Hyundai
86
176,684
Bobcat Compact Track Loader S570 Service Manual 6989675enUS
Brand: Bobcat
Type of Machine: Compact Track Loader
Model: Bobcat S570 Compact Track Loader
Part Number: 6989675enUS
Publication Date: 2019
Number of Pages: 1240 Pages
FOREWORD
FOREWORD​
SAFETY INSTRUCTIONS​
FIRE PREVENTION​
SERIAL NUMBER LOCATIONS​
DELIVERY REPORT​
LOADER IDENTIFICATION​
SAFETY AND MAINTENANCE
LIFTING AND BLOCKING THE LOADER​
LIFT ARM SUPPORT DEVICE​
OPERATOR CAB​
TRANSPORTING THE LOADER ON A TRAILER​
TOWING THE LOADER​
REMOTE START TOOL KIT - MEL1563​
REMOTE START TOOL (SERVICE TOOL) KIT - 7217666​
SERVICE SCHEDULE​
ENGINE AIR CLEANER​
ENGINE COOLING SYSTEM (EARLIER MODELS)​
ENGINE COOLING SYSTEM (LATER MODELS)​
FUEL SYSTEM​
ENGINE LUBRICATION SYSTEM​
HYDRAULIC / HYDROSTATIC SYSTEM (EARLIER MODELS)​
HYDRAULIC / HYDROSTATIC SYSTEM (LATER MODELS)​
FINAL DRIVE TRANSMISSION (CHAINCASE)​
BOB-TACH (HAND LEVER)​
BOB-TACH (POWER)​
LUBRICATING THE LOADER​
TIRE MAINTENANCE​
SPARK ARRESTER MUFFLER​
PIVOT PINS​
LOADER STORAGE AND RETURN TO SERVICE​
STOPPING THE ENGINE AND LEAVING THE LOADER​
EMERGENCY EXIT​
SEAT BELT​
HYDRAULIC SYSTEM
HYDRAULIC / HYDROSTATIC SCHEMATICS​
HYDRAULIC SYSTEM INFORMATION​
CYLINDER (LIFT)​
CYLINDER (TILT)​
CYLINDER (LIFT) (AZNB11488 & ABOVE)​
CYLINDER (TILT) (AZNB11488 & ABOVE)​
CYLINDER (BOB-TACH)​
MAIN RELIEF VALVE​
HYDRAULIC CONTROL VALVE (STANDARD)​
HYDRAULIC CONTROL VALVE (ACS) OR (SJC)​
LIFT ARM BYPASS CONTROL VALVE​
HYDRAULIC PUMP​
HYDRAULIC PUMP (HIGH FLOW)​
HYDRAULIC / HYDROSTATIC FILTERS​
HYDRAULIC FLUID RESERVOIR​
OIL COOLER (EARLIER MODELS)​
OIL COOLER (LATER MODLES)​
BUCKET POSITION VALVE​
REAR AUXILIARY DIVERTER VALVE​
BOB-TACH (POWER) BLOCK (S/N A7U711001 - A7U714726)​
BOB-TACH (POWER) BLOCK (S/N A7U714727 & ABOVE)​
FRONT AUXILIARY HYDRAULIC COUPLER BLOCK​
AUTOMATIC RIDE CONTROL​
HYDROSTATIC SYSTEM
HYDROSTATIC SYSTEM INFORMATION​
HYDROSTATIC DRIVE MOTOR​
HYDROSTATIC DRIVE MOTOR (TWO-SPEED)​
HYDROSTATIC MOTOR CARRIER​
HYDROSTATIC MOTOR CARRIER (TWO-SPEED)​
CHARGE PRESSURE​
HYDROSTATIC PUMP​
HYDROSTATIC PUMP (SJC)​
DRIVE BELT​
TWO-SPEED​
DRAIN MANIFOLD​
DRIVE SYSTEM
BRAKE​
DRIVE COMPONENTS​
CHAINCASE​
MAINFRAME
SEAT BAR​
OPERATOR CAB​
OPERATOR SEAT​
OPERATOR SEAT (SUSPENSION)​
BOB-TACH (POWER)​
LIFT ARMS​
REAR GRILLE​
REAR DOOR (TAILGATE)​
FUEL TANK​
CONTROL PEDALS AND LINKAGES​
CONTROL PEDALS AND LINKAGES (ACS)​
CONTROL PANEL​
CONTROL PANEL (SJC)​
CONTROL HANDLE / LEVER​
CONTROL HANDLE / LEVER (ACS)​
ACCESS PANEL (INSIDE)​
CONTROL HANDLE / LEVER (SJC)​
ACCESS PANEL (INSIDE) (SJC)​
WINDOW (REAR)​
WINDOW (TOP)​
WINDOW (SIDE)​
CAB DOOR​
ARMREST​
LEFT SIDE LOWER PANEL​
RIGHT SIDE LOWER PANEL​
HEADLINER​
ELECTRICAL SYSTEM
ELECTRICAL SCHEMATICS​
ELECTRICAL SYSTEM INFORMATION​
BATTERY​
ALTERNATOR​
STARTER​
INSTRUMENT PANELS​
LIGHTS​
BOBCAT CONTROLLERS (GATEWAY AND AUXILIARY)​
BOBCAT CONTROLLER (ACS)​
BOBCAT CONTROLLER (SJC) (DRIVE)​
DIAGNOSTIC SERVICE CODES​
BOBCAT INTERLOCK CONTROL SYSTEM (BICS™)​
SEAT BAR SENSOR​
TRACTION LOCK​
CONTROL SYSTEM (ACS)​
ELECTRICAL / HYDRAULIC CONTROLS​
ELECTRICAL / HYDRAULIC CONTROLS (ACS)​
ELECTRICAL / HYDRAULIC CONTROLS (SJC)​
SERVICE PC (LAPTOP COMPUTER)​
CALIBRATION​
STEERING DRIFT COMPENSATION (OPERATOR MODE)​
STEERING DRIFT COMPENSATION (SERVICE MODE)​
FLYWHEEL RPM SENSOR​
CONTROL PANEL SETUP​
PASSWORD SETUP (DELUXE INSTRUMENTATION PANEL)​
PASSWORD SETUP (KEYLESS START PANEL)​
MAINTENANCE CLOCK​
BACK-UP ALARM SYSTEM​
FRONT HORN​
TELEMATICS​
ENGINE SERVICE
ENGINE INFORMATION​
ENGINE SPEED CONTROL (HAND)​
ENGINE SPEED CONTROL (FOOT)​
MUFFLER​
AIR CLEANER​
LUBRICATION SYSTEM​
FUEL SYSTEM​
CYLINDER HEAD​
CRANKSHAFT AND PISTONS​
CAMSHAFT AND TIMING GEARS​
TURBOCHARGER​
FLYWHEEL AND HOUSING​
EXHAUST GAS RECIRCULATION (EGR) SYSTEM​
HEATING, VENTILATION, AND AIR CONDITIONING (HVAC)
AIR CONDITIONING SYSTEM FLOW​
REGULAR MAINTENANCE​
TROUBLESHOOTING​
SYSTEM CHARGING AND RECLAMATION​
COMPRESSOR​
CONDENSER (EARLIER MODELS)​
CONDENSER (LATER MODELS)​
RECEIVER / DRIER (EARLIER MODELS)​
RECEIVER / DRIER (LATER MODELS)​
EVAPORATOR / HEATER UNIT​
THERMOSTAT​
EXPANSION VALVE​
EVAPORATOR COIL​
HEATER COIL​
BLOWER FAN​
HEATER VALVE​
EVAPORATOR / HEATER COVER​
SPECIFICATIONS
(S570) LOADER SPECIFICATIONS​
TECHNICAL SERVICE GUIDE SPECIFICATIONS​
TORQUE SPECIFICATIONS FOR BOLTS​
HYDRAULIC CONNECTION SPECIFICATIONS​
HYDRAULIC / HYDROSTATIC FLUID SPECIFICATIONS​
CONVERSIONS​
SERVICE TOOLS REQUIRED​
ALPHABETICAL INDEX
