Hyundai
86
176,834
Case IH Axial Rotary Combines AF11 Operators Manual 92736079 2025
Brand: Case IH
Type of Machine: Axial Rotary Combines
Model: Case IH AF11 Axial Rotary Combines
Part Number: 92736079
Publication Date: 2025
Number of Pages: 934 Pages
GENERAL INFORMATION
Intended use​
Engine tampering​
Electro-Magnetic Compatibility (EMC)​
Cybersecurity declarations​
Manual scope​
Product identification​
Operator's manual storage on the machine​
Machine orientation​
SAFETY INFORMATION
Safety alert symbol and signal word definition​
Safety signs – Overview​
General safety rules​
General maintenance safety rules​
Wheel and tire safety​
Transporting on public roads​
Fire prevention​
Fire extinguisher​
Battery safety​
Battery disconnect switch​
Seat belt precautions​
Instructional seat safety​
Operator presence system​
Safety rules​
Warning lights​
Air-conditioning system​
Reverse alarm and light​
Personal Protective Equipment (PPE)​
Do Not Operate hang tag​
Hazardous chemicals​
Electrical storm safety​
Utility safety​
Mounting and dismounting precautions​
Operating the machine​
Connecting a header​
Hydraulic system safety​
Working at heights​
Ecology and the environment​
Illustrations​
Lift cylinder lockout​
Urgent stop button​
Airborne noise emission​
Vehicle vibration levels​
Machine disposal​
Safety signs – Right-hand side​
Safety signs – Front​
Safety signs – Left-hand side​
Safety signs – Rear​
Safety signs – Top​
Selective Catalytic Reduction (SCR) exhaust treatment - Safety signs​
Road travel signs and decals​
Informational decals​
CONTROLS AND INSTRUMENTS
Access to operator's platform​
Machine access​
Rear platform access​
Engine access​
Rotary dust screen – access​
Transmission access​
Side shields – Open/Close​
Service platforms and shielding​
Handwash station​
Rotor module – Access​
Cleaning system – Access folding hitch/step​
Grain tank – Covers​
Grain tank access​
Clean out doors​
Grain tank – Clean out covers​
Adjustable threshing vanes – Access​
Battery access​
Access to operator’s platform​
Cab mirrors – access​
Folding ladder - If equipped​
Cab layout​
Emergency exit​
Operator's seat​
Operator's seat​
Seat belt – Operator’s seat​
Instructional seat​
Instructional seat – Overview​
Seat belt – Instructional seat​
Under seat cooler​
Forward controls​
Steering column​
Urgent stop button​
Foot controls​
Right-hand side controls​
Threshing controls​
Cleaning controls​
Grain handling​
Residue controls​
Machine controls​
Start console​
Multi-Function Handle (MFH)​
Unload tube​
Pivoting unloading spout​
Quick stop​
Feedrate control​
AFS Accuguide™​
Automatic Header Height Control (AHHC)​
Configurable header position control – MFH​
Configurable reel position control​
Configurable position control Setting​
Feeder fore/aft tilt – In cab adjustment​
Grain tank unloading drive​
Shift button​
Right-hand console​
Drive engagement switches​
Reel drive – Controls​
Rotor speed – Switch​
Concave clearance – Controls​
Adjustable cage vane switch – switch​
Threshing short cut – shortcut switch​
Cleaning fan speed control – Switch​
Upper sieve – Switch​
Lower sieve – Switch​
Cleaning settings shortcut – switch​
Gear selector​
Throttle control​
Light memory – switch​
Road / Auto guide mode – switch​
Grain tank covers – switch​
Folding unload tube – switch​
Chopper counter knife – Position switch​
Spreader speed – Control switch​
Spread distribution – switch​
Residue spreader – shortcut switch​
Automatic differential – switch​
Parking brake​
Variable Powered Rear Axle (VPRA) – Control​
High/Low – Control​
Header height control​
Feeder – Controls​
Vertical knife – Control​
AFS Pro-1200​
Armrest - Overview​
Rearward controls​
Rear window​
Cab features – Storage and fuse access​
Overhead controls​
Overhead controls​
Sun screens​
Cab climate controls​
Overhead storage​
Cab radio​
Cab radio - DEA730 radio​
Phone app​
Interior lamps​
Communication equipment – Power connection and mounting​
Exterior controls​
Exterior switches – Rear frame control panel​
Battery connect – operation​
Display​
AFS®Pro 1200 display​
AFS® Pro 1200 display overview – Overview​
Notification bar​
Machine status area​
Work switch status​
Faults & Warnings​
Global Navigation Satellite System (GNSS)​
Connectivity​
Applications​
Help​
Clock​
User Profiles​
Menu - Settings​
Headers​
Calibrations​
Menu screens​
System settings​
Data settings​
ISOBUS settings​
Connectivity settings​
Header settings​
Combine settings​
Header setup​
FD2/D2 Header​
Combine corn header – Set up​
Grain header – Set up​
Draper/Varifeed™ header – Set up​
Pickup header – Set up​
Procedures & Calibration​
Yield & Moisture Monitor​
GNSS & Guidance settings​
Activations​
Diagnostics​
AFS® Pro 1200 diagnostics and troubleshooting​
Header diagnostics​
Combine diagnostics​
Productivity​
Automatic Crop Settings (ACS)​
AFS Harvest Command™ – Overview​
Camera - Overview​
Procedures​
Calibrations​
Concave opening​
Feeder fore/aft tilt​
Gear position​
Inclination sensor(s)​
Hydro-mechanical rotor​
Side Shake Upper Shoe​
Remote adjustable vanes​
Spreader Frame Position​
Swath Door Position – Actuator​
Side Shake Grain Pan​
Sieves – Upper and lower sieves​
Steering Angle​
ActiveTrac 4-Roller Track - Height​
Folding unload tube​
Feeder Hydro-mechanical​
Zero Returns​
Counter knives​
Distance calibration​
Unloading tube swing​
Chopper gearbox​
Rotor gearbox​
Steering valve​
Calibration error list​
Procedure Overview​
Kill stall​
Sieves – Pressure sensor test​
Automatic Deslug Feeder​
Automatic Deslug Feeder + Rotor – System overview​
Fluid level check​
Rotor Loss Sensor – Test​
ActiveTrac 4-Roller Track – Tension / Untension​
Sieve Loss Sensor – Test​
Cleanout control​
Run screens​
Overview​
Sensitivity settings​
Lighting and mirrors​
Lighting controls​
Selective Catalytic Reduction (SCR) system​
Selective Catalytic Reduction (SCR) exhaust treatment - Overview​
NO TITLE
NO TITLE​
NO TITLE​
NO TITLE
NO TITLE​
NO TITLE​
NO TITLE
NO TITLE​
NO TITLE​
OPERATING INSTRUCTIONS
Commissioning the unit​
Before driving the combine​
Track Transmission Unlock​
Starting the unit​
Daily start up procedure​
Starting the engine – Cold weather​
Stopping the unit​
Engine idle speed​
Moving the unit​
Moving the machine​
Road travel​
ActiveTrac 4-Roller Track – Road travel​
ActiveTrac 4-Roller Track​
Parking brake – Manual release​
Transmission – Manual shifting​
TRANSPORT OPERATIONS
Preparing for road transport​
Jacking points – Locations​
Transporting on a trailer – Tie downs for shipping​
Transport latches​
Operator's platform – Prepare for transport​
Engine shield​
Attaching a trailer​
Speed and gradeability​
Recovery transport​
Towing the machine​
WORKING OPERATIONS
General information​
Introduction to harvesting​
Initial crop settings​
NO TITLE
NO TITLE​
NO TITLE​
NO TITLE
NO TITLE​
NO TITLE​
NO TITLE
NO TITLE​
NO TITLE​
Performance indicators​
Change from grain to corn configuration​
Losses​
Kill-Stall diagnosis​
Crop setup values – Crop condition adjustment​
Header height control – Overview​
Header status – Header Height Control Status Icons​
Header height control – Manual mode​
Header height control – Sensitivity​
Header height control – Return To Cut (RTC) mode​
Header height control – Auto Header Height Control (AHHC)​
Header height control – Pressure float mode​
Header height control – Lateral tilt​
Feedrate control​
Feedrate control​
ACS Automatic Crop Settings​
AFS Harvest Command™​
AFS Harvest Command™ – Activation​
AFS Harvest Command™ – Run screen​
AFS Harvest Command™ – Basic tab​
AFS Harvest Command™ – Advanced tab​
AFS Harvest Command™ – Sensitivities tab​
AFS Harvest Command™ – Headland tab​
AFS Harvest Command™ – Status tab​
AFS Harvest Command™ – Ranges tab​
AFS Harvest Command™ – Information​
AFS Harvest Command™ – Operation​
AFS Harvest Command™ – Sensitivity adjustment​
Automation – Residue control​
Header connection​
Disconnecting a header​
Feeding​
Feeding​
Synchronized Feed System (SFS) - Rock trap​
Synchronized Feed System (SFS) – Reverser​
Feeder drum – Adjust lower stop​
Feeder chain – Adjustment​
Feeder chain – Link removal​
Reel speed​
Feeder reverse system - Overview​
Threshing​
Rotor – Dual rotor​
Rotor cage - module overview​
Module Adjustment – Position overview​
Concave – Leveling​
Concave H-Frame – Concave concentricity​
Concave – Minimum, maximum concave opening​
Concave - Remove​
Concave - Install​
Suggested start up configurations for major crops​
Rotor overview​
Rotor deslug​
Concave Overload Protection – (if equipped)​
Separation​
Separator grates - Overview​
Separator grates - Remove​
Separator grates - Install​
Separator grate – For wet and green crops​
Beater / Chopper​
Hood mounted chopper​
Integrated chopper​
Discharge beater​
Discharge beater grate​
Integrated chopper​
Integrated chopper – Chopper grate​
Cleaning​
Cleaning – System overview​
Cleaning system​
Sieves – Controls​
Sieves – Calibrate​
Cleaning fan​
Automatic cleaning fan speed​
Tailings system​
Tailings return system - Adjust​
Tailings return system - Overview – Cover storage location​
Grain handling​
Grain handling​
Grain sample access​
Grain tank with covers​
Unloading tube – Folding unload tube​
Unloading operation​
Grass seed unload assistance – Kit​
Grain handling deslug – Clean out​
Residue handling​
Residue handling​
Chaff deflectors​
Chaff pan​
Chaff pan – Position for sieve removal​
Chaff pan – Loss check position (Hood mounted chopper only)​
Swath chute – and Straw rakes​
Residue controls – In cab spreader controls​
In cab residue mode control​
Residue handling – Operational Modes​
Troubleshooting​
Integrated chopper​
Horizontal Disc Spreader​
Spreader Integrated Chopper​
Integrated chopper – Overview​
Integrated chopper counter knives​
Integrated chopper counter knives – Lateral adjustment​
Knife replacement – Integrated Chopper counter knives​
Knife replacement – Chopper​
Horizontal disc spreader​
Residue handling – Disc spreader integrated chopper configuration​
Horizontal Disc Spreader – Recommended operational settings – Integrated Chopper​
Residue spreader – Position​
Swath Door Position – (if equipped)​
Swath roller – (if equipped)​
Oscillating deflector​
Spreader Integrated Chopper – Spread width adjustment​
Horizontal spreader – Recommended operational settings – Integrated Chopper​
Spreader Hood Mounted Chopper​
Hood mounted chopper – Overview​
Chopper speed​
Counter knife​
Counter knife – Blades​
Straw chopper – Blades​
Straw chopper blades - configuration for corn​
Straw beater – Blades​
Spreader Hood Mounted Chopper – Position​
Spreader Hood Mounted Chopper – Spread width adjustment​
Chopper bypass – (If equipped)​
Horizontal spreader – Recommended operational settings – Hood Mounted Chopper​
MAINTENANCE
Maintenance - Overview​
Torque specifications for hardware​
Torque - Standard torque data for hydraulic connections - Standard torque data for hydraulic connections​
Chain wear tables - roller chains​
Battery – Overview​
Battery box ventilation – Overview​
Battery – Charging and jump starting​
Air reservoir​
General specification - Diesel fuel​
General specification - Biodiesel fuels​
Organic Acid Technology (OAT) coolant​
Engine oils​
Engine oils​
Fluids, lubricants, and capacities​
Maintenance planning​
Maintenance chart​
Every 2 hours​
ActiveTrac 4-roller Track​
After the first 10 hours​
Belt tension​
Every 10 hours or daily​
Cab air pre-filter - Cleaning – Pre-screen​
Rotary dust screen – Cleaning​
Cooler fan gearbox – Gearbox level​
Power Take-Off (PTO) gearbox oil level​
Hydraulic oil tank​
Rock trap​
ActiveTrac 4-Roller Track – Inspection​
Hood mounted chopper – Cleaning​
Hood mounted chopper – Straw chopper blades​
Hood mounted chopper – Counter knife blades​
Every 50 hours or weekly​
Front face adjustment – wear strip check​
Every 50 hours​
50-hour grease points​
Tire pressure – Check​
Rotary dust screen brush - Brush adjustment​
Feeder conveyor chain​
Belt tension​
Fuel tank breather filter - Clean​
Every 100 hours​
100-hour grease points​
Every 250 hours​
Stone trapping system - Check​
Every 300 hours​
300 hour grease points​
Transmission oil level​
Rotor gearbox oil level​
Right-hand rotor gearbox​
Synchronized Feed System (SFS) gearbox oil level​
Integrated chopper gearbox​
Tailings gearbox​
Feeder header drive gearbox – level​
Every 600 hours​
Diesel Exhaust Fluid (DEF)/AdBlue® tank vent filter​
Cab fresh air filter​
Cab recirculation filter​
Air cleaner element​
Every 600 hours or yearly​
Engine fuel filter​
Fuel prefilter/water separator​
Concave control system - Grease​
Every 750 hours​
Lower unloading gearbox – Change oil​
Final Drive Oil - Change – Change oil​
Transmission – Change oil​
Tailings gearbox – Change oil​
Feeder header drive gearbox – Change oil​
Feeder header drive slip-clutch – Change oil​
Right-hand rotor gearbox – Change oil​
Synchronized Feed System (SFS) - Change oil​
Cooler fan gearbox – Change oil​
Integrated chopper drive gearbox – Change oil​
Rotor drive gearbox – Change oil​
Power Take-Off (PTO) gearbox – Change oil​
Hood mounted chopper gearbox – Change oil​
Variable Powered Rear Axle (VPRA) – Central gearbox oil change​
Variable Powered Rear Axle (VPRA) - Change oil​
Hydraulic oil reservoir - Change oil​
Every 750 hours or every 2 years​
Fuel tank breather​
Fuel tank strainer​
Engine oil and filter - Cursor 16L​
Every 1200 hours​
Diesel Exhaust Fluid (DEF)/AdBlue® in tank filter​
Every 1200 hours or two years​
Air cleaner safety element​
Air conditioning filter drier​
Every 1500 hours​
ActiveTrac 4-Roller Track – Oil change​
Alternator belt – (Cursor 16)​
Every 1800 hours​
Engine crankcase breather filter​
Engine crankcase breather filter - (Cursor 16 Only)​
Every 2400 hours​
Engine valve adjustment​
Every 3600 hours or two years​
Diesel Exhaust Fluid (DEF)/AdBlue® supply module filter​
As required maintenance​
Machine cleaning​
Machine cleaning​
GrainCam™ – Cleaning​
Windshield washer reservoir​
Fuel system bleeding​
Hydraulic fluid – filling​
Roof lights​
Steering toe-in - Adjust​
Rear axle steering cylinder - Adjust​
Fuse and relay locations​
Storage​
Post-season​
Residue spreader - Post season cleaning​
Preseason service​
TROUBLESHOOTING
Alarm(s)​
Display alarms​
GrainCam™ – Alarms​
SPECIFICATIONS
Tire care​
Wheel removal​
Single drive wheel – Mounting​
Floatation drive wheel – Mounting​
Dual drive wheel – Mounting​
Temporary transport – Single wheel​
Steering axle – Overview​
Steering wheel​
Approved tires and tracks​
NO TITLE
NO TITLE​
NO TITLE
NO TITLE​
NO TITLE
NO TITLE​
Tire inflation​
Tire inflation pressures - 20 kph (12mph)​
NO TITLE
NO TITLE​
NO TITLE
NO TITLE​
NO TITLE
NO TITLE​
NO TITLE
NO TITLE​
NO TITLE
NO TITLE​
Tire inflation pressures - 25 kph (16mph)​
NO TITLE
NO TITLE​
NO TITLE
NO TITLE​
NO TITLE
NO TITLE​
NO TITLE
NO TITLE​
NO TITLE
NO TITLE​
Tire inflation pressures - 30 kph (19mph)​
NO TITLE
NO TITLE​
NO TITLE
NO TITLE​
NO TITLE
NO TITLE​
NO TITLE
NO TITLE​
NO TITLE
NO TITLE​
Tire inflation pressures - 40 kph (25mph)​
NO TITLE
NO TITLE​
NO TITLE
NO TITLE​
NO TITLE
NO TITLE​
NO TITLE
NO TITLE​
NO TITLE
NO TITLE​
Machine dimensions​
ACCESSORIES
Feeding​
Threshing and separation​
Engine​
Clean grain, grain tank, and unloading​
Cab​
Residue handling​
Miscellaneous​
FORMS AND DECLARATIONS
Delivery report - Owner Copy​
Delivery report - Dealer Copy​
Service record - 1st 50 Hour, Customer Copy​
Service record - 1st 50 Hour, Dealer Copy​
ActiveTrac 4-Roller Track – Workshop data sheet​
ActiveTrac 4-Roller Track – Difficult to align - Report​
FD2/D2 Header​
