Bobcat Excavator E85 Service Manual 7320318enUS 2018
Brand: Bobcat
Type of Machine: Excavator
Model: Bobcat E85 Excavator
S/N B48411001 & Above
Part Number: 7320318enUS
Publication Date: 2018
Number of Pages: 891 Pages
FOREWORD
SERVICE SCHEDULE SYMBOLS
Brand: Bobcat
FOREWORD
FOREWORD
SAFETY INSTRUCTIONS
FIRE PREVENTION
SERIAL NUMBER LOCATIONS
DELIVERY REPORT
EXCAVATOR IDENTIFICATION
SAFETY AND MAINTENANCELIFTING AND BLOCKING THE EXCAVATOR
LIFTING THE EXCAVATOR
OPERATOR CAB (ROPS / TOPS)
OPERATOR CAB (ROPS / TOPS / FOPS)
TRANSPORTING THE EXCAVATOR ON A TRAILER
TAILGATE
RIGHT SIDE COVER
CENTER COVER
SERVICE SCHEDULE
AIR CLEANER SERVICE
CAB FILTERS
ENGINE COOLING SYSTEM
FUEL SYSTEM
ENGINE LUBRICATION SYSTEM
HYDRAULIC SYSTEM
LUBRICATING THE EXCAVATOR
PIVOT PINS
TRAVEL MOTOR
EMERGENCY EXIT
SEAT BELT
CONTROL CONSOLE LOCKOUTS
TOWING THE EXCAVATOR
REMOTE START TOOL KIT - MEL1563
REMOTE START TOOL (SERVICE TOOL) KIT - 7217666
HYDRAULIC SYSTEMHYDRAULIC / HYDROSTATIC SCHEMATICS
HYDRAULIC SYSTEM INFORMATION
CYLINDER (BOOM)
CYLINDER (ARM)
CYLINDER (BOOM SWING)
CYLINDER (BUCKET)
CYLINDER (BLADE)
CYLINDER (CLAMP)
VALVE (MAIN RELIEF)
VALVE (PORT RELIEF)
VALVE (CROSS PORT RELIEF)
VALVE (PRESSURE REDUCING)
HYDRAULIC CONTROL VALVE
HYDRAULIC PUMP
MANIFOLD ASSEMBLY / ACCUMULATOR
TRAVEL MOTOR
SWIVEL JOINT
SWING MOTOR
SWING MOTOR (DRIVE CARRIER)
CONTROL PATTERN SELECTOR VALVE
RIGHT CONTROL LEVER (JOYSTICK)
LEFT CONTROL LEVER (JOYSTICK)
HYDRAULIC FILTER MOUNT
HYDRAULIC RESERVOIR
OIL COOLER
BLADE CONTROL LEVER
CASE DRAIN FILTER MOUNT
TRAVEL CONTROL VALVE
REMOVING AIR FROM THE HYDRAULIC SYSTEM
MANIFOLD (PIN GRABBER)
SECONDARY AUXILIARY VALVE
VALVE (BOOM LOCK)
VALVE (ARM LOCK)
UNDERCARRIAGEBLADE
TRACK UNDERCARRIAGE COMPONENTS (RUBBER TRACK)
TRACK UNDERCARRIAGE COMPONENTS (STEEL TRACK)
TRACK MAINTENANCE
SWING CIRCLE GEAR
UPPERSTRUCTURE AND SWING SECTIONUPPERSTRUCTURE
CAB
SEAT
RIGHT CONSOLE
LEFT CONSOLE
LEFT UPPERSTRUCTURE COVER
RIGHT UPPERSTRUCTURE COVER
COUNTERWEIGHT
TRAVEL LEVERS AND PEDALS
FLOOR MAT
FUEL TANK
HORN
SWING FRAME
BOOM
ARM
BUCKET
CLAMP
TAILGATE
QUICK COUPLER (PIN GRABBER)
RIGHT SIDE COVER
TOOL BOX
CENTER COVER
ELECTRICAL SYSTEM AND ANALYSISELECTRICAL SCHEMATICS
ELECTRICAL SYSTEM INFORMATION
BATTERY
ALTERNATOR
STARTER
LIGHTS
MAGNETIC LOCKOUT SENSOR
FUEL LEVEL SENDER
DIAGNOSTIC SERVICE CODES
CONTROL PANEL SETUP
INSTRUMENT PANEL
CONTROLLER (GATEWAY AND AUXILIARY)
CONTROLLER (PIN GRABBER)
ENGINE CONTROL UNIT (ECU)
KEY SWITCH
WIPER MOTOR
MOTION ALARM SYSTEM
SERVICE PC (LAPTOP COMPUTER)
SHUT-OFF SWITCH
TRAVEL MOTOR AUTO-SHIFT
AUTO IDLE PRESSURE SENSOR
CONNECTED MACHINE
ENGINE SERVICEENGINE INFORMATION
DIESEL OXIDATION CATALYST (DOC)
AIR CLEANER
LUBRICATION SYSTEM
FUEL SYSTEM
CYLINDER HEAD
CRANKSHAFT AND PISTONS
CAMSHAFT
GEARCASE
TURBOCHARGER
FLYWHEEL AND HOUSING
EXHAUST GAS RECIRCULATION (EGR) SYSTEM
HEATING, VENTILATION AND AIR CONDITIONINGAIR CONDITIONING SYSTEM FLOW
REGULAR MAINTENANCE
TROUBLESHOOTING
SYSTEM CHARGING AND RECLAMATION
COMPRESSOR
CONDENSER
RECEIVER / DRIER
EVAPORATOR / HEATER UNIT
THERMOSTAT
EXPANSION VALVE
EVAPORATOR COIL
HEATER COIL
BLOWER FAN
HEATER VALVE
HVAC DUCT
SPECIFICATIONSEXCAVATOR SPECIFICATIONS
TECHNICAL SERVICE GUIDE SPECIFICATIONS
TORQUE SPECIFICATION FOR BOLTS
HYDRAULIC CONNECTION SPECIFICATIONS
HYDRAULIC FLUID SPECIFICATIONS
CONVERSIONS
SERVICE TOOLS REQUIRED
ALPHABETICAL INDEXSERVICE SCHEDULE SYMBOLS
- Bobcat Heavy Equipment Full Hydraulic Schematics & Electrical Schematics PDF
- Bobcat Compact Mini Excavator 320D-322D i, 320G-322G Parts Manual
- BOBCAT Service Library 2014 Service, Operator, Maintenance, Bulletines, etc...
- Bobcat 753 Service Manual
- Bobcat S130 Parts Manual
- Bobcat X220 Excavator 05-89 Service Manual
- Bobcat 442 Mini Excavator Service Manual
- Bobcat 435 Mini Excavator Parts Manual
- Bobcat Compact Mini Excavator 773 G-Series Parts Manual
- Bobcat Excavators 323 6986958 Service Manual 2-08
- Bobcat S175, S185 Parts Manual
- Bobcat Skid Steer Loader 863 Service Manual
- Bobcat S150-S160 Skid-Steer Loader Service Manual 6902730
- Bobcat 430 Service Manual s/n 563011001 AND UP
- Bobcat s175, s185 operators manual
