Hyundai
86
176,834
Bobcat Compact Excavator E26 Service Manual 6990097enUS 2018
Brand: Bobcat
Type of Machine: Compact Excavator
Model: Bobcat E26 Compact Excavator
S/N AJRY11001 & Above
S/N B33211001 & Above
S/N B3JE11001 & Above
Part Number: 6990097enUS
Publication Date: 2018
Number of Pages: 964 Pages
FOREWORD
FOREWORD​
SAFETY INSTRUCTIONS​
FIRE PREVENTION​
SERIAL NUMBER LOCATIONS​
DELIVERY REPORT​
EXCAVATOR IDENTIFICATION​
SAFETY AND MAINTENANCE
LIFTING AND BLOCKING THE EXCAVATOR​
LIFTING THE EXCAVATOR​
OPERATOR CAB (ROPS / TOPS) S/N AJRY11001 & ABOVE AND B33211001 & ABOVE​
OPERATOR cab (ROPS / TOPS) S/N B3JE11001 & ABOVE​
OPERATOR CANOPY (ROPS / TOPS)​
TRANSPORTING THE EXCAVATOR ON A TRAILER​
TAILGATE​
RIGHT SIDE COVER​
SERVICE SCHEDULE​
AIR CLEANER SERVICE​
CAB FILTERS (S/N AJRY11001 - AJRY12331)​
CAB FILTERS (S/N AJRY12332 & ABOVE, B33211000 & Above AND B3JE11001 & ABOVE)​
ENGINE COOLING SYSTEM​
FUEL SYSTEM​
ENGINE LUBRICATION SYSTEM​
HYDRAULIC SYSTEM​
LUBRICATING THE EXCAVATOR​
PIVOT PINS​
TRAVEL MOTOR​
SPARK ARRESTER MUFFLER​
EMERGENCY EXIT​
SEAT BELT​
CONTROL CONSOLE LOCKOUTS​
TOWING THE EXCAVATOR​
REMOTE START TOOL KIT - MEL1563​
REMOTE START TOOL (SERVICE TOOL) KIT - 7217666​
HYDRAULIC SYSTEM
HYDRAULIC / HYDROSTATIC SCHEMATIC​
HYDRAULIC SYSTEM INFORMATION​
CYLINDER (BOOM)​
CYLINDER (ARM)​
CYLINDER (BOOM SWING)​
CYLINDER (BUCKET)​
CYLINDER (BLADE)​
CYLINDER (CLAMP)​
VALVES (MAIN RELIEF)​
VALVES (PORT RELIEF)​
VALVES (CROSS PORT RELIEF)​
VALVES (PILOT PRESSURE RELIEF)​
HYDRAULIC CONTROL VALVE​
HYDRAULIC PUMP​
MANIFOLD ASSEMBLY / ACCUMULATOR​
TRAVEL MOTOR​
SWIVEL JOINT​
SWING MOTOR (S/N AJRY11001 - AJRY12382)​
SWING MOTOR (S/N AJRY12383 & ABOVE, B33211001 & ABOVE AND B3JE11001 & ABOVE)​
SWING MOTOR (DRIVE CARRIER)​
CONTROL PATTERN SELECTOR VALVE​
RIGHT CONTROL LEVER (JOYSTICK) (S/N AJRY11001 - AJRY12331)​
RIGHT CONTROL LEVER (JOYSTICK) (S/N AJRY12332 & ABOVE, B33211001 & ABOVE AND B3JE11001 & ABOVE)​
LEFT CONTROL LEVER (JOYSTICK) (S/N AJRY11001 - AJRY12331)​
LEFT CONTROL LEVER (JOYSTICK) (S/N AJRY12332 & ABOVE, B33211001 & ABOVE AND B3JE11001 & ABOVE)​
HYDRAULIC FILTER MOUNT​
HYDRAULIC RESERVOIR​
OIL COOLER​
DIRECT TO TANK VALVE​
BLADE CONTROL LEVER​
CASE DRAIN FILTER MOUNT​
TRAVEL CONTROL VALVE​
REMOVING AIR FROM THE HYDRAULIC SYSTEM​
SECONDARY AUXILIARY VALVE​
VALVE (BOOM LOAD HOLDING VALVE)​
VALVE (ARM LOAD HOLDING VALVE)​
UNDERCARRIAGE
BLADE​
TRACK UNDERCARRIAGE COMPONENTS (RUBBER TRACK)​
TRACK MAINTENANCE​
SWING CIRCLE GEAR​
UPPERSTRUCTURE AND SWING SECTION
UPPERSTRUCTURE​
ROPS CANOPY​
CAB​
SEAT​
RIGHT CONSOLE (S/N AJRY11001 - AJRY12331)​
RIGHT CONSOLE (S/N AJRY12332 & ABOVE, B33211000 & ABOVE AND B3JE11001 & ABOVE)​
LEFT CONSOLE​
LEFT UPPERSTRUCTURE COVER​
RIGHT UPPERSTRUCTURE COVER​
COUNTERWEIGHT​
TRAVEL LEVERS AND PEDALS​
FLOOR MAT​
FUEL TANK​
HORN​
SWING FRAME​
BOOM​
ARM (STANDARD AND LONG)​
BUCKET​
CLAMP​
TAILGATE​
X-CHANGE™​
BOBCAT HYDRAULIC PIN GRABBER COUPLER HPG2​
RIGHT SIDE COVER​
TOOL BOX​
ELECTRICAL SYSTEM AND ANALYSIS
ELECTRICAL SCHEMATICS​
ELECTRICAL SYSTEM INFORMATION​
BATTERY​
ALTERNATOR​
STARTER​
LIGHTS​
MAGNETIC LOCKOUT SENSOR​
FUEL LEVEL SENDER​
DIAGNOSTICS SERVICE CODE (S/N AJRY11001 - AJRY12331)​
DIAGNOSTIC SERVICE CODES (S/N AJRY12332 & ABOVE, B33211000 & ABOVE AND B3JE11001 & ABOVE)​
DELUXE INSTRUMENT PANEL SETUP (S/N AJRY11001 - AJRY12331)​
CONTROL PANEL SETUP (S/N AJRY12332 & ABOVE, B33211000 & ABOVE AND B3JE11001 & ABOVE)​
INSTRUMENT PANEL / CONTROLLER (S/N AJRY11001 - AJRY12331)​
INSTRUMENT PANEL (S/N AJRY12332 & ABOVE, B33211001 & ABOVE AND B3JE11001 & ABOVE)​
CONTROLLER (S/N AJRY12332 & ABOVE, B33211001 & ABOVE AND B3JE11001) (GATEWAY AND AUXILIARY)​
KEY SWITCH​
WIPER MOTOR​
MOTION ALARM SYSTEM​
SERVICE PC (LAPTOP COMPUTER)​
CONNECTED MACHINE CONTROLLER​
CONNECTED MACHINE ANTENNA​
ENGINE SERVICE
ENGINE INFORMATION​
ENGINE SPEED CONTROL​
MUFFLER​
AIR CLEANER​
LUBRICATION SYSTEM​
FUEL SYSTEM​
CYLINDER HEAD​
CRANKSHAFT AND PISTONS​
CAMSHAFT AND TIMING GEARS​
FLYWHEEL AND HOUSING​
HEATING, VENTILATION AND AIR CONDITIONING S/N ACRA11001 - ACRA13000
AIR CONDITIONING SYSTEM FLOW​
REGULAR MAINTENANCE​
TROUBLESHOOTING​
SYSTEM CHARGING AND RECLAMATION​
COMPRESSOR​
CONDENSER​
RECEIVER / DRIER​
EVAPORATOR / HEATER UNIT​
THERMOSTAT​
EXPANSION VALVE​
EVAPORATOR COIL​
HEATER COIL​
BLOWER FAN​
HEATER VALVE​
HVAC DUCT​
HEATING, VENTILATION AND AIR CONDITIONING S/N AJRY12332 & ABOVE, B33211001 & ABOVE AND B3JE11001 & ABOVE
TROUBLESHOOTING​
COMPRESSOR​
CONDENSER​
RECEIVER / DRIER​
THERMOSTAT​
EXPANSION VALVE​
EVAPORATOR COIL​
HEATER COIL​
BLOWER FAN​
HEATER VALVE​
HVAC DUCT​
SPECIFICATIONS
EXCAVATOR SPECIFICATIONS (S/N AJRY11001 & ABOVE AND B33211001 & ABOVE)​
EXCAVATOR SPECIFICATIONS (S/N B3JE11001 & ABOVE)​
TECHNICAL SERVICE GUIDE SPECIFICATIONS​
HYDRAULIC CONNECTION SPECIFICATIONS​
HYDRAULIC FLUID SPECIFICATIONS​
CONVERSIONS​
SERVICE TOOLS REQUIRED​
ALPHABETICAL INDEX
