Bobcat Compact Track Loader T66 Service Manual 7353050enUS
Brand: Bobcat
Type of Machine: Compact Track Loader
Model: Bobcat T66 Compact Track Loader
S/N B4SB11001 & Above
Part Number: 7353050enUS
Publication Date: 2021
Number of Pages: 948 Pages
FOREWORD
Brand: Bobcat
FOREWORD
FOREWORD
SAFETY INSTRUCTIONS
FIRE PREVENTION
SERIAL NUMBER LOCATIONS
DELIVERY REPORT
LOADER IDENTIFICATION
SAFETY & MAINTENANCELIFTING AND BLOCKING THE LOADER
LIFT ARM SUPPORT
OPERATOR CAB
TRANSPORTING THE LOADER ON A TRAILER
TOWING THE LOADER
REMOTE START TOOL (SERVICE TOOL) KIT - 7217666
SERVICE SCHEDULE
ENGINE AIR CLEANER
ENGINE COOLING SYSTEM
FUEL SYSTEM
ENGINE LUBRICATION SYSTEM
HYDRAULIC SYSTEM
BOB-TACH (HAND LEVER)
BOB-TACH (POWER)
LUBRICATING THE LOADER
PIVOT PINS
LOADER STORAGE AND RETURN TO SERVICE
STOPPING THE ENGINE AND LEAVING THE MACHINE
EMERGENCY EXITS
SEAT BELT
HYDRAULIC SYSTEMHYDRAULIC / HYDROSTATIC SCHEMATICS
HYDRAULIC SYSTEM INFORMATION
CYLINDER (LIFT)
CYLINDER (TILT)
CYLINDER (BOB-TACH)
CYLINDER (BOB-TACH) (LATER MODELS)
MAIN RELIEF VALVE
HYDRAULIC CONTROL VALVE
LIFT ARM BYPASS CONTROL VALVE
HYDRAULIC PUMP
HYDRAULIC PUMP (HIGH FLOW)
HYDRAULIC FILTERS
HYDRAULIC FLUID RESERVOIR
OIL COOLER
BUCKET POSITION SENSORS
REAR AUXILIARY DIVERTER VALVE
Bob-Tach (POWER) BLOCK
FRONT AUXILIARY HYDRAULIC COUPLER BLOCK
AUTOMATIC RIDE CONTROL
HYDROSTATIC SYSTEMHYDROSTATIC SYSTEM INFORMATION
HYDROSTATIC DRIVE MOTOR
CHARGE PRESSURE
HYDROSTATIC PUMP (MANUAL)
HYDROSTATIC PUMP (SJC)
TWO-SPEED / BRAKE VALVE
DRAIN MANIFOLD
DRIVE SYSTEMBRAKE
BRAKE (TWO-SPEED)
TRACK UNDERCARRIAGE COMPONENTS (SOLID-MOUNTED)
TRACK UNDERCARRIAGE COMPONENTS (TORSION SUSPENSION)
TRACK MAINTENANCE
MAINFRAMESEAT BAR
OPERATOR CAB
OPERATOR SEAT
OPERATOR SEAT (SUSPENSION)
BOB-TACH (POWER)
LIFT ARMS
REAR GRILLE
REAR DOOR (TAILGATE)
FUEL TANK
CONTROL PEDALS (MANUAL)
FOOTREST (SJC)
CONTROL LEVER ASSEMBLY
CONTROL LEVER CENTERING ASSEMBLY
CONTROL HANDLE / LEVER (MANUAL)
CONTROL HANDLE (SJC)
ACCESS PANELS (LOWER)
ACCESS PANELS (UPPER)
WINDOW (REAR)
WINDOW (TOP)
WINDOW (SIDE)
CAB DOOR
ARMREST
HEADLINER
ELECTRICAL SYSTEMELECTRICAL SCHEMATICS
ELECTRICAL SYSTEM
BATTERY
ALTERNATOR
STARTER
INSTRUMENT PANEL IDENTIFICATION
LIGHTS
BOBCAT HUB CONTROLLER
BOBCAT MID CONTROLLER
BOBCAT CONTROLLER (SJC) (DRIVE)
ENGINE CONTROL UNIT (ECU)
DIAGNOSTIC SERVICE CODES
BOBCAT INTERLOCK CONTROL SYSTEM (BICS™)
SEAT BAR SENSOR
TRACTION LOCK
CONTROL IDENTIFICATION
SERVICE PC (LAPTOP COMPUTER)
CALIBRATION
STEERING DRIFT COMPENSATION
NAVIGATION (STANDARD DISPLAY)
VITALS (STANDARD DISPLAY)
SERVICE (STANDARD DISPLAY)
SETTINGS (STANDARD DISPLAY)
GAUGES (TOUCH DISPLAY)
CAMERA (TOUCH DISPLAY)
PHONE (TOUCH DISPLAY)
AUDIO (TOUCH DISPLAY)
SERVICE (TOUCH DISPLAY)
ATTACHMENTS (TOUCH DISPLAY)
SETTINGS (TOUCH DISPLAY)
PASSWORD SETUP
MAINTENANCE CLOCK
BACK-UP ALARM SYSTEM
FRONT HORN
ENGINE SPEED CONTROL (FOOT)
ENGINE SPEED CONTROL (HAND)
CAMSHAFT AND CRANKSHAFT POSITION SENSOR
MACHINE IQ
ENGINE SERVICEENGINE INFORMATION
DIESEL OXIDATION CATALYST (DOC)
AIR CLEANER
LUBRICATION SYSTEM
FUEL SYSTEM
CYLINDER HEAD
CRANKSHAFT AND PISTONS
CAMSHAFT
GEARCASE
TURBOCHARGER
FLYWHEEL AND HOUSING
EXHAUST GAS RECIRCULATION (EGR) SYSTEM
EXHAUST MANIFOLD
HEATING, VENTILATION AND AIR CONDITIONING (HVAC)AIR CONDITIONING SYSTEM FLOW
REGULAR MAINTENANCE
TROUBLESHOOTING
SYSTEM CHARGING AND RECLAMATION
COMPRESSOR
CONDENSER
RECEIVER / DRIER
HVAC ASSEMBLY
THERMOSTAT
EXPANSION VALVE
EVAPORATOR COIL
HEATER COIL
BLOWER FAN
HEATER VALVE
EVAPORATOR / HEATER COVER
AUTO HVAC MODULE
SPECIFICATIONSLOADER SPECIFICATIONS
TECHINCAL SERVICE GUIDE SPECIFICATIONS
TORQUE SPECIFICATIONS FOR BOLTS
HYDRAULIC CONNECTION SPECIFICATIONS
HYDRAULIC FLUID SPECIFICATIONS
CONVERSIONS
SERVICE TOOLS REQUIRED
ALPHABETICAL INDEX
- Bobcat Heavy Equipment Full Hydraulic Schematics & Electrical Schematics PDF
- Bobcat Compact Mini Excavator 320D-322D i, 320G-322G Parts Manual
- BOBCAT Service Library 2014 Service, Operator, Maintenance, Bulletines, etc...
- Bobcat 753 Service Manual
- Bobcat S130 Parts Manual
- Bobcat X220 Excavator 05-89 Service Manual
- Bobcat 442 Mini Excavator Service Manual
- Bobcat 435 Mini Excavator Parts Manual
- Bobcat Compact Mini Excavator 773 G-Series Parts Manual
- Bobcat Excavators 323 6986958 Service Manual 2-08
- Bobcat S175, S185 Parts Manual
- Bobcat Skid Steer Loader 863 Service Manual
- Bobcat S150-S160 Skid-Steer Loader Service Manual 6902730
- Bobcat 430 Service Manual s/n 563011001 AND UP
- Bobcat s175, s185 operators manual
