Bobcat Backhoe Loader B730 Service Manual 7402295enUS
Brand: Bobcat
Model: Bobcat B730 Backhoe Loader
SN B53S11000 & Above
SN B53T11000 & Above
SN B57G11000 & Above
Part Number: 7402295enUS
Publication Date: 2020
Number of Pages: 1350 Pages
FOREWORD
Brand: Bobcat
FOREWORD
FOREWORD
SAFETY INSTRUCTIONS
PUBLICATIONS AND TRAINING RESOURCES
SERIAL NUMBER LOCATION
DELIVERY REPORT
BOBCAT BACKHOE LOADER IDENTIFICATION
SAFETY AND MAINTENANCESERVICE SCHEDULE
LIFTING AND BLOCKING THE MACHINE
TOWING THE MACHINE
TRANSPORTING THE BACKHOE LOADER ON A TRAILER
STOPPING THE ENGINE AND LEAVING THE MACHINE
STORAGE AND RETURN TO SERVICE
OPERATOR CAB
EMERGENCY EXIT
BACKHOE BOOM / SWING LOCK
APPROVED LIFT ARM SUPPORT DEVICE
TIRE MAINTENANCE
ENGINE COVER
GRILLE
ENGINE AIR CLEANER
FUEL SYSTEM
ENGINE LUBRICATION SYSTEM
ENGINE COOLING SYSTEM
HYDRAULIC SYSTEM
REAR AXLE
TRANSMISSION
ALTERNATOR AND FAN BELT
ATTACHMENT COUPLING SYSTEMS
LUBRICATING THE MACHINE
HYDRAULIC SYSTEMHYDRAULIC / HYDROSTATIC SCHEMATICS
HYDRAULIC SYSTEM INFORMATION
HYDRAULIC SYSTEM
RETURN LINE CHECK VALVE
LOADER ARM LIFT CYLINDERS
LOADER BUCKET (TILT) CYLINDER
CLAMPSHELL CYLINDER
BACKHOE BOOM CYLINDER
BACKHOE ARM CYLINDER
BACKHOE BUCKET CYLINDER
TELESCOPIC ARM CYLINDER
BACKHOE SWING CYLINDERS
BACKHOE STABILIZER CYLINDERS
SIDE SHIFT LOCK CYLINDERS
HYDRAULIC PUMP
BACKHOE CONTROL VALVE
BRAKE PEDAL AND BOOSTER
HYDRAULIC FLUID RESERVOIR
LOADER CONTROL VALVE
STEERING COLUMN AND UNIT
BACKHOE DISTRIBUTOR BLOCK
DRIVE SYSTEMTRANSMISSION (MECHANICAL 2-WHEEL DRIVE)
TRANSMISSION (MECHANICAL 4-WHEEL DRIVE)
TRANSMISSION (AUTOSHIFT 4-WHEEL DRIVE)
FRONT AXLE (2-WHEEL DRIVE)
FRONT AXLE (4-WHEEL DRIVE)
REAR AXLE
FRONT SHAFT
REAR SHAFT
SERVICE BRAKE
MAIN FRAMEBACKHOE BOOM / SWING LOCK
BUCKET TEETH
BACKHOE BOOM
CAB (PILOT CONTROL)
CAB (MECHANICAL CONTROL)
COUNTERWEIGHT
ENGINE COVER
FRONT MUDGUARD
PARKING LEVER
FUEL TANK
KINGPOST
SIDE SHIFT
BACKHOE ARM
FRONT CONSOLE
STABILIZER WEAR PADS
ELECTRICAL SYSTEMELECTRICAL SCHEMATICS
ELECTRICAL SYSTEM
BATTERY
FUSES
RELAYS
INSTRUMENT PANEL
HORN
BACK-UP ALARM
TRAVEL DIRECTION CONTROL LEVER
MULTI-FUNCTION LEVER
FUEL LEVEL SENDER
ENGINE SERVICE (TIER 2)ENGINE INFORMATION
ENGINE SPECIFICATIONS
CYLINDER HEAD
PISTON AND CONNECTING ROD ASSEMBLIES
CRANKSHAFT ASSEMBLY
TIMING CASE AND DRIVE ASSEMBLY
CYLINDER BLOCK ASSEMBLY
ENGINE TIMING
ASPERATION SYSTEM
LUBRICATION SYSTEM
FUEL SYSTEM
FLYWHEEL AND HOUSING
ELECTRICAL SYSTEM
AUXILIARY EQUIPMENT
SPECIAL TOOLS
ENGINE
ACCELERATOR PEDAL
EXHAUST
ENGINE AIR CLEANER
ENGINE SERVICE (TIER 3)ENGINE INFORMATION
LUBRICATION SYSTEM
FUEL SYSTEM
CYLINDER HEAD
CRANKSHAFT AND PISTONS
CAMSHAFT AND TIMING GEARS
TURBOCHARGER
ENGINE BLOCK
ENGINE
ACCELERATOR PEDAL
EXHAUST
ENGINE AIR CLEANER
HEATING, VENTILATION AND AIR CONDITIONING (HVAC)HVAC UNIT
SPECIFICATIONSBACKHOE LOADER SPECIFICATIONS (B53S)
BACKHOE LOADER SPECIFICATIONS (B53T)
BACKHOE LOADER SPECIFICATIONS (B57G)
MACHINE TORQUE SPECIFICATIONS
TORQUE SPECIFICATIONS FOR BOLTS
HYDRAULIC CONNECTION SPECIFICATIONS
REGULAR MAINTENANCE ITEMS
CONVERSIONS
SERVICE TOOLS REQUIRED
ALPHABETICAL INDEX
- Bobcat Heavy Equipment Full Hydraulic Schematics & Electrical Schematics PDF
- Bobcat Compact Mini Excavator 320D-322D i, 320G-322G Parts Manual
- BOBCAT Service Library 2014 Service, Operator, Maintenance, Bulletines, etc...
- Bobcat 753 Service Manual
- Bobcat S130 Parts Manual
- Bobcat X220 Excavator 05-89 Service Manual
- Bobcat 442 Mini Excavator Service Manual
- Bobcat 435 Mini Excavator Parts Manual
- Bobcat Compact Mini Excavator 773 G-Series Parts Manual
- Bobcat Excavators 323 6986958 Service Manual 2-08
- Bobcat S175, S185 Parts Manual
- Bobcat Skid Steer Loader 863 Service Manual
- Bobcat S150-S160 Skid-Steer Loader Service Manual 6902730
- Bobcat 430 Service Manual s/n 563011001 AND UP
- Bobcat s175, s185 operators manual
