Case IH Agricultural STEIGER 425 to STEIGER 785 QUADTRAC Operators Manual 92811178 2026
Brand: Case IH
Type of Machine: Agricultural
Model: Case IH
STEIGER® 425, STEIGER® 425
ROWTRAC™, STEIGER® 475,
STEIGER® 475 QUADTRAC®,
STEIGER® 475 ROWTRAC™,
STEIGER® 525, STEIGER® 525
QUADTRAC®, STEIGER® 525
ROWTRAC™, STEIGER® 555,
STEIGER® 555 QUADTRAC®,
STEIGER® 595, STEIGER® 595
QUADTRAC®, STEIGER® 645,
STEIGER® 645 QUADTRAC®,
STEIGER® 715 QUADTRAC®,
STEIGER® 785 QUADTRAC®
PIN JEEZXXXXXTF30001 and above
Part Number: 92811178
Publication Date: 2026
Number of Pages: 744 Pages
GENERAL INFORMATION
Brand: Case IH
Model: Case IH
GENERAL INFORMATION
Note to the owner
Intended use
CNH Industrial America LLC technical manuals
Your tractor
Electro-Magnetic Compatability (EMC)
ISOBUS certification
Cybersecurity declarations
Product identification
Operator's manual storage on the machine
Machine orientation
Component location
SAFETY INFORMATIONSafety alert symbol and signal word definition
Safety rules
Ecology and the environment
Protective structures
Emergency exit
Articulation cylinder locking blocks
Safety signs
Organic Acid Technology (OAT) coolant - Safety signs
Global warming potential
Informational signs
Lifting the machine
CONTROLS AND INSTRUMENTSAccess to operator's platform
Cab access/exit
Wireless phone charger
Operator's seat
Operator's seat
Control identification
Instructional seat
Overview
Forward controls
Ignition switch
Transmission control lever
Turn signal lever/indicators
Main lighting control
Horn switch
Windshield wiper and washer controls
Pedal controls
Steering column adjustment
Ventilation
Front sun shade
Right-hand side controls
Armrest console
Multi-function handle
Engine speed controls
Primary navigation panel
Power Take-Off (PTO) controls
Hitch controls
Center armrest controls
Remote valve controls
Adjusting the armrest console
Rearward controls
Ventilation
Rear sun shade
Cab storage
Overhead controls
Headliner console
Cab climate controls
Cab climate control system
Interior and access lights
Step courtesy light
Interior rear-view mirror
Exterior controls
Exterior hitch control
Outside extendable mirrors
Display
Date, time, units and language setup
Brightness and volume
Display overview
User management
Armrest control configuration
Tractor settings - saved configurations
Admin settings
Armrest navigation settings
Instrument cluster
Overview
Gauges
Warning and status indicators
PowerDrive working status and settings
CVXDrive™ working status and settings
Operating status
Tractor setup
Tractor lighting
Tire radius calibration
Radar calibration
Tire radius chart
Tire Pressure Monitoring System (TPMS)
Camera locations and settings
Radio app - 700 series non-DAB radio (if equipped)
Radio app - DAB radio (if equipped)
Premium audio
Phone app
OPERATING INSTRUCTIONSCommissioning the unit
Before starting the engine
Starting the unit
Normal engine starting
Cold starting aids
Cold temperature operation
Stopping the unit
Stopping the machine and the engine
Battery isolator logic switch
Moving the unit
Full powershift transmission
Continuously Variable Transmission (CVT)
All tractors
Inching (clutch) pedal operation
Overview
PowerDrive transmission controls
Direction, gear and status display
Driving the PowerDrive transmission
PowerDrive transmission settings
Automatic Productivity Management (APM)
ECO power mode
CVXDrive™ transmission
CVXDrive™ brake, pedal and throttle operation
CVXDrive™ controls
Direction, range and status display
Driving the CVXDrive™ transmission
Assisted Steering (AST)
Electro-hydraulic backup system
Wheel angle sensor calibration
Steering valve calibration
Differential lock system
Engagement zone
Power management
Constant Engine Speed (CRPM)
Headland Management Control (HMC)
ISOBUS automation
Engine compression brake
Reversible Cooling Fan
Parking the unit
Automatic park lock
Park brake engagement - CVXDrive™ transmission
TRANSPORT OPERATIONSRoad transport
Tractor warning lamps
Operating the tractor warning lamps
Safe transport speed
Implement warning lamps and Slow Moving Vehicle (SMV) symbol
Safety chain
Shipping transport
Securing the tractor for shipping
Recovery transport
Safety rules
Towing the tractor
WORKING OPERATIONSGeneral information
Product overview
REAR POWER TAKE-OFF (PTO)
Power Take-Off (PTO) safety rules
Connecting the Power Take-Off (PTO)
Power Take-Off (PTO) operation
Auto Power Take-Off (PTO) operation
THREE-POINT HITCH
Identification
Link adjustment
Sway block adjustment
Mechanical float adjustment
Hitch quick coupler - Category IVN
Roading switch - hydraulic transport lock
Hitch operation
Rear remote hitch switch
Work switch source setting
Position control operation
Slip control operation
Automatic Depth Control (ADC)
Rear hitch position sensor calibration
Hitch valve calibration
DRAWBARS AND TOWING ATTACHMENTS
Safety rules
Drawbar capacities
Scraper operation
TRAILER BRAKE COUPLER
Safety rules
Trailer brake connections
AUXILIARY POWER CONNECTIONS
External power and lighting connections
Cab connectivity ports
HMC power outlet
GPS signal for implements
HYDRAULIC REMOTE CONTROL VALVES
Valve couplers and connections
Auxiliary hydraulic circuits
Operating the lever controls
Remote valve display screens
Auto auxiliary mode operation
Auto trailer steering lock
Hydraulic oil level warnings
BALLASTING THE TRACTOR
Guidelines
Weights, cast metal and liquid
Wheel weight bolt torque
Wheel slip
FRONT AND REAR AXLE
Tire safety
Pressure and load ratings
Wheel installation
Wheel tread settings on bar axles
Pre-conditioning rubber tracks
MAINTENANCEGeneral information
General information
Engine hood
Engine side shields
Filling the windshield washer fluid
Opening the right-hand service door
Battery access
Power cut-off switch
Filling the fuel tank
Fuel tank capacity
Tire and rim service
Tractor jacking points
Engine oils
Consumables - Diesel fuel - Diesel fuel
Consumables - Biodiesel fuels - Biodiesel fuels
Electrical specifications
Battery system
Auxiliary battery connections
Engine hourmeter
Maintenance planning
Maintenance chart
At warning message display
Engine air filter message
Fuel filters - Replace
Every 10 hours or daily
Engine oil level
Wheel bolt torque
Idler and roller wheel oil
Tracks
Transmission oil level
Hydraulic and axle oil level
Engine coolant level
Secondary cooling system level
Fuel level
General tractor inspection
Every 50 hours
Fuel tank and fuel filter
Articulation hinge - Upper front
Oscillation hinge - Rear
Articulation hinge - Lower
Articulation cylinder - Front, left hand, right hand
Articulation cylinder - Rear, left hand and right hand
Hitch cylinder pin - Upper (if equipped)
Hitch cylinder pin - Lower (if equipped)
Hitch rockshaft - Left-hand and right hand
Hitch lift links and top link
Driveshaft carrier bearing
Track inspection
First 100 hours
PowerDrive transmission filter
PowerDrive transmission clutches
CVXDrive™ transmission filters
CVXDrive™ transmission clutches
Power Take-Off clutches on CVXDrive™ transmission
Engine fuel filter
Hydraulic oil filters
First 600 hours
Engine valve adjustment - 13L engine
Every 600 hours
Engine oil and filter
Engine fuel filter
Engine fuel pre-filter
Fuel tank vent
Cab air filter, outside
Air tubing - engine
Power Take Off (PTO) carrier bearing
Power Take Off (PTO) slip joint
Radiator and coolers
Cab recirculation filter
Drive wheel scraper
Door lock/hinges and hood latch
Track inspection and bolt torque
Idler/Automatic belt tensioner - 16L engine
Every 1200 hours
PowerDrive transmission oil and filter
PowerDrive transmission breather
CVXDrive™ transmission oil and filters
CVXDrive™ transmission breather
Engine air filters
Battery electrolyte level
Front End Accessory Drive (FEAD) belt
Every 1800 hours
Hydraulic oil and filters
Hydraulic reservoir breather
Engine crankcase breather filter
Every 2400 hours
Idler/Automatic belt tensioner - 13L engine
Suspended undercarriage thrust washers
Every 3600 hours
Engine coolant drain and flush
Secondary cooling system drain and flush
Every 4800 hours
Undercarriage bushing and seals
Yearly
Ride height - Suspended undercarriage
As required
Vehicle fire prevention
Remote valve couplers
Pressure cooling system hoses
Hydraulic system hoses
Tire pressure
Viscous fan drive
Track tension release
Track alignment
Cab fabric and carpet
Seat belt
Battery removal and installation
Saddle tanks
Tool box
Fuse and relay locations
Component identification
Storage
Placing in storage
Removing from storage
TROUBLESHOOTINGFault code resolution
Fault code message overview
Alarm(s)
Display warnings overview
High severity display warnings
Medium severity display warnings
Low severity display warnings
Symptom(s)
Engine symptoms
Transmission symptoms
Hydraulic symptoms
Hitch symptoms
Brake symptoms
Cab environment symptoms
Electrical power system symptoms
SPECIFICATIONSEngine specifications
Power train and hydraulics
Fluids, lubricants, and capacities
Speed charts - PowerDrive transmission
Speed charts - CVXDrive™ transmission
Transport speed and weight for tracked machines
Vehicle dimensions and shipping weight
Maximum operating weight
ACCESSORIESChemical tank mounting
General accessories
Business band radios
Dual displays
DiagnosticsManaging service records
Monitoring tractor components
- Case IH Model Tractors JX60 - JX70-JX80-JX90-JX95 Service Manual
- Case IH Tractor Puma 170CVX,185CVX, 200CVX,215CVX,230CVX,170,185,200 Service Manual
- Case David Brown 885-885G Instruction Book
- Case 40XT Hydraulic & Wiring Diagram
- Case 40XT Skid Steer Bur 6-22031NA Operators Manual
- Case IH Tractor 5100 Series Maxxum Service Manual 7-32487
- Case David Brown 880 Selectamatic Service Parts Catalogue Manual
- Case 580F Side Shift Backhoe-Loader Specification Manual
- Case IH Tractor 955 1055 Diesel Service Manual_1091320R1
- Case IH Series Tractor Operators Manual CD
- Case 75XT Skid Steer 7-11463 Service Manual
- Case IH Service Manual 1640, 1660, 1680 Axial-Flow Combine 7-38422 English
- Case IH 956 1056 XL Workshop Service Manual
- Case David Brown Tractors 1210-1212 Instruction Book
- Case IH Tractor MXM120 MXM130, MXM140, MXM155, MXM175, MXM190 Repair Manual 87613647
