
Cleaning
Cleaning – System overview
Cleaning system
Sieves – Controls
Sieves – Calibrate
Sieves – Removal
Sieves – Installation
Cleaning fan
Automatic cleaning fan speed
Tailings system
Tailings return system - Adjust
Tailings return system - Overview – Cover storage location
Grain handling
Grain handling
Unloading
Grain sample access
Grain tank with covers
Unloading tube – Folding unload tube
Unloading operation
Grain handling deslug – Clean out
Residue handling
Residue handling
Chaff deflectors
Chaff pan
Chaff pan – Position for sieve removal
Chaff pan – Loss check position (Hood mounted chopper only)
Discharge deflector
Swath chute – and Straw rakes
Residue controls – In cab spreader controls
In cab residue mode control
Residue handling – Operational Modes
Troubleshooting
Integrated chopper
Horizontal Disc Spreader
Spreader Integrated Chopper
Integral chopper – Overview
Integrated chopper counter knives
Integrated chopper counter knives – Lateral adjustment
Knife replacement – Integrated Chopper counter knives
Knife replacement – Chopper
Residue handling – Disc spreader integrated chopper configuration
Horizontal disc spreader – Recommended operational settings – Integrated Chopper
Residue spreader – Position
Swath Door Position – (if equipped)
Swath roller – (if equipped)
Oscillating deflector
Spreader Integrated Chopper – Spread width adjustment
Horizontal spreader – Recommended operational settings – Integrated Chopper
Spreader Hood Mounted Chopper
Hood mounted chopper – Overview
Chopper speed
Counter knife
Counter knife – Blades
Straw chopper – Blades
Straw chopper blades - configuration for corn
Straw beater – Blades
Spreader Hood Mounted Chopper – Position
Spreader Hood Mounted Chopper – Spread width adjustment
Chopper bypass – (If equipped)
Horizontal spreader – Recommended operational settings – Hood Mounted Chopper
MAINTENANCEGeneral information
Maintenance - Overview
Torque specifications for hardware
Torque - Standard torque data for hydraulic connections - Standard torque data for hydraulic connections
Chain wear tables - roller chains
Battery – Overview
Battery box ventilation – Overview
Battery – Charging and jump starting
Air reservoir
General specification - Biodiesel fuels
Organic Acid Technology (OAT) coolant
Engine oils
Engine oils
Fluids, lubricants, and capacities
Maintenance planning
Maintenance chart
Every 10 hours or daily during the first week
Wheel bolt torque
Every 2 hours
After the first 10 hours
Belt tension
Cab air pre-filter - Cleaning – Pre-screen
Rotary dust screen – Cleaning
Cooler fan gearbox – Gearbox level
Check the engine oil level
Power Take-Off (PTO) gearbox oil level
Hydraulic oil tank
Rock trap
Coolant level
Coolant level
ActiveTrac 4-Roller Track – Inspection
ActiveTrac 4-Roller Track – Suspended track Inspection
Hood mounted chopper – Cleaning
Hood mounted chopper – Straw chopper blades
Hood mounted chopper – Counter knife blades
Every 50 hours or weekly
Front face adjustment – wear strip check
Every 50 hours
50-hour grease points
Tire pressure – Check
Rotary dust screen - Brush adjustment
Feeder conveyor chain
Belt tension
ActiveTrac 4-Roller Track – Oil level
Every 100 hours
100-hour grease points
Every 250 hours
Every 300 hours
300 hour grease points
Transmission oil level
Final drive oil level
Lower unloading gearbox – Oil level
Rotor gearbox oil level
Right-hand rotor gearbox
Synchronized Feed System (SFS) gearbox oil level
Integrated chopper gearbox
Tailings gearbox
Feeder header drive gearbox – level
After the first 600 hours
Engine - valve clearance check – (Cursor 13 only)
Every 600 hours
Cab fresh air filter
Cab recirculation filter
Air cleaner element
Every 600 hours or yearly
Engine fuel filter
Fuel prefilter/water separator
Battery Box
Every 750 hours
Lower unloading gearbox – Change oil
Final Drive Oil - Change – Change oil
Transmission – Change oil
Tailings gearbox – Change oil
Feeder header drive gearbox – Change oil
Feeder header drive slip-clutch – Change oil
Right-hand rotor gearbox – Change oil
Synchronized Feed System (SFS) - Change oil
Cooler fan gearbox – Change oil
Integrated chopper drive gearbox – Change oil
Power Take-Off (PTO) – Change oil
Rotor drive gearbox – Change oil
Hydraulic oil reservoir - Change oil
Hood mounted chopper gearbox – Change oil
Variable Powered Rear Axle (VPRA) – Central gearbox oil change
Variable Powered Rear Axle (VPRA) - Change oil
Every 750 hours or every 2 years
Engine oil and filter – Cursor 16
Engine oil and filter – Cursor 13
Fuel tank breather
Fuel tank strainer
Every 1200 hours
Alternator belt – (Cursor 13)
Every 1200 hours or two years
Air cleaner safety element
Air conditioning filter drier
Every 1500 hours
ActiveTrac 4-Roller Track – Oil change
Alternator belt – (Cursor 16)
Every 1800 hours
Engine crankcase breather filter
Engine crankcase breather filter - (Cursor 16 Only)
Every 2400 hours
Engine valve adjustment
Every 4000 hours or four years
Engine coolant replacement
As required maintenance
Machine cleaning
Machine cleaning
GrainCam™ – Cleaning
Windshield washer reservoir
Fuel system bleeding
Hydraulic fluid – filling
Roof lights
Steering toe-in - Adjust
Rear axle steering cylinder - Adjust
Fuse and relay locations
Storage
Post-season
Residue spreader - Post season cleaning
Preseason service
TROUBLESHOOTINGAlarm(s)
Alarm description
Display alarms
GrainCam™ – Alarms
SPECIFICATIONSTire care
Wheel removal
Single drive wheel – Mounting
Floatation drive wheel – Mounting
Dual drive wheel – Mounting
Temporary transport – Single wheel
Steering axle – Overview
Steering wheel
Approved tires and tracks
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLEAF9 Tire pressure
NO TITLE
Tire inflation
Tire inflation pressures - AF9 - 20 kph (12mph)
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
Tire inflation pressures - AF9 - 25 kph (16mph)
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
Tire inflation pressures - AF9 - 30 kph (19mph)
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
Tire inflation pressures - AF9 - 40 kph (25mph)
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLEAF10 Tire pressure
NO TITLE
Tire inflation pressures - AF10 - 20 kph (12mph)
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
Tire inflation pressures - AF10 - 25 kph (16mph)
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
Tire inflation pressures - AF10 - 30 kph (19mph)
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
Tire inflation pressures - AF10 - 40 kph (25mph)
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
NO TITLENO TITLE
Machine dimensions
Machine specifications
ACCESSORIESGeneral information
Feeding
Clean grain, grain tank, and unloading
Residue handling
Miscellaneous
FORMS AND DECLARATIONSDelivery report - Owner Copy
Delivery report - Dealer Copy
Service record - 1st 50 Hour, Customer Copy
Service record - 1st 50 Hour, Dealer Copy
ActiveTrac 4-Roller Track – Workshop data sheet
ActiveTrac 4-Roller Track – Difficult to align - Report
FD2/D2 Header
- Case IH Model Tractors JX60 - JX70-JX80-JX90-JX95 Service Manual
- Case IH Tractor Puma 170CVX,185CVX, 200CVX,215CVX,230CVX,170,185,200 Service Manual
- Case David Brown 885-885G Instruction Book
- Case 40XT Hydraulic & Wiring Diagram
- Case 40XT Skid Steer Bur 6-22031NA Operators Manual
- Case IH Tractor 5100 Series Maxxum Service Manual 7-32487
- Case David Brown 880 Selectamatic Service Parts Catalogue Manual
- Case 580F Side Shift Backhoe-Loader Specification Manual
- Case IH Tractor 955 1055 Diesel Service Manual_1091320R1
- Case IH Series Tractor Operators Manual CD
- Case 75XT Skid Steer 7-11463 Service Manual
- Case IH Service Manual 1640, 1660, 1680 Axial-Flow Combine 7-38422 English
- Case IH 956 1056 XL Workshop Service Manual
- Case David Brown Tractors 1210-1212 Instruction Book
- Case IH Tractor MXM120 MXM130, MXM140, MXM155, MXM175, MXM190 Repair Manual 87613647
