Hyundai
86
176,834
Bobcat Compact Track Loader T7x Service Manual 7476691enUS 2024
Brand: Bobcat
Type of Machine: Compact Track Loader
Type of Manual: Service Manual, Electric Diagram
Model: Bobcat T7x Compact Track Loader
Serial Number: B61D11001 & Above
Part Number: 7476691enUS
Publication Date: 2024
Number of Pages: 252 Pages
FOREWORD
FOREWORD​
General Inspection​
SAFETY INSTRUCTIONS​
Before Operation​
Call Before You Dig​
Safe Operation Is The Operator’s Responsibility​
Safe Operation Needs A Qualified Operator​
A Qualified Operator Must Do The Following​
Silica Dust Exposure​
FIRE PREVENTION​
Maintenance​
Operation​
Electrical​
Charging Safety​
Welding And Grinding​
Fire Extinguishers​
SERIAL NUMBER LOCATIONS​
Machine Serial Number Location​
High Voltage Battery Pack Serial Number Location​
DELIVERY REPORT​
MACHINE IDENTIFICATION​
Front View​
Rear View​
SAFETY AND MAINTENANCE
LIFTING AND BLOCKING THE MACHINE​
Lifting And Blocking The Machine Procedure​
LIFT ARM SUPPORT​
Lift Arm Support Description​
Installing Lift Arm Support​
Removing Lift Arm Support​
OPERATOR CAB​
Inspecting Operator Cab​
Cab Door Sensor Description​
Raising Operator Cab​
Lowering Operator Cab​
Clear Side Enclosed Cab Option​
Inspecting And Maintaining Clear Side Enclosed Cab Option​
TRANSPORTING THE MACHINE​
Loading And Unloading Machine​
Fastening Machine To Transport Vehicle​
TOWING THE MACHINE​
Towing Procedure​
SERVICE SCHEDULE​
Maintenance Intervals​
Service Schedule​
BOB-TACH SYSTEM (HAND LEVER)​
Inspecting And Maintaining Hand Lever Bob-Tach System​
MACHINE LUBRICATION​
Lubricating Grease Fittings​
Actuator Lubrication​
COOLANT REPLACEMENT PROCEDURE​
Coolant System Description​
Removing The EVCM And Drive Motor Coolant​
Filling The EVCM And Drive Motor Coolant​
Purging The Air From The System​
Removing The Battery Coolant​
Filling The Battery With Coolant​
PIVOT PINS​
Checking Pivot Pin Torque​
MACHINE STORAGE AND RETURN TO SERVICE​
Machine Extended Storage Procedure​
Machine Return To Service Procedure​
BATTERY SYSTEM​
De-energizing The High Voltage Battery​
Prove De-energized Process​
CLEANING THE MACHINE​
Cleaning The Machine Description​
Washing The Lift And Tilt Actuators​
Washing Drive Motors​
Internal Cleaning Of The Machine​
Cleaning Under The Cab​
Cleaning Of Charge Port And Plug​
EMERGENCY EXITS​
Removing Rear Window With Latches​
Removing Rear Window With Rubber Cord​
Removing Rear Window With Latches From Outside Machine​
Removing Rear Window With Rubber Cord From Outside Machine​
Making An Emergency Exit Through Front Door​
Front Door Reassembly​
SEAT BELT​
Inspecting And Maintaining The Seat Belt​
DRIVE SYSTEM
BRAKE​
Brake Description​
TRACK UNDERCARRIAGE COMPONENTS (SOLID-MOUNTED)​
Track Undercarriage Components (Solid-Mounted) Description​
Checking Track Tension​
Adjusting Tension​
Removing And Installing Track​
Idler (Front) Removal And Installation​
Removing And Installing Track Tensioner​
Disassembling And Assembling Track Tensioner​
Removing And Installing Idler (Rear)​
Removing And Installing Roller​
Removing And Installing Sprocket​
Removing And Installing Track Frame​
TRACTION DRIVE MOTOR​
Traction Drive Motor Description​
Removing And Replacing Fluid​
Removing And Installing Traction Drive Motor​
TRACK MAINTENANCE​
Track Damage Identification​
MAINFRAME
SEAT BAR​
Seat Bar Description​
Removing And Installing The Seat Bar​
Disassembling And Assembling The Seat Bar​
Disassembling And Assembling Seat Bar Compression Spring​
OPERATOR CAB​
Removing And Installing Cab Gas Spring​
Disassembling And Assembling Cab Gas Spring Bracket​
Removing And Installing Operator Cab​
OPERATOR SEAT (SUSPENSION)​
Removing And Installing The Operator Seat (Suspension)​
Removing And Installing Slide Rail​
Removing And Installing Seat Belt (Suspension Seat)​
Removing Lower Cushion​
Installing Lower Cushion​
Removing And Installing Back Cushion​
Removing And Installing 3-Point Seat Belt​
LIFT ARMS​
Removing And Installing Lift Arms Driver Link​
Driver Link Pivot Pin Removal And Installation​
Removing And Installing Lift Arms Follower Link​
Removing And Installing Lift Arm​
REAR HOOD​
Raising The Rear Hood​
Removing And Installing The Rear Hood​
Lowering The Rear Hood​
Removing And Installing The Rear Hood Shield​
REAR DOOR (TAILGATE)​
Removing And Installing Rear Door (Tailgate)​
Removing And Installing Rear Door (Tailgate) Striker​
Disassembling And Assembling Rear Door (Tailgate) Striker​
Adjusting Rear Door (Tailgate) Striker​
Removing And Installing Rear Door (Tailgate) Latch​
FOOTREST​
Removing And Installing Footrest (SJC) (Right Side)​
Removing And Installing Footrest (SJC) (Left Side)​
CONTROL HANDLE (SJC)​
Control Handle (SJC) Description​
Testing The Joystick​
Removing And Installing The Joystick​
ACCESS PANELS (LOWER)​
Removing And Installing Access Panel (Lower) (Left Side)​
Removing And Installing Access Panel (Lower) (Right Side)​
ACCESS PANELS (UPPER)​
Removing And Installing Access Panels (Upper) (Center Panel)​
Removing And Installing Access Panel (Upper) (Left Side)​
Removing And Installing Access Panel (Upper) (Right Side)​
WINDOW (REAR)​
Disassembling And Assembling Rear Window Latches​
Removing Rear Window Rubber Cord​
Installing Rear Window Rubber Cord​
WINDOW (TOP)​
Removing And Installing Window (Top)​
WINDOW (SIDE)​
Removing And Installing Window (Side)​
CAB DOOR​
Cab Door Description​
Removing And Installing The Cab Door​
Disassembling And Assembling Cab Door​
Aligning The Cab Door​
Adjusting The Cab Door​
Checking The Cab Door Operation​
ARMREST​
Armrest Description​
Removing And Installing The Armrest​
Disassembling And Assembling The Armrest​
HEADLINER​
Removing And Installing The Headliner​
ELECTRICAL SYSTEM
ELECTRICAL SCHEMATICS​
Standard Machine​
ELECTRICAL SYSTEM​
Glossary Of Electrical Symbols​
Electrical System Description​
Fuse And Relay Identification​
HIGH VOLTAGE BATTERY PACK (HVBP)​
Removing And Installing The High Voltage Battery Pack ( HVBP)​
ELECTRIC VEHICLE CONTROL MODULE (EVCM)​
Electric Vehicle Control Module (EVCM)​
COOLING SYSTEM​
Removing And Installing EVCM And Drive Motor Coolant Pump​
Removing And Installing Battery Coolant Pump​
Removing And Installing Coolant Fan / Radiator Assembly​
Removing And Installing Coolant Fan​
Removing And Installing EVCM And Drive Motor Coolant Reservoir​
Removing And Installing Coolant Reservoir​
LIFT ACTUATOR​
Removing And Installing Lift Actuator​
TILT ACTUATOR​
Removing And Installing Tilt Actuator​
SPECIFICATIONS
MACHINE DIMENSIONS​
MACHINE SPECIFICATIONS​
Performance Specifications​
Drive System Specifications​
Control Specifications​
Electric Motor Specifications​
Electrical System Specifications​
Fluid Capacities​
Tracks​
Ground Pressure​
Torque Specification For Bolts​
