Hyundai
86
176,834
Bobcat Skid-Steer Loader S450 Service Manual 6990808enUS 2018
Brand: Bobcat
Type of Machine: Skid-Steer Loader
Model: Bobcat S450 Skid-Steer Loader
S/N AV9V11001 & Above
S/N BIE611001 & Above
Part Number: 6990808enUS
Publication Date: 2018
Number of Pages: 994 Pages
FOREWORD
FOREWORD​
SAFETY INSTRUCTIONS​
Avoid Silica Dust​
FIRE PREVENTION​
Maintenance​
Operation​
Electrical​
Hydraulic System​
Fueling​
Starting​
Spark Arrester Exhaust System​
Welding And Grinding​
Fire Extinguishers​
SERIAL NUMBER LOCATIONS​
Loader Serial Number​
Engine Serial Number​
DELIVERY REPORT​
LOADER IDENTIFICATION​
SAFETY AND MAINTENANCE
LIFTING AND BLOCKING THE LOADER​
Procedure​
LIFT ARM SUPPORT DEVICE​
Description​
Installing​
Removing​
OPERATOR CAB​
Description​
Cab Door Sensor​
Raising​
Lowering​
TRANSPORTING THE LOADER ON A TRAILER​
Loading And Unloading​
Fastening​
TOWING THE LOADER​
Procedure​
REMOTE START TOOL KIT - MEL1563​
Remote Start Tool - MEL1563​
Service Tool Harness Communicator - MEL1566​
Remote Start Procedure​
REMOTE START TOOL (SERVICE TOOL) KIT - 7217666​
Description​
Remote Start Tool (Service Tool) - 7022042​
Loader Service Tool Harness - 6689747​
Computer Service Tool Harness - 6689746​
SERVICE SCHEDULE​
Maintenance Intervals​
ENGINE AIR CLEANER​
Replacing Filters​
ENGINE COOLING SYSTEM​
Maintenance Platform​
Cleaning​
Checking And Adding Coolant​
Removing And Replacing Coolant​
FUEL SYSTEM​
Fuel Specifications​
Biodiesel Blend Fuel​
Filling The Fuel Tank​
Fuel Filters​
Removing Air From The Fuel System​
ENGINE LUBRICATION SYSTEM​
Checking And Adding Engine Oil​
Engine Oil Chart​
Removing And Replacing Oil And Filter​
HYDRAULIC / HYDROSTATIC SYSTEM​
Checking And Adding Fluid​
Hydraulic / Hydrostatic Fluid Chart​
Removing And Replacing Hydraulic Fluid​
Removing And Replacing Hydraulic / Hydrostatic Filter​
Removing And Replacing Hydraulic Charge Filter​
Replacing Reservoir Breather Cap​
FINAL DRIVE TRANSMISSION (CHAINCASE)​
Removing And Replacing Fluid​
BOB-TACH (HAND LEVER)​
Inspection And Maintenance​
BOB-TACH (POWER)​
LUBRICATING THE LOADER​
Lubrication Locations​
TIRE MAINTENANCE​
Wheel Nuts​
Rotating​
Mounting​
SPARK ARRESTER MUFFLER​
Cleaning Procedure​
PIVOT PINS​
LOADER STORAGE AND RETURN TO SERVICE​
Storage​
Return To Service​
STOPPING THE ENGINE AND LEAVING THE LOADER​
Procedure​
EMERGENCY EXIT​
Rear Window Identification​
Rear Window Removal (Latches)​
Rear Window Removal (Rubber Cord)​
External Access (Rear Window With Latches)​
External Access (Rear Window With Rubber Cord)​
Front Door​
SEAT BELT​
HYDRAULIC SYSTEM
HYDRAULIC / HYDROSTATIC SCHEMATICS​
HYDRAULIC SYSTEM INFORMATION​
Glossary Of Hydraulic / Hydrostatic Symbols​
Troubleshooting​
CYLINDER (LIFT)​
Testing​
Removal And Installation​
Parts Identification​
Disassembly​
Assembly​
CYLINDER (TILT)​
Testing​
Base End Pivot Pin Removal And Installation​
Disassembly​
Assembly​
CYLINDER (LIFT) (AZNB11488 & ABOVE)​
Disassembly​
Assembly​
CYLINDER (TILT) (AZNB11488 & ABOVE)​
Disassembly​
Assembly​
CYLINDER (BOB-TACH)​
Testing​
Disassembly​
Assembly​
MAIN RELIEF VALVE​
Description​
Testing​
Adjusting​
HYDRAULIC CONTROL VALVE (STANDARD)​
Description​
Mount Bracket Removal And Installation​
Identification Chart​
Lift Load Check Valve Removal And Installation​
Load Check Valve Removal And Installation (Tilt And Auxiliary)​
Anti-Cavitation Valve Removal And Installation (Lift, Rod End)​
Port Relief / Anti-Cavitation Valve Removal And Installation (Lift, Base End)​
Port Relief / Anti-Cavitation Valve Removal And Installation (Tilt, Base End)​
Port Relief / Anti-Cavitation Valve Removal And Installation (Tilt, Rod End)​
Port Relief Valve Removal And Installation​
Plug Removal And Installation​
Rubber Boot Removal And Installation​
End Cap Block Removal And Installation​
Lift Spool And Detent Removal And Installation​
Tilt Spool Removal And Installation​
Auxiliary Spool Removal And Installation​
Auxiliary Solenoid Removal And Installation​
Lock Valve Removal And Installation​
Lift Arm Bypass Orifice Removal And Installation​
Main Relief Valve Removal And Installation​
HYDRAULIC CONTROL VALVE (ACS) OR (SJC)​
Description​
Actuator Removal And Installation (In Loader)​
Actuator Removal And Installation (Out Of Loader)​
Lift Spool Removal And Installation​
Lift Spool Disassembly And Assembly​
LIFT ARM BYPASS CONTROL VALVE​
Description​
Testing​
HYDRAULIC PUMP​
Description​
Pump Test At Quick Couplers​
Direct Pump Test (Standard Section)​
Direct Pump Test (Charge Section)​
Hydraulic Pump Startup​
HYDRAULIC / HYDROSTATIC FILTERS​
Description​
Housing Removal And Installation​
HYDRAULIC FLUID RESERVOIR​
Description​
Hydraulic Fluid Screen​
Gauge Removal And Installation​
OIL COOLER​
BUCKET POSITION VALVE​
Description​
Solenoid Testing​
BOB-TACH (POWER) BLOCK (EARLIER MODELS)​
Description​
BOB-TACH (POWER) BLOCK (LATER MODELS)​
Description​
Testing Relief Valve​
FRONT AUXILIARY HYDRAULIC COUPLER BLOCK​
Description​
Disassembly And Assembly (FFI/FI)​
Disassembly And Assembly (FFH/FH)​
HYDROSTATIC SYSTEM
HYDROSTATIC SYSTEM INFORMATION​
Description​
Troubleshooting​
HYDROSTATIC DRIVE MOTOR​
Description​
Shaft Seal Replacement​
CHARGE PRESSURE​
Description​
Testing​
Adjusting​
Sender Removal And Installation​
HYDROSTATIC PUMP​
Description​
Hydrostatic Pump Startup​
Replenishing / High Pressure Relief Valve Removal And Installation​
Parts Identification (Left Half)​
Parts Identification (Right Half)​
Disassembly​
Assembly​
HYDROSTATIC PUMP (SJC)​
Description​
Hydraulic Controller Removal And Installation​
High Pressure Relief And Bypass Valve​
Charge Relief Valve​
Mechanical Neutral Adjustment​
Hydraulic Controller Neutral Adjustment​
DRIVE BELT​
Belt Adjustment​
Belt Replacement​
Tensioner Pulley Removal And Installation​
Tensioner Pulley Disassembly And Assembly​
DRAIN MANIFOLD​
Description​
Drain Manifold Removal And Installation​
DRIVE SYSTEM
BRAKE​
Description​
Disc Removal And Installation​
DRIVE COMPONENTS​
Description​
Axle Seal Removal And Installation​
Axle, Sprocket And Bearings Removal And Installation​
Chain Removal And Installation​
CHAINCASE​
Description​
Front Cover Removal And Installation​
Center Cover Removal And Installation​
MAINFRAME
SEAT BAR​
Description​
Compression Spring Disassembly And Assembly​
OPERATOR CAB​
Gas Spring Removal And Installation​
Gas Spring Bracket Disassembly And Assembly​
OPERATOR SEAT​
Seat Belt Removal And Installation (Retractable)​
Seat Belt And Bracket Removal And Installation (Standard)​
Seat Belt Bracket Removal And Installation​
OPERATOR SEAT (SUSPENSION)​
Slide Rail Removal And Installation​
Seat Belt Removal And Installation​
Lower Cushion Removal​
Lower Cushion Installation​
Back Cushion Removal And Installation​
Shock Removal And Installation​
3-Point Seat Belt Removal And Installation​
Description​
Lever And Wedge Disassembly And Assembly​
Pivot Pin Bushing And Seal Removal And Installation​
BOB-TACH (POWER)​
Description​
LIFT ARMS​
REAR GRILLE​
Removing​
Installing​
REAR DOOR (TAILGATE)​
Striker Removal And Installation​
Striker Disassembly And Assembly​
Striker Adjusting​
Latch Removal And Installation​
FUEL TANK​
Fuel Fill Screen Removal And Installation​
Fuel Level Sender Removal And Installation​
CONTROL PEDALS AND LINKAGES​
Description​
Pedal Removal And Installation​
Linkage Removal And Installation​
Pedal (Adjusting)​
Floor Pan Removal And Installation​
CONTROL PEDALS AND LINKAGES (ACS)​
Description​
Pedal (Adjusting)​
CONTROL PEDALS AND LINKAGES (SJC)​
Description​
CONTROL PANEL​
Description​
Pintle Arm Disassembly And Assembly​
Linkage Neutral (Adjusting)​
Linkage Travel (Adjusting)​
CONTROL PANEL (SJC)​
Description​
CONTROL HANDLE / LEVER​
Description​
Lever Removal And Installation​
CONTROL HANDLE / LEVER (ACS)​
Description​
Handle Sensor Removal And Installation​
Handle Removal And Installation​
Handle Disassembly And Assembly​
CONTROL HANDLE / LEVER (SJC)​
Description​
Joystick Testing​
Joystick Removal And Installation​
WINDOW (REAR)​
Installation (Rubber Cord)​
Removal And Installation (Latches)​
Disassembly And Assembly (Latches)​
WINDOW (TOP)​
WINDOW (SIDE)​
CAB DOOR​
Description​
Aligning​
Adjusting​
Checking Operation​
ARMREST​
Description​
LEFT SIDE LOWER PANEL​
RIGHT SIDE LOWER PANEL​
HEADLINER​
ELECTRICAL SYSTEM AND ANALYSIS
ELECTRICAL SCHEMATICS​
ELECTRICAL SYSTEM INFORMATION​
Glossary Of Electrical Symbols​
Standard Cab Harness Connectors​
Deluxe Cab Harness Connectors​
Mainframe / Engine Harness Connectors - Manual Controls (Earlier Models)​
Mainframe / Engine Harness Connectors - SJC/ACS Controls (Earlier Models)​
Mainframe / Engine Harness Connectors - Manual Controls (Later Models)​
Mainframe / Engine Harness Connectors - SJC/ACS Controls (Later Models)​
Description​
Fuse And Relay Location / Identification​
Troubleshooting​
Solenoid Testing​
BATTERY​
Servicing​
Maintaining Battery Charge Level​
Battery Service During Machine Storage​
Battery Testing​
Battery Charging​
Using A Booster Battery (Jump Starting)​
ALTERNATOR​
Belt Adjustment​
Belt Replacement​
Charging System Inspection​
Alternator Voltage Testing​
Low Voltage Testing​
High Voltage Testing​
STARTER​
Testing​
INSTRUMENT PANELS​
Left Panel​
Display Screen​
Right Panel (Standard Key Panel)​
Right Panel (Keyless Start Panel)​
Right Panel (Deluxe Instrumentation Panel)​
Left Switch Panel​
Right Switch Panel​
Left Side Lower Panel​
Right Side Lower Panel​
Left Panel Removal And Installation​
Right Panel (Standard Key Panel) Removal And Installation​
Right Panel (Keyless Start Panel) Removal And Installation​
Right Panel (Deluxe Instrumentation Panel) Removal And Installation​
Key Switch Disassembly And Assembly​
Alarm Disassembly And Assembly​
Left Switch Panel Removal And Installation​
Right Switch Panel Removal And Installation​
LIGHTS​
Front Removal And Installation​
Rear Removal And Installation​
Cab Light Removal And Installation​
BOBCAT CONTROLLERS (ACS AND AUXILIARY)​
Description​
Connector And Wire Identification​
BOBCAT CONTROLLER (GATEWAY)​
Description​
Connector Identification​
BOBCAT CONTROLLER (SJC) (DRIVE)​
Description​
DIAGNOSTIC SERVICE CODES​
Viewing Service Codes​
Service Codes List​
BOBCAT INTERLOCK CONTROL SYSTEM (BICS™)​
Description​
Inspecting The BICS™ (Engine STOPPED – Key ON)​
Inspecting Deactivation Of The Auxiliary Hydraulics System (Engine STOPPED – Key ON)​
Inspecting The Seat Bar Sensor (Engine RUNNING)​
Inspecting The Traction Lock And Parking Brake (Engine RUNNING)​
Inspecting The Lift Arm Bypass Control​
Inspecting Deactivation Of Lift And Tilt Functions (ACS And SJC)​
Troubleshooting​
SEAT BAR SENSOR​
Description​
Troubleshooting​
Testing​
Removal​
Installation​
Bobcat Interlock Control System (BICS™) Circuit Test​
TRACTION LOCK​
Description​
Troubleshooting​
Inspecting​
CONTROL SYSTEM (ACS)​
Description​
Troubleshooting​
Handle Sensor Connector Disassembly And Assembly​
Switch Handle Removal​
Switch Handle Installation​
Actuator Connector Disassembly And Assembly​
Handle Lock Solenoid Removal And Installation​
Handle Lock Solenoid Disassembly And Assembly​
Foot Sensor Removal And Installation​
Foot Sensor Disassembly And Assembly​
Foot Sensor Lock Solenoid Removal And Installation​
ELECTRICAL / HYDRAULIC CONTROLS​
Description​
Identification Chart ACD Group 0​
Identification Chart ACD Group 1​
Identification Chart ACD Group 2​
Identification Chart ACD Group 3​
ELECTRICAL / HYDRAULIC CONTROLS (ACS)​
Description​
ELECTRICAL / HYDRAULIC CONTROLS (SJC)​
Description​
SERVICE PC (LAPTOP COMPUTER)​
Connecting Remote Start Tool​
Connecting Remote Start Tool (Service Tool)​
CALIBRATION​
Description​
Actuator Testing​
Lift And Tilt Calibration (SJC)​
Hydrostatic Pump Calibration (SJC)​
Lift And Tilt Calibration (ACS)​
STEERING DRIFT COMPENSATION (OPERATOR MODE)​
Description​
Operation​
STEERING DRIFT COMPENSATION (SERVICE MODE)​
Description​
Operation​
FLYWHEEL RPM SENSOR​
Description​
Removal​
Installation​
CONTROL PANEL SETUP​
Right Panel Setup (Deluxe Instrumentation Panel)​
PASSWORD SETUP (DELUXE INSTRUMENTATION PANEL)​
Password Description​
Changing The Owner Password​
Changing The User Passwords​
Password Lockout Feature​
PASSWORD SETUP (KEYLESS START PANEL)​
MAINTENANCE CLOCK​
Description​
Setup​
Reset​
BACK-UP ALARM SYSTEM​
Description​
Inspecting​
Adjusting Switch Position​
Troubleshooting (Standard And ACS)​
Troubleshooting (Joystick)​
Alarm Removal And Installation​
Switch Removal And Installation​
FRONT HORN​
Troubleshooting​
ENGINE SERVICE
ENGINE INFORMATION​
Description​
Specifications​
Torque Values​
Troubleshooting​
Engine Removal And Installation​
Engine Mount Replacement​
Compression - Testing​
ENGINE SPEED CONTROL (HAND)​
Cable Removal And Installation​
ENGINE SPEED CONTROL (FOOT) (SJC)​
Description​
Disassembly and Assembly​
Pedal (Adjusting)​
MUFFLER​
AIR CLEANER​
Radiator / Oil Cooler Removal And Installation​
Hydraulic Fan Description​
Fan Duct Removal And Installation​
Hydraulic Fan Motor Assembly Removal And Installation (Earlier Models)​
Hydraulic Fan Motor Removal And Installation (Earlier Models)​
Hydraulic Fan Motor Disassembly And Assembly (Earlier Models)​
Hydraulic Fan Motor Assembly Removal And Installation (Later Models)​
Fan Removal And Installation (Later Models)​
Hydraulic Fan Motor Removal And Installation (Later Models)​
Hydraulic Fan Motor Disassembly And Assembly (Later Models)​
Water Pump Removal And Installation​
Water Pump Disassembly And Assembly​
Thermostat Housing Removal And Installation​
Thermostat - Testing​
LUBRICATION SYSTEM​
Oil Pan Removal And Installation​
Relief Valve - Inspection​
Oil Pump Removal And Installation​
Oil Pump Inspection​
Engine Oil Pressure - Testing​
FUEL SYSTEM​
Fuel Shutoff Solenoid - Testing​
Fuel Shutoff Solenoid Removal And Installation​
Fuel Injection Pump - Testing​
Fuel Injection Pump Removal And Installation​
Governor Disassembly And Assembly​
Fuel Camshaft Removal And Installation​
Fuel Injection Pump - Timing​
Fuel Injector Removal And Installation​
Fuel Injector Nozzle Pressure - Checking​
Nozzle Spray Condition​
Valve Seat Tightness​
CYLINDER HEAD​
Glow Plugs - Testing​
Glow Plugs Removal And Installation​
Valve Clearance Adjustment​
Valve Timing - Inspecting​
Cylinder Head Removal And Installation​
Cylinder Head Disassembly And Assembly​
Cylinder Head - Servicing​
Cylinder Head Top Clearance​
Valve Guide - Inspecting​
Valve Guide Removal And Installation​
Reconditioning The Valve And Valve Seat​
Valve Spring​
Valve Tappets​
Rocker Arm And Shaft - Inspecting​
Push Rod Alignment - Inspecting​
CRANKSHAFT AND PISTONS​
Piston And Connecting Rod Removal And Installation​
Piston And Connecting Rod - Servicing​
Cylinder Bore - Inspecting​
Connecting Rod Alignment​
Crankshaft Gear Removal And Installation​
Crankshaft And Bearings Removal And Installation​
Crankshaft And Bearings - Servicing​
CAMSHAFT AND TIMING GEARS​
Timing Gearcase Cover Removal And Installation​
Timing Gears Backlash - Inspection​
Idler Gear And Camshaft Removal And Installation​
Camshaft - Servicing​
Idler Gear And Shaft - Servicing​
FLYWHEEL AND HOUSING​
Flywheel Removal And Installation​
Ring Gear Removal And Installation​
HEATING, VENTILATION AND AIR CONDITIONING (HVAC)
AIR CONDITIONING SYSTEM FLOW​
Description​
Chart​
Components​
Safety Equipment​
REGULAR MAINTENANCE​
Filters​
Belt Adjustment​
Belt Replacement​
Air Conditioning Condenser​
Air Conditioning Lubrication​
Air Conditioning Service Chart​
Evaporator / Heater Coil​
TROUBLESHOOTING​
Blower Motor Does Not Operate​
Blower Motor Operates Normally, But Air Flow Is Insufficient​
Insufficient Cooling Although Air Flow And Compressor Operation Are Normal​
The Compressor Does Not Operate At All, Or Operates Improperly​
Gauge Pressure Related Troubleshooting​
Troubleshooting Tree​
Temperature / Pressure Chart​
Poor A/C Performance​
HVAC Repair And Leaks​
Electrical System​
Engine Coolant Bypassing The Heater Valve​
Heater Valve Not Opening Or Closing​
SYSTEM CHARGING AND RECLAMATION​
Refrigerant Identification​
Reclamation And Charging With Recovery / Charging Unit​
COMPRESSOR​
Oil​
Oil Check​
CONDENSER​
RECEIVER / DRIER​
Receiver / Drier Removal And Installation​
Pressure Switch Removal And Installation​
Schrader® Valve Removal And Installation​
EVAPORATOR / HEATER UNIT​
THERMOSTAT​
Description​
EXPANSION VALVE​
EVAPORATOR COIL​
HEATER COIL​
BLOWER FAN​
HEATER VALVE​
SPECIFICATIONS
(S450) LOADER SPECIFICATIONS​
Machine Dimensions​
Performance​
Engine​
Drive System​
Controls​
Hydraulic System​
Electrical System​
Capacities​
Tires​
Environmental​
Temperature Range​
TECHNICAL SERVICE GUIDE SPECIFICATIONS​
Engine​
Engine Torques​
Cooling System​
Loader Torques​
Hydraulic / Hydrostatic System​
Fuel Consumption​
TORQUE SPECIFICATIONS FOR BOLTS​
Torque For General SAE Bolts​
Torque For General Metric Bolts​
HYDRAULIC CONNECTION SPECIFICATIONS​
Straight Thread O-ring Fitting​
Flare Fitting​
Tubelines And Hoses​
HYDRAULIC / HYDROSTATIC FLUID SPECIFICATIONS​
Specifications​
CONVERSIONS​
Decimal And Millimeter Equivalent Chart​
U.S. To Metric Conversion Chart​
SERVICE TOOLS REQUIRED​
Remote Start Tools​
Hydraulic Tools​
Mainframe And Drive Tools​
Electrical Tools​
Engine Tools​
HVAC Tools​
ALPHABETICAL INDEX
