Hyundai
86
176,834
Case IH Agricultural FARMALL 100M 110M 120M Operators Manual 92684499 2025
Brand: Case IH
Type of Machine: Agricultural
Model: Case IH FARMALL 100M,FARMALL 110M, FARMALL 120M Agricultural
Part Number: 92684499
Publication Date: 2025
Number of Pages: 432 Pages
GENERAL INFORMATION
Note to the Owner​
Intended use​
Electro-Magnetic Compatibility (EMC)​
ISOBUS certification​
Manual scope and required training level​
Metric and imperial units abbreviations​
Identification plates​
Cab identification​
Programming tractor functions​
Operator's manual storage on the machine​
Machine orientation​
Component identification​
Health and safety related standards applied to your tractor​
Selective Catalytic Reduction (SCR-T) exhaust treatment - Product overview​
International symbols​
SAFETY INFORMATION
Safety rules and signal word definitions​
Safety rules​
Personal protective equipment (PPE)​
Ecology and the environment​
Noise level​
Vibration levels​
Machine stability​
Towing the tractor for recovery​
Tractor jacking points​
Burn prevention​
Prevention of fire or explosions​
Protection offered by the tractor​
Hazardous substances​
Emergency escape from cab​
Wheel chock​
Instructional seat​
Guards and shields​
Safety signs​
Instructional signs​
CONTROLS AND INSTRUMENTS
Access to operator's platform​
Mounting and dismounting​
Getting to know the internal parts of the cab​
Rear-view outside mirrors​
Operator's seat​
Air seat – “DELUXE” model​
Air seat – “PREMIUM” model​
Seat belt​
Forward controls​
Dashboard​
Front controls​
Left-hand side controls​
Left side post controls​
Left side console​
Handbrake​
Right-hand side controls​
Right side post controls​
Heating, ventilation or air-conditioning control​
Cab air filters​
Right-hand console​
Hand throttle​
Park lock​
Exterior controls​
Exterior controls​
Display​
Performance windows​
Adjusting the dashboard/display brightness​
Ground speed calibration​
Setting the implement width​
Programming maintenance work​
Activating/deactivating buzzer​
Setting units of measurement​
Regenerating the diesel particulate filter (DPF) automatically/manually​
Resetting the oil change counter​
Viewing error codes​
Warning and advisory symbols​
Display warnings overview​
OPERATING INSTRUCTIONS
Commissioning the unit​
Basic operating safety rules​
Refueling​
Filling the Diesel Exhaust Fluid (DEF)/AdBlue® tank​
Starting the unit​
Engine operation​
Coolant immersion heater (where fitted)​
Transmission oil heater (where fitted)​
Stopping the unit​
Stopping the engine​
Electronic battery isolator - Operating​
Moving the unit​
Machine movement start-up​
Operating in cold temperatures​
Low idle speed management​
TRANSPORT OPERATIONS
Road transport​
Transporting the machine​
Recovery transport​
Recovery and towing​
Towing the tractor​
WORKING OPERATIONS
General information​
Constant engine RPM​
Four wheel drive​
Front axle suspension (where fitted)​
Transmission​
Transmission operation​
Autoshift function​
Rear remote control valves​
General safety rules​
Front remote control valve couplers​
Hydraulic oil level when using remote hydraulic equipment​
Mid-mount control valve​
Mechanical Joystick​
Electronic Joystick​
Rear Power Take-Off (PTO)​
Safety rules​
Changing the Power Take-Off (PTO) shaft​
Attaching Power-Take Off (PTO) driven equipment​
Indipendent Power Take-Off​
Power take-off speeds​
Auto Power Take-Off (PTO) operation​
Rear Power Take-Off (PTO) brake control - Operating​
Power Take-Off (PTO) external controls​
Stationary power take off operation switch​
Front Power Take-Off (PTO)​
Safety rules​
Rear hydraulic lift​
Safety precautions​
Rear hitch controls​
Operating Instructions​
Front hydraulic lift​
Safety rules​
Front hydraulic lift - How it works​
External hitch controls​
Rear three-point hitch​
Three-point hitch adjustments​
Rear three-point hitch - Operating — Tractor setup when towing a trailer with single or multi axles​
Three-point hitch front​
Towbar​
Safety rules​
Towbar​
Towing hitch​
Towing hook​
Automatic pickup hitch - Operating​
Trailer braking systems​
Hydraulic trailer brakes - Dual line​
Brake control switch - Operating​
Wheels and Tires​
Wheels and tires​
Tire dimensions​
Tread and fender settings​
Track adjustment​
Front tracks diagram — Permitted track for driving on roads​
Rear tracks diagram — Permitted track for driving on roads​
Adjustment of the steering angles​
Adjustment of the front mudguards​
Ballasting​
Safety rules​
Ballasting​
Front ballast​
Rear Ballast​
Liquid ballast​
Power sockets​
Power sockets​
Diagnostic socket​
Cab internal ISOBUS 11783​
External ISOBUS 11783​
MAINTENANCE
General safety before you service​
Introduction​
Dealer service and parts​
Body maintenance​
Cleaning the tractor​
Selective Catalytic Reduction (SCR) exhaust treatment - Basic instructions​
General specification - Diesel fuel​
General specification - Paraffinic (Diesel) Fuels​
Engine oils​
Organic Acid Technology (OAT) coolant​
Fluids, lubricants and capacities​
Opening the hood​
Maintenance planning​
Maintenance chart​
As required​
Radiator - Check – Fluid level​
Windshield washer fluid reservoir - Filling​
Air conditioning - Check​
Remote control valve reservoir - Check​
Radiator - Cleaning​
Diesel Exhaust Fluid (DEF)/AdBlue®/ARLA tank - Cleaning - Filler neck filter​
Brake pedals - Check​
Wheels - Check​
Hydraulic steering line - Check​
Fuel tank - Cleaning - Filler neck filter​
Selective Catalytic Reduction (SCR) exhaust treatment - Cleaning - System cover air ducts​
At warning message display​
Air cleaner - Cleaning​
Fuel filters - Drain fluid​
Brake fluid reservoir - Filling​
Diesel Exhaust Fluid (DEF)/AdBlue®/ARLA tank - Change fluid​
Every 10 hours or daily​
Engine - Check - Oil Level​
Air tanks - Drain fluid​
Remove all trash or organic debris material accumulation​
After the first 50 hours of operation​
Maintenance - Tighten​
Maintenance - Check​
Maintenance - Replace​
Maintenance - Cleaning​
Maintenance - Test​
Maintenance - Grease​
Every 50 hours​
Rear three-point hitch linkage - Grease​
Tow hook - Grease​
Axle articulation - Grease​
Axle support bracket - Grease – Suspension axle​
Front hitch - Grease​
Every 100 hours​
Air-conditioning condenser - Cleaning​
Transmission cooler - Cleaning​
Aftercooler - Cleaning​
Cab air filters - Cleaning​
Cab air filters - Cleaning - Recirculation filters​
Accessory belt - Check - Alternator belt​
Compressor drive belt - Check - Air conditioner belt​
Every 300 hours​
Lifting device oil filter – Replacement​
Hydraulic oil filter – Auxiliary services – Replacement​
Transmission housing - Check — Oil level​
Steering knuckle housing and steering articulation hub - Grease - right-hand side​
Steering knuckle housing and steering articulation hub - Grease - left-hand side​
Four-Wheel Drive (4WD) axle - Check - Oil Level​
Final drive - Check - Oil Level​
Front Power Take-Off (PTO) housing - Check — Oil level​
Every 600 hours​
Engine oil - Change​
Engine oil filter - Replace​
Fuel filter - Replace​
Secondary fuel filter - Replace​
Front wheels - Tighten - right hand wheel​
Front wheels - Tighten - left hand wheel​
Rear wheel - Tighten - right hand wheel​
Rear wheel - Tighten - left hand wheel​
Diesel Exhaust Fluid (DEF)/AdBlue®/ARLA supply module - Cleaning - in line filter​
Hand brake lever - Check​
Every 1200 hours or annually​
Cab air filters - Replace​
Cab air filters - Replace - Recirculation Filters​
Air cleaner - Replace - External cartridge​
Air cleaner - Replace - Internal cartridge​
Final drive housing - Grease - right-hand side​
Final drive housing - Grease - left-hand side​
Fuel tank - Level make up​
Every 1200 hours or two years​
Final drive - Change fluid - right-hand side​
Final drive - Change fluid - left-hand side​
Four-Wheel Drive (4WD) axle - Change fluid​
Transmission housing - Change fluid​
Accessory belt - Replace - Alternator belt​
Compressor drive belt - Replace - Air conditioner belt​
Diesel Exhaust Fluid (DEF)/AdBlue®/ARLA filters - Replace - Tank level sensor and heater assembly suction filter​
Front Power Take-Off (PTO) housing - Change fluid​
EVERY 1800 HOURS OR EVERY 2 YEARS​
Engine breather filter - Replace​
Every two years​
Receiver-dryer - Replace​
Every 3600 hours or two years​
Diesel Exhaust Fluid (DEF)/AdBlue®/ARLA supply module - Replace - Main Filter​
Every 3600 hours or four years​
Radiator - Change fluid​
Electrical System​
Battery - Check​
Turn signal and/or hazard lights - Replace​
Front light - Adjust​
Front light - Replace​
Fuse and relay box - Replace - Fuses and Relays​
Fuse and relay locations​
Fuse and relay box - Component localization - Fuse and relay​
Storage​
Tractor storage​
Machine disposal​
Removal from off-season storage​
Calibration​
Transmission clutch calibration​
Clutch calibration fault codes​
TROUBLESHOOTING
Fault code resolution​
Error code identification​
Selective Catalytic Reduction (SCR) exhaust treatment - Overview​
Symptom(s)​
Engine - Troubleshooting​
Electrical systems - Troubleshooting​
Transmission - Troubleshooting​
Hydraulic systems - Troubleshooting​
Rear three-point hitch - Troubleshooting​
Hydraulic service brakes - Troubleshooting​
Cab climate control - Troubleshooting​
SPECIFICATIONS
Dimensions and weights​
Maximum permitted loads on front and rear axle​
Maximum permitted loads on drawbar​
Maximum permitted loads on towing hitch​
16 x 16 transmission speed table​
32 x 32 transmission speed table​
Additional equipment attachment points - Standard axle support​
Additional equipment attachment points - Multifunction axle support on request​
Technical data​
ACCESSORIES
Front-end loader fixation points​
Backup alarm and light​
Cuna type hydraulic coupling joint for agricultural trailers with single line braking system (where applicable)​
FORMS AND DECLARATIONS
Telematics module declaration of conformity​
