Case Crawler Loader 1450 Operators Manual 9-4492
Brand: Case
Type of Machine: Crawler Loader
Model: Case 1450 Crawler Loader
Part Number: 9-4492
Number of Pages: 144 Pages
Introduction
To the Owner
Delivery of the New
Machine
After Delivery Checkup
Safety
Roll-Over Protective Structure
Serial Number L.ocation
Specifications
Crawler Operating Instructions
Instruments and Controls
Engine Operation
Run —In
Starting
Idling
Stopping
Starting Aids
Ether Injection
Engine Pre-Heater
Starting Fluid Aerosol
Can
Coolant Heater
Batteries
Driving the Crawler
Seat Adjustment
Gear Selection
Checking Brakes Before
Operating
Steering
Inching the Crawler
Stopping the Crawler
Hillside Operation
the Crawler
Cold Weather Operation
Hot Weather Operation
Loader Operating Instructions
Lift Arm and Bucket Control
Return-To-Dig
Bucket Height Control
Bucket Level Indicator
4-1n-1 Bucket
Position Indicator
Clam Indicator
Positioning the Bucket
and Clam
Loader Operating Tips
Job Layout
Loading Loose Material
Excavating Banks
Excavating on the Flat
Material
Stockpile Dumping
Truck Loading
Digging Basements
Clearing
Winch Operating Instructions
Winch Controls
Winching
Cable
Winch Operating Tips
Jammed Cable
Pulling Stumps
Multiple Pulls
Anchors
Stuck Machines
Logging
Ripper Operating Instructions
Control
Ripper Teeth
Ripper Operating Tips
Fuels and Lubricants
Fuel, Fluids and Lubricants Chart
Maintenance
Introduction
Run—In Maintenance Chart
Scheduled Maintenance Chart
Grease Fittings
Engine Lubrication System
Oil Level
Oil Change
Oil Filter
Air Cleaning System
Rain Cap
Intake Screen
Restriction Indicator
Air Cleaner Servicing
Single Element
Servicing
Double Element
Servicing
Radiator Cap
Coolant
Cleaning the System
Thermostat
Fuel System
Components
Cleaning the System
Replacing the Fuel Filters
Bleeding the System
Fuel Tank Filler
Lights
Battery Care
Screen
Booster Batteries
Oil Level
Return Line Filter
Suction Line Screen
Breather
Oil Change
Transmission hydraulic System
Oil Level
Pressure Line Filter
Suction Screen
Breathers
Oil Change
Recoil Hou sings
Final Drives
Oil Level
Oil Change
Track System
Track Tension
Fan Belts
Return—To-Dig Adjustment
Adjustment
Bucket Teeth
Winch Maintenance
Servicing the Cable
Winch Hydraulic System
Oil Level
Oil Drain and Refill
Suction Line Screen
Cable Ferrule
Seat Belt Inspection and Care
Machine Storage
Reactivating Machine
Brand: Case
Part Number: 9-4492
Introduction
To the Owner
Delivery of the New
Machine
Safety
Specifications
Engine Operation
Run —In
Starting
Idling
Stopping
Starting Aids
Ether Injection
Engine Pre-Heater
Can
Coolant Heater
Batteries
Driving the Crawler
Seat Adjustment
Gear Selection
Operating
Steering
Inching the Crawler
Hillside Operation
the Crawler
Return-To-Dig
4-1n-1 Bucket
Position Indicator
Clam Indicator
and Clam
Job Layout
Excavating Banks
Material
Stockpile Dumping
Truck Loading
Digging Basements
Clearing
Winch Controls
Winching
Cable
Jammed Cable
Pulling Stumps
Multiple Pulls
Anchors
Stuck Machines
Logging
Control
Ripper Teeth
Maintenance
Introduction
Grease Fittings
Oil Level
Oil Change
Oil Filter
Air Cleaning System
Rain Cap
Intake Screen
Single Element
Servicing
Double Element
Servicing
Radiator Cap
Coolant
Cleaning the System
Thermostat
Fuel System
Components
Cleaning the System
Bleeding the System
Fuel Tank Filler
Lights
Battery Care
Screen
Booster Batteries
Oil Level
Return Line Filter
Suction Line Screen
Breather
Oil Change
Oil Level
Suction Screen
Breathers
Oil Change
Recoil Hou sings
Final Drives
Oil Level
Oil Change
Track System
Track Tension
Fan Belts
Adjustment
Bucket Teeth
Winch Maintenance
Servicing the Cable
Oil Level
Suction Line Screen
Cable Ferrule
Machine Storage
- CASE IH & NEW HOLLAND FAULT CODES
- Case MXM Series 120-190 Tractor Service Manual
- Case 845, 865, 885 Graders Service Manual
- CASE 85XT, 90XT, 95XT Complete Service Manual
- Case Loader 621D Service Manual
- Case IH PUMA 165-225 CVX Service manual
- Case STX Series Steiger Tractor Redefind Four-Wheel Drive Industry
- CASE Backhoe Loader Schematic for 580SR; 590SR; 695SR
- Case Backhoe Loaders 580T 580ST 590ST 695ST Service Manual
- CASE 580SM, 590SM Series 3 Loader Backhoe Electrical Schematic
- CAT 140H Motor Grader Parts Manual
- Case CX210 Crawler Excavator Shop Manual
- Case 845-865-885 Grader Service Manual
- Case Wheel Loader W18-W20 Service Manual
- CASE IH MX215-305 Electrical diagram
