Hyundai
86
176,834
BYD ATTO3 Maintenance Manual
Brand: BYD
Type of Machine: Automotive
Type of Manual: Maintenance Manual
Model: BYD ATTO3
Number of Pages: 103 Pages
Maintenance Information
Maintenance Instructions
Precautions For Maintenance
Maintenance Cycle Reminder And Display
Maintenance Information Under Severe Working Conditions
Filling Of Maintenance Records
Safe Operation Guide For Maintenance
Maintenance
Tools And Equipment Required For Maintenance
Reading And Clearing Of Fault Records
Visual Inspection Of The Inside And Outside Of The Vehicle Body
Inspection Of Automatic Control Function Of Low Beam
Inspection Of Exterior Light Function
Inspection Of Interior Light Function
Inspection And Adjustment Of Headlight
Inspection Of Electrical Functions
Inspection Of On-Board Items
Inspection Of Seat Belt
Inspection And Replacement Of Hepa Filter
Inspection And Cleaning Of Sunroof
Inspection And Setting Of Power Window Function
Inspection Of Washer Fluid Anti-Freezing Temperature
Inspection Of Washer Fluid Level
Inspection Of Wiper Blade Position
Inspection Of Wiper Blade State
Inspection Of Wiper Arm Lock Nut
Inspection Of Coolant Anti-Freezing Temperature
Inspection Of Coolant Level
Lubrication Of Door Brake
Lubrication Of Hood Lock Catch
Inspection Of Hood Lock Body Assembly
Inspection Of 12 V Battery Wiring Harness
Inspection Of 12 V Battery Voltage
Visual Inspection Of High-Voltage Components And Wires
Inspection Of Warning Labels For High-Voltage Components
Inspection Of Charging Port
Visual Inspection Of Electric Powertrain And Front Compartment Components
Inspection Of Tire Pressure (Indirect Resetting)
Inspection Of Tires
Tire Rotation
Inspection And Calibration Of Tire Pressure Monitoring Display
Inspection Of Wheel Fixing Nut Torque
Inspection Of Steering Wheel
Inspection Of Brake Pad Thickness
Inspection Of Brake Disc
Inspection Of Brake Fluid Level
Visual Inspection Of Brake Device
Inspection Of Brake Caliper Guide Pin
Inspection Of Brake Pedal And Epb Switch
Inspection Of High-Voltage Battery Soc
Maintenance And Charging Of High-Voltage Battery
Visual Inspection Of Lower Control Arm Ball Stud Dust Cover And Rubber Support
Visual Inspection Of Tie Rod Dust Cover And Stabilizer Bar Rubber Support
Visual Inspection Of Damping Components
Visual Inspection Of Cv Joint Universal Joint Dust Cover
Inspection Of Steering Link Ball Stud
Inspection Of Lower Control Arm Ball Stud And Stabilizer Bar Tie Rod Ball Joint
Inspection Of Chassis Fixing Bolts And Nuts
Visual Inspection Of Chassis Protection
Inspection Of Test Drive Items
