Bobcat Skid-Steer Loader S530 Service Manual 6990328enUS 2020
Brand: Bobcat
Type of Machine: Skid-Steer Loader
Model: Bobcat S530 Skid-Steer Loader
S/N A7TW11001 & Above
S/N AZN711001 & Above
S/N ATZD11001 & Above
S/N AZN611001 & Above
Part Number: 6990328enUS
Publication Date: 2020
Number of Pages: 1082 Pages
FOREWORD
Brand: Bobcat
FOREWORD
FOREWORD
SAFETY INSTRUCTIONS
FIRE PREVENTION
SERIAL NUMBER LOCATIONS
DELIVERY REPORT
LOADER IDENTIFICATION
SAFETY AND MAINTENANCELIFTING AND BLOCKING THE LOADER
LIFT ARM SUPPORT
OPERATOR CAB
TRANSPORTING THE LOADER ON A TRAILER
TOWING THE LOADER
REMOTE START TOOL KIT - MEL1563
REMOTE START TOOL (SERVICE TOOL) KIT - 7217666
SERVICE SCHEDULE
ENGINE AIR CLEANER
ENGINE COOLING SYSTEM (EARLIER MODELS)
ENGINE COOLING SYSTEM (LATER MODELS)
FUEL SYSTEM
ENGINE LUBRICATION SYSTEM
HYDRAULIC / HYDROSTATIC SYSTEM (EARLIER MODELS)
HYDRAULIC / HYDROSTATIC SYSTEM (LATER MODELS)
FINAL DRIVE TRANSMISSION (CHAINCASE)
BOB-TACH (HAND LEVER)
BOB-TACH (POWER)
LUBRICATING THE LOADER
TIRE MAINTENANCE
SPARK ARRESTER MUFFLER
PIVOT PINS
LOADER STORAGE AND RETURN TO SERVICE
STOPPING THE ENGINE AND LEAVING THE LOADER
EMERGENCY EXIT
SEAT BELT
HYDRAULIC SYSTEMHYDRAULIC / HYDROSTATIC SCHEMATICS
HYDRAULIC SYSTEM INFORMATION
CYLINDER (LIFT)
CYLINDER (TILT)
CYLINDER (BOB-TACH)
MAIN RELIEF VALVE
HYDRAULIC CONTROL VALVE (STANDARD)
HYDRAULIC CONTROL VALVE (ACS) OR (SJC)
LIFT ARM BYPASS CONTROL VALVE
HYDRAULIC PUMP
HYDRAULIC / HYDROSTATIC FILTERS
HYDRAULIC FLUID RESERVOIR
OIL COOLER (EARLIER MODELS)
OIL COOLER (LATER MODELS)
BUCKET POSITION VALVE
REAR AUXILIARY DIVERTER VALVE
BOB-TACH (POWER) BLOCK (EARLIER MODELS)
BOB-TACH (POWER) BLOCK (LATER MODELS)
FRONT AUXILIARY HYDRAULIC COUPLER BLOCK
AUTOMATIC RIDE CONTROL
HYDROSTATIC SYSTEMHYDROSTATIC SYSTEM INFORMATION
HYDROSTATIC DRIVE MOTOR
HYDROSTATIC DRIVE MOTOR (TWO-SPEED)
HYDROSTATIC MOTOR CARRIER
HYDROSTATIC MOTOR CARRIER (TWO-SPEED)
CHARGE PRESSURE
HYDROSTATIC PUMP
HYDROSTATIC PUMP (SJC)
DRIVE BELT
TWO-SPEED
DRAIN MANIFOLD
DRIVE SYSTEMBRAKE
DRIVE COMPONENTS
CHAINCASE
MAINFRAMESEAT BAR
OPERATOR CAB
OPERATOR SEAT
OPERATOR SEAT (SUSPENSION)
BOB-TACH (POWER)
LIFT ARMS
REAR GRILLE
REAR DOOR (TAILGATE)
FUEL TANK
CONTROL PEDALS AND LINKAGES
CONTROL PEDALS AND LINKAGES (ACS)
CONTROL PANEL
CONTROL PANEL (SJC)
CONTROL HANDLE / LEVER
CONTROL HANDLE / LEVER (ACS)
CONTROL HANDLE / LEVER (SJC)
ACCESS PANEL (INSIDE)
ACCESS PANEL (INSIDE) (SJC)
WINDOW (REAR)
WINDOW (TOP)
WINDOW (SIDE)
CAB DOOR
ARMREST
LEFT SIDE LOWER PANEL
RIGHT SIDE LOWER PANEL
HEADLINER
ELECTRICAL SYSTEM AND ANALYSISELECTRICA SCHEMATICS
ELECTRICAL SYSTEM INFORMATION
BATTERY
ALTERNATOR BELT
STARTER
INSTRUMENT PANELS IDENTIFICATION
LIGHTS
BOBCAT CONTROLLERS (GATEWAY AND AUXILIARY)
BOBCAT CONTROLLER (ACS)
BOBCAT CONTROLLER (SJC) (DRIVE)
DIAGNOSTIC SERVICE CODES
BOBCAT INTERLOCK CONTROL SYSTEM (BICS™)
SEAT BAR SENSOR
TRACTION LOCK
CONTROL SYSTEM (ACS)
ELECTRICAL / HYDRAULIC CONTROLS
ELECTRICAL / HYDRAULIC CONTROLS (ACS)
ELECTRICAL / HYDRAULIC CONTROLS (SJC)
SERVICE PC (LAPTOP COMPUTER)
CALIBRATION
STEERING DRIFT COMPENSATION (OPERATOR MODE)
STEERING DRIFT COMPENSATION (SERVICE MODE)
FLYWHEEL RPM SENSOR
CONTROL PANEL SETUP
PASSWORD SETUP (DELUXE INSTRUMENTATION PANEL)
PASSWORD SETUP (KEYLESS START PANEL)
MAINTENANCE CLOCK
BACK-UP ALARM SYSTEM
FRONT HORN
MACHINE IQ
ENGINE SERVICEENGINE INFORMATION
ENGINE SPEED CONTROL (HAND)
ENGINE SPEED CONTROL (FOOT)
MUFFLER
AIR CLEANER
LUBRICATION SYSTEM
FUEL SYSTEM
CYLINDER HEAD
CRANKSHAFT AND PISTONS
CAMSHAFT AND TIMING GEARS
FLYWHEEL AND HOUSING
HEATING AND VENTILATIONREGULAR MAINTENANCE
TROUBLESHOOTING
HEATER UNIT
HEATER COIL
BLOWER FAN
HEATER VALVE
EVAPORATOR / HEATER COVER
SPECIFICATIONS(S530) LOADER SPECIFICATIONS
TECHNICAL SERVICE GUIDE SPECIFICATIONS
TORQUE SPECIFICATIONS FOR BOLTS
HYDRAULIC CONNECTION SPECIFICATIONS
HYDRAULIC / HYDROSTATIC FLUID SPECIFICATIONS
CONVERSIONS
SERVICE TOOLS REQUIRED
ALPHABETICAL INDEX
- Bobcat Heavy Equipment Full Hydraulic Schematics & Electrical Schematics PDF
- Bobcat Compact Mini Excavator 320D-322D i, 320G-322G Parts Manual
- BOBCAT Service Library 2014 Service, Operator, Maintenance, Bulletines, etc...
- Bobcat 753 Service Manual
- Bobcat S130 Parts Manual
- Bobcat X220 Excavator 05-89 Service Manual
- Bobcat 442 Mini Excavator Service Manual
- Bobcat 435 Mini Excavator Parts Manual
- Bobcat Compact Mini Excavator 773 G-Series Parts Manual
- Bobcat Excavators 323 6986958 Service Manual 2-08
- Bobcat S175, S185 Parts Manual
- Bobcat Skid Steer Loader 863 Service Manual
- Bobcat S150-S160 Skid-Steer Loader Service Manual 6902730
- Bobcat 430 Service Manual s/n 563011001 AND UP
- Bobcat s175, s185 operators manual
