BT Forklift C4E250V to C4E350V Parts Catalog IT EN FR DE ES
Language: Italian, English, French, German, Spanish
Brand: BT
Type of Machine: Forklift
Type of Manual: Spare Parts Catalogue
Model:
C4E250V SN. 216285
C4E300VL SN. 220749
C4E300V SN. 217188
C4E350V SN. 219498
Part Number: 0350184R1
Date: 2004
Number of Pages: 548 Pages
1 - ETICHETTE E TARGHETTE / LABELS AND PLATES / ETIQUETTES ET PLAQUES / AUFKLEBER UND TYPENSCHILDER / ETIQUETAS Y PLACAS
2 - TELAIO / FRAME / CHASSIS / RAHMEN / CHASIS
3 - SEDILE / SEAT / SIEGE / SITZ / ASIENTO
4 - CRUSCOTTO / DASHBOARD / PANNEAU DES INSTRUMENTS / ARMATURENBRETT / SALPICADERO
5 - PIANTONE STERZO / STEERING COLUMN / COLONNE DE DIRECTION / LENKSÄULE / COLUMNA DE DIRECCION
6 - AZIONATORE CLACSON / HORN CONTROL / COMMANDE CLAXON / HUPEHEBEL / PALANCA DE CLAXON
7 - ASSALE A BILICO / REAR AXLE / ESSIEU ARRIERE / HINTERE ACHSE / EJE TRASERO
9 - RUOTE DIRETTRICI / STEER WHEELS / ROUES DIRECTRICES / LENKRAEDER / RUEDA DIRECTRIZ
10 - SCHEMA IMPIANTO GUIDA IDRAULICA / DIAGRAM OF STEERING ASSISTANCE SYSTEM / INSTALLATION DIRECTION ASSISTEE / HYDROLENKUNGSANLAGE / INSTALACION DIRECCION ASISTIDA
11 - IMPIANTO IDRAULICO PRINCIPALE / MAIN HYDRAULIC SYSTEM / INSTALLATION HYDRAULIQUE PRINCIPALE / HYDRAULISCHE HAUFTANLAGE / INSTALACION HYDRAULICA PRINCIPALE
12 - IMPIANTO IDRAULICO PRINCIPALE (con Finger-tip e Joystick) / MAIN HYDRAULIC SYSTEM (with Finger-tip and Joystick) / INSTALLATION HYDRAULIQUE PRINCIPALE (avec Finger-tip et Joystic) /
13 - DISTRIBUTORE - HAWE / DISTRIBUTOR - HAWE / DISTRIBUTEUR - HAWE / STEUERBLOCK - HAWE / DISTRIBUIDOR - HAWE
13 - DISTRIBUTORE A LEVE / LEVERS DISTRIBUTOR / DISTRIBUTEUR À LEVIERS / HEBEL STEUERBLOCK / DISTRIBUIDOR PALANCAS
14 - FINGERT.-JOYSTICK- (FINO A MATR. CE326511) / FINGERT.-JOYSTICK- (UNTIL S/n° CE326511) / FINGERT.-JOYSTICK- (JUSQU'A MATR. CE326511) / FINGERT.-JOYSTICK- (BIS FABRIKNR CE326511) / FINGERT.-
14 - FINGERT.-JOYSTICK- (DA MATR. CE326514) / FINGERT.-JOYSTICK- (FROM S/n° CE326514) / FINGERT.-JOYSTICK- (DEPUIS MATR. CE326514) / FINGERT.-JOYSTICK- (VON FABRIKNR. CE326514) / FINGERT.-
15 - MOTORE E POMPA DI SOLLEVAMENTO (25-30) / LIFTING MOTOR AND PUMP (25-30) / MOTEUR ET POMPE DE ELEVATION (25-30) / MOTOR UND HUBPOMPE (25-30) / MOTOR Y BOMBA DE ELEVACION (25-30)
15 - MOTORE E POMPA DI SOLLEVAMENTO (30L-35-35se) / MOTOR AND LIFTING PUMP (30L-35-35se) / MOTEUR ET POMPE DE SOULEVEMENT (30L-35-35se) / MOTOR AND HUBPUMPE (30L-35-35se) / MOTOR Y
16 - MOTORE DI TRAZIONE E RIDUTTORE SINISTRO / DRIVE MOTOR AND LEFT REDUCTION GEAR / MOTEUR DE TRACTION ET REDUCT.GAUCHE / FAHRMOTOR UND LINKE GETRIEBE / MOTOR DE TRACCION Y
17 - RIDUTTORE DESTRO-DIFFERENZIALE / DIFFERENTIAL- RIGHT REDUCTION GEAR / REDUCTEUR DROITE ET DIFFERENTIEL / RECHTE GETRIEBE UND DIFFERENTIAL / REDUCTOR DERECHO Y DIFERENCIAL
18 - RIDUTTORE DESTRO-FREN0 / BRAKE AND RIGHT REDUCTION GEAR / REDUCTOR DERECHO Y FRENO / RECHTE GETRIEBE UND BREMSE / REDUCTEUR DROITE ET FREIN
19 - RUOTE MOTRICI / DRIVE WHEEL / ROUE MOTRICE / ANTRIEBSRAD / RUEDA MOTRIZ
20 - COMPONENTI ELETTRICI / MISCELLANEOUS ELETTRICAL / COMPOSANTES ELECTRIQUES / ELEKTRISCHE KOMPONENTE / COMPONENTES ELECTRICOS
21 - PEDALIERA ACCELERATORE / SPEED PEDAL / PEDALIER D' ACCELERATEUR / FAHRPEDAL / PEDALES ACELERADOR
22 - PEDALIERA E POMPA FRENO / BRAKE PUMP AND PEDAL / POMPE DE FREIN ET PEDALE / HAUPTBREMSZYLINDER UND PEDAL / PEDALES Y BOMBA DE FRENO
23 - FRENO DI STAZIONAMENTO / PARKING BRAKE / FREIN DE PARKING / FESTSTELLBREMSE / FRENO DE APARCAMIENTO
24 - MARTINETTO INCLINAZIONE / TILTING JACK / VERIN D'INCLINAISON / NEIGUNGZYLINDER / CILINDRO DE INCLINACION
25 - DISPOSITIVI E ACCESSORI / DEVICES AND ACCESSORIESES / DISPOSITIFS ET ACCESSOIRES / EINRICHTUNGEN UND ZUBEHÖRTEILE / DISPOSITIVOS Y ACCESSORIOS
26 - INVERSORE AL VOLANTE / DIRECTION INVERSOR LEVER / INVERSEUR DE DIRECTION / HANDUMSCHALTUNG / PALANCA DE INVERSION
27 - GRUPPO MONTANTI 25 / 30 / MASTS GROUP 25 / 30 / GROUPE MATS 25 / 30 / MASTGRUPPE 25 / 30 / GRUPO MASTILE 25 / 30
29 - GRUPPO MONTANTI 35 / MASTS GROUP 35 / GROUPE MATS 35 / MASTGRUPPE 35 / GRUPO MASTILE 35
30 - GRUPPO MONTANTI 25/30 - VERSIONE 4 CILINDRI / MASTS GROUP 25/30 - 4 CYLINDERS VERSION / GROUPE MATS 25/30 - VERSION 4 CYLINDERS / MASTGRUPPE 25/30 - 4 ZYLINDER VERSION / GRUPO Page 415
31 - GRUPPO MONTANTI 30L/35 - VERSIONE 4 CILINDRI / MASTS GROUP 30L/35 - 4 CYLINDERS VERSION / GROUPE MATS 30L/35 - VERSION 4 CYLINDERS / MASTGRUPPE 30L/35 - 4 ZYLINDER VERSION / GRUPO Page 483
Brand: BT
Model:
C4E250V SN. 216285
C4E300VL SN. 220749
C4E300V SN. 217188
C4E350V SN. 219498
Date: 2004
- BT LPE200,220,250 Spare Parts
- BT VCE150A, 150AC, 125ASF, 125ACSF, C15 Service Manual
- BT Forklift SPE125,125L,135S,160,160L,200D, 200, 200L Service Manual
- BT Pallet Stacker SPE 125 125L 135S 160(L) 200(D,L) 924454 Service Manual 230076-040
- BT Forklift BT DPM & GPM 20-30H Service Manual
- BT Forklift Master serie RT Service Manual
- BT Pallet Truck LHM 230(O_P_Q_QP_QX_U_UO_UQ_QUX_UX_WS_X) 3121000 Quality Parts 221867
- BT Pallet Truck LWE140_160_180_200_250 6053221-up Repair Manual 258944-040
- BT Reach Truck RRE140 RRE160 RRE180 RRE200 RRE250 6070557 Repair Manual 7510399-040
- BT SPE125,SPE160 Spare Parts
- BT Forklift CBD 4.0 - 4.5 - 5.0 Service Manual
- BT Forklift CBE 2.5 - 3.0 - 3.0L - 3.5 Service Manual
- BT Forklift CBE 4.0 4.5 5.0 DC Version Service Manual
- BT Forklif CBD2.5 CBD3.0 CBD3.5 CBG2.5 CBG3.0 CBG3.5 Service Manual
- BT Forklift CBE 4.0 4.5 5.0 AC Power Service Manual
