Momed80
150
35,046
Bobcat Telescopic Handler TL25.60 Parts Manual
Brand: Bobcat
Type of Machine: Telescopic Handler
Model: Bobcat TL25.60 Telescopic Handler
Serial Number: B5PY11001 & Above
Number of Pages: 469 Pages
Maintenance Items (Service Parts)
Maintenance Items (Literature)
Maintenance Kits (Scheduled Maintenance)
Scheduled Maintenance Items (Every 10 Hours)
Scheduled Maintenance Items (First 100 Hours)
Scheduled Maintenance Items (Every 500 Hours Or Every 12 Months)
Scheduled Maintenance Items (Every 1000 Hours Or Every 12 Months)
Scheduled Maintenance Items (Every 2000 Hours or Every 24 Months)
Scheduled Maintenance Items (Every 3000 Hours or Every 36 Months)
Recommended Stocking Guide
Main Frame
Counterweight
Engine Basket
Engine Hood
Insulation
Outer Boom
Inner Boom
Attachment Carrier (Bob-Tach)
Attachment Carrier (Bob-Tach) (Assembly)
Attachment Carrier (Quick-tach)
Attachment Carrier (Manitach)
Road Lights & RH Mirror
Operator CAB
Operator CAB (Structure)
Operator CAB (Interior Cladding)
Operator CAB (Exterior)
Operator CAB (Door)
Operator CAB (Door Window)
Operator CAB (Wipers)
Operator Controls (Standard Display)
Operator Controls (Steering Column)
Steering Column (Stationary)
Steering Column (Tilting Only)
Steering Column (Tilting & Telescopic)
Operator Seat (Mechanical Suspension)
Throttle Pedal
Heating & Cooling (Heat Only)
Heating & Cooling (Heat & A_C)
Heating & Cooling (Heater)
Heating & Cooling (Air Conditioner)
Heating & Cooling (Control Panel)
Document Storage
Drive Train
Drive Shaft
Front Axle (Housing)
Front Axle (Differential)
Front Axle (Brakes)
Front Axle (Steering)
Front Axle (Wheel Hub)
Rear Axle (Housing)
Rear Axle (Differential)
Rear Axle (Steering)
Rear Axle (Wheel Hub)
Mudguards (16.5_ Wheels)
Mudguards (17.5_, 18_ & 20_ Wheels)
Hydraulic Tank
Hydraulic Circuitry (Gear Pump)
Hydraulic Circuitry (Control Valve) (W_O Boom Auxiliary)
Hydraulic Circuitry (Control Valve) (W_Boom Auxiliary)
Hydraulic Circuitry (Tilt) (W_O Boom Auxiliary)
Hydraulic Circuitry (Tilt) (W_Boom Auxiliary)
Hydraulic Circuitry (Boom Auxiliary)
Hydraulic Circuitry (Power Attachment Lock)
Hydraulic Circuitry (Extension)
Hydraulic Circuitry (Lift)
Hydraulic Circuitry (Fan Motor) (Non-reversible)
Hydraulic Circuitry (Fan Motor) (Reversible)
Hydraulic Circuitry (Steering)
Hydraulic Circuitry (Brake System)
Hydraulic Circuitry (Brake System) (Germany Configuration)
Hydraulic Circuitry (Brake System) (Italy Configuration)
Coupler Block
Gear Pump
Control Valve (W_O Auxiliary)
Control Valve (W_Auxiliary)
Control Valve (Inlet Section)
Control Valve (Working Section) (Lift)
Control Valve (Working Section) (Tilt)
Control Valve (Working Section) (Extension)
Control Valve (Working Section) (Auxiliary)
Control Valve (Outlet Section)
Fan Motor (Non-reversible)
Fan Motor (Reversible)
Service Brake Pedal
Power Lock Valve
Lift Cylinder
SELF-LEVELING Cylinder
Extension Cylinder
Tilt Cylinder
Hydrostatic Circuitry (Oil Cooling & Filtration)
Hydrostatic Circuitry (Pump & Motor)
Hydrostatic Motor
Hydrostatic Pump
Hydrostatic Pump (Charge Pump Assembly)
Hydrostatic Pump (Control Unit)
CAB Electrical Circuitry (Standard Harness)
CAB Electrical Circuitry (Simplified Harness)
Engine Electrical Circuitry (Main Harness)
Engine Electrical Circuitry (Engine ECU Harness, Sensors & Brackets)
Engine Electrical Circuitry (Engine Starting & Charging)
Frame Electrical Circuitry
Fuse & Relay Center (Cab)
Fuse & Relay Center (Engine)
Fuse & Relay Center (Frame)
Battery & Cables (Cold Start) (1000cca)
Engine & Attaching Parts (Radiator Water Exchanger)
Engine & Attaching Parts (Heat & A_C Components)
Engine & Attaching Parts (Air Intake)
Engine & Attaching Parts (Exhaust System)
Engine & Attaching Parts (Engine Mounts)
Engine & Attaching Parts (Fuel System)
Engine & Attaching Parts (Fuel Filter)
Flywheel Housing (1)
Flywheel Housing
Flywheel
Cylinder Head & Valves
Engine Lift Hooks
Rocker Arm Cover
Rocker Arm Bracket ASSY
Rocker Arm Cover Hose
Camshaft
Piston & Crankshaft
Oil Pan
Oil Pump & Suction Tube
Oil Cooler & Filter
Thermostat
Intake Stake
Intake Manifold (Engine S_N 000001 - 025256)
Intake Manifold (Engine S_N 025257 & Above)
Exhaust Manifold
Gearcase
Turbocharger
Exhaust Gas Recirculation
Injection Nozzle
Fuel Line
Injection Pipe
Glow Plugs
Muffler DOC Assembly
Air Cleaner
Attachment Angle Gauge Kit
Blue Work Lights Kit
Boom Harness
Boom Retract Cushion Kit
Boom Stop Kit
Boom Valve Kit (Float Only)
Boom Valve Kit (Float and Suspension)
Boom Valve Kit (Float and Suspension) (Suspension Valve Assembly)
Boom Work Light Kit (Halogen)
Boom Work Light Kit (LED)
Decals (Inside)
Decals (Outside)
Double Electric Mirror Kit
Dual Travel Direction Kit
Dust Protection Kit
Easy Greasing Kit
Fire Extinguisher Kit
Front Window Guard Kit
Hand Throttle Kit
Hose Guide Kit
Keychain
Keypad Upgrade Kit
License Plate Holder (Front)
License Plate Light (Rear)
LOW-PROFILE LED Beacon Kit
Machine IQ
Phone Holder Kit
Power Attachment Lock Kit (Bob-Tach) (Cylinder)
Power Attachment Lock Kit (Manitach)
Power Attachment Lock Kit (Quick-Tach)
Power Attachment Lock Kit (Manitach & Quicktach) (Cylinder)
Rear Electrical Plug
Rear Hitch Kit (Basic)
Rear Hitch Kit (Rotating)
Rear Mirror Kit
Rear View Camera Kit
Reversible Fan Motor Kit
Seat Kit (Air Suspension)
Seats (Air Suspension)
Seats (Air Suspension) (Suspension Assembly)
Seats (Mechanical Suspension)
Seats (Mechanical Suspension) (Suspension Assembly)
Secondary Frame Fuse & Relay Center
Service Wrench
Side Mirror Work Lights Kit
Smart Joystick Kit
Sound System
Sun Visor Kit
Tires & Rims (16.5_)
Tires & Rims (17.5_)
Tires & Rims (18_)
Tires & Rims (20_)
Tool Box Kit
Wheel Stop
Rear Work Light Kit
Auxiliary Relief Valve Kit
