BT Forklift C3E120 to C3E200 Service Manual IT EN FR DE ES
Language: Italian, English, French, German, Spanish
Brand: BT
Type of Machine: Forklift
Model:
C3E150 SN. CE351051
C3E160 SN. CE349182
C3E160L SN. CE351054
C3E180 SN. CE351165
C3E180L SN. CE353400
C3E200 SN. CE348825
Publication Number: 0350202R3-0
Date: 2010
Number of Pages: 260 Pages
1 - ETICHETTE E TARGHETTE / LABELS AND PLATES / ETIQUETTES ET PLAQUES / AUFKLEBER UND TYPENSCHILDER / ETIQUETAS Y PLACAS
2 - TELAIO / FRAME / CHASSIS / RAHMEN / CHASIS
3 - SEDILE STD. / SEAT STD. / SIEGE STD. / SITZ STD. / ASIENTO STD
4 - SEDILE OPT. / SEAT OPT. / SIEGE OPT. / SITZ OPT. / ASIENTO OPT
5 - SEDILE OPT. PARTI INTERNE PER LEVE / OPT. SEAT WITH INNER PARTS FOR LEVERS / SIEGE OPT. AVEC PARTIES INTERIEURES POUR LEVIERS / OPTIONALER SITZ, INNERE TEILE FUER HEBEL / ASIENTO
6 - SEDILE OPT. PARTI INTERNE PER BRACCIOLO / OPT. SEAT WITH INNER PARTS FOR ARMREST / SIEGE OPT. AVEC PARTIES INTERIEURES POUR ACCOUDOIR / OPTIONALER SITZ, INNERE TEILE FUER
7 - POSTO GUIDA / DRIVING POSITION / PLACE DU CONDUCTEUR / FÜHRERSITZ / PUESTO DE CONDUCCION
8 - ASSALE STERZANTE - 3R / STEERING AXLE - 3R / ESSIEU DIRECTEUR - 3R / LENKACHSE - 3R / EJE DE DIRECCION - 3R
9 - RUOTE POSTERIORI / REAR WHEELS / ROUES ARRIERE / HINTERRÄDER / RUEDAS TRASERAS
10 - IMPIANTO GUIDA IDRAULICA / POWER STEERING SYSTEM / INSTALLATION DIRECTION ASSISTEE / HYDROLENKUNGSANLAGE / INSTALACION DIRECCION ASISTIDA
11 - IMPIANTO IDRAULICO PRINCIPALE / MAIN HYDRAULIC SYSTEM / INSTALLATION HYDRAULIQUE PRINCIPALE / HYDRAULISCHE HAUFTANLAGE / INSTALACION HYDRAULICA PRINCIPALE
12 - IMPIANTO IDRAULICO PRINCIPALE (con Finger-tip e Joystick) / MAIN HYDRAULIC SYSTEM (with Finger-tip and Joystick) / INSTALLATION HYDRAULIQUE PRINCIPALE (avec Finger-tip et Joystic)
13 - DISTRIBUTORE A LEVE / LEVERS CONTROL VALVE / DISTRIBUTEUR À LEVIERS / HEBEL STEUERBLOCK / DISTRIBUIDOR PALANCAS
13 - DISTRIBUTORE - HYDROCONTROL / DISTRIBUTOR - HYDROCONTROL / DISTRIBUTEUR - HYDROCONTROL / STEUERBLOCK - HYDROCONTROL / DISTRIBUIDOR - HYDROCONTROL
14 - FINGER-TIP E JOYSTICK - STD. / FINGER-TIP AND JOYSTICK - STD. / FINGER-TIP ET JOYSTICK - STD. / FINGER-TIP UND JOYSTICK - STD. / FINGER-TIP Y JOYSTICK - STD
14 - DISTRIBUTORE - HAWE / DISTRIBUTOR - HAWE / DISTRIBUTEUR - HAWE / STEUERBLOCK - HAWE / DISTRIBUIDOR - HAWE
14 - FINGER-TIP E JOYSTICK - OPT. / FINGER-TIP AND JOYSTICK - OPT. / FINGER-TIP ET JOYSTICK - OPT. / FINGER-TIP UND JOYSTICK - OPT. / FINGER-TIP Y JOYSTICK - OPT
15 - MOTORE E POMPA DI SOLLEVAMENTO / LIFTING MOTOR AND PUMP / MOTEUR ET POMPE DE ELEVATION / MOTOR UND HUBPUMPE / MOTOR Y BOMBA DE ELEVACION
15 - MOTORE SOLLEVAMENTO / LIFTING MOTOR / MOTEUR DE ELEVATION / HUBMOTOR / MOTOR DE ELEVACION
16 - MOTORE TRAZIONE / DRIVE MOTOR / MOTEUR DE TRACTION / ANTRIEBSMOTOR / MOTOR DE TRACCION
17 - RIDUTTORE / REDUCTION GEAR / REDUCTEUR / GETRIEBE / REDUCTOR
18 - RUOTE ANTERIORI / FRONT WHEELS / ROUES AVANT / VORDERRÄDER / RUEDAS DELANTERAS
19 - COMPONENTI ELETTRICI / ELECTRICAL COMPONENTS / COMPOSANTES ELECTRIQUES / ELEKTRISCHE KOMPONENTE / COMPONENTES ELECTRICOS
20 - PEDALIERA ACCELERATORE / SPEED PEDAL / PEDALIER D' ACCELERATEUR / FAHRPEDAL / PEDALES ACELERADOR
21 - PEDALIERA ACCELERATORE (INVERSORE AL VOLANTE) / SPEED PEDAL (HAND DIRECTION LEVER) / PEDALIER D' ACCELERATEUR (INVERSEUR DE DIRECTION) / FAHRPEDAL (HANDUMSCHALTUNG)
22 - IMPIANTO FRENI NEGATIVI / NEGATIVE BRAKES SYSTEM / SYSTEME DE FREINS NEGATIFS / ANLAGE DER NEGATIVBREMSEN / INSTALACION DE FRENOS NEGATIVOS
22 - PEDALIERA E POMPA FRENO / BRAKE PUMP AND PEDAL / POMPE DE FREIN ET PEDALE / HAUPTBREMSZYLINDER UND PEDAL / PEDALES Y BOMBA DE FRENO
23 - MARTINETTO INCLINAZIONE / TILTING JACK / VERIN D'INCLINAISON / NEIGUNGZYLINDER / CILINDRO DE INCLINACION
24 - DISPOSITIVI E ACCESSORI / DEVICES AND ACCESSORIES / DISPOSITIFS ET ACCESSOIRES / EINRICHTUNGEN UND ZUBEHÖRTEILE / DISPOSITIVOS Y ACCESSORIOS
25 - GRUPPO MONTANTI 150-160-160L / MAST GROUP 150-160-160L / GROUPE MAT 150-160-160L / MASTGRUPPE 150-160-160L / GRUPO MASTIL 150-160-160L
26 - GRUPPO MONTANTI 180-180L-200 / MAST GROUP 180-180L-200 / GROUPE MAT 180-180L-200 / MASTGRUPPE 180-180L-200 / GRUPO MASTIL 180-180L-200
Brand: BT
Model:
C3E150 SN. CE351051
C3E160 SN. CE349182
C3E180 SN. CE351165
C3E200 SN. CE348825
Date: 2010
- BT LPE200,220,250 Spare Parts
- BT VCE150A, 150AC, 125ASF, 125ACSF, C15 Service Manual
- BT Forklift SPE125,125L,135S,160,160L,200D, 200, 200L Service Manual
- BT Pallet Stacker SPE 125 125L 135S 160(L) 200(D,L) 924454 Service Manual 230076-040
- BT Forklift BT DPM & GPM 20-30H Service Manual
- BT Forklift Master serie RT Service Manual
- BT Pallet Truck LHM 230(O_P_Q_QP_QX_U_UO_UQ_QUX_UX_WS_X) 3121000 Quality Parts 221867
- BT Pallet Truck LWE140_160_180_200_250 6053221-up Repair Manual 258944-040
- BT Reach Truck RRE140 RRE160 RRE180 RRE200 RRE250 6070557 Repair Manual 7510399-040
- BT SPE125,SPE160 Spare Parts
- BT Forklift CBD 4.0 - 4.5 - 5.0 Service Manual
- BT Forklift CBE 2.5 - 3.0 - 3.0L - 3.5 Service Manual
- BT Forklift CBE 4.0 4.5 5.0 DC Version Service Manual
- BT Forklif CBD2.5 CBD3.0 CBD3.5 CBG2.5 CBG3.0 CBG3.5 Service Manual
- BT Forklift CBE 4.0 4.5 5.0 AC Power Service Manual
