Bobcat Compact Excavator E26 Service Manual 6990097enUS 2019
Brand: Bobcat
Type of Machine: Compact Excavator
Model: Bobcat E26 Compact Excavator
S/N AJRY11001 & Above
S/N B33211001 & Above
S/N B3JE11001 & Above
Part Number: 6990097enUS
Publication Date: 2019
Number of Pages: 972 Pages
FOREWORD
Brand: Bobcat
FOREWORD
FOREWORD
SAFETY INSTRUCTIONS
FIRE PREVENTION
SERIAL NUMBER LOCATIONS
DELIVERY REPORT
EXCAVATOR IDENTIFICATION
SAFETY AND MAINTENANCELIFTING AND BLOCKING THE EXCAVATOR
LIFTING THE EXCAVATOR
OPERATOR CAB (ROPS / TOPS) S/N AJRY11001 & ABOVE AND B33211001 & ABOVE
OPERATOR cab (ROPS / TOPS) S/N B3JE11001 & ABOVE
OPERATOR CANOPY (ROPS / TOPS)
TRANSPORTING THE EXCAVATOR ON A TRAILER
TAILGATE
RIGHT SIDE COVER
SERVICE SCHEDULE
AIR CLEANER SERVICE
CAB FILTERS (S/N AJRY11001 - AJRY12331)
CAB FILTERS (S/N AJRY12332 & ABOVE, B33211000 & Above AND B3JE11001 & ABOVE)
ENGINE COOLING SYSTEM
FUEL SYSTEM
ENGINE LUBRICATION SYSTEM
HYDRAULIC SYSTEM
LUBRICATING THE EXCAVATOR
PIVOT PINS
TRAVEL MOTOR
SPARK ARRESTER MUFFLER
EMERGENCY EXIT
SEAT BELT
CONTROL CONSOLE LOCKOUTS
TOWING THE EXCAVATOR
REMOTE START TOOL KIT - MEL1563
REMOTE START TOOL (SERVICE TOOL) KIT - 7217666
HYDRAULIC SYSTEMHYDRAULIC / HYDROSTATIC SCHEMATICS
HYDRAULIC SYSTEM INFORMATION
CYLINDER (BOOM)
CYLINDER (ARM)
CYLINDER (BOOM SWING)
CYLINDER (BUCKET)
CYLINDER (BLADE)
CYLINDER (CLAMP)
VALVES (MAIN RELIEF)
VALVES (PORT RELIEF)
VALVES (CROSS PORT RELIEF)
VALVES (PILOT PRESSURE RELIEF)
HYDRAULIC CONTROL VALVE
HYDRAULIC PUMP
MANIFOLD ASSEMBLY / ACCUMULATOR
TRAVEL MOTOR
SWIVEL JOINT
SWING MOTOR (S/N AJRY11001 - AJRY12382)
SWING MOTOR (S/N AJRY12383 & ABOVE, B33211001 & ABOVE AND B3JE11001 & ABOVE)
SWING MOTOR (DRIVE CARRIER)
CONTROL PATTERN SELECTOR VALVE
RIGHT CONTROL LEVER (JOYSTICK) (S/N AJRY11001 - AJRY12331)
RIGHT CONTROL LEVER (JOYSTICK) (S/N AJRY12332 & ABOVE, B33211001 & ABOVE AND B3JE11001 & ABOVE)
LEFT CONTROL LEVER (JOYSTICK) (S/N AJRY11001 - AJRY12331)
LEFT CONTROL LEVER (JOYSTICK) (S/N AJRY12332 & ABOVE, B33211001 & ABOVE AND B3JE11001 & ABOVE)
HYDRAULIC FILTER MOUNT
HYDRAULIC RESERVOIR
OIL COOLER
DIRECT TO TANK VALVE
BLADE CONTROL LEVER
CASE DRAIN FILTER MOUNT
TRAVEL CONTROL VALVE
REMOVING AIR FROM THE HYDRAULIC SYSTEM
SECONDARY AUXILIARY VALVE
VALVE (BOOM LOAD HOLDING VALVE)
VALVE (ARM LOAD HOLDING VALVE)
UNDERCARRIAGEBLADE
TRACK UNDERCARRIAGE COMPONENTS (RUBBER TRACK)
TRACK MAINTENANCE
SWING CIRCLE GEAR
UPPERSTRUCTURE AND SWING SECTIONUPPERSTRUCTURE
ROPS CANOPY
CAB
SEAT
RIGHT CONSOLE (S/N AJRY11001 - AJRY12331)
RIGHT CONSOLE (S/N AJRY12332 & ABOVE, B33211000 & ABOVE AND B3JE11001 & ABOVE)
LEFT CONSOLE
LEFT UPPERSTRUCTURE COVER
RIGHT UPPERSTRUCTURE COVER
COUNTERWEIGHT
TRAVEL LEVERS AND PEDALS
FLOOR MAT
FUEL TANK
HORN
SWING FRAME
BOOM
ARM (STANDARD AND LONG)
BUCKET
CLAMP
TAILGATE
X-CHANGE
BOBCAT HYDRAULIC PIN GRABBER COUPLER HPG2
RIGHT SIDE COVER
TOOL BOX
ELECTRICAL SYSTEM AND ANALYSISELECTRICAL SCHEMATICS
ELECTRICAL SYSTEM INFORMATION
BATTERY
ALTERNATOR
STARTER
LIGHTS
MAGNETIC LOCKOUT SENSOR
FUEL LEVEL SENDER
DIAGNOSTICS SERVICE CODE (S/N AJRY11001 - AJRY12331)
DIAGNOSTIC SERVICE CODES (S/N AJRY12332 & ABOVE, B33211000 & ABOVE AND B3JE11001 & ABOVE)
DELUXE INSTRUMENT PANEL SETUP (S/N AJRY11001 - AJRY12331)
CONTROL PANEL SETUP (S/N AJRY12332 & ABOVE, B33211000 & ABOVE AND B3JE11001 & ABOVE)
INSTRUMENT PANEL / CONTROLLER (S/N AJRY11001 - AJRY12331)
INSTRUMENT PANEL (S/N AJRY12332 & ABOVE, B33211001 & ABOVE AND B3JE11001 & ABOVE)
CONTROLLER (S/N AJRY12332 & ABOVE, B33211001 & ABOVE AND B3JE11001) (GATEWAY AND AUXILIARY)
KEY SWITCH
WIPER MOTOR
MOTION ALARM SYSTEM
SERVICE PC (LAPTOP COMPUTER)
BOBCAT MACHINE IQ WIRELESS COMMUNICATIONS
ENGINE SERVICEENGINE INFORMATION
ENGINE SPEED CONTROL
MUFFLER
AIR CLEANER
LUBRICATION SYSTEM
FUEL SYSTEM
CYLINDER HEAD
CRANKSHAFT AND PISTONS
CAMSHAFT AND TIMING GEARS
FLYWHEEL AND HOUSING
HEATING, VENTILATION AND AIR CONDITIONING S/N ACRA11001 - ACRA13000AIR CONDITIONING SYSTEM FLOW
REGULAR MAINTENANCE
TROUBLESHOOTING
SYSTEM CHARGING AND RECLAMATION
COMPRESSOR
CONDENSER
RECEIVER / DRIER
EVAPORATOR / HEATER UNIT
THERMOSTAT
EXPANSION VALVE
EVAPORATOR COIL
HEATER COIL
BLOWER FAN
HEATER VALVE
HVAC DUCT
HEATING, VENTILATION AND AIR CONDITIONING S/N AJRY12332 & ABOVE, B33211001 & ABOVE AND B3JE11001 & ABOVEAIR CONDITIONING SYSTEM FLOW
REGULAR MAINTENANCE
TROUBLESHOOTING
COMPRESSOR
CONDENSER
RECEIVER / DRIER
THERMOSTAT
EXPANSION VALVE
EVAPORATOR COIL
HEATER COIL
BLOWER FAN
HEATER VALVE
HVAC DUCT
SPECIFICATIONSEXCAVATOR SPECIFICATIONS (S/N AJRY11001 & ABOVE AND B33211001 & ABOVE)
EXCAVATOR SPECIFICATIONS (S/N B3JE11001 & ABOVE)
TECHNICAL SERVICE GUIDE SPECIFICATIONS
HYDRAULIC CONNECTION SPECIFICATIONS
HYDRAULIC FLUID SPECIFICATIONS
CONVERSIONS
SERVICE TOOLS REQUIRED
ALPHABETICAL INDEX
- Bobcat Heavy Equipment Full Hydraulic Schematics & Electrical Schematics PDF
- Bobcat Compact Mini Excavator 320D-322D i, 320G-322G Parts Manual
- BOBCAT Service Library 2014 Service, Operator, Maintenance, Bulletines, etc...
- Bobcat 753 Service Manual
- Bobcat S130 Parts Manual
- Bobcat X220 Excavator 05-89 Service Manual
- Bobcat 442 Mini Excavator Service Manual
- Bobcat 435 Mini Excavator Parts Manual
- Bobcat Compact Mini Excavator 773 G-Series Parts Manual
- Bobcat Excavators 323 6986958 Service Manual 2-08
- Bobcat S175, S185 Parts Manual
- Bobcat Skid Steer Loader 863 Service Manual
- Bobcat S150-S160 Skid-Steer Loader Service Manual 6902730
- Bobcat 430 Service Manual s/n 563011001 AND UP
- Bobcat s175, s185 operators manual
