Bobcat Compact Track Loader T870 Service Manual 7248302enUS
Brand: Bobcat
Type of Machine: Compact Track Loader
Model: Bobcat T870 Compact Track Loader
S/N ASWT11001 & Above
S/N B3BZ11001 & Above
Part Number: 7248302enUS
Publication Date: 2018
Number of Pages: 1052 Pages
FOREWORD
Brand: Bobcat
FOREWORD
FOREWORD
SAFETY INSTRUCTIONS
FIRE PREVENTION
SERIAL NUMBER LOCATIONS
DELIVERY REPORT
LOADER IDENTIFICATION
SAFETY AND MAINTENANCELIFTING AND BLOCKING THE LOADER
LIFT ARM SUPPORT DEVICE
OPERATOR CAB
TRANSPORTING THE LOADER ON A TRAILER
TOWING THE LOADER
REMOTE START TOOL KIT - MEL1563
REMOTE START TOOL (SERVICE TOOL) KIT - 7217666
SERVICE SCHEDULE
ENGINE AIR CLEANER
ENGINE COOLING SYSTEM
FUEL SYSTEM
ENGINE LUBRICATION SYSTEM
HYDRAULIC / HYDROSTATIC SYSTEM
BOB-TACH (HAND LEVER)
BOB-TACH (POWER)
LUBRICATING THE LOADER
PIVOT PINS
LOADER STORAGE AND RETURN TO SERVICE
STOPPING THE ENGINE AND LEAVING THE LOADER
EMERGENCY EXIT
SEAT BELT
HYDRAULIC SYSTEMHYDRAULIC / HYDROSTATIC SCHEMATICS
HYDRAULIC SYSTEM INFORMATION
CYLINDER (LIFT)
CYLINDER (TILT)
CYLINDER (BOB-TACH)
MAIN RELIEF VALVES
HYDRAULIC CONTROL VALVE (SJC)
HYDRAULIC CONTROL VALVE (SCPA)
LIFT ARM BYPASS CONTROL VALVE
HYDRAULIC PUMP
HYDRAULIC PUMP (HIGH FLOW)
HYDRAULIC / HYDROSTATIC FILTERS
HYDRAULIC FLUID RESERVOIR
OIL COOLER
BUCKET POSITION VALVE
REAR AUXILIARY DIVERTER VALVE
BOB-TACH (POWER) BLOCK
FRONT AUXILIARY HYDRAULIC COUPLER BLOCK
AUTOMATIC RIDE CONTROL
HYDROSTATIC SYSTEMHYDROSTATIC SYSTEM INFORMATION
HYDROSTATIC DRIVE MOTOR
HYDROSTATIC DRIVE MOTOR (TWO-SPEED)
CHARGE PRESSURE
HYDROSTATIC PUMP (SJC AND SCPA)
DRIVE BELT
TWO-SPEED / BRAKE VALVE
DRAIN MANIFOLD
DRIVE SYSTEMBRAKE
TRACK UNDERCARRIAGE COMPONENTS (ROLLER SUSPENSION)
TRACK MAINTENANCE
MAINFRAMESEAT BAR
OPERATOR CAB
OPERATOR SEAT (SUSPENSION)
BOB-TACH (POWER)
LIFT ARMS
REAR GRILLE
REAR DOOR (TAILGATE)
FUEL TANK
FUEL TANK (AUXILIARY)
CONTROL PEDALS AND LINKAGES (SCPA)
CONTROL PANEL (SJC)
CONTROL PANEL (SCPA)
CONTROL HANDLE / LEVER (SJC)
CONTROL HANDLE / LEVER (SCPA)
ACCESS PANEL (INSIDE) (SJC)
ACCESS PANEL (INSIDE) (SCPA)
WINDOW (REAR)
WINDOW (TOP)
WINDOW (SIDE)
CAB DOOR
ARMREST
LEFT SIDE LOWER PANEL
RIGHT SIDE LOWER PANEL
HEADLINER
FAN DUCT PANELS
ELECTRICAL SYSTEM AND ANALYSISELECTRICAL SCHEMATICS
ELECTRICAL SYSTEM INFORMATION
BATTERY
ALTERNATOR
STARTER
INSTRUMENT PANELS
LIGHTS
BOBCAT CONTOLERS (GATEWAY AND AUXILLIARY)
BOBCAT CONTROLLER (ACS)
BOBCAT CONTROLLER (SJC) (DRIVE)
BOBCAT CONTROLLER (SCPA) (DRIVE)
DOSING CONTROL UNIT (DCU)
ENGINE CONTROL UNIT (ECU)
DIAGNOSTIC SERVICE CODES
BOBCAT INTERLOCK CONTROL SYSTEM (BICS™)
SEAT BAR SENSOR
TRACTION LOCK
ELECTRICAL / HYDRAULIC CONTROLS (SJC)
ELECTRICAL / HYDRAULIC CONTROLS (SCPA)
SERVICE PC (LAPTOP COMPUTER)
CALIBRATION
STEERING DRIFT COMPENSATION (OPERATOR MODE)
STEERING DRIFT COMPENSATION (SERVICE MODE)
CONTROL PANEL SETUP
PASSWORD SETUP (DELUXE INSTRUMENTATION PANEL)
PASSWORD SETUP (KEYLESS START PANEL)
MAINTENANCE CLOCK
BACK-UP ALARM SYSTEM
FRONT HORN
ENGINE COMPARTMENT TEMPERATURE SENSOR
ENGINE SERVICEENGINE INFORMATION
ENGINE SPEED CONTROL (HAND)
ENGINE SPEED CONTROL (FOOT)
SELECTIVE CATALYTIC REDUCTION (SCR) SYSTEM
DIESEL OXIDATION CATALYST (DOC)
AIR CLEANER
LUBRICATION SYSTEM
FUEL SYSTEM
CYLINDER HEAD
CRANKSHAFT AND PISTONS
CAMSHAFT
GEARCASE
TURBOCHARGER
FLYWHEEL AND HOUSING
EXHAUST GAS RECIRCULATION (EGR) SYSTEM
DIESEL EXHAUST FLUID (DEF) / ADBLUE® SYSTEM
HEATING, VENTILATION AND AIR CONDITIONING (HVAC)AIR CONDITIONING SYSTEM FLOW
REGULAR MAINTENANCE
TROUBLESHOOTING
SYSTEM CHARGING AND RECLAMATION
COMPRESSOR
CONDENSER
RECEIVER / DRIER
EVAPORATOR / HEATER UNIT
THERMOSTAT
EXPANSION VALVE
EVAPORATOR COIL
HEATER COIL
BLOWER FAN
HEATER VALVE
EVAPORATOR / HEATER COVER
SPECIFICATIONS(T870) LOADER SPECIFICATIONS
TECHNICAL SERVICE GUIDE SPECIFICATIONS
TORQUE SPECIFICATIONS FOR BOLTS
HYDRAULIC CONNECTION SPECIFICATIONS
HYDRAULIC / HYDROSTATIC FLUID SPECIFICATIONS
CONVERSIONS
SERVICE TOOLS REQUIRED
ALPHABETICAL INDEX
- Bobcat Heavy Equipment Full Hydraulic Schematics & Electrical Schematics PDF
- Bobcat Compact Mini Excavator 320D-322D i, 320G-322G Parts Manual
- BOBCAT Service Library 2014 Service, Operator, Maintenance, Bulletines, etc...
- Bobcat 753 Service Manual
- Bobcat S130 Parts Manual
- Bobcat X220 Excavator 05-89 Service Manual
- Bobcat 442 Mini Excavator Service Manual
- Bobcat 435 Mini Excavator Parts Manual
- Bobcat Compact Mini Excavator 773 G-Series Parts Manual
- Bobcat Excavators 323 6986958 Service Manual 2-08
- Bobcat S175, S185 Parts Manual
- Bobcat Skid Steer Loader 863 Service Manual
- Bobcat S150-S160 Skid-Steer Loader Service Manual 6902730
- Bobcat 430 Service Manual s/n 563011001 AND UP
- Bobcat s175, s185 operators manual
