Case Backhoe Loader 580SR 590SR 695SM 695SR Service Manual Cre 9-91452 2005
Brand: Case
Type of Manual: Service Manual, Hydraulic Diagram, Electrical Diagram
Model: Case 580SR 590SR 695SM 695SR Backhoe Loader
Part Number: Cre 9-91452
Publication Date: 2005
Number of Pages: 996 Pages
Section 00 - Health, Safety, Maintenance
Chapter 1 - General
Description Page
General Specifications
Section 10 - Engine
Chapter 1 - Injection Pump
Description Page
Special Tools
Removal
Installation
Section 17 - Torque Convertor
Chapter 1 - With Powershuttle Transmission
Description Page
Overhaul
Chapter 2 - With Powershift Transmission
Description Page
Overhaul
Section 21 - Transmissions
Chapter 1 - 4x4 Compact Shuttle
Description Page
Description And Operation
Overhaul
Chapter 2 - Powershift Introduction
Description Page
Removal
Chapter 3 - Powershift Operating Lever
Description Page
Fault Finding
Chapter 4 - Powershift Overhaul (Includes 4 Wheel Steer)
Description Page
Fault Finding
Overhaul
Section 25 - Front Axles
Chapter 1 - Front Axle For 2 And 4 Wheel Drive Only
Description Page
Overhaul
Chapter 2 - Front Axle For 4 Wheel Steer Only
Description Page
Overhaul
Chapter 3 - Front Axle
Description Page
Identification
Overhaul
Chapter 7 - Front Axle
Description Page
Identification
Overhaul
Chapter 10 - Front Axle
Description Page
Identification
Section 27 - Rear Axles
Chapter 1 - Rear Axle With Foot Operated Diff Lock For 2 And 4 Wheel Drive Only
Description Page
Overhaul
Chapter 2 - Rear Axle With Electrically Operated Diff Lock For 2 And 4 Wheel Drive
Only
Description Page
Overhaul
Chapter 3 - 5hdu$[OhIru:Khho6whhu2qo\
Description Page
Overhaul
Chapter 4 - Rear Axle
Description Page
Identification
Overhaul
Section 33 - Brake Systems
Chapter 1 - Brakes For 2 And 4 Wheel Drive Only
Description Page
Overhaul
Chapter 2 - Brakes For 4 Wheel Steer Only
Description Page
Overhaul
Section 35 - Hydraulic Systems
Chapter 1 - Hydraulic Circuits And Components For Husco Only
Description Page
Hydraulic Valve Spool Seals
Stabliliser And Extendible Dipper Control Valves
Loader Control Valve
Backhoe Control Valve
Chapter 2 - Fault Finding, Pressure And Flow Testing For Husco Only
Description Page
Fault Finding
Pressure Testing
Flow Testing (Pump Performance Test)
Chapter 3 - Hydraulic Circuits And Components For Rexroth
Description Page
Hydraulic Circuits
Chapter 4 - Fault Finding, Pressure And Flow Testing For Rexroth Only
Description Page
Preliminary Checks
Fault Finding Charts
Pressure Testing
Chapter 5 - Control Valves For Rexroth With Mechanical Or Hydraulic Control
Description Page
Overhaul
Disassembly
Chapter 6 - Swing System And Hydraulic Cylinders
Description Page
Swing System Description And Operation
Hydraulic Cylinders Description And Operation
Backhoe And Loader Cylinders - Removal And Installation
Backhoe And Loader Cylinder Overhaul
Swing Cylinder Removal And Overhaul
Chapter 7 - Hydraulic Pump
Description Page
Tightening Torques
Pump Overhaul
Chapter 8 - Rexroth Control Blocks
Description Page
Tightening Torques
Exploded Wiew Of The Lever
Overhaul Of The Control Block
Section 39 - Vehicle Chassis
Chapter 1 - Chassis Components
Description Page
Overhaul
Section 41 - Steering Systems
Chapter 1 - Steering For 2 And 4 Wheel Drive Only
Description Page
Fault Finding
Overhaul
Chapter 2 - Steering For 4 Wheel Steer Only
Description Page
Fault Finding
Overhaul
Section 50 - Cab Heating And Air Conditioning
Chapter 1 - Cab Heating
Description Page
Fault Finding
Overhaul
01/2005
Chapter 2 - Cab Air Conditioning
Description Page
Description & Operation
Fault Finding
Overhaul
Section 55 - Electrical System
Chapter 1 - System General
Description Page
Tempory Wiring Harness Repair
Electrical System General Fault Finding
Chapter 2.1 - Powershuttle Wiring Diagrams (N/A And Europeen Model)
Description Page
Fuses And Relays
Components
Connectors
Connectors (Details)
Chapter 2.2 - Powershift Wiring Diagrams (N/A And Europeen Model)
Description Page
Fuses And Relays
Components
Connectors
Chapter 2.3 - Powershift 4 Ws Wiring Diagrams (N/A And Europeen Model)
Description Page
Fuses And Relays
Components
Connectors
Chapter 2.4 - Rops Wiring Diagrams (N/A And Europeen Model)
Description Page
Fuses And Relays
Components
Connectors
Chapter 3 - Starter Motor 2.7kw
Description Page
Fault Finding
Exploded Wiew Of The Starter
01/2005
Chapter 4 - Alternator 90a
Description Page
Fault Finding
Exploded Wiew Of The Alternator
Chapter 5 - Battery
Description Page
Battery Maintenance And Tests
Chapter 6 - Service Diagnostics, Calibration And Immobiliser
Description Page
Service Indicators
Alarms And Diagnostics Signalling
Calibration Of Speedometer
Immobiliser Circuit
Chapter 7 - Component Testing
Description Page
General Introduction
Component Testing
Component Earth Points
Key Start And Stop Switch
Starter Motor - Starter Relay
Safety Start Relais
Transmissions
Steering Control Unit
Loader
Backhoe
Section 82 - Loader
Chapter 1 - Loader Frame, Controls And Buckets For 2 And 4 Wheel Drive Only
Description Page
Overhaul
Chapter 2 - Loader Frame, Controls And Buckets For 4 Wheel Steer Only
Description Page
Overhaul
Section 84 - Backhoe
Chapter 1 - Backhoe, Boom And Dipperstick Assembly
Description Page
Backhoe Control Linkage Overhaul
Component Removal
Dipperstick
Extendible Dipperstick Overhaul
Brand: Case
Chapter 1 - General
Description Page
Section 10 - Engine
Description Page
Special Tools
Removal
Installation
Description Page
Overhaul
Description Page
Overhaul
Description Page
Overhaul
Description Page
Removal
Description Page
Fault Finding
Description Page
Fault Finding
Overhaul
Description Page
Overhaul
Description Page
Overhaul
Description Page
Identification
Overhaul
Description Page
Identification
Overhaul
Description Page
Identification
Description Page
Overhaul
Only
Description Page
Overhaul
Description Page
Overhaul
Description Page
Identification
Overhaul
Description Page
Overhaul
Description Page
Overhaul
Description Page
Description Page
Fault Finding
Pressure Testing
Description Page
Hydraulic Circuits
Description Page
Preliminary Checks
Pressure Testing
Description Page
Overhaul
Disassembly
Description Page
Description Page
Tightening Torques
Pump Overhaul
Description Page
Tightening Torques
Description Page
Overhaul
Description Page
Fault Finding
Overhaul
Description Page
Fault Finding
Overhaul
Description Page
Fault Finding
Overhaul
01/2005
Description Page
Fault Finding
Overhaul
Description Page
Description Page
Fuses And Relays
Components
Connectors
Description Page
Fuses And Relays
Components
Connectors
Description Page
Fuses And Relays
Components
Connectors
Description Page
Fuses And Relays
Components
Connectors
Description Page
Fault Finding
01/2005
Description Page
Fault Finding
Chapter 5 - Battery
Description Page
Description Page
Service Indicators
Immobiliser Circuit
Description Page
Component Testing
Safety Start Relais
Transmissions
Loader
Backhoe
Section 82 - Loader
Description Page
Overhaul
Description Page
Overhaul
Description Page
Component Removal
Dipperstick
- CASE IH & NEW HOLLAND FAULT CODES
- Case MXM Series 120-190 Tractor Service Manual
- Case 845, 865, 885 Graders Service Manual
- CASE 85XT, 90XT, 95XT Complete Service Manual
- Case Loader 621D Service Manual
- Case IH PUMA 165-225 CVX Service manual
- Case STX Series Steiger Tractor Redefind Four-Wheel Drive Industry
- CASE Backhoe Loader Schematic for 580SR; 590SR; 695SR
- Case Backhoe Loaders 580T 580ST 590ST 695ST Service Manual
- CASE 580SM, 590SM Series 3 Loader Backhoe Electrical Schematic
- CAT 140H Motor Grader Parts Manual
- Case CX210 Crawler Excavator Shop Manual
- Case 845-865-885 Grader Service Manual
- Case Wheel Loader W18-W20 Service Manual
- CASE IH MX215-305 Electrical diagram
