Bobcat Excavator E10 Operation and Maintenance Manual 7334487enUS
Brand: Bobcat
Type of Machine: Excavator
Type of Manual: Operation and Maintenance Manual
Model: Bobcat E10 Excavator
Part Number: 7334487enUS
Publication Date: 2024
Number of Pages: 118 Pages
FOREWORD
SERVICE SCHEDULE SYMBOLS
Brand: Bobcat
FOREWORD
BOBCAT COMPANY IS ISO 9001 CERTIFIED
REGULAR MAINTENANCE ITEMS
SERIAL NUMBER LOCATIONS
Excavator Serial Number
Engine Serial Number
DELIVERY REPORT
EXCAVATOR IDENTIFICATION
FEATURES, ACCESSORIES AND ATTACHMENTS
Standard Items
Options And Accessories
Buckets Available
SAFETY AND TRAINING RESOURCESSAFETY INSTRUCTIONS
Before Operation
Safe Operation Is The Operator’s Responsibility
Safe Operation Needs A Qualified Operator
Avoid Silica Dust
FIRE PREVENTION
Maintenance
Operation
Electrical
Fueling
Starting
Spark Arrester Exhaust System
Welding And Grinding
Fire Extinguishers
PUBLICATIONS AND TRAINING RESOURCES
MACHINE SIGNS (DECALS)
Pictorial Only Safety Signs
OPERATING INSTRUCTIONSINTENDED USE
INSTRUMENTS AND CONSOLES
Instrumentation
Operator Controls
Raising And Lowering The Console(s)
Adjusting The Console Position
Engine Speed Control Lever
Two-Speed Travel
STD / ISO Selector Valve
Upperstructure Slew Lock
TIP-OVER PROTECTIVE STRUCTURE (TOPS)
TOPS Position
Raising And Lowering The TOPS
MOTION ALARM SYSTEM
Operation
TRAVEL CONTROLS
Description
Forward And Reverse Travels
Turning
HYDRAULIC CONTROLS
Description
STANDARD Control Pattern
ISO Control Pattern
Auxiliary Hydraulic Pedal
Relieve Hydraulic Pressure (Excavator And Attachment)
Quick Couplers
ENGINE SPEED CONTROL
BOOM SWING PEDAL
Operation
BLADE CONTROL LEVER
Blade / Track Expansion Switch
Raising And Lowering The Blade
TRACK FRAME EXPANSION
Expanding And Retracting The Tracks
DAILY INSPECTION
Daily Inspection And Maintenance
PRE-STARTING PROCEDURE
Operation & Maintenance Manual And Operator’s Handbook Locations
Entering The Excavator
Seat Adjustment
Seat Belt
Control Console
STARTING THE ENGINE
Key Switch
Keyless
Warming The Hydraulic System
Cold Temperature Starting
STOPPING THE ENGINE AND LEAVING THE EXCAVATOR
Procedure
Installing And Removing The Attachment
OPERATING PROCEDURE
Inspect The Work Area
Basic Operating Instructions
Lowering The Work Equipment (Engine STOPPED)
Object Handling
Lift Capacity
Driving The Excavator
Operating On Slopes
Operating In Water
Avoiding Track Damage
TOWING THE EXCAVATOR
Procedure
LIFTING THE EXCAVATOR
Procedure
TRANSPORTING THE EXCAVATOR ON A TRAILER
Loading And Unloading
Fastening To Transport Vehicle
PREVENTIVE MAINTENANCEMAINTENANCE SAFETY
SERVICE SCHEDULE
Maintenance Intervals
CONTROL CONSOLE LOCKOUTS
SEAT BELT
MOTION ALARM SYSTEM
Description
Inspecting
Adjusting Switch Position
TAILGATE
Opening And Closing
AIR CLEANER
Daily Check
Replacing The Filter Elements
FUEL SYSTEM
Fuel Specifications
Biodiesel Blend Fuel
Filling The Fuel Tank
Fuel Filters
Draining The Fuel Tank
Removing Air From The Fuel System
ENGINE LUBRICATION SYSTEM
Checking And Adding Engine Oil
Engine Oil Chart
Removing And Replacing Oil And Filter
ENGINE COOLING SYSTEM
Cleaning
Coolant Types
Coolant Concentration
Checking Level
Removing And Replacing Coolant
ELECTRICAL SYSTEM
Description
Fuses
Fuel Timer, Relays And Diode Location / Identification
Battery Maintenance
Maintaining Battery Charge Level
Battery Service During Machine Storage
Battery Testing
Battery Charging
Using A Booster Battery (Jump Starting)
Removing And Installing The Battery
HYDRAULIC SYSTEM
Checking And Adding Hydraulic Oil
Hydraulic / Hydrostatic Fluid Chart
Removing And Replacing The Hydraulic Filter
Removing And Replacing The Hydraulic Fluid
SPARK ARRESTER MUFFLER
Cleaning Procedure
TRACK TENSION
Adjusting
TRAVEL MOTOR
Checking And Adding Oil
ALTERNATOR BELT
Belt Adjustment
BLADE EXTENSION
Description
Extending And Retracting
TRACK ROLLER AND IDLER LUBRICATION
Procedure
LUBRICATING THE EXCAVATOR
Lubrication Locations
PIVOT PINS
EXCAVATOR STORAGE AND RETURN TO SERVICE
Storage
Return To Service
SYSTEM SETUP AND ANALYSISPASSWORD SETUP (KEYLESS START PANEL)
Password Description
Changing The Owner Password
SPECIFICATIONSE10 EXCAVATOR SPECIFICATIONS
Excavator Machine Dimensions
Rated Lift Capacity
Rated Lift Capacity (Demolition Kit)
Performance
Controls
Hydraulic Cylinders
Hydraulic Cycle Times
Drive System
Slew System
Undercarriage
Crawler Track Design
Electrical
Capacities
Tracks
Type
Ground Pressure
WARRANTYWARRANTY
ALPHABETICAL INDEXSERVICE SCHEDULE SYMBOLS
- Bobcat Heavy Equipment Full Hydraulic Schematics & Electrical Schematics PDF
- Bobcat Compact Mini Excavator 320D-322D i, 320G-322G Parts Manual
- BOBCAT Service Library 2014 Service, Operator, Maintenance, Bulletines, etc...
- Bobcat 753 Service Manual
- Bobcat S130 Parts Manual
- Bobcat X220 Excavator 05-89 Service Manual
- Bobcat 442 Mini Excavator Service Manual
- Bobcat 435 Mini Excavator Parts Manual
- Bobcat Compact Mini Excavator 773 G-Series Parts Manual
- Bobcat Excavators 323 6986958 Service Manual 2-08
- Bobcat S175, S185 Parts Manual
- Bobcat Skid Steer Loader 863 Service Manual
- Bobcat S150-S160 Skid-Steer Loader Service Manual 6902730
- Bobcat 430 Service Manual s/n 563011001 AND UP
- Bobcat s175, s185 operators manual
