Hyundai
86
176,834
Case IH Agricultural Puma 185 to 260 CVX AFS Connect Operators Manual 92742525 2025
Brand: Case IH
Type of Machine: Agricultural
Model: Case IH
Puma® 185 CVX AFS Connect™
Puma® 200 CVX AFS Connect™
Puma® 220 CVX AFS Connect™
Puma® 240 CVX AFS Connect™
Puma® 260 CVX AFS Connect™
PIN *NDL50001 and above
Part Number: 92742525
Publication Date: 2025
Number of Pages: 754 Pages
GENERAL INFORMATION
Note to the owner​
Note to the owner (Chinese market only)​
Intended use​
Electro-Magnetic Compatability (EMC)​
Manual scope and required training level​
Metric and imperial units abbreviations​
Product identification​
Engine identification​
Drive line identification​
Cab identification​
Product identification plate​
Programming tractor functions​
Operator's manual storage​
Before operating the tractor​
Tractor orientation​
Selective catalytic reduction (SCR) system​
SAFETY INFORMATION
Safety rules and signal word definitions​
Safety rules​
Personal protective equipment (PPE)​
Instructor's seat​
Wheel chocks​
Emergency exit​
Protection offered by the tractor​
Burn prevention​
Prevention of fire or explosions​
Fire extinguisher​
Hazardous substances​
Ecology and the environment​
Machine stability​
Safety decals​
Tractor jacking points​
CONTROLS AND INSTRUMENTS
ACCESS TO OPERATOR'S PLATFORM​
Key entry​
Keyless entry (where fitted)​
Keyless Entry System (where fitted)​
Mounting and dismounting the tractor​
Rear window​
Sun visor​
Cab storage​
Phone/tablet mounting bracket​
Additional monitor mounting​
OPERATOR'S SEAT​
Operator's seat​
Air suspension seat deluxe​
Air suspension seat with Dynamic Damping System (DDS)​
Air suspension seat 'evolution active'​
Seat belt​
INSTRUCTOR'S SEAT​
Instructional seat​
FORWARD CONTROLS​
Steering column adjustment​
Shuttle lever​
Turn signal lever/indicators​
Windshield wiper and washer controls​
Clutch pedal​
Foot brakes​
Engine exhaust brake (where fitted)​
LEFT-HAND SIDE CONTROLS​
Main lighting control​
Horn switch​
RIGHT-HAND SIDE CONTROLS​
Armrest console​
Multifunction Handle​
Engine speed controls​
Primary navigation panel​
Power Take-Off (PTO) controls​
Hitch controls​
Center armrest controls​
Remote valve controls​
Joystick (where fitted)​
Adjusting the armrest console​
OVERHEAD CONTROLS​
Headliner console​
Cab climate controls​
Cab climate control system​
Interior lights​
Step courtesy light​
EXTERIOR CONTROLS​
Rear fender controls​
Front hitch controls​
DISPLAY​
Date, time, units and language setup​
Brightness and volume​
Display overview​
User management​
Armrest control configuration​
Tractor settings - saved configurations​
INSTRUMENT CLUSTER​
Instrument cluster​
Gauges​
Warning and status indicators​
Transmission status and settings​
Operating status​
TRACTOR SETUP​
Tractor lighting​
Managing key fobs, Keyless Entry System setup​
Phone app​
Radio app - DEA7xx radio​
Radio app - DEA5xx radio​
Subwoofer (where fitted)​
OPERATING INSTRUCTIONS
COMMISSIONING THE UNIT​
Before starting the engine​
Refueling the tractor​
STARTING THE UNIT​
Normal engine starting (with key)​
Normal engine starting (keyless)​
Starting and moving in cold temperatures​
Grid heater cold start aid (where fitted)​
Fuel heater (where fitted)​
Coolant immersion heater (where fitted)​
Transmission oil heater (where fitted)​
Battery isolator functionality​
Jump starting​
STOPPING THE UNIT​
Stopping the engine​
Automatic engine shut down​
MOVING THE UNIT​
Clutch pedal and throttle​
Direction, range and status display​
Driving the tractor​
Low idle speed management​
PARKING THE UNIT​
Park brake​
Automatic park brake (APB)​
Hand brake​
TRANSPORT OPERATIONS
PREPARING FOR ROAD TRANSPORT​
Carrying the tractor on a transporter​
RECOVERY TRANSPORT​
Freeing a stuck tractor​
Towing the tractor​
WORKING OPERATIONS
GENERAL INFORMATION​
Field operation​
Suspension​
Engine operation​
After Treatment System​
Steering​
Four Wheel Drive (4WD) - Mechanical Front Drive (MFD)​
Differential lock system​
Engagement zone / Relative hitch position​
Suspended axle​
Hydraulic cab suspension​
Constant Engine Speed (CRPM)​
Reversible fan​
Selective Catalytic Reduction (SCR) system​
Engine low idle increase message​
Engine idling or full catalyst messages​
Variable Ratio Steering (VRS)​
TRANSMISSION​
Transmission operation​
Transmission brake, pedal and throttle operation​
Transmission controls​
Transmission controls on color display​
Pneumatic Trailer Brake Stabilization System​
REAR POWER TAKE-OFF (PTO)​
Power Take-Off (PTO) operating precautions​
Changing the PTO output shaft​
Attaching PTO driven equipment​
Rear Power Take-Off (PTO) operation​
Multiple speed Power Take-Off (PTO) systems (electrical)​
Two speed Power Take-Off (PTO) systems (mechanical)​
Auto Power Take-Off (PTO) operation​
Power Take-Off (PTO) fender switch operation​
FRONT POWER TAKE OFF​
Front Power Take-Off (PTO) operation​
External PTO controls​
REAR HITCH​
Identification​
Attaching three-point hitch equipment​
Lift rod adjustment​
Top link adjustment​
Quick hitch​
Automatic stabilizers (where fitted)​
Hydraulic stabilizers (where fitted)​
Hydraulic right links (where fitted)​
Rear hitch controls​
Position control operation​
Draft control operation​
Ride control operation​
Slip control operation​
External hitch controls​
FRONT HITCH​
Settings and adjustments​
Front hitch operation​
Auxiliary front couplers (where fitted)​
External controls for front couplers​
ELECTRO-HYDRAULIC REMOTE CONTROL VALVES (where fitted)​
Valve couplers and connections​
Non pressure oil return port​
Hydraulic master switch​
Operating the controls​
Remote valve display screens​
Auto auxiliary control valve​
Auto trailer steering lock​
Joystick operation​
External EHR controls​
Transmission, rear axle, and hydraulic system oil level​
Automated headland functions​
Automated headland functions - Basic​
Automated headland functions - Advanced (where fitted)​
GPS based Automatic Playback of headland management sequence​
Headland Management Control (HMC II)​
Recording a sequence​
Creating a sequence in standstill​
Saving a sequence​
Replaying a sequence​
Editing sequences​
Recalling and deleting a sequence​
Symbols and triggers​
Warning messages​
AFS AccuTurn Pro™ operation with GPS Trigger​
HYDRAULIC POWER BEYOND PORT​
Power beyond circuit​
DRAWBARS AND TOWING ATTACHMENTS​
Drawbars and towing attachments​
Swinging drawbar​
Automatic pickup hitch​
Rear trailer hitches​
TRAILER BRAKING SYSTEMS​
Air-operated trailer brakes (Universal type)​
Air-operated trailer brakes (UK type)​
Auxiliary air supply connector (where fitted)​
Hydraulic trailer brakes (Universal type - Dual line)​
Hydraulic trailer brakes (Universal type - Single line)​
WHEELS AND TIRES​
Front wheels​
Rear wheels​
Tightening torques​
Safety precautions​
Tire combinations​
Front wheel track adjustment​
Front wheel alignment​
Steering stops​
Front axle oscillation stops​
Front wheel fenders​
Flange type axle (where fitted)​
Bar type axle (where fitted)​
Dual rear wheels (where fitted)​
Front wheel tightening torque values​
Rear wheel tightening torque values​
BALLASTING AND TIRES​
Ballasting and tires​
Rear wheel weights​
Front ballast​
Liquid ballast​
Tire inflation​
Tire pressures and permissible loads​
AUXILIARY POWER CONNECTIONS​
Electrical power connectors​
Diagnostic socket​
Trailer electrical socket​
Internal power connectors​
External power connectors​
ISOBUS classes and Tractor Implement Management (TIM)​
ISOBUS automation and Tractor Implement Management (TIM) activation​
Reconfigurable inputs for ISOBUS function​
MAINTENANCE
Introduction​
Fuel requirement - Diesel fuel​
Fuel - Storage, handling and transport​
General specification - Paraffinic (Diesel) Fuels​
Biodiesel fuel - Biodiesel fuels​
Fluids, lubricants, and capacities​
Engine oils​
Protective devices​
Organic Acid Technology (OAT) coolant​
Managing service records​
Monitoring tractor components​
MAINTENANCE CHART​
Maintenance chart​
WHEN THE WARNING LAMP LIGHTS​
Change the engine air cleaner outer element​
Drain the fuel system water separator​
FIRST 10 HOURS​
Check the front loader screws​
EVERY 10 HOURS OR EACH DAY​
Remove all trash or organic debris material accumulation​
Check the engine coolant level​
Check the engine oil level​
Check the remote control valve drain bottles​
Check windscreen washer reservoir​
Drain air reservoir on air operated trailer brake​
FIRST 50 HOURS​
Service operations​
EVERY 50 HOURS​
Clean the cab air filter​
Clean the cooler section​
Grease all fittings (except rear axle)​
Check the front wheel, rear wheel and rear wheel weight nuts​
Check the tire pressures and the tire condition​
EVERY 150 HOURS​
Check the air operated trailer brakes compressor belt​
EVERY 375 HOURS​
Check the main belt​
Check the battery fluid level​
Check the transmission oil level, the rear axle oil level and the hydraulic oil level​
Check the front PTO gearbox oil level​
Adjust the hand brake​
EVERY 750 HOURS​
Change the engine oil and filter​
Change the fuel filters​
Change the charge pump filter cartridge​
Change the transmission oil filter​
Change the lubrication filter​
Check the engine air intake connections​
Check the transmission oil cooler pipe couplings​
Check the 4WD front axle differential oil​
Check the front hubs oil level​
EVERY 750 HOURS OR EVERY YEAR​
Clean the front PTO breather filter​
Grease the rear axle shaft bearing​
EVERY 750 HOURS OR EVERY 2 YEARS​
Change the front hubs oil​
Check the handbrake​
EVERY YEAR​
Check the diaphragm accumulators (where fitted)​
EVERY 1500 HOURS​
Change the front PTO suction filter and gearbox oil​
EVERY 1500 HOURS OR EVERY YEAR​
Change the internal cab air filters​
Change the external cab air filters​
EVERY 1500 HOURS OR EVERY 2 YEARS​
Change the engine air cleaner inner element​
Change the air brake drier reservoir​
Change the transmission oil, the rear axle oil and the hydraulic oil​
Change the suction filter cartridge​
Change the 4WD differential oil​
Change the engine breather filter​
Change the Diesel Exhaust Fluid (DEF)/AdBlue® suction filter​
EVERY 2 YEARS​
Change the air conditioning receiver drier​
EVERY 1500 HOURS OR EVERY 4 YEARS​
Change the main belt​
Change the air operated trailer brakes compressor belt​
EVERY 2250 HOURS​
Check the engine tappet valve clearance​
EVERY 3750 HOURS OR EVERY 3 YEARS​
Change the DEF/AdBlue main filter​
EVERY 3750 HOURS OR EVERY 4 YEARS​
Change the engine coolant fluid​
GENERAL MAINTENANCE​
Cleaning the tractor​
Catalyst Management​
Cleaning the DEF/AdBlue control unit area​
Check first stage fuel filter and water trap​
Bleeding the fuel system​
Hydraulic system hoses​
Electrical socket maintenance​
Check the brake pedal latching/unlatching​
Adjust the cab suspension​
Adjust the automatic pickup hitch​
Headlight adjustment​
Work light adjustment​
Bulb replacement​
Fuses and relays​
Protecting the electronic and electrical systems during battery charging or welding​
Battery removal and installation​
Fob battery​
STORAGE​
Tractor storage​
Machine long-term storage and/or disposal​
Removing the machine from storage​
TROUBLESHOOTING
FAULT CODE RESOLUTION​
General​
Fault code message overview​
ALARM(S)​
ISOBUS automation fault codes​
Display warnings overview​
High severity display warnings​
Medium severity display warnings​
Low severity display warnings​
ISOBUS automation fault codes overview​
Alarm and fault code index​
SYMPTOM(S)​
TRACTOR CALIBRATIONS​
Engine​
Transmission​
Hydraulics​
Three-point hitch​
Rear Power Take-Off (PTO)​
Brakes​
Cab​
Electrical system​
Electronic Park Lock (EPL) - Initialization​
Overview​
Wheel angle sensor calibration​
Steering valve calibration​
SPECIFICATIONS
General dimensions​
Minimum turn radius​
Axle dimension​
Maximum permissible operating weights​
Tractor weights​
Maximum operating angle​
Engine​
Fuel system​
Air cleaner system​
Cooling system​
Transmission​
Front Power Take-Off (PTO)​
Hydraulic system​
Rear three-point hitch​
Front three-point hitch​
Remote control valves​
Front remote control valve​
Brakes​
Steering​
Electrical equipment​
Minimum hardware tightening torques​
ACCESSORIES
Rear-view mirrors​
Cameras (where fitted)​
Wireless camera (where fitted)​
Extremity warning lights​
Rotating beacon​
Municipality light bar (where fitted)​
Hand rinse tank (where fitted)​
Auxiliary pneumatic coupler​
FORMS AND DECLARATIONS
Telematics module declaration of conformity​
