Cadillac CT5 2020-2024 Service Repair Manual
Brand: Cadillac
Type of Machine: Automotive
Type of Manual: Service Repair Manual
Model: Cadillac CT5 2020-2024
Number of Pages: 10378 Pages
Cadillac CT5 2020-2024 Preface
PREFACE
GENERAL INFORMATION
BODY HARDWARE AND TRIM
BODY REPAIR
BODY SYSTEMS
BRAKES
DIAGNOSTIC OVERVIEW, STARTING POINT, AND PROGRAMMING
DRIVELINE|AXLE
DRIVER INFORMATION AND ENTERTAINMENT
ENGINE|PROPULSION
HVAC
HVAC
Roof
ROOF
Safety and Security
SAFETY AND SECURITY
Seats
SEATS
Steering
STEERING
Suspension
SUSPENSION
1-2-3-4-5-6-reverse-clutch-apply-plate-specifications-166
1-3-5-6-7-8-9-clutch-backing-plate-specifications-165
adhesives--fluids--lubricants--and-sealers-161
approximate-fluid-capacities-162
automatic-transmission-fluid-leaks-137
bushing-and-mating-shaft-inspection-127
case-porosity-repair-136
clutch-backing-plate-retaining-ring-specifications-164
clutch-plate-diagnosis-133
control-valve-solenoid-body-identification-information-6
definitions-and-abbreviations-4
drive-range--eighth-gear--hydraulic-circuits--30
drive-range--eighth-gear--mechanical-powerflow--31
drive-range--fifth-gear--hydraulic-circuits--24
drive-range--fifth-gear--mechanical-powerflow--25
drive-range--first-gear--hydraulic-circuits--17
drive-range--first-gear--mechanical-powerflow--16
drive-range--fourth-gear--hydraulic-circuits--23
drive-range--fourth-gear--mechanical-powerflow--22
drive-range--ninth-gear--hydraulic-circuits--32
drive-range--ninth-gear--mechanical-powerflow--33
drive-range--second-gear--hydraulic-circuits--18
drive-range--second-gear--mechanical-powerflow--19
drive-range--seventh-gear--hydraulic-circuits--28
drive-range--seventh-gear--mechanical-powerflow--29
drive-range--sixth-gear--hydraulic-circuits--27
drive-range--sixth-gear--mechanical-powerflow--26
drive-range--tenth-gear--hydraulic-circuits--34
drive-range--tenth-gear--mechanical-powerflow--35
drive-range--third-gear--hydraulic-circuits--21
drive-range--third-gear--mechanical-powerflow--20
dtc-c1201-86
dtc-p06af-89
dtc-p17c5--p17c6--p17cc--p17cd--or-p17d6-104
dtc-p17f5-p17f7-or-p17fa-p17fc-105
dtc-p18a1--p18aa--p18ab--or-p27ec-108
dtc-p18a2-p18a4-109
dtc-p18a8-110
dtc-p18ae-111
dtc-p27a7-p27ae-115
dtc-p27eb--p27ed--or-p27ee-117
dtc-p30bd-119
dtc-p175e-99
dtc-p175f-100
dtc-p176b-p176d--p178f--or-p17d3-102
dtc-p187d--p187e--p18e7--or-p18e8-106
dtc-p189c-107
dtc-p0601-p0604--p0606--p0607--p060a--p062f--p16f3--or-p16fb-87
dtc-p0658--p0659--p2812--p2814--p2815--p281b--p281d--or-p281e-88
dtc-p0711-p0713-90
dtc-p0716--p0717--p07bf--p07c0--p1783--or-p17ce-91
dtc-p0721-p0723--p077c--p077d--p172a--or-p172b-92
dtc-p0741--p2817--or-p2818-93
dtc-p0746-or-p0747-94
dtc-p0776-or-p0777-95
dtc-p0796-or-p0797-96
dtc-p0815--p0816--p0826--or-p1876---manual-mode-or-tap-up-tap-down-switch-malfunction-97
dtc-p0960--p0962-p0964--p0966-p0968--p0970--p0971--p2670--p2671--p2718--p2720--p2721--p2727--p2729--p2730--p2736--p2738--p2739--p2824--p2826--or-p2827-98
dtc-p1761-101
dtc-p1775-103
dtc-p2714-or-p2715-112
dtc-p2723-or-p2724-113
dtc-p2732-or-p2733-114
dtc-p2796-p2799-116
dtc-p2820-or-p2821-118
electronic-component-description-9
engine-coolant-water-in-transmission-134
fastener-specifications--off-vehicle--158
fastener-specifications--on-vehicle--159
figure-1--auxiliary-control-valve-body---auxiliary-control-valve-body-spacer-plate-side-37
figure-1--bushing--bearing--and-washer-locations-79
figure-1--case-and-associated-parts-1-of-3-65
figure-1--component-location-77
figure-1--seal-locations--1-of-3--81
figure-2--auxiliary-control-valve-body-spacer-plate---auxiliary-control-valve-body-side-38
figure-2--case-and-associated-parts-2-of-3-66
figure-2--seal-locations--2-of-3--82
figure-3--case-and-associated-parts-3-of-3-67
figure-3--control-valve-channel-plate---fluid-pan-side-39
figure-3--seal-locations-3-of-3-83
figure-4--clutch-assemblies-and-associated-parts-56
figure-4--clutch-assemblies-and-associated-parts-68
figure-4--control-valve-spacer-plate---control-valve-channel-plate-side-40
figure-5--control-valve-assembly-69
figure-5--control--with-body-and-valve--valve-assembly-57
figure-6--stator-shaft-support-assembly-58
figure-6--stator-shaft-support-assembly-70
figure-7--direct-overdrive-internal-gear-assembly-59
figure-7--direct-overdrive-internal-gear-assembly-71
figure-8--2-3-4-5-7-9-10-clutch-assembly-60
figure-8--2-3-4-5-7-9-10-clutch-assembly-72
figure-9--1-2-3-4-6-7-8-10-reverse-and-4-5-6-7-8-9-10-reverse-clutch-assembly-61
figure-9--1-2-3-4-6-7-8-10-reverse-and-4-5-6-7-8-9-10-reverse-clutch-assembly-73
figure-10--1-3-5-6-7-8-9-clutch-assembly-62
figure-10--1-3-5-6-7-8-9-clutch-assembly-74
figure-11--park-system-components-63
figure-11--park-system-components-75
flex-plate-torque-converter-vibration-test-126
fluid-leak-diagnosis-135
harsh-garage-shift-140
harsh--soft--delayed-or-slipping-first--second--eighth--ninth--tenth--or-reverse-shift-144
harsh--soft--delayed-or-slipping-first--second--third--fourth--fifth--sixth--or-reverse-shift-142
harsh--soft--delayed-or-slipping-first--second--third--fourth--sixth--seventh--eighth--tenth--or-reverse-shift-148
harsh--soft--delayed-or-slipping-first--third--fifth--sixth--seventh--eighth--or-ninth-shift-150
harsh--soft--delayed-or-slipping-fourth--fifth--sixth--seventh--eighth--ninth--tenth--or-reverse-shift-152
harsh--soft--delayed-or-slipping-second--third--fourth--fifth--seventh--ninth--or-tenth-shift-146
neutral---engine-running--hydraulic-circuits--15
neutral---engine-running--mechanical-powerflow--14
no-drive-in-all-ranges-141
no-first--second--eighth--ninth--tenth--or-reverse-shift-gear-145
no-first--second--third--fourth--fifth--sixth--or-reverse-gear-143
no-first--second--third--fourth--sixth--seventh--eighth--tenth--or-reverse-gear-149
no-first--third--fifth--sixth--seventh--eighth--or-ninth-gear-151
no-fourth--fifth--sixth--seventh--eighth--ninth--tenth--or-reverse-gear-153
noise-and-vibration-analysis-129
noisy-in-all-gears-130
noisy-in-reverse-only-131
no-park-or-drive-139
no-second--third--fourth--fifth--seventh--ninth--or-tenth-gear-147
no-torque-converter-clutch-apply-154
no-torque-converter-clutch-release-155
park---engine-running--hydraulic-circuits--11
park---engine-running--mechanical-powerflow--10
range-reference-167
reverse--hydraulic-circuits--12
reverse--mechanical-powerflow--13
road-test-124
shift-indicator-indicates-wrong-gear-selection-138
shift-solenoid-valve-state-and-gear-ratio-168
solenoid-valve-characterization-reprogramming-120
symptoms---automatic-transmission-121
temperature-versus-resistance---b13-automatic-transmission-fluid-temperature-sensor-157
torque-converter-diagnosis-125
transmission-case-washer-specifications-163
transmission-component-and-system-description-8
transmission-fluid-fill-procedure-123
transmission-fluid-level-and-condition-check-122
transmission-general-description-7
transmission-general-specifications-160
transmission-identification-information-5
transmission-parts-kit-specifications-169
transmission-solenoid-information-84
vibration-128
whine-growl-noise-that-changes-with-vehicle-speed-132
Brand: Cadillac
PREFACE
GENERAL INFORMATION
BODY REPAIR
BODY SYSTEMS
BRAKES
DRIVELINE|AXLE
ENGINE|PROPULSION
HVAC
HVAC
Roof
ROOF
Safety and Security
SAFETY AND SECURITY
Seats
SEATS
Steering
STEERING
Suspension
SUSPENSION
dtc-c1201-86
dtc-p06af-89
dtc-p18a2-p18a4-109
dtc-p18a8-110
dtc-p18ae-111
dtc-p27a7-p27ae-115
dtc-p30bd-119
dtc-p175e-99
dtc-p175f-100
dtc-p189c-107
dtc-p0711-p0713-90
dtc-p1761-101
dtc-p1775-103
dtc-p2796-p2799-116
range-reference-167
road-test-124
vibration-128
- Cadillac CTS CTS-V 2008-2009 Service Repair Manual
- Cadillac ATS, ATS-V 2013-2017 Workshop Manual & Wiring Diagrams
- Cadillac XTS 2012-2016 Service Repair Manual & Electrical Wiring Diagrams
- Cadillac XTS (3.6L) System Wiring Diagrams 2012+
- Cadillac Seville (4.6L) 1998-2004 Service Repair Manual
- Cadillac Escalade 2014 Workshop Manual
- Cadillac ELR 2014-2016 Service Manual & Electrical Wiring Diagrams
- Cadillac Escalade 2007-2013 (GMT900) Workshop Manual and Wiring Diagrams
- Cadillac XT5 (3.6L) System Wiring Diagrams 2017+
- Cadillac CTS 2007-2011 Workshop Manual and Electrical Wiring Diagram
- Cadillac Escalade 2007-2009 Service Repair Manual and Electrical Wiring Diagram
- Cadillac XT6 2020 Wiring Diagram
- Cadillac Escalade 2023 V8-6.2L Repair Manual and Wiring Diagrams
- Cadillac Escalade (ESV) 2021-2024 Service Repair Manual and Electrical Wiring Diagram
- Cadillac XTS 2017 Service Repair Manual and Electrical and Wiring Diagram
