Hyundai
86
176,834
BT Forklift HWE100 HWE100S LWE130 Repair Manual 7609559-040
Brand: BT
Type of Machine: Forklift
Type of Manual: Repair Manual, Wiring Diagram
Model: BT HWE100, HWE100S, LWE130 Forklift
Part Number: 7609559-040
Publication Date: 2025
Number of Pages: 586 Pages
1 General Introduction
1.1 Images And Other Information​
1.2 How To Use This Manual​
1.3 Warning Levels And Symbols​
1.4 Pictograms​
1.5 Abbreviations​
2 General Safety Rules
2.1 Work Safety​
2.2 Authorised Personnel​
2.3 Insulation Test​
2.4 Truck Modifications​
2.5 Electrical System​
2.6 Safe Lifting​
2.7 Software​
2.8 Hydraulic System​
3 Operating Principle
3.1 Description​
4 Parameters
4.1 Software​
4.2 Parameters In General​
4.3 Parameters On Commissioning​
4.4 Parameter List​
5 Installation
5.1 Transport​
5.2 Lifting The Truck​
5.3 Battery​
5.4 Commissioning​
6 Maintenance
6.1 Introduction​
6.2 Maintenance Instructions​
6.3 Periodic Maintenance​
7 Troubleshooting
7.1 Initial Troubleshooting​
7.2 General Method For Starting When Troubleshooting​
7.3 Concluding Troubleshooting​
7.4 Auxiliary Functions​
7.5 Troubleshooting Using Error Codes​
8 Chassis C0000
8.1 Overview​
8.2 Overview​
8.3 Checking Links And Spring Pins​
8.4 Checking The Chassis​
8.5 Applying Grease To Chassis Grease Nipples​
8.6 Frame, Chassis C0300​
8.7 Frame/Chassis Components C0400​
8.8 Safety Equipment C0800​
9 Motors C1000
9.1 Electric Motors C1700​
10 Transmission/Drive Gear C2000
10.1 Drive Unit, Final Gear C2500​
11 Brake/Wheel/Track System C3000
11.1 Parking Brake Details C3300​
11.2 Wheels C3500​
12 Steering System C4000
12.1 Mechanical Steering System C4100​
13 Electrical System C5000
13.1 Using The Anti-Static Carpet​
13.2 Insulation Test​
13.3 Tighten Cable Connections​
13.4 Programming Tools​
13.5 General Electric Equipment C5100​
13.6 Instrument Panel, Display C5200​
13.7 Power System Travel Function C5400​
13.8 Control System, Working Function C5500​
13.9 Power System Working Function C5600​
13.10 Control/Protection Electronics C5700​
13.11 Protective Sensors, Position Sensors C5800​
13.12 Calibrations​
14 Hydraulics/Pneumatics C6000
14.1 Overview​
14.2 Overview​
14.3 General Information​
14.4 Checking Hydraulic Hoses And Hose Couplings​
14.5 Hydraulic Unit C6100​
14.6 Hydraulic Cylinder C6600​
14.7 Quick Change Connectors​
14.8 Hydraulic Unit Tightening Torques​
15 Work Function - Lifting Masts C7000
15.1 Description​
15.2 Chain System, General​
15.3 Checking Chains And Rollers​
15.4 Lubricating The Chains​
15.5 Checking The Split Pins / Securing Pins​
15.6 Tightening The Mast Fixing Points​
15.7 Main Mast C7100​
15.8 Lifting/Carrying/Clamping Devices C7400​
16 Auxiliary Equipment, Installation Equipment C8000
17 Optional Equipment/Extra Equipment C9000
17.1 Extra Electrical Equipment C9400​
17.2 Other Extra Equipment C9500​
18 Instructions For Disposal
18.1 General​
18.2 Marking Of Plastics​
18.3 Pressure Vessels​
18.4 Sorting Categories​
19 Wiring Diagram
19.1 Colour Code Table​
19.2 List Of Fuses​
19.3 Diagram​
19.4 Diagram​
19.5 Diagram​
19.6 Diagram​
20 Hydraulics Schematics
20.1 List Of Symbols​
20.2 Diagram​
20.3 Diagram​
21 Tools
21.1 Tools For Electric Connectors​
21.2 Lubricating Tool​
21.3 Special Tools​
22 Service Data And Grease Specifications
22.1 General Tightening Torques​
22.2 Lubricants Specification​
22.3 Cleaning The Truck​
23 Technical Data
23.1 Truck Data​
23.2 Truck Dimensions​
23.3 Truck Dimensions​
23.4 Truck Dimensions​
