Case IH Agricultural MAXXUM 115 to MAXXUM 150 Operators Manual 92798149 2026
Brand: Case IH
Type of Machine: Agricultural
Model: Case IH
MAXXUM® 115
MAXXUM® 125
MAXXUM® 135
MAXXUM® 145
MAXXUM® 150
Part Number: 92798149
Publication Date: 2026
Number of Pages: 546 Pages
GENERAL INFORMATION
Brand: Case IH
Model: Case IH
MAXXUM® 115
MAXXUM® 125
MAXXUM® 135
MAXXUM® 145
MAXXUM® 150
GENERAL INFORMATION
Note to the owner
Intended use
Electro-magnetic compatibility (EMC)
Manual scope and required training level
Metric and imperial units abbreviations
Product identification
Engine identification
Drive line identification
Transmission identification
Cab identification
Product identification plate
Operator's manual storage
Programming tractor functions
Before operating the tractor
Machine orientation
Selective Catalytic Reduction (SCR) system
SAFETY INFORMATIONSafety rules and signal word definitions
Safety rules
Personal protective equipment (PPE)
Instructor's seat
Wheel chocks
Emergency exit
Protection offered by the tractor
Burn prevention
Prevention of fire or explosions
Fire extinguisher
Hazardous substances
Ecology and the environment
Machine stability
Safety decals
Tractor jacking points
CONTROLS AND INSTRUMENTSACCESS TO OPERATOR'S PLATFORM
Introduction
Cab air filters
In cab storage (where fitted)
Cable and wiring routing
Phone/tablet mounting bracket
Implement monitor installation
OPERATOR'S SEAT
Operator's seat
Air suspension seat deluxe
Air suspension seat with Dynamic Damping System (DDS)
Seat belt
INSTRUCTOR'S SEAT
Instructional seat
FORWARD CONTROLS
Ignition key
Hazard light switch
Lights and turn indicator lever
Follow me home lights
Windshield wiper and washer controls
Clutch pedal
Foot throttle pedal
Hand throttle
Foot brakes
Exhaust brake (where fitted)
Steering column
LEFT-HAND SIDE CONTROLS
Hand brake
RIGHT-HAND SIDE CONTROLS
Switch panel
Advanced Steering Control activation switch
Autoguidance system
REARWARD CONTROLS
Switches on C-pillar
Battery isolator control switch
Hydraulic master switch
Climate controls (Low-profile cab)
Manual temperature control (Low-profile cab)
OVERHEAD CONTROLS
Switch panel
Left-hand and right-hand outermost work light switch
Interior light
Climate controls
Automatic Temperature Control (ATC)
INSTRUMENT CLUSTER
Analog Digital Instrument Cluster (ADIC)
Gauges
Indicator and warning lights
Displays
Keypad enhanced
Selecting or changing the display settings
Ground speed calibration
Performance monitor
Active and Manual Catalyst Management
Color monitor (where fitted)
Pop-up screens on color display
Performance monitor on color display
Programming the displays
Alarm functions
Accessing stored fault codes
Selective Catalytic Reduction (SCR) exhaust treatment - Overview
Warning and advisory symbols
OPERATING INSTRUCTIONSCOMMISSIONING THE UNIT
Refueling the tractor
STARTING THE UNIT
Starting the engine
Grid heater cold start aid (where fitted)
Fuel heater (where fitted)
Coolant immersion heater (where fitted)
Transmission oil heater (where fitted)
Jump starting
STOPPING THE UNIT
Stopping the engine
Automatic engine shut down
MOVING THE UNIT
Operating in cold temperatures
Low idle speed management
TRANSPORT OPERATIONSPREPARING FOR ROAD TRANSPORT
Carrying the tractor on a transporter
Secure the high visibility roof panel
RECOVERY TRANSPORT
Freeing a stuck tractor
Towing the tractor
WORKING OPERATIONSGENERAL INFORMATION
HTS standard
Variable engine power management
Constant engine speed
Differential lock
Four wheel drive
Front axle suspension (where fitted)
Quick guide
Explanation of symbols
Recording and replaying
Recording a sequence
Replaying a sequence
TRANSMISSION
Shuttle lever
Shuttle aggressiveness
Transmission operation
Transmission display
Transmission controls
Shuttle mode
Powershift control lever
Driving the tractor
Auto take off
Speed matching
Auto shift function
Auto shifting field mode
Auto shifting in road mode
Changing the field mode auto shift point
Creeper gears
Fault codes
REAR POWER TAKE-OFF
Power Take-Off (PTO) operating precautions
Changing the PTO output shaft
Attaching PTO driven equipment
Power Take-Off (PTO) operation
Two or Three speed PTO systems
Ground drive PTO (where fitted)
External PTO controls
Auto PTO operation
FRONT POWER TAKE OFF
REAR HITCH
Electronic Draft Control (EDC)
Electronic Draft Control (EDC) operation
External hitch controls
FRONT HITCH
Settings and adjustments
Hitch operation
Auxiliary front couplers (where fitted)
Front hitch management
HYDRAULIC REMOTE CONTROL VALVES
Remote control valves
Connecting remote cylinders
Operating with remote valves
Hydraulic oil level when using remote hydraulic equipment
HYDRAULIC POWER BEYOND PORT
Hydraulic power beyond for external services
THREE POINT HITCH
Attaching three-point hitch equipment
Lift rod adjustment
Top link adjustment
Quick hitch
Linkage stabilizer adjustment
DRAWBARS AND TOWING ATTACHMENTS
Drawbars and towing attachments
Swinging drawbar
Automatic pickup hitch
Rear trailer hitches
TRAILER BRAKING SYSTEMS
Trailer brake release switch
Air-operated trailer brakes (Universal type)
Air-operated trailer brakes (UK type)
Auxiliary air supply connector (where fitted)
Hydraulic trailer brakes (Universal type - Dual line)
Hydraulic trailer brakes (Universal type - Single line)
WHEELS AND TIRES
Front wheels
Rear wheels
Tightening torques
Tire combinations
Front wheel track adjustment
Front wheel alignment (four wheel drive)
Steering stops
Wheel Angle Sensor (WAS) calibration
Front axle oscillation stops
Front fender
Flange type axle (where fitted)
Bar type axle (where fitted)
Dual rear wheels (where fitted)
Front wheel tightening torque values
Rear wheel tightening torque values
BALLASTING AND TIRES
Ballasting and tires
Iron weights (where fitted)
Liquid ballast
Tire inflation
Tire pressures and permissible loads
AUXILIARY POWER CONNECTIONS
ELECTRICAL POWER CONNECTORS
Diagnostic socket
Trailer socket electrical
Internal power connectors
External power connectors
ISOBUS classes
MAINTENANCEGENERAL INFORMATION
Introduction
Fuel requirement - Diesel fuel
Fuel - Storage, handling and transport
General specification - Paraffinic (Diesel) Fuels
Biodiesel fuel
Protective devices
Engine oils
Fluids, lubricants and capacities
Organic Acid Technology (OAT) coolant
MAINTENANCE CHART
Maintenance chart
WHEN THE WARNING LIGHT IS ON
Change the engine air cleaner outer element
Drain the fuel system water separator
Check the brake fluid level
FIRST 10 HOURS
Check the front loader screws
EVERY 10 HOURS OR EACH DAY
Remove all trash or organic debris material accumulation
Check the engine coolant level
Check the engine oil level
Check the remote control valve drain bottles
Check windscreen washer reservoir
Drain air reservoir on air operated trailer brake
FIRST 50 HOURS
Service operations
EVERY 50 HOURS
Clean the cab air filter
Clean the cooler section
Grease all fittings
Check the front wheel, rear wheel and rear wheel weight nuts
Check the tire pressures and the tire condition
EVERY 150 HOURS
Check the main belt
Check the air conditioning compressor drive belt
Check the compressor drive belt
EVERY 375 HOURS
Check the battery fluid level
Check the transmission oil level, the rear axle oil level and the hydraulic oil level
Check the 4WD differential oil
Check the front hubs oil level
Check the front PTO gearbox oil level
EVERY 750 HOURS
Change engine oil and filter
Change the fuel filters
Change the charge pump filter (CCLS system)
Change the low pressure filter (OCLS system)
Check the engine air intake connections
Check the transmission oil cooler pipe couplings
Clean the DEF/AdBlue® suction filter
EVERY 750 HOURS OR EVERY YEAR
Check the accumulators (where fitted)
EVERY 750 HOURS OR EVERY 2 YEARS
Change the front hubs oil
Check the handbrake
EVERY 1500 HOURS
Change the front PTO gearbox oil
EVERY 1500 HOURS OR EVERY YEAR
Change the external cab air filters
Change the internal cab air filters
Grease the rear axle shaft bearing
EVERY 1500 HOURS OR EVERY 2 YEARS
Change the engine air cleaner inner element
Check the valve tappet clearance
Change the Diesel Exhaust Fluid (DEF)/AdBlue® suction filter
Change the suction filter cartridge (CCLS system)
Change the suction filter (OCLS system)
Change the air brake drier cartridge
Change the transmission oil, the rear axle oil and the hydraulic oil
Change the 4WD differential oil
Change the engine breather filter
Change the air conditioning compressor drive belt
EVERY 1500 HOURS OR EVERY 4 YEARS
Change the main belt
Change the pneumatic trailer brakes compressor belt
EVERY 2 YEARS
Change the air conditioning desiccant bag
EVERY 3750 HOURS OR EVERY 3 YEARS
Change the DEF/AdBlue® main filter
EVERY 3750 HOURS OR EVERY 4 YEARS
Change the engine coolant fluid
GENERAL MAINTENANCE
Cleaning the tractor
Cleaning the DEF/AdBlue control unit area
Check first stage fuel filter and water trap
Bleeding the fuel system
Hydraulic system hoses
Check the brake pedal latching/unlatching
Adjust the automatic pickup hitch
Headlight adjustment
Work light adjustment
Bulb replacement
Fuses and relays
Protecting the electronic and electrical systems during battery charging or welding
Battery removal and installation
STORAGE
Tractor storage
Machine long-term storage and/or disposal
Preparation for use after storage
TROUBLESHOOTINGFAULT CODE RESOLUTION
General
Introduction
ALARM(S)
Fault codes and symbols
SYMPTOM(S)
Hydraulics
Three-point hitch
Brakes
Electrical system
SPECIFICATIONSGeneral dimensions
Minimum turn radius
Axle dimension
Maximum operating angle
Maximum tractor operating weights
Tractor weights
Fuel system
Air cleaner system
Cooling system
Rear Power Take-Off (PTO)
Front Power Take-Off (PTO)
Three-point hitch
Three-point hitch front
Hydraulic system
Front remote control valve couplers
Brakes
Steering
Electrical equipment
Ground speed chart
Minimum hardware tightening torques
ACCESSORIESRadio (where fitted)
External rear view mirrors
Border marker plates (where fitted)
Auxiliary headlights
Rotating beacon (where fitted)
Front-end loader fixation points
FORMS AND DECLARATIONSTelematics module declaration of conformity
- Case IH Model Tractors JX60 - JX70-JX80-JX90-JX95 Service Manual
- Case IH Tractor Puma 170CVX,185CVX, 200CVX,215CVX,230CVX,170,185,200 Service Manual
- Case David Brown 885-885G Instruction Book
- Case 40XT Hydraulic & Wiring Diagram
- Case 40XT Skid Steer Bur 6-22031NA Operators Manual
- Case IH Tractor 5100 Series Maxxum Service Manual 7-32487
- Case David Brown 880 Selectamatic Service Parts Catalogue Manual
- Case 580F Side Shift Backhoe-Loader Specification Manual
- Case IH Tractor 955 1055 Diesel Service Manual_1091320R1
- Case IH Series Tractor Operators Manual CD
- Case 75XT Skid Steer 7-11463 Service Manual
- Case IH Service Manual 1640, 1660, 1680 Axial-Flow Combine 7-38422 English
- Case IH 956 1056 XL Workshop Service Manual
- Case David Brown Tractors 1210-1212 Instruction Book
- Case IH Tractor MXM120 MXM130, MXM140, MXM155, MXM175, MXM190 Repair Manual 87613647
