Case Excavator CX80 Operators Manual 87490339NA
Brand: Case
Type of Machine: Excavator
Model: Case CX80 Excavator
Engine: ISUZU AU-4LE2X
Part Number: 87490339NA
Publication Date: 2008
Number of Pages: 196 Pages
To the Owner
Safety Labels
For Safe Driving
Safety Section
Precaution Identification Plates (DECALS)
Identification Plates inside the Cabin
Outside Identification Plate
Precaution Identification Plates on Parts (Examples)
Prior to Operation
Confirmation of Safety items
During Operation
While Traveling
After Operating
While Transporting
Before Regular Inspection & Maintenance
Inspection and Maintenance
Instruments and Controls
Location of Components
Overall View
Operator’s Cab
Right Console
Right Console
Monitor & Switch Panel
Moniter Display
Switch Panel
Left Console
Left Console
Switch
Air Conditioner
Air Conditioner (If equipped)
Explanation of device
Radio
Operation Levers
Operation Levers
Operator’s Seat
Operator’s Seat
Operator’s Cab
Fuses
Fuses
Battery
Starting the Engine by Using Booster Cables
Operating Instructions
Operation of New Machine
Using a New Machine
Daily Inspections
Daily Inspections
Starting and Stopping the Engine
Inspections before Starting the Engine
Starting the Engine
Inspections after Starting the Engine
Stopping the Engine (Normal Operation)
Warm-up Operation
Warm-up Operation
Operations (Traveling)
Operations (Swing)
Swing Operation
Operations (Attachment)
Operations
Blade Operation
Characteristics of Hydraulic Excavator
Cautions for operations
Cautions for Interference
Operating Instructions (Cautions)
Operating Instructions (Procedures)
Bucket: Turning Over and Replacement
On Completion of Daily Operations
Operating in Cold Climates
Operating under Extreme Conditions
Transportation
Loading and Unloading
Switch settings during loading and unloading
Transportation
Storing
Inspections and Maintenance
General Cautions
Periodic Maintenance Check List
Daily Inspections (Prior to Operation)
Fuel / Lubricants for Different Ambient Temperature
Settings
Genuine CASE Company LLC Parts and Elements 3-5
Disposable Items
Grease / Oil and Elements
Inspection Prior to Operation
Inspections Prior to Operation
Greasing Attachments
Greasing Front Attachment Pins
Fuel System
Fuel
Fuel Refilling and Fuel Level Checking
Drainage of Water and Sediments in the Fuel Tank
Draining Water from the Water Separator
Fuel Filter (Main) Replacement
Engine Oil Replacement
Engine Oil Filter Replacement
Inspecting and Refilling Coolant
Replacing the Coolant
Cleaning and Inspecting the Radiator Net and Fin
Cleaning and Replacing the Air Cleaner (double elements)
Inspection and Adjustment of Fan Belt
Bolt Torque
Bolt and Nut Torque
Hydraulic Oil
Hydraulic Oil Level Inspection
Refilling Hydraulic Oil
Draining Water and Sediment from the Hydraulic Oil
Tank
Hydraulic Oil Management
Hydraulic Oil Replacement
Bleeding Air from the Hydraulic Components
Air Bleeding Procedures
Air Bleeding from Hydraulic Pump
Air Bleeding from Cylinder
Air Bleeding from Swing Motor
Cleaning and Replacing Suction Filter
Replacing Return Filter
Replacing Air Breather Element
Replacing Pilot Oil Filter Element
Replacement Intervals for Hydraulic Oil and Filters when
Using Breaker
Checking Hoses and Lines
Battery
Battery Inspection and Charge
Upper Frame
Turntable Bearing Greasing
Greasing Swing Ring Gear
Travel Unit
Travel Reduction Gear
Oil Level Inspection and Refilling of Travel Reduction
Gear
Oil Replacement for Travel Reduction Gear
Inspecting Upper/Lower Take-up Roller (Idler Wheel)
Inspection and Tightening of Shoe Plate
Cleaning Crawler
Inspection and Adjustment of Track Shoe Tension
Bucket
Replacing Bucket Teeth: Standard type (Length Pin
Type)
Adjustment of Bucket Backlash
Air Conditioner
Inspection and Care of Air Conditioner (If Equipped)
Routine Replacement Safety Parts
Troubleshooting
Contacting Us
Specifications
Conversion Factors
CONVERSION FACTORS
Specifications
CX80
Optional Components
Breakers
Handling the Breaker (Attachment)
When Using a Hydraulic Breaker
Operating the breaker
Importance of Hydraulic oil Control
Crusher
Using the Crusher (Attachment)
Load Lifting Operation
Brand: Case
To the Owner
Safety Labels
For Safe Driving
Safety Section
Prior to Operation
During Operation
While Traveling
After Operating
While Transporting
Overall View
Operator’s Cab
Right Console
Right Console
Moniter Display
Switch Panel
Left Console
Left Console
Switch
Air Conditioner
Radio
Operation Levers
Operation Levers
Operator’s Seat
Operator’s Seat
Operator’s Cab
Fuses
Fuses
Battery
Using a New Machine
Daily Inspections
Daily Inspections
Starting the Engine
Warm-up Operation
Warm-up Operation
Operations (Swing)
Swing Operation
Operations
Blade Operation
Transportation
Transportation
Storing
General Cautions
Settings
Disposable Items
Fuel System
Fuel
Bolt Torque
Bolt and Nut Torque
Hydraulic Oil
Tank
Using Breaker
Battery
Upper Frame
Travel Unit
Gear
Cleaning Crawler
Bucket
Type)
Air Conditioner
Troubleshooting
Contacting Us
Specifications
Conversion Factors
CONVERSION FACTORS
Specifications
CX80
Optional Components
Breakers
Crusher
- CASE IH & NEW HOLLAND FAULT CODES
- Case MXM Series 120-190 Tractor Service Manual
- Case 845, 865, 885 Graders Service Manual
- CASE 85XT, 90XT, 95XT Complete Service Manual
- Case Loader 621D Service Manual
- Case IH PUMA 165-225 CVX Service manual
- Case STX Series Steiger Tractor Redefind Four-Wheel Drive Industry
- CASE Backhoe Loader Schematic for 580SR; 590SR; 695SR
- Case Backhoe Loaders 580T 580ST 590ST 695ST Service Manual
- CASE 580SM, 590SM Series 3 Loader Backhoe Electrical Schematic
- CAT 140H Motor Grader Parts Manual
- Case CX210 Crawler Excavator Shop Manual
- Case 845-865-885 Grader Service Manual
- Case Wheel Loader W18-W20 Service Manual
- CASE IH MX215-305 Electrical diagram
