Case Hydraulic Excavator CX470B Operators Manual 6-34450NA
Brand: Case
Model: Case CX470B Hydraulic Excavator
Engine: Isuzu AH-6UZ1XYSS
Part Number: 6-34450NA
Number of Pages: 248 Pages
To the Owner
Safety Labels
For Safe Driving
Safety Section
Precaution Identification Plates (DECALS)
Identification Plates inside the Cabin
Outside Identification Plate
Precaution Identification Plates on Parts (Examples)
Prior to Operation
Confirmation of Safety items
During Operation
While Traveling
After Operating
While Transporting
Before Regular Inspection & Maintenance
Inspection and Maintenance
Instruments and Controls
Location of Components
Overall View
Operator’s Cab
Seat and Console
Right Panel
Console right side front
Explanation of device
Right Console
Left Console
Right Panel
Control Levers
Operator’s Seat
Operator’s Cab
Radio
Air Conditioner
Fuses
Battery
Starting the Engine by Using Booster Cables
Anti-theft Protection
Using the Anti-theft Protection Function
Operating Instructions
Operation of New Machine
Using a New Machine
Daily Inspections
Daily Inspections
Starting and Stopping the Engine
Inspections before Starting the Engine
Starting the Engine
Inspections after Starting the Engine
Stopping the Engine (Normal Operation)
Warm-up Operation
Warm-up Operation
Operations (Traveling)
Operations (Swing)
Swing Operation
Operations (Attachment)
Operations
Characteristics of Hydraulic Excavator
Cautions for operations
Cautions for Interference
Special Attachments
Operating Instructions (Cautions)
Operating Instructions (Procedures)
Bucket: Turning Over and Replacement
On Completion of Daily Operations
Operating in Cold Climates
Operating under Extreme Conditions
Transportation
Loading and Unloading
Switch settings during loading and unloading
Transportation
Disassembling before transporting
How to Remove the Counterweight
Storing
Inspections and Maintenance
General Cautions
Periodic Maintenance Check List
Daily Inspections (Prior to Operation)
Fuel / Lubricants for Different Ambient Temperature
Settings
Genuine CASE Company LLC Parts and Elements 3-5
Disposable Items
Grease / Oil and Elements
Inspection Prior to Operation
Inspections Prior to Operation
Greasing Attachments
Greasing Front Attachment Pins
Fuel System
Fuel
Fuel Refilling and Fuel Level Checking
Drainage of Water and Sediments in the Fuel Tank
Draining Water from the Pre Fuel Filter
Pre Fuel Filter Replacement
Draining Water from the Fuel Filter (Main)
Fuel Filter (Main) Replacement
Bleeding Air from the Fuel System
Engine Oil Replacement
Engine Oil Filter Replacement
Inspecting and Refilling Coolant
Replacing the Coolant
Cleaning and Inspecting the Radiator Net and Fin
Cleaning and Replacing the Air Cleaner (double elements)
Inspection and Adjustment of Alternator Drive Belt3-32
Bolt Torque
Bolt and Nut Torque
Hydraulic Oil
Hydraulic Oil Level Inspection
Refilling Hydraulic Oil
Draining Water and Sediment from the Hydraulic Oil
Tank
Hydraulic Oil Management
Hydraulic Oil Replacement
Bleeding Air from the Hydraulic Components
Air Bleeding Procedures
Air Bleeding from Hydraulic Pump
Air Bleeding from Cylinder
Air Bleeding from Swing Motor
Cleaning and Replacing Suction Filter
Replacing Return Filter
Replacing Air Breather Element
Replacing Pilot Oil Filter Element
Replacement Intervals for Hydraulic Oil and Filters when
Using Breaker
Checking Hoses and Lines
Battery
Battery Inspection and Charge
Upper Frame
Turntable Bearing Greasing
Greasing Swing Ring Gear
Swing Unit
Oil Level Inspection and Refilling of Swing Reduction
Gear
Oil Replacement for Swing Reduction Gear
Greasing Swing Reduction Gear
Travel Unit
Travel Reduction Gear
Oil Level Inspection and Refilling of Travel Reduction
Gear
Oil Replacement for Travel Reduction Gear
Inspecting Upper/Lower Take-up Roller (Idler Wheel)
Inspection and Tightening of Shoe Plate
Cleaning Crawler
Inspection and Adjustment of Track Shoe Tension
Bucket
Replacing Bucket Teeth: Heavy Digging Type
Adjustment of Bucket Backlash
Air Conditioner
Inspection and Care of Air Conditioner
Routine Replacement Safety Parts
Troubleshooting
Contacting Us
Specifications
Conversion Factors
CONVERSION FACTORS
Specifications
Optional Components
Selector Valve
Selector valve (2-way)
Breakers
Handling the Breaker (Attachment)
When Using a Hydraulic Breaker
Importance of Hydraulic oil Control
Crusher
Using the Crusher (Attachment)
Special Attachments
Controlling Rocker switch
Position of control pedal
Operating the Special attachment
CTWT
How to fit counter weight (CTWT)
How to remove counter weight (CTWT)
