Bobcat Skid-Steer Loader S450 Service Manual 6990812enUS 2021
Brand: Bobcat
Type of Machine: Skid-Steer Loader
Model: Bobcat S450 Skid-Steer Loader
S/N B1ED11001 & Above
Part Number: 6990812enUS
Publication Date: 2021
Number of Pages: 1032 Pages
FOREWORD
Brand: Bobcat
FOREWORD
FOREWORD
SAFETY INSTRUCTIONS
FIRE PREVENTION
Maintenance
Operation
Electrical
Fueling
Starting
Spark Arrester Exhaust System
Welding And Grinding
Fire Extinguishers
SERIAL NUMBER LOCATIONS
Loader Serial Number
Engine Serial Number
DELIVERY REPORT
LOADER IDENTIFICATION
SAFETY AND MAINTENANCELIFTING AND BLOCKING THE LOADER
Procedure
LIFT ARM SUPPORT
Description
Installing
Removing
OPERATOR CAB
Description
Cab Door Sensor
Raising
Lowering
TRANSPORTING THE LOADER ON A TRAILER
Loading And Unloading
Fastening
TOWING THE LOADER
Procedure
REMOTE START TOOL KIT - MEL1563
Remote Start Tool - MEL1563
Service Tool Harness Communicator - MEL1566
Remote Start Procedure
REMOTE START TOOL (SERVICE TOOL) KIT - 7217666
Description
Remote Start Tool (Service Tool) - 7022042
Loader Service Tool Harness - 6689747
Computer Service Tool Harness - 6689746
SERVICE SCHEDULE
Maintenance Intervals
ENGINE AIR CLEANER
Replacing Filters
ENGINE COOLING SYSTEM
Maintenance Platform
Cleaning
Checking And Adding Coolant
Removing And Replacing Coolant
FUEL SYSTEM
Fuel Specifications
Biodiesel Blend Fuel
Filling The Fuel Tank
Fuel Filters
Removing Air From The Fuel System
ENGINE LUBRICATION SYSTEM
Checking And Adding Engine Oil
Engine Oil Chart
Removing And Replacing Oil And Filter
HYDRAULIC / HYDROSTATIC SYSTEM
Checking And Adding Fluid
Hydraulic / Hydrostatic Fluid Chart
Removing And Replacing Hydraulic Fluid
Removing And Replacing Hydraulic / Hydrostatic Filter
Removing And Replacing Hydraulic Charge Filter
Replacing Reservoir Breather Cap
FINAL DRIVE TRANSMISSION (CHAINCASE)
Removing And Replacing Fluid
BOB-TACH (HAND LEVER)
Inspection And Maintenance
BOB-TACH (POWER)
LUBRICATING THE LOADER
Lubrication Locations
TIRE MAINTENANCE
Wheel Nuts
Rotating
Mounting
SPARK ARRESTER MUFFLER
Cleaning Procedure
PIVOT PINS
LOADER STORAGE AND RETURN TO SERVICE
Storage
Return To Service
STOPPING THE ENGINE AND LEAVING THE LOADER
Procedure
EMERGENCY EXIT
Rear Window Identification
Rear Window Removal (Latches)
Rear Window Removal (Rubber Cord)
External Access (Rear Window With Latches)
External Access (Rear Window With Rubber Cord)
Front Door
SEAT BELT
HYDRAULIC SYSTEMHYDRAULIC / HYDROSTATIC SCHEMATICS
HYDRAULIC SYSTEM INFORMATION
Glossary Of Hydraulic / Hydrostatic Symbols
Troubleshooting
CYLINDER (LIFT)
Testing
Removal And Installation
Parts Identification
Disassembly
Assembly
CYLINDER (TILT)
Testing
Base End Pivot Pin Removal And Installation
Disassembly
Assembly
CYLINDER (LIFT) (AZNB11488 & ABOVE)
Disassembly
Assembly
CYLINDER (TILT) (AZNB11488 & ABOVE)
Disassembly
Assembly
CYLINDER (BOB-TACH)
Testing
Disassembly
Assembly
MAIN RELIEF VALVE
Description
Testing
Adjusting
HYDRAULIC CONTROL VALVE (STANDARD)
Description
Mount Bracket Removal And Installation
Identification Chart
Lift Load Check Valve Removal And Installation
Load Check Valve Removal And Installation (Tilt And Auxiliary)
Anti-Cavitation Valve Removal And Installation (Lift, Rod End)
Port Relief / Anti-Cavitation Valve Removal And Installation (Lift, Base End)
Port Relief / Anti-Cavitation Valve Removal And Installation (Tilt, Base End)
Port Relief / Anti-Cavitation Valve Removal And Installation (Tilt, Rod End)
Port Relief Valve Removal And Installation
Plug Removal And Installation
Rubber Boot Removal And Installation
End Cap Block Removal And Installation
Lift Spool And Detent Removal And Installation
Tilt Spool Removal And Installation
Auxiliary Spool Removal And Installation
Auxiliary Solenoid Removal And Installation
Lock Valve Removal And Installation
Lift Arm Bypass Orifice Removal And Installation
Main Relief Valve Removal And Installation
HYDRAULIC CONTROL VALVE (ACS) OR (SJC)
Description
Actuator Removal And Installation (In Loader)
Actuator Removal And Installation (Out Of Loader)
Lift Spool Removal And Installation
Lift Spool Disassembly And Assembly
Tilt Spool Disassembly And Assembly
LIFT ARM BYPASS CONTROL VALVE
Description
Testing
HYDRAULIC PUMP
Description
Pump Test At Quick Couplers
Direct Pump Test (Standard Section)
Direct Pump Test (Charge Section)
Hydraulic Pump Startup
HYDRAULIC / HYDROSTATIC FILTERS
Description
Housing Removal And Installation
HYDRAULIC FLUID RESERVOIR
Description
Hydraulic Fluid Screen
Gauge Removal And Installation
OIL COOLER
BUCKET POSITION VALVE
Description
Solenoid Testing
BOB-TACH (POWER) BLOCK (EARLIER MODELS)
Description
BOB-TACH (POWER) BLOCK (LATER MODELS)
Description
Testing Relief Valve
FRONT AUXILIARY HYDRAULIC COUPLER BLOCK
Description
Disassembly And Assembly (FFI/FI)
Disassembly And Assembly (FFH/FH)
HYDROSTATIC SYSTEMHYDROSTATIC SYSTEM INFORMATION
Description
Troubleshooting
HYDROSTATIC DRIVE MOTOR (EARLIER MODELS)
Description
Shaft Seal Replacement
HYDROSTATIC DRIVE MOTOR (LATER MODELS)
Description
CHARGE PRESSURE
Description
Testing
Adjusting
Sender Removal And Installation
HYDROSTATIC PUMP
Description
Hydrostatic Pump Startup
Replenishing / High Pressure Relief Valve Removal And Installation
Parts Identification (Left Half)
Parts Identification (Right Half)
Disassembly
Assembly
HYDROSTATIC PUMP (SJC)
Description
Hydraulic Controller Removal And Installation
High Pressure Relief And Bypass Valve
Charge Relief Valve
Mechanical Neutral Adjustment
Hydraulic Controller Neutral Adjustment
DRIVE BELT
Belt Adjustment
Belt Replacement
Tensioner Pulley Removal And Installation
Tensioner Pulley Disassembly And Assembly
DRAIN MANIFOLD
Description
Drain Manifold Removal And Installation
DRIVE SYSTEMBRAKE
Description
Disc Removal And Installation
DRIVE COMPONENTS
Description
Axle Seal Removal And Installation
Axle, Sprocket And Bearings Removal And Installation
Chain Removal And Installation
CHAINCASE
Description
Front Cover Removal And Installation
Center Cover Removal And Installation
MAINFRAMESEAT BAR
Description
Compression Spring Disassembly And Assembly
OPERATOR CAB
Gas Spring Removal And Installation
Gas Spring Bracket Disassembly And Assembly
OPERATOR SEAT
Seat Belt Removal And Installation (Retractable)
Seat Belt And Bracket Removal And Installation (Standard)
Seat Belt Bracket Removal And Installation
OPERATOR SEAT (SUSPENSION)
Slide Rail Removal And Installation
Lower Cushion Removal
Lower Cushion Installation
Back Cushion Removal And Installation
Shock Removal And Installation
3-Point Seat Belt Removal And Installation
Description
Lever And Wedge Disassembly And Assembly
Pivot Pin Bushing And Seal Removal And Installation
BOB-TACH (POWER)
Description
LIFT ARMS
REAR GRILLE
Removing
Installing
REAR DOOR (TAILGATE)
Striker Removal And Installation
Striker Disassembly And Assembly
Striker Adjusting
Latch Removal And Installation
FUEL TANK
Fuel Fill Screen Removal And Installation
Fuel Level Sender Removal And Installation
CONTROL PEDALS AND LINKAGES
Description
Pedal Removal And Installation
Linkage Removal And Installation
Pedal (Adjusting)
Floor Pan Removal And Installation
CONTROL PEDALS AND LINKAGES (ACS)
Description
Pedal (Adjusting)
CONTROL PEDALS AND LINKAGES (SJC)
Description
CONTROL PANEL
Description
Pintle Arm Disassembly And Assembly
Linkage Neutral (Adjusting)
Linkage Travel (Adjusting)
CONTROL PANEL (SJC)
Description
CONTROL HANDLE / LEVER
Description
Lever Removal And Installation
CONTROL HANDLE / LEVER (ACS)
Description
Handle Sensor Removal And Installation
Handle Removal And Installation
Handle Disassembly And Assembly
CONTROL HANDLE / LEVER (SJC)
Description
Joystick Testing
Joystick Removal And Installation
WINDOW (REAR)
Installation (Rubber Cord)
Removal And Installation (Latches)
Disassembly And Assembly (Latches)
WINDOW (TOP)
WINDOW (SIDE)
CAB DOOR
Description
Aligning
Adjusting
Checking Operation
ARMREST
Description
LEFT SIDE LOWER PANEL
RIGHT SIDE LOWER PANEL
HEADLINER
ELECTRICAL SYSTEM AND ANALYSISELECTRICAL SCHEMATICS
ELECTRICAL SYSTEM INFORMATION
Glossary Of Electrical Symbols
Standard Cab Harness Connectors
Deluxe Cab Harness Connectors
Mainframe / Engine Harness Connectors - Manual Controls (Earlier Models)
Mainframe / Engine Harness Connectors - SJC/ACS Controls (Earlier Models)
Mainframe / Engine Harness Connectors - Manual Controls (Later Models)
Mainframe / Engine Harness Connectors - SJC/ACS Controls (Later Models)
Description
Fuse And Relay Location / Identification
Troubleshooting
Solenoid Testing
BATTERY
Servicing
Maintaining Battery Charge Level
Battery Service During Machine Storage
Battery Testing
Battery Charging
Using A Booster Battery (Jump Starting)
ALTERNATOR
Belt Adjustment
Belt Replacement
Charging System Inspection
Alternator Voltage Testing
Low Voltage Testing
High Voltage Testing
STARTER
Testing
INSTRUMENT PANELS
Left Panel
Display Screen
Right Panel (Standard Key Panel)
Right Panel (Keyless Start Panel)
Right Panel (Deluxe Instrumentation Panel)
Left Switch Panel
Right Switch Panel
Left Side Lower Panel
Right Side Lower Panel
Left Panel Removal And Installation
Right Panel (Standard Key Panel) Removal And Installation
Right Panel (Keyless Start Panel) Removal And Installation
Right Panel (Deluxe Instrumentation Panel) Removal And Installation
Key Switch Disassembly And Assembly
Alarm Disassembly And Assembly
Left Switch Panel Removal And Installation
Right Switch Panel Removal And Installation
LIGHTS
Front Removal And Installation
Rear Removal And Installation
Cab Light Removal And Installation
BOBCAT CONTROLLERS (ACS AND AUXILIARY)
Description
Connector And Wire Identification
BOBCAT CONTROLLER (GATEWAY)
Description
Connector Identification
BOBCAT CONTROLLER (SJC) (DRIVE)
Description
DIAGNOSTIC SERVICE CODES
Viewing Service Codes
Service Codes List
BOBCAT INTERLOCK CONTROL SYSTEM (BICS™)
Description
Inspecting The BICS™ (Engine STOPPED – Key ON)
Inspecting Deactivation Of The Auxiliary Hydraulics System (Engine STOPPED – Key ON)
Inspecting The Seat Bar Sensor (Engine RUNNING)
Inspecting The Traction Lock And Parking Brake (Engine RUNNING)
Inspecting The Lift Arm Bypass Control
Inspecting Deactivation Of Lift And Tilt Functions (ACS And SJC)
Troubleshooting
SEAT BAR SENSOR
Description
Troubleshooting
Testing
Removal
Installation
Bobcat Interlock Control System (BICS™) Circuit Test
TRACTION LOCK
Description
Troubleshooting
Inspecting
CONTROL SYSTEM (ACS)
Description
Troubleshooting
Handle Sensor Connector Disassembly And Assembly
Switch Handle Removal
Switch Handle Installation
Actuator Connector Disassembly And Assembly
Handle Lock Solenoid Removal And Installation
Handle Lock Solenoid Disassembly And Assembly
Foot Sensor Removal And Installation
Foot Sensor Disassembly And Assembly
Foot Sensor Lock Solenoid Removal And Installation
ELECTRICAL / HYDRAULIC CONTROLS
Description
Identification Chart ACD Group 0
Identification Chart ACD Group 1
Identification Chart ACD Group 2
Identification Chart ACD Group 3
ELECTRICAL / HYDRAULIC CONTROLS (ACS)
Description
ELECTRICAL / HYDRAULIC CONTROLS (SJC)
Description
SERVICE PC (LAPTOP COMPUTER)
Connecting Remote Start Tool
Connecting Remote Start Tool (Service Tool)
CALIBRATION
Description
Actuator Testing
Lift And Tilt Calibration (SJC)
Hydrostatic Pump Calibration (SJC)
Lift And Tilt Calibration (ACS)
STEERING DRIFT COMPENSATION (OPERATOR MODE)
Description
Operation
STEERING DRIFT COMPENSATION (SERVICE MODE)
Description
Operation
FLYWHEEL RPM SENSOR
Description
Removal
Installation
CONTROL PANEL SETUP
Right Panel Setup (Deluxe Instrumentation Panel)
PASSWORD SETUP (DELUXE INSTRUMENTATION PANEL)
Password Description
Changing The Owner Password
Changing The User Passwords
Password Lockout Feature
PASSWORD SETUP (KEYLESS START PANEL)
MAINTENANCE CLOCK
Description
Setup
Reset
BACK-UP ALARM SYSTEM
Description
Inspecting
Adjusting Switch Position
Troubleshooting (Standard And ACS)
Troubleshooting (Joystick)
Alarm Removal And Installation
Switch Removal And Installation
FRONT HORN
Troubleshooting
ENGINE SERVICEENGINE INFORMATION
Description
Specifications
Torque Values
Troubleshooting
Engine Removal And Installation
Engine Mount Replacement
Compression - Testing
ENGINE SPEED CONTROL (HAND)
Cable Removal And Installation
ENGINE SPEED CONTROL (FOOT) (SJC)
Description
Pedal (Adjusting)
MUFFLER
AIR CLEANER
Radiator / Oil Cooler Removal And Installation
Hydraulic Fan Description
Fan Duct Removal And Installation
Hydraulic Fan Motor Assembly Removal And Installation (Earlier Models)
Hydraulic Fan Motor Removal And Installation (Earlier Models)
Hydraulic Fan Motor Disassembly And Assembly (Earlier Models)
Hydraulic Fan Motor Assembly Removal And Installation (Later Models)
Fan Removal And Installation (Later Models)
Hydraulic Fan Motor Removal And Installation (Later Models)
Hydraulic Fan Motor Disassembly And Assembly (Later Models)
Fan Shroud Removal And Installation
Water Pump Removal And Installation
Water Pump Disassembly And Assembly
Thermostat Housing Removal And Installation
Thermostat - Testing
LUBRICATION SYSTEM
Oil Pan Removal And Installation
Relief Valve - Inspection
Oil Pump Removal And Installation
Oil Pump Inspection
Engine Oil Pressure - Testing
FUEL SYSTEM
Fuel Shutoff Solenoid - Testing
Fuel Shutoff Solenoid Removal And Installation
Fuel Injection Pump - Testing
Fuel Injection Pump Removal And Installation
Governor Disassembly And Assembly
Fuel Camshaft Removal And Installation
Fuel Injection Pump - Timing
Fuel Injector Removal And Installation
Fuel Injector Nozzle Pressure - Checking
Nozzle Spray Condition
Valve Seat Tightness
CYLINDER HEAD
Glow Plugs - Testing
Glow Plugs Removal And Installation
Valve Clearance Adjustment
Valve Timing - Inspecting
Cylinder Head Removal And Installation
Cylinder Head Disassembly And Assembly
Cylinder Head - Servicing
Cylinder Head Top Clearance
Valve Guide - Inspecting
Valve Guide Removal And Installation
Reconditioning The Valve And Valve Seat
Valve Spring
Valve Tappets
Rocker Arm And Shaft - Inspecting
Push Rod Alignment - Inspecting
CRANKSHAFT AND PISTONS
Piston And Connecting Rod Removal And Installation
Piston And Connecting Rod - Servicing
Cylinder Bore - Inspecting
Connecting Rod Alignment
Crankshaft Gear Removal And Installation
Crankshaft And Bearings Removal And Installation
Crankshaft And Bearings - Servicing
CAMSHAFT AND TIMING GEARS
Timing Gearcase Cover Removal And Installation
Timing Gears Backlash - Inspection
Idler Gear And Camshaft Removal And Installation
Camshaft - Servicing
Idler Gear And Shaft - Servicing
FLYWHEEL AND HOUSING
Flywheel Removal And Installation
Ring Gear Removal And Installation
HEATING, VENTILATION AND AIR CONDITIONING (HVAC)AIR CONDITIONING SYSTEM FLOW
Description
Chart
Components
Safety Equipment
REGULAR MAINTENANCE
Filters
Belt Adjustment
Belt Replacement
Air Conditioning Condenser
Air Conditioning Lubrication
Air Conditioning Service Chart
Evaporator / Heater Coil
TROUBLESHOOTING
Blower Motor Does Not Operate
Blower Motor Operates Normally, But Air Flow Is Insufficient
Insufficient Cooling Although Air Flow And Compressor Operation Are Normal
The Compressor Does Not Operate At All, Or Operates Improperly
Gauge Pressure Related Troubleshooting
Troubleshooting Tree
Temperature / Pressure Chart
Poor A/C Performance
HVAC Repair And Leaks
Engine Coolant Bypassing The Heater Valve
Heater Valve Not Opening Or Closing
SYSTEM CHARGING AND RECLAMATION
Refrigerant Identification
Reclamation And Charging With Recovery / Charging Unit
COMPRESSOR
Oil
Oil Check
CONDENSER
RECEIVER / DRIER
Receiver / Drier Removal And Installation
Pressure Switch Removal And Installation
Schrader® Valve Removal And Installation
EVAPORATOR / HEATER UNIT
THERMOSTAT
Description
EXPANSION VALVE
EVAPORATOR COIL
HEATER COIL
BLOWER FAN
HEATER VALVE
SPECIFICATIONS(S450) LOADER SPECIFICATIONS
Machine Dimensions
Performance
Drive System
Controls
Capacities
Tires
TECHNICAL SERVICE GUIDE SPECIFICATIONS
Engine Torques
Loader Torques
Hydraulic / Hydrostatic System
Fuel Consumption
TORQUE SPECIFICATIONS FOR BOLTS
Torque For General SAE Bolts
Torque For General Metric Bolts
HYDRAULIC CONNECTION SPECIFICATIONS
Straight Thread O-ring Fitting
Flare Fitting
Tubelines And Hoses
HYDRAULIC / HYDROSTATIC FLUID SPECIFICATIONS
Specifications
CONVERSIONS
Decimal And Millimeter Equivalent Chart
U.S. To Metric Conversion Chart
SERVICE TOOLS REQUIRED
Remote Start Tools
Hydraulic Tools
Mainframe And Drive Tools
Electrical Tools
Engine Tools
HVAC Tools
ALPHABETICAL INDEX
- Bobcat Heavy Equipment Full Hydraulic Schematics & Electrical Schematics PDF
- Bobcat Compact Mini Excavator 320D-322D i, 320G-322G Parts Manual
- BOBCAT Service Library 2014 Service, Operator, Maintenance, Bulletines, etc...
- Bobcat 753 Service Manual
- Bobcat S130 Parts Manual
- Bobcat X220 Excavator 05-89 Service Manual
- Bobcat 442 Mini Excavator Service Manual
- Bobcat 435 Mini Excavator Parts Manual
- Bobcat Compact Mini Excavator 773 G-Series Parts Manual
- Bobcat Excavators 323 6986958 Service Manual 2-08
- Bobcat S175, S185 Parts Manual
- Bobcat Skid Steer Loader 863 Service Manual
- Bobcat S150-S160 Skid-Steer Loader Service Manual 6902730
- Bobcat 430 Service Manual s/n 563011001 AND UP
- Bobcat s175, s185 operators manual
