Hyundai
86
176,834
Bobcat Compact Excavator E26 Service Manual 6989695enUS
Brand: Bobcat
Type of Machine: Compact Excavator
Model: Bobcat E26 Compact Excavator
S/N ACRA11001 & Above
Part Number: 6989695enUS
Publication Date: 2018
Number of Pages: 876 Pages
MAINTENANCE SAFETY
FOREWORD
FOREWORD​
SAFETY INSTRUCTIONS​
FIRE PREVENTION​
SERIAL NUMBER LOCATIONS​
DELIVERY REPORT​
EXCAVATOR IDENTIFICATION​
SAFETY AND MAINTENANCE
LIFTING AND BLOCKING THE EXCAVATOR​
LIFTING THE EXCAVATOR​
OPERATOR CAB (ROPS / TOPS)​
OPERATOR CANOPY (ROPS / TOPS)​
TRANSPORTING THE EXCAVATOR ON A TRAILER​
TAILGATE​
RIGHT SIDE COVER​
SERVICE SCHEDULE​
AIR CLEANER SERVICE​
ENGINE COOLING SYSTEM​
FUEL SYSTEM​
ENGINE LUBRICATION SYSTEM​
HYDRAULIC SYSTEM​
LUBRICATING THE EXCAVATOR​
PIVOT PINS​
TRAVEL MOTOR​
EMERGENCY EXIT​
SEAT BELT​
CONTROL CONSOLE LOCKOUTS​
TOWING THE EXCAVATOR​
REMOTE START TOOL KIT - MEL1563​
REMOTE START TOOL (SERVICE TOOL) KIT - 7217666​
HYDRAULIC SYSTEM
HYDRAULIC / HYDROSTATIC SCHEMATICS​
HYDRAULIC SYSTEM INFORMATION​
CYLINDER (BOOM)​
CYLINDER (ARM)​
CYLINDER (BOOM SWING)​
CYLINDER (BUCKET)​
CYLINDER (BLADE)​
CYLINDER (CLAMP)​
VALVES (MAIN RELIEF)​
VALVES (PORT RELIEF)​
VALVES (CROSS PORT RELIEF)​
VALVES (PILOT PRESSURE RELIEF)​
HYDRAULIC CONTROL VALVE​
HYDRAULIC PUMP​
MANIFOLD ASSEMBLY / ACCUMULATOR​
TRAVEL MOTOR​
SWIVEL JOINT (EARLIER MODELS)​
SWIVEL JOINT (LATER MODELS)​
SWING MOTOR​
SWING MOTOR (S/N ACRA12227 & ABOVE)​
RIGHT CONTROL LEVER (JOYSTICK) (S/N ACRA11001 - ACRA12177)​
RIGHT CONTROL LEVER (JOYSTICK) (S/N ACRA12178 & ABOVE)​
LEFT CONTROL LEVER (JOYSTICK) (S/N ACRA11001 - ACRA12177)​
LEFT CONTROL LEVER (JOYSTICK) (S/N ACRA12178 & ABOVE)​
HYDRAULIC FILTER MOUNT​
HYDRAULIC RESERVOIR​
OIL COOLER​
DIRECT TO TANK VALVE​
BLADE CONTROL LEVER​
CASE DRAIN FILTER MOUNT​
TRAVEL CONTROL VALVE​
REMOVING AIR FROM THE HYDRAULIC SYSTEM​
SECONDARY AUXILIARY VALVE (EARLIER MODELS)​
SECONDARY AUXILIARY VALVE (LATER MODELS)​
VALVE (BOOM LOAD HOLDING VALVE)​
VALVE (ARM LOAD HOLDING VALVE)​
UNDERCARRIAGE
BLADE​
TRACK UNDERCARRIAGE COMPONENTS (RUBBER TRACK)​
TRACK UNDERCARRIAGE COMPONENTS (STEEL TRACK)​
TRACK MAINTENANCE​
SWING CIRCLE GEAR​
UPPERSTRUCTURE AND SWING SECTION
UPPERSTRUCTURE​
ROPS CANOPY​
CAB​
SEAT​
RIGHT CONSOLE (S/N ACRA11001 - ACRA12999)​
RIGHT CONSOLE (S/N ACRA13001 & ABOVE)​
LEFT CONSOLE​
LEFT UPPERSTRUCTURE COVER​
RIGHT UPPERSTRUCTURE COVER​
COUNTERWEIGHT​
TRAVEL LEVERS AND PEDALS​
FLOOR MAT​
FUEL TANK​
HORN​
SWING FRAME​
BOOM​
ARM (STANDARD AND LONG)​
BUCKET​
CLAMP​
TAILGATE​
QUICK COUPLER (KLAC™ SYSTEM)​
QUICK COUPLER (LEHNHOFF ® SYSTEM)​
QUICK COUPLER (BOBCAT HYDRAULIC PIN GRABBER COUPLER HPG2)​
RIGHT SIDE COVER​
TOOL BOX​
ELECTRICAL SYSTEM AND ANALYSIS
ELECTRICAL SCHEMATICS​
ELECTRICAL SYSTEM INFORMATION​
BATTERY​
ALTERNATOR​
STARTER​
LIGHTS​
MAGNETIC LOCKOUT SENSOR​
FUEL LEVEL SENDER​
DIAGNOSTIC SERVICE CODES (S/N ACRA11001 - ACRA12177)​
DIAGNOSTIC SERVICE CODES (S/N ACRA12178 & ABOVE)​
DELUXE INSTRUMENT PANEL SETUP (S/N ACRA11001 - ACRA12177)​
CONTROL PANEL SETUP (S/N ACRA112178 & ABOVE)​
INSTRUMENT PANEL / CONTROLLER (S/N ACRA11001 - ACRA12177)​
INSTRUMENT PANEL (S/N ACRA12178 & ABOVE)​
CONTROLLER (S/N ACRA12178 & ABOVE) (GATEWAY AND AUXILIARY)​
KEY SWITCH​
WIPER MOTOR​
MOTION ALARM SYSTEM​
SERVICE PC (LAPTOP COMPUTER)​
SHUT-OFF SWITCH​
ENGINE SERVICE
ENGINE INFORMATION​
ENGINE SPEED CONTROL (DIAL GAUGE)​
ENGINE SPEED CONTROL (LEVER)​
MUFFLER​
AIR CLEANER​
LUBRICATION SYSTEM​
FUEL SYSTEM​
CYLINDER HEAD​
CRANKSHAFT AND PISTONS​
CAMSHAFT AND TIMING GEARS​
FLYWHEEL AND HOUSING​
HEATING AND VENTILATION
REGULAR MAINTENANCE (S/N ACRA11001 - ACRA13000)​
REGULAR MAINTENANCE (S/N ACRA13001 & ABOVE)​
TROUBLESHOOTING​
HEATER UNIT​
HEATER COIL (S/N ACRA11001 - ACRA13000)​
HEATER COIL (S/N ACRA13001 & ABOVE)​
BLOWER FAN (S/N ACRA11001 - ACRA13000)​
BLOWER FAN (S/N ACRA13001 & ABOVE)​
HEATER VALVE​
HEATING / VENTILATION DUCT (S/N ACRA11001 - ACRA12177)​
HEATING / VENTILATION DUCT (S/N ACRA12178 & ABOVE)​
SPECIFICATIONS
EXCAVATOR SPECIFICATIONS​
TECHNICAL SERVICE GUIDE SPECIFICATIONS​
TORQUE SPECIFICATION FOR BOLTS​
HYDRAULIC CONNECTION SPECIFICATIONS​
HYDRAULIC FLUID SPECIFICATIONS​
CONVERSIONS​
SERVICE TOOLS REQUIRED​
ALPHABETICAL INDEX
