Bomag Soil Stabilizer MPH 122-2 Service Manual 00891725
Brand: Bomag
Type of Machine: Soil Stabilizer, Asphalt Recycler
Type of Manual: Service Manual, Hydraulics, Pneumatic And Electrical Schematic
Model: Bomag MPH 122-2 Soil Stabilizer
Serial Number: 10159006....> ; 10159007....>
Part Number: 00891725
Publication Date: 2011
Number of Pages: 1274 Pages
1 General
1 General
1.1 Introduction
General
Transport work with cranes and lifting tackle
Precautions and codes of conduct for welding work
Operation of high-voltage systems
Old oils
Hydraulics
Fuels
Hot fuels
Synthetic rubber
Poisonous substances
Air conditioning system
Battery
Special safety regulations
The values specified in the table apply for screws:
2 BOMAG Stabilizer / Recycler
3 Technical data
3 Technical data
<GRAFIK>
<TABELLE>
4 Maintenance
4 Maintenance
4.1 General notes on maintenance
4.2 Fuels and lubricants
Coolant
Mineral oil based hydraulic oil
Bio-degradable hydraulic oil
Gear oil
Milling gear oil
Lubrication grease
Thermal oil
Compressor service unit
5 E-Plan wiring diagrams
6 Electrics
6 Electrics
DTM Series
6.20 Battery service, checking the main battery switch
6.21 Starting with jump wires
7 Electronic control
8 Engine electrics
8 Engine electrics
9 Engine
9 Engine
9.9 Check, adjust the valve clearance
9.10 Checking the engine oil level
9.11 Changing engine oil and oil filter cartridge
9.12 Check the coolant level
9.13 Checking the condition of the coolant
9.14 Checking/changing the coolant
9.15 Check, clean the water separator
9.16 Changing the fuel filter
9.17 Replacing the fuel pre-filter cartridge, bleed the fuel system
9.18 Cleaning, changing the dry air filter cartridge
9.19 Servicing the generator V-belt
9.20 Check the engine mounts
9.21 Check the fastening of engine / turbocharger / combustion air hoses
9.22 Cleaning the intercooler
9.23 Intercooler, draining off oil/ condensation water
9.24 Checking the crankcase pressure
9.25 Replacing the crankcase ventilation valve
10 Air conditioning system
10.10 Servicing the air conditioning compressor
10.11 Service the air conditioning
11 Hydraulics
11 Hydraulics
Variable displacement pumps, A4VG28EP to A4VG180EP
Swash plate principle
External gear pumps
Multiple gear pumps
Description of function
Function logic of the rotor drive
Plug-in fixed displacement motors A2FE and A2FM
OSP steering valve
Control valve blocks SP-08
11.17 Raising/lowering the cabin
11.18 Towing
External gear motors
3-way flow control valve, adjustable
11.20 Cleaning the intercooler
11.21 Checking the hydraulic oil level
11.22 Changing hydraulic oil and breather filter
11.23 Checking the contamination of the hydraulic oil filters
11.24 Change the hydraulic oil fine filter
12 Water injection
12 Water injection
12.2 Water dosing system
12.3 Water sprinkler system, maintenance in the event of frost
13 Bitumen dosing system
13.4 Checking the reaction water level
13.5 Reaction water tank
13.6 Checking the oil level for the reaction water pump
13.7 Checking the oil level in compressor and service unit
13.8 Checking the thermal oil
13.9 Checking the contamination of the hydraulic oil filters
13.10 Checking the binder pump
13.11 Checking the spraying sections
13.12 Checking, cleaning the additional fuel filter
13.13 Change the additional fuel filter
13.14 Changing the thermal oil
13.15 Compressor oil change
13.16 Cleaning the bitumen filter
14 Cutting teeth
14 Cutting teeth
14.1 Checking the condition of the cutters
14.2 Replacing the cutting teeth/ cutting tooth holders
15 Suppliers documentation
15.7 Axle
16 Circuit diagrams
16 Circuit diagrams
S/N Wiring diagram 20
S/N Wiring diagram 42
