Bobcat Excavator E35Z Service Manual 7362211enUS 2025
Brand: Bobcat
Type of Machine: Excavator
Type of Manual: Service Manual, Electrical and Hydraulic Diagrams
Model: Bobcat E35Z Excavator
Part Number: 7362211enUS
Publication Date: 2025
Number of Pages: 906 Pages
FOREWORD
SERVICE SCHEDULE SYMBOLS
Brand: Bobcat
FOREWORD
FOREWORD
SAFETY INSTRUCTIONS
FIRE PREVENTION
Maintenance
Operation
Electrical
Fueling
Starting
Spark Arrester Exhaust System
Welding And Grinding
Fire Extinguishers
SERIAL NUMBER LOCATIONS
Excavator Serial Number
Engine Serial Number
DELIVERY REPORT
EXCAVATOR IDENTIFICATION
SAFETY AND MAINTENANCELIFTING AND BLOCKING THE EXCAVATOR
Procedure
LIFTING THE EXCAVATOR
Procedure
OPERATOR CAB (ROPS / TOPS / FOPS)
Description
Cab Door
Front Window
Front Wiper
Window Washer Reservoir
Right Side Window
OPERATOR CANOPY (ROPS / TOPS / FOPS)
Description
TRANSPORTING THE EXCAVATOR ON A TRAILER
Loading And Unloading
Fastening
TAILGATE
Opening And Closing
Adjusting The Latch
RIGHT SIDE COVER
Opening And Closing
SERVICE SCHEDULE
Maintenance Intervals
AIR CLEANER SERVICE
Daily Check
Replacing The Filter Elements
CAB FILTERS
Cleaning And Maintenance
ENGINE COOLING SYSTEM
Cleaning
Checking Level
Coolant Types
Coolant Concentration
Removing And Replacing Coolant
FUEL SYSTEM
Fuel Specifications
Biodiesel Blend Fuel
Filling The Fuel Tank
Fuel Filters
Draining The Fuel Tank
Removing Air From The Fuel System
ENGINE LUBRICATION SYSTEM
Checking And Adding Engine Oil
Engine Oil Chart
Removing And Replacing Oil And Filter
HYDRAULIC SYSTEM
Checking And Adding Hydraulic Fluid
Hydraulic / Hydrostatic Fluid Chart
Removing And Replacing Hydraulic Filters
Removing And Replacing Hydraulic Fluid
LUBRICATING THE EXCAVATOR
Lubrication Locations
PIVOT PINS
Inspection And Maintenance
TRAVEL MOTOR
Checking And Adding Oil
SPARK ARRESTER MUFFLER
Cleaning Procedure
EMERGENCY EXIT
Right Side Rear Window
Front Window
SEAT BELT
CONTROL CONSOLE LOCKOUTS
TOWING THE EXCAVATOR
Procedure
REMOTE START TOOL KIT - MEL1563
Remote Start Tool Kit - MEL1563
Service Tool Harness Control - MEL1565
Service Tool Harness Communicator - MEL1566
REMOTE START TOOL (SERVICE TOOL) KIT - 7217666
Description
Remote Start Tool (Service Tool) - 7022042
Excavator Service Tool Harness - 6689747
Computer Service Tool Harness - 6689746
HYDRAULIC SYSTEMHYDRAULIC / HYDROSTATIC SCHEMATICS
S/N B4S511001 & Above
HYDRAULIC SYSTEM INFORMATION
Glossary Of Hydraulic / Hydrostatic Symbols
Troubleshooting The Hydraulic Circuit
Troubleshooting The Cylinder Circuit
Troubleshooting The Swing (Upperstructure Slew) Circuit
Troubleshooting The Travel Circuit
CYLINDER (BOOM)
Testing
Removal And Installation
Parts Identification (Earlier Models)
Parts Identification (Later Models)
Disassembly (Earlier Models)
Disassembly (Later Models)
Assembly (Earlier Models)
Assembly (Later Models)
CYLINDER (ARM)
Testing
CYLINDER (BOOM SWING)
Testing
CYLINDER (BUCKET)
Testing
CYLINDER (BLADE)
Testing
CYLINDER (CLAMP)
Testing
Disassembly
Assembly
VALVE (MAIN RELIEF)
Description
VALVE (PORT RELIEF)
Testing And Adjusting Port Relief Valve Pressure
VALVE (CROSS PORT RELIEF)
Testing
Disassembly And Assembly
VALVE (PILOT PRESSURE RELIEF)
Testing And Adjusting The Pilot Pressure Relief Valve
HYDRAULIC CONTROL VALVE
Description
Disassembly
Assembly
Inlet Valve Section Disassembly And Assembly
Boom Swing Valve Section Disassembly And Assembly
Slew Valve Section Disassembly And Assembly
Blade Valve Section Disassembly And Assembly
Right And Left Travel Valve Section Disassembly And Assembly
Boom Valve Section Disassembly And Assembly
Auxiliary, Arm, Bucket And Angle Blade Valve Section Disassembly And Assembly
Outlet Valve Section Disassembly And Assembly
HYDRAULIC PUMP
Hydraulic Pump Work Sheet
Pump Testing
Description
Coupler Removal And Installation
Hydraulic Pump Startup
Gear Pump Disassembly And Assembly
Piston Pump Parts Identification
Piston Pump Disassembly And Assembly
MANIFOLD ASSEMBLY / ACCUMULATOR
Description
MANIFOLD ASSEMBLY / ACCUMULATOR (WITH ANGLE BLADE)
Description
TRAVEL MOTOR
Description
Parts Identification Hydraulic Motor
Parts Identification Gear Reduction Hub
Disassembly
Assembly
SWIVEL JOINT
SWING MOTOR
SWING MOTOR (DRIVE CARRIER)
CONTROL PATTERN SELECTOR VALVE
RIGHT CONTROL LEVER (JOYSTICK)
Testing
Handle Removal And Installation
Joystick Assembly Removal And Installation
LEFT CONTROL LEVER (JOYSTICK)
Testing
HYDRAULIC FILTER MOUNT
HYDRAULIC RESERVOIR
OIL COOLER
DIRECT TO TANK VALVE
BLADE CONTROL LEVER
CASE DRAIN FILTER MOUNT
TRAVEL CONTROL VALVE
REMOVING AIR FROM THE HYDRAULIC SYSTEM
Procedure
HYDRAULIC X-CHANGE MANIFOLD
SECONDARY AUXILIARY VALVE
VALVE (BOOM LOCK) (LATER MODELS)
VALVE (BOOM LOCK) (EARLIER MODELS)
VALVE (ARM LOCK) (LATER MODELS)
VALVE (ARM LOCK) (EARLIER MODELS)
UNDERCARRIAGEBLADE
TRACK UNDERCARRIAGE COMPONENTS (RUBBER TRACK)
Description
Track Lug Height
Checking Tension
Adjusting Tension
Idler Removal And Installation
Idler Parts Identification
Idler Disassembly
Idler Assembly
Track Tensioner Removal And Installation
Track Tensioner Parts Identification
Track Tensioner Disassembly And Assembly
Roller Removal And Installation
Sprocket Removal And Installation
TRACK UNDERCARRIAGE COMPONENTS (STEEL TRACK)
Description
Checking Tension
Adjusting Tension
Track Removal And Installation
Idler Disassembly
Idler Assembly
Guide Plate Removal And Installation
TRACK MAINTENANCE
Track Damage Identification
SWING CIRCLE GEAR
Swing Bearing Removal
Swing Bearing Installation
UPPERSTRUCTURE AND SWING SECTIONUPPERSTRUCTURE
Removal
Installation
ROPS CANOPY
CAB
Door Removal And Installation
Front Window Removal And Installation
Right Side Sliding Window Removal And Installation
Glass Removal
Glass Installation
SEAT
Seat Mount Removal And Installation
RIGHT CONSOLE
Console Cover Removal And Installation
LEFT CONSOLE
Lower Console Cover Removal And Installation
Upper Console Cover Removal And Installation
Compression Spring Removal And Installation
Lock Lever Removal And Installation
Console Removal And Installation
LEFT UPPERSTRUCTURE COVER
RIGHT UPPERSTRUCTURE COVER
COUNTERWEIGHT
Add On Counterweight Removal And Installation
TRAVEL LEVERS AND PEDALS
FLOOR MAT AND FLOORPLATE
FUEL TANK
Fuel Tank Fitting Removal And Installation
HORN
SWING FRAME
Boom Swing Frame Hose Routing
Bushing Removal
Bushing Installation
BOOM
ARM (STANDARD AND LONG)
Arm To Boom Bushing Removal And Installation
Arm To Bucket And Bucket Link Bushing Removal And Installation
ARM (EXTENDABLE)
Arm To Bucket Bushing Removal And Installation
Shimming Procedure
BUCKET
Bucket Teeth Removal And Installation
Bucket Side Cutting Edge Removal And Installation
CLAMP
TAILGATE
Disassembly and Assembly
QUICK COUPLER (KLAC™ SYSTEM)
Troubleshooting
Daily Inspection
Disassembly
Assembly
QUICK COUPLER (PIN GRABBER)
Troubleshooting
Daily Inspection
RIGHT SIDE COVER
Latch Removal And Installation
LEFT SIDE COVER
TOOL BOX
ELECTRICAL SYSTEM AND ANALYSISELECTRICAL SCHEMATICS
S/N B4S511001 through B4S511840
S/N B4S511841 & Above
Wiring Schematic Options
ELECTRICAL SYSTEM INFORMATION
Troubleshooting Chart
Description
Fuse And Relay Location / Identification
BATTERY
Servicing
Maintaining Battery Charge Level
Battery Service During Machine Storage
Battery Testing
Battery Charging
Using A Booster Battery (Jump Starting)
ALTERNATOR
Belt Adjustment
Belt Replacement
Charging System Inspection
Alternator Voltage Testing
Low Voltage Testing
High Voltage Testing
STARTER
Testing
LIGHTS
Boom Light Removal And Installation
Boom Light Bulb Replacement
MAGNETIC LOCKOUT SENSOR
FUEL LEVEL SENDER
Testing
DIAGNOSTIC SERVICE CODES
Viewing Service Codes
Number Codes List
CONTROL PANEL SETUP
Panel Setup (Deluxe Instrument Panel)
Password Setup (Keyless Start Panel)
Password Setup (Deluxe Instrument Panel)
Maintenance Clock
INSTRUMENT PANEL
CONTROLLER
Description
Auxiliary Controller Removal And Installation
Gateway Controller Removal And Installation
KEY SWITCH
WIPER MOTOR
MOTION ALARM SYSTEM
Description
Inspecting
Adjusting Switch Position
SERVICE PC (LAPTOP COMPUTER)
Connecting The Remote Start Tool
Connecting Remote Start Tool (Service Tool)
SHUT-OFF SWITCH
Description
TRAVEL MOTOR AUTO-SHIFT
Auto-Shift Drive System (If Equipped)
Troubleshooting
ENGINE SPEED CONTROL
AUTO IDLE PRESSURE SENSOR
Description
BOBCAT MACHINE IQ WIRELESS COMMUNICATIONS
Antenna Removal And Installation
ENGINE SERVICEENGINE INFORMATION
Description
Specifications
Crankshaft Re-grind Data
Torque For Kubota® Metric Bolts
Troubleshooting
Engine Removal And Installation
Compression - Testing
Calibration
Actuator Removal And Installation
MUFFLER
AIR CLEANER
LUBRICATION SYSTEM
Oil Pan Removal And Installation
Oil Pump Removal And Installation
Oil Pump Inspection
Engine Oil Pressure - Testing
Radiator Removal And Installation
Fan Removal And Installation
Water Pump Removal And Installation
Water Pump Disassembly And Assembly
Thermostat Removal And Installation
Thermostat - Testing
Thermostat Housing Removal And Installation
FUEL SYSTEM
Fuel Shutoff Solenoid - Testing
Fuel Shut-off Solenoid Removal And Installation
Fuel Injection Pump - Testing
Fuel Injection Pump Removal And Installation
Fuel Injection Pump - Timing
Fuel Camshaft Removal And Installation
Fuel Camshaft Governor
Fuel Injector Removal And Installation
Fuel Injector Nozzle Pressure - Testing
Nozzle Spray Condition
Valve Seat Tightness
CYLINDER HEAD
Glow Plugs - Testing
Glow Plugs Removal And Installation
Valve Clearance Adjustment
Valve Timing - Inspecting
Cylinder Head Removal And Installation
Cylinder Head Disassembly And Assembly
Cylinder Head - Servicing
Cylinder Head Top Clearance
Valve Guide - Inspecting
Valve Guide Removal And Installation
Reconditioning The Valve And Valve Seat
Valve Spring
Valve Tappets
Rocker Arm And Shaft - Inspecting
Push Rod Alignment - Inspecting
CRANKSHAFT AND PISTONS
Piston And Connecting Rod Removal And Installation
Piston And Connecting Rod - Servicing
Cylinder Bore - Inspecting
Connecting Rod Alignment
Crankshaft Gear Removal And Installation
Crankshaft And Bearings Removal And Installation
Crankshaft And Bearings - Servicing
CAMSHAFT AND TIMING GEARS
Timing Gearcase Cover Removal And Installation
Timing Gears Backlash - Inspecting
Idle Gear And Camshaft Removal And Installation
Camshaft - Servicing
Idle Gear And Shaft - Servicing
FLYWHEEL AND HOUSING
Hydraulic Pump Coupler Removal And Installation
Flywheel Removal And Installation
Flywheel Ring Gear
HEATING, VENTILATION AND AIR CONDITIONING (HVAC)AIR CONDITIONING SYSTEM FLOW
Description
Chart
Components
Safety Equipment
REGULAR MAINTENANCE
Cab Filters
Air Conditioning Compressor Belt Adjustment
Air Conditioning Compressor Belt Replacement
Condenser
Air Conditioning Lubrication
Evaporator / Heater Coil
Air Conditioning Service Chart
TROUBLESHOOTING
Blower Motor Does Not Operate
Blower Motor Operates Normally, But Air Flow Is Insufficient
Insufficient Cooling Although Air Flow And Compressor Operation Are Normal
The Compressor Operates Improperly Or Not At All
Gauge Pressure Related Troubleshooting
Temperature / Pressure Chart
Poor A/C Performance
HVAC Repair And Leaks
Engine Coolant Bypassing The Heater Valve
SYSTEM CHARGING AND RECLAMATION
Refrigerant Identification
Reclamation And Charging With Recovery / Charging Unit
COMPRESSOR
Oil
Oil Check
CONDENSER
RECEIVER / DRIER
Receiver / Drier Removal And Installation
Pressure Switch Removal And Installation
EVAPORATOR / HEATER UNIT
THERMOSTAT
Description
EXPANSION VALVE
EVAPORATOR COIL
HEATER COIL
BLOWER FAN
HEATER VALVE
HVAC DUCT
SPECIFICATIONSEXCAVATOR SPECIFICATIONS
Machine Dimensions
Machine Dimensions - Standard Arm
Machine Dimensions - Long Arm
Rated Lift Capacity For Standard Arm, Medium Counterweight, And Canopy
Rated Lift Capacity For Standard Arm, Medium Counterweight, And Cab
Rated Lift Capacity For Long Arm, Heavy Counterweight, And Canopy
Rated Lift Capacity For Long Arm, Heavy Counterweight, And Cab
Performance
Controls
Hydraulic Cycle Times
Hydraulic Cylinders
Drive System
Slew System
Undercarriage
Electrical
Capacities
Tracks
Ground Pressure
Temperature Range
TECHNICAL SERVICE GUIDE SPECIFICATIONS
Engine Torques
Excavator Torques
TORQUE SPECIFICATION FOR BOLTS
Torque For General SAE Bolts
Torque For General Metric Bolts
HYDRAULIC CONNECTION SPECIFICATIONS
O-ring Face Seal Connection
Straight Thread O-ring Fitting
Tubelines And Hoses
Flare Fitting
O-ring Flare Fitting
Port Seal Fitting
Push To Connect Fittings
HYDRAULIC FLUID SPECIFICATIONS
Specifications
CONVERSIONS
Decimal And Millimeter Equivalent Chart
U.S. To Metric Conversion Chart
SERVICE TOOLS REQUIRED
Remote Start Tools
Hydraulic Tools
Engine Tools
Electrical Tools
General Tools
HVAC Tools
ALPHABETICAL INDEXSERVICE SCHEDULE SYMBOLS
- Bobcat Heavy Equipment Full Hydraulic Schematics & Electrical Schematics PDF
- Bobcat Compact Mini Excavator 320D-322D i, 320G-322G Parts Manual
- BOBCAT Service Library 2014 Service, Operator, Maintenance, Bulletines, etc...
- Bobcat 753 Service Manual
- Bobcat S130 Parts Manual
- Bobcat X220 Excavator 05-89 Service Manual
- Bobcat 442 Mini Excavator Service Manual
- Bobcat 435 Mini Excavator Parts Manual
- Bobcat Compact Mini Excavator 773 G-Series Parts Manual
- Bobcat Excavators 323 6986958 Service Manual 2-08
- Bobcat S175, S185 Parts Manual
- Bobcat Skid Steer Loader 863 Service Manual
- Bobcat S150-S160 Skid-Steer Loader Service Manual 6902730
- Bobcat 430 Service Manual s/n 563011001 AND UP
- Bobcat s175, s185 operators manual
