Martin Welker
107
235,284
BMW 1 Series F20 F21 2011-2016 Service Repair Manual
Brand: BMW
Type of Machine: Automotive
Type of Manual: Service Repair Manual
Model: BMW 1 Series F20 F21
Date: 2011-2016
Number of Pages: 2336 Pages
Removing and installing complete front left or right spring strut (adaptive M chassis and suspension)
Removing and installing renewing central bass speaker -driver's side- (under front seat)
Removing and installing replacing CHAMP radio receiver (BMW Professional radio)
Removing and installing replacing interference suppression filter
Removing and installing replacing rear panel on rear centre seat backrest
Removing and installing replacing switch for front passenger airbag deactivation
Removing and installing replacing upper section of steering column shroud
Repairing damage to windscreen caused by stone chips (clear and tinted laminated safety glass)
Wheel Alignment F20 REAR WHEEL M135i
Abbreviations
AC performance test
Additional work for camber correction
Additional work in event of faulty drive gearing for longitudinal adjustment
Adjust door
Adjust the fog lights (with electronic headlight adjustment device MAHA Lite 3)
Adjust the high-beam headlight (with electronic headlight adjustment device MAHA Lite 3)
Adjust the low-beam headlight (with electronic headlight adjustment device MAHA Lite 3)
Adjusting engine compartment lid
Adjusting fog lights
Adjusting glass slide tilt sunroof panel
Adjusting headlights
Adjusting left or right striker on engine compartment lid
Adjusting parking brake
Adjusting rear axle
Adjusting rear lid lock
Adjusting replacing bump stops 1
Adjusting tailgate
Adjusting timing of camshaft(s) (N55)
Adjusting toe-in on front axle
aRemoving and installing replacing front left protective plate
Automatic engine start-stop function 1
Battery replacement information
Bleeding brake system with DSC
Blind rivet
Bonding steel on steel
Butt connector for repairing a plug connection
Calibrating reversing camera
Calibrating the compass on the inside mirror
Carbon canister blocked
Carry out ride height adjustment
CBS reset
CD change Malfunction
Changeover of differential oils
Check accessories kit
Check fuel delivery pressure (N20,N26 ,N55 )
Check fuel pressure
Check horn, headlight flashers and hazard warning flashers
Checking automatic seat belt
Checking brakes on test stand
Checking camshaft timing (N55)
Checking compression of all cylinders (N55)
Checking cooling system for watertightness
Checking cylinder head for water leaks
Checking engine oil pressure (N55)
Checking one road wheel on balancing machine for lateral and radial runout (wheel removed)
Checking thickness of brake pad
Checking topping up oil level in rear axle final drive
Checking wheel rim for lateral and radial runout
Cleaning and care of leather in vehicles
Cleaning evaporator
Clutch diagnostics
Coding control module
Completely removing and installing front axle with engine and transmission (.N55)
Completely replacing left carrier support
Cooling System Test F20
Corrosion protection
Deactivating and reactivating airbags acoustic seat belt reminder
Deactivating front passenger airbags with key switch
Dent repairs without damaging paintwork
Detaching wheel bearing inner ring from drive flange (drive flange removed)
Diagnosis of fuel tank systems with fuel tank leak diagnosis module (DMTL)
Disassembling and assembling lock barrel (lock barrel removed)
Draining and adding coolant (N55)
Draining and filling fuel tank
Drawing off, evacuating and filling heating and air conditioning system (R134a)
EMC screws
Engine identification
Engine oil consumption measurement
Equipment recoding special tool number of the transverse member for fixing the engine in the installation location
Exhaust standard EURO 4 and E‐OBD for diesel engines
Fault patterns, valve gear (N20-26 N55)
Frame reference dimension, body
Front axle + steering wheel chassis alignment check must be carried out after the following work
Front axle overview
Front licence plate holder
Gap dimensions, body
General chassis and suspension definitions
General information on light alloy disc wheels
General instructions on paintwork
General notes for labelling with adhesive films
General procedure when dismantling installing bonded window glass
Grinding aluminium components
Headlight fogging fault pattern
IHKA control panel LED in AC button flashes
Inflating tyres with nitrogen (N2)
Information for handling the documents repair instructions, technical data, AZD 1
Information on using cleaning agent paints (personal protection equipment)
Information recommendations and repair methods for aluminium wheels
Information sticker exterior paintwork
Initialising Run Flat Indicator (RPA)
Initialising Telestart hand-held transmitter
Installing and removing replacing chain tensioner piston (N55)
Installing headlight repair kit
Installing replacement transmission (GS6-45BZ DZ)
Installing servodrive
Instructions for desiccant insert replacement
Instructions for opening and part replacement in refrigerant circuit
Instructions for removing and installing ear clips
Instructions for repair work on cooling system
Instructions for repairing stone chip damage on laminated safety glass (clear and tinted)
Instructions for replacement of air conditioning capacitors and radiator coolers 1
KDS chassis wheel alignment check with vehicle load up to design position
KDS wheel alignment check with ride height measurement without vehicle load
Leaded fuel in vehicles with catalytic converters
Leak detection with forming gas
Leak detection with ultraviolet additives (UV additives) (BMW leak-testing case)
Lowering raising rear axle support (universal lifter)
Maintenance work F20
Materials for bonding window
Microencapsulated screws
Min max tolerance sample catalogue for paintwork and corrosion damage
Mounting engine on assembly stand (N55)
Musty odour due to heating and air conditioning system, evaporator cleaning
New BMW paint brochure
New repair methods Gluing Riveting on steel bodies
Note for handling R134a refrigerant
Notes for bonding sound insulation (SI), doors
Notes for changing the air conditioning compressor (amount of refrigerant oil of new air conditioning compressor known)
Notes for changing the air conditioning compressor (amount of refrigerant oil of new air conditioning compressor not known)
Notes for handling bulbs bulb light sources (exterior lights)
Notes for replacing the protective cap of the headlight
Notes on component bonding adhesive tape
Notes on fitting window guide seals
Notes on handling wiring harnesses and cables
Notes on initialisation of electric seat actuator drives
Notes on initializing power windows
Notes on mechatronics (GA8HP45Z)
Notes on radio-operated system (vehicle access, radio-operated opening, radio-operated closing)
Notes on scrapping vehicles with gas generators (airbag system)
Notes on the water drain hose of the slide
Notes on window bonding repair kit
Overview of actuator drives on heater air conditioner
Overview of aerial diversity
Overview of audio components
Overview of brake lines
Overview of brake master cylinder brake booster
Overview of brakes
Overview of consumables (Electronic Parts Catalogue)
Overview of electronic components brakes
Overview of engine gearbox mounting
Overview of front brake
Overview of gearshift mechanism for manual gearbox
Overview of handbrake
Overview of heater - AC system components
Overview of propeller shaft (rear flexible disc)
Overview of rear axle final drive output shafts
Overview of rear axle support with rubber mounts
Overview of rear brake
Overview of steering links
Overview of transmission housing (GS6-45BZZ)
Overview, rain sensor (additional work when replacing the windscreen sensor replacement)
Precision-turning both front brake discs on both sides
Pressing output shaft out of drive flange and drawing in
Procedure after airbag deployment as result of an accident
Raising vehicle with trolley jack
RDC resetting
Rear axle layout
Rear axle wheelchassis alignment check must be carried out after the following work
Recommendation for heating tyres before removing or installing
Reinforcement plate (bonded)
Remove and install (replace) control unit Front Electronic Module (FEM)
Remove and install (replace) control unit Rear Electronic Module (REM)
Remove and install or replace battery
Remove or install front or rear wheel
Remove or install replace cover left or right thigh support from on the front seat
Remove windscreen with Roll Out 2000
Remove, fit replace additional oil cooler (N55)
Removing air duct (N55)
Removing and installing replacing handbrake lever
Removing and installing replacing master brake cylinder for DSC
Removing and installing replacing exhaust camshaft (N55)
Removing and installing replacing expansion tank for hydraulic brake control
Removing and installing replacing rear left or right coil spring
Removing and installing replacing rear left or right mid-range speaker
Removing and installing replacing rear seat
Removing and installing (replacing) Car Information Computer (CIC)
Removing and installing (replacing) control unit for reversing camera
Removing and installing (replacing) decorative trim at centre console
Removing and installing (replacing) decorative trim of control panel
Removing and installing (replacing) front bumper panel
Removing and installing (replacing) front left or right door trim panel
Removing and installing (replacing) front storage compartment
Removing and installing (replacing) HU-H)
Removing and installing (replacing) insert in centre armrest storage compartment
Removing and installing (replacing) left (Xenon) headlight
Removing and installing (replacing) left B-pillar sensor
Removing and installing (replacing) left headlight
Removing and installing (replacing) left rear light
Removing and installing (replacing) M sports steering wheel
Removing and installing (replacing) ornamental grille for bumper panel (side)
Removing and installing (replacing) power window regulator in left or right front door
Removing and installing (replacing) rear axle differential
Removing and installing (replacing) rear bumper panel
Removing and installing (replacing) rear left or right door trim panel
Removing and installing (replacing) steering column switch cluster
Removing and installing (replacing) Telematic Communication Box
Removing and installing (replacing) the headlight driver module
Removing and installing (replacing) trailer module
Removing and installing (replacing) voltage transformer
Removing and installing (replacing) wireless remote control
Removing and installing all ignition coils and injector wells (N55)
Removing and installing complete bearing support for foot pedal
Removing and installing complete exhaust system (N55)
Removing and installing complete glass slide
Removing and installing complete left or right spring strut shock absorber
Removing and installing complete rear axle support
Removing and installing control panel of heater air conditioning system
Removing and installing control panel of heaterair conditioning system
Removing and installing cylinder head (N55)
Removing and installing decorative strip on left dashboard
Removing and installing decorative strip on right dashboard
Removing and installing door
Removing and installing engine (N55)
Removing and installing engine compartment lid
Removing and installing eplacing sport steering wheel
Removing and installing flap for fuel filler neck
Removing and installing front passenger seat
Removing and installing front seat, driver's side
Removing and installing front side wall on left
Removing and installing gearshift lever
Removing and installing glass slide tilt sunroof panel
Removing and installing grab handle holder
Removing and installing instrument panel trim
Removing and installing intake plenum (N55)
Removing and installing left or right front passenger seat side
Removing and installing left or right front seat, driver's side
Removing and installing operating element for assist system
Removing and installing or replacing accelerator pedal module
Removing and installing or replacing aerial amplifier
Removing and installing or replacing airbag module on passenger's side
Removing and installing or replacing alternator (N55)
Removing and installing or replacing armrest on door trim panel, front left or right
Removing and installing or replacing both handbrake Bowden cables
Removing and installing or replacing brake booster
Removing and installing or replacing carbon canister
Removing and installing or replacing chain module for oil pump vacuum pump (N55)
Removing and installing or replacing clutch pedal
Removing and installing or replacing clutch release bearing lever
Removing and installing or replacing console for windscreen washer system complete with motor
Removing and installing or replacing control unit for electric fuel pump
Removing and installing or replacing cover on door handle, front left or right
Removing and installing or replacing door handle on door trim, front left or right
Removing and installing or replacing door handle on door trim, rear left or right
Removing and installing or replacing flat motor for front left or right power window regulator
Removing and installing or replacing front grab handle
Removing and installing or replacing front left or right head restraint
Removing and installing or replacing fuel filler pipe
Removing and installing or replacing fuel tank (diesel)
Removing and installing or replacing fuel tank (petrol gasoline)
Removing and installing or replacing gaiter for handbrake lever
Removing and installing or replacing guide tube for handbrake cables
Removing and installing or replacing inner cover on left or right front seat
Removing and installing or replacing inside door opener in left or right front door
Removing and installing or replacing intake and exhaust camshaft adjusters (N55)
Removing and installing or replacing left or right gas pressure spring for tailgate
Removing and installing or replacing left or right head airbag
Removing and installing or replacing outer door handle from left or right front door
Removing and installing or replacing rear carpet on seat pan
Removing and installing or replacing rear left or right seat belts
Removing and installing or replacing rear panel on left or right front seat backrest
Removing and installing or replacing retaining ring on left or right exterior mirror
Removing and installing or replacing side airbag, front left or right seat
Removing and installing or replacing sun visor and left or right counter support
Removing and installing or replacing trim for left or right door pillar (bottom)
Removing and installing or replacing trim for rear lid
Removing and installing or replacing trim for roof pillar at front (A-pillar), left or right
Removing and installing or replacing trim panel for cover on left or right side member
Removing and installing or replacing trim panel for left or right rear roof pillar (C-pillar)
Removing and installing or replacing trim panel on left or right door post (top)
Removing and installing or replacing window cavity cover strip on outside of left or right front door
Removing and installing output shaft (inserted) completely
Removing and installing radiator (N55)
Removing and installing radio and AC control panel (for vehicles equipped with CID)
Removing and installing rear left or right fixed door window in rear window frame
Removing and installing rear left or right shock absorber (adaptive M chassis and suspension))
Removing and installing renewing all parking brake pads
Removing and installing renewing all spark plugs (N55)
Removing and installing renewing all washer jets of windscreen washer system
Removing and installing renewing both rear brake discs
Removing and installing renewing button for steering wheel heating
Removing and installing renewing centre console operating facility
Removing and installing renewing cover on outer door handle with lock barrel
Removing and installing renewing evaporator
Removing and installing renewing fan cowl with electric fan (N55)
Removing and installing renewing footwell light
Removing and installing renewing gear selector switch
Removing and installing renewing ICM control unit
Removing and installing renewing oil level sensor for engine oil (N55)
Removing and installing renewing roof aerial
Removing and installing renewing steering shaft lower section (N47 N55)
Removing and installing renewing steering wheel module control unit
Removing and installing renewing USB interface connecting socket
Removing and installing renewing water channel for glass slide tilt sunroof
Removing and installing replacing (left or right) underbody panelling
Removing and installing replacing (RFK) reversing camera
Removing and installing replacing 12-V power socket
Removing and installing replacing a front centre left (inside) ultrasonic transducer (Park Distance Control)
Removing and installing replacing a front centre left ultrasonic sensor (M Aerodynamics package ) (PDC)
Removing and installing replacing a front centre right (inside) ultrasonic transducer (Park Distance Control)
Removing and installing replacing a front centre right ultrasonic sensor (M Aerodynamics package ) (PDC)
Removing and installing replacing a front left (outside) ultrasonic transducer (Park Distance Control) 1
Removing and installing replacing a front right (outside) ultrasonic transducer (Park Distance Control)
Removing and installing replacing a pressure line (N55)
Removing and installing replacing a rear centre left ultrasonic sensor (M Aerodynamics package )
Removing and installing replacing a rear centre right ultrasonic sensor (M Aerodynamics package)
Removing and installing replacing a rear middle left ultrasonic transducer
Removing and installing replacing actuator drive for blending flap (left)
Removing and installing replacing actuator drive for blending flap (right)
Removing and installing replacing actuator drive for defrosting flap
Removing and installing replacing actuator drive for fresh recirculated air flap
Removing and installing replacing actuator drive for fuel filler flap
Removing and installing replacing aerial for Comfort Access on left or right
Removing and installing replacing airbag control unit
Removing and installing replacing airbag unit (sport steering wheel)
Removing and installing replacing all guide sleeves for rear head restraints
Removing and installing replacing all pistons (N55)
Removing and installing replacing all rear lower straps
Removing and installing replacing all rocker arms (N55)
Removing and installing replacing all valves (N55)
Removing and installing replacing amplifier (hi-fi system Harman Kardon)
Removing and installing replacing amplifier (with DVD changer hifi system Harman Kardon)
Removing and installing replacing an injector (N55)
Removing and installing replacing an ultrasonic converter at the front left (M Aerodynamics package, PDC)
Removing and installing replacing an ultrasonic converter at the front right (M Aerodynamics package, PDC)
Removing and installing replacing armrest for rear seat backrest
Removing and installing replacing armrest in rear door, left or right
Removing and installing replacing auxiliary radiator (N55)
Removing and installing replacing backrest adjustment motor
Removing and installing replacing backrest for left rear seat
Removing and installing replacing backrest for right rear seat
Removing and installing replacing backrest frame for centre rear seat
Removing and installing replacing backrest frame on left or right front seat
Removing and installing replacing backrest side section on left or right rear seat backrest
Removing and installing replacing back-up aerial
Removing and installing replacing base plate (with rear passenger compartment fresh air grille)
Removing and installing replacing both front brake discs (Brembo)
Removing and installing replacing both multifunction steering wheel switches (M sports steering wheel)
Removing and installing replacing both rear brake pads of disc brake
Removing and installing replacing both solenoid valves (N55)
Removing and installing replacing both windscreen wiper arms
Removing and installing replacing Bowden cable for inside door opener on left or right front door
Removing and installing replacing Bowden cable for inside door opener on left or right rear door
Removing and installing replacing brake pads on both front disc brakes (Brembo)
Removing and installing replacing bumper aerial for Comfort Access
Removing and installing replacing button for rear lid actuation
Removing and installing replacing camera for Lane Departure Warning
Removing and installing replacing capacitor (with desiccant insert) for heating and air conditioning system
Removing and installing replacing carrier for instrument panel
Removing and installing replacing catalytic converter (N55)
Removing and installing replacing CD changer
Removing and installing replacing Central Information Display (CID)
Removing and installing replacing centre armrest
Removing and installing replacing centre console cover
Removing and installing replacing centre console LED
Removing and installing replacing centre fresh air grille
Removing and installing replacing charge air cooler (N20, N26, N55)
Removing and installing replacing clutch master cylinder
Removing and installing replacing clutch slave cylinder (plastic)
Removing and installing replacing clutch switch module
Removing and installing replacing Combobox
Removing and installing replacing complete centre console
Removing and installing replacing complete interior roof light (front)
Removing and installing replacing complete interior roof light (rear)
Removing and installing replacing complete lock barrel in left or right front door
Removing and installing replacing complete rear left or right power window regulator
Removing and installing replacing control unit for air conditioning
Removing and installing replacing control unit for camera-based driver support systems (KAFAS)
Removing and installing replacing control unit for Vertical Dynamic Control
Removing and installing replacing control unit module for left or right seat adjustment
Removing and installing replacing control unit module for seat heating
Removing and installing replacing controller
Removing and installing replacing coolant expansion tank
Removing and installing replacing coolant pump (N55)
Removing and installing replacing coolant thermostat (N55)
Removing and installing replacing cover (seal) on front door at bottom left or right
Removing and installing replacing cover cap on left or right exterior mirror
Removing and installing replacing cover for rear bottom bumper panel (M Aerodynamics package)
Removing and installing replacing cover for rear window frame on left or right
Removing and installing replacing cover in engine compartment on left or right
Removing and installing replacing cover on outer door handle, left or right
Removing and installing replacing cover on outside door handle
Removing and installing replacing cover on window frame of rear door (front), left or right
Removing and installing replacing cover on window frame of rear door, rear left or right
Removing and installing replacing cowl panel cover
Removing and installing replacing damper for glove box
Removing and installing replacing delivery unit (petrol)
Removing and installing replacing distribution box (front)
Removing and installing replacing distribution box (rear)
Removing and installing replacing door handle light on left or right front door
Removing and installing replacing door handle light on left or right rear door
Removing and installing replacing door lock in left or right front door
Removing and installing replacing door lock in left or right rear door
Removing and installing replacing door stop on left or right front door
Removing and installing replacing door stop on left or right rear door
Removing and installing replacing door window glass, front left or right
Removing and installing replacing drive unit for seat cushion tilt adjustment
Removing and installing replacing driver's side fold-down compartment
Removing and installing replacing DSC control unit
Removing and installing replacing DSC hydraulic unit
Removing and installing replacing eccentric shaft (N55)
Removing and installing replacing emergency power siren with tilt sensor
Removing and installing replacing emergency starting coil
Removing and installing replacing empty housing for roof-mounted aerial
Removing and installing replacing engine electrical system for lane departure warning (M sports steering wheel)
Removing and installing replacing exhaust turbocharger (N55)
Removing and installing replacing expander for parking brake shoes
Removing and installing replacing expansion valve (N20, N26, N55)
Removing and installing replacing feed line (N55)
Removing and installing replacing finisher rod on ornamental grille for bumper panel
Removing and installing replacing finishing strip on rear left or right entrance (outer)
Removing and installing replacing flat motor for rear left or right power window regulator
Removing and installing replacing flywheel (N55)
Removing and installing replacing footwell temperature sensor (left)
Removing and installing replacing footwell temperature sensor (right)
Removing and installing replacing forward back seat adjustment drive unit
Removing and installing replacing front (inside) left or right door sill cover strip
Removing and installing replacing front anti-roll bar
Removing and installing replacing front carpet for passenger compartment
Removing and installing replacing front centring mount for propeller shaft
Removing and installing replacing front left or right seat belt
Removing and installing replacing front left or right wheel arch cover (front section)
Removing and installing replacing front left or right wheel arch cover (rear section)
Removing and installing replacing front lower strap fitting (belt tensioner), driver's seat
Removing and installing replacing front lower strap fitting (belt tensioner), front passenger seat
Removing and installing replacing front positive battery cable distributor
Removing and installing replacing front radiator grille, middle left or right
Removing and installing replacing front underbody protection
Removing and installing replacing full-flow oil filter (N55)
Removing and installing replacing glove box cover
Removing and installing replacing glovebox light
Removing and installing replacing grip trim for gear selector switch 1
Removing and installing replacing guide for rear centre bumper panel
Removing and installing replacing guide for the bumper panel, rear left or right
Removing and installing replacing handle strip for sliding roof
Removing and installing replacing hands-free microphone, driver's side
Removing and installing replacing hands-free system speaker
Removing and installing replacing headlining (version with slide tilt sunroof)
Removing and installing replacing headrest for left or right rear seat
Removing and installing replacing heating and air conditioning blower
Removing and installing replacing heating and air-conditioning unit (N13,N20,N26,N55)
Removing and installing replacing high pressure pump (Bosch) (N55)
Removing and installing replacing high-pressure exhaust turbocharger (small turbocharger) (N47S)
Removing and installing replacing high-pressure nozzle of headlight cleaning system on left (or right)
Removing and installing replacing hinge for engine compartment lid
Removing and installing replacing hot film air mass meter (N55)
Removing and installing replacing hotel position switch
Removing and installing replacing housing cover on inner left or right door window frame
Removing and installing replacing housing on left or right exterior mirror
Removing and installing replacing hydraulic valve (N55)
Removing and installing replacing ignition coil cover (N55)
Removing and installing replacing inside door opener of rear left or right door
Removing and installing replacing inside mirror (overview)
Removing and installing replacing instrument panel trim, bottom right
Removing and installing replacing insulation lining on engine hood bonnet
Removing and installing replacing intake camshaft (N55)
Removing and installing replacing intake silencer housing (N55)
Removing and installing replacing integrated chassis management control unit (complete procedure)
Removing and installing replacing interior aerial for Comfort Access (front storage compartment)
Removing and installing replacing interior aerial for comfort access system (rear centre console)
Removing and installing replacing intermediate levers (N55)
Removing and installing replacing LED for left or right door post trim panel
Removing and installing replacing left engine compartment lid lock.
Removing and installing replacing left fog light
Removing and installing replacing left luggage compartment wheel arch panel
Removing and installing replacing left or right camber arm cover
Removing and installing replacing left or right capping in luggage compartment
Removing and installing replacing left or right deformation element for front bumper panel
Removing and installing replacing left or right fanfare
Removing and installing replacing left or right front brake caliper
Removing and installing replacing left or right gas pressure spring for engine compartment lid
Removing and installing replacing left or right head airbag
Removing and installing replacing left or right knee pad
Removing and installing replacing left or right number license plate light
Removing and installing replacing left or right output shaft
Removing and installing replacing left or right rear brake caliper
Removing and installing replacing left or right shift paddle for automatic transmission
Removing and installing replacing left or right steering assembly cover
Removing and installing replacing left or right toe arm
Removing and installing replacing left or right trailing link
Removing and installing replacing left or right wishbone
Removing and installing replacing left-hand charge air duct (N55 )
Removing and installing replacing light operating facility
Removing and installing replacing lock for left or right rear seat backrest
Removing and installing replacing lower section of steering column shroud
Removing and installing replacing low-pressure exhaust turbocharger (large turbocharger) (N47S)
Removing and installing replacing luggage compartment aerial for Comfort Access
Removing and installing replacing luggage compartment floor trim panel
Removing and installing replacing luggage compartment light
Removing and installing replacing lumbar support on front seat
Removing and installing replacing lumbar support pump with valve body for lumbar support backrest width adjustment
Removing and installing replacing mechanism for glass slide tilt sunroof
Removing and installing replacing mirror light
Removing and installing replacing mirror on left or right front door
Removing and installing replacing non-return valve for brake booster
Removing and installing replacing oil pressure sensor (N55)
Removing and installing replacing oil pump (N55)
Removing and installing replacing oil temperature sensor (N55)
Removing and installing replacing one rear left ultrasonic sensor
Removing and installing replacing one rear middle right ultrasonic sensor
Removing and installing replacing ornamental grille for bumper panel (centre)
Removing and installing replacing outer cover on left or right front seat (normal electric)
Removing and installing replacing outer door handle on left or right rear door
Removing and installing replacing outside temperature sensor
Removing and installing replacing park assist control unit
Removing and installing replacing partition wall attachment, right
Removing and installing replacing positive battery cable at partition seal (engine compartment)
Removing and installing replacing power window switch (driver's side)
Removing and installing replacing pressure line (N55)
Removing and installing replacing pull cable for hood bonnet locks at front
Removing and installing replacing push rod (anti-roll bar link) for left right anti-roll bar
Removing and installing replacing radio receiver
Removing and installing replacing rail (Bosch high pressure pump) (N55)
Removing and installing replacing RDC wheel electronics (2nd generation 3rd generation)
Removing and installing replacing rear (inside) left or right door sill cover strip
Removing and installing replacing rear anti-roll bar
Removing and installing replacing rear BMW badge
Removing and installing replacing rear cabin fresh air grille (High AC system)
Removing and installing replacing rear centre console cover
Removing and installing replacing rear centre lower straps
Removing and installing replacing rear centre seat belt
Removing and installing replacing rear centring mount for propeller shaft
Removing and installing replacing rear ignition coil cover (N55)
Removing and installing replacing rear left (or right) protective plate
Removing and installing replacing rear left or right lower straps
Removing and installing replacing rear left or right wheel arch cover
Removing and installing replacing rear panel on right rear seat backrest
Removing and installing replacing rear positive battery cable distributor
Removing and installing replacing rear right ultrasonic sensor
Removing and installing replacing rear underbody protection
Removing and installing replacing rear window wiper blade
Removing and installing replacing rear windscreen washer pump for windscreen washer system
Removing and installing replacing rear wiper motor
Removing and installing replacing relay for fan control
Removing and installing replacing reversing camera (M Aerodynamics package)
Removing and installing replacing right charge-air duct (N55)
Removing and installing replacing right engine compartment lid lock.
Removing and installing replacing right front fog light
Removing and installing replacing right glove box with housing
Removing and installing replacing right luggage compartment wheel arch panel
Removing and installing replacing rocker panel trim on front left or right entrance (outer)
Removing and installing replacing screen panel for glass slide tilt sunroof
Removing and installing replacing sealing cap for oil pump chain tensioner (N55)
Removing and installing replacing seat height adjustment drive unit
Removing and installing replacing sensor for automatic recirculated air control (AUC)
Removing and installing replacing servomotor for eccentric shaft (N55)
Removing and installing replacing side panel on dashboard on left or right
Removing and installing replacing side trim panel, footwell, on A-pillar, left
Removing and installing replacing side trim panel, footwell, on A-pillar, right
Removing and installing replacing sliding head liner for glass slide tilt sunroof panel
Removing and installing replacing socket housing for left rear light
Removing and installing replacing sound insulation in left or right front door
Removing and installing replacing sound insulation on left or right rear door
Removing and installing replacing speaker (mid-range speaker, in instrument panel)
Removing and installing replacing speaker (tweeter in mirror triangle)
Removing and installing replacing speaker (tweeter, in dashboard)
Removing and installing replacing speaker cover on front left or right door trim panel
Removing and installing replacing speakers (mid-range speaker, front door left and right)
Removing and installing replacing Start Stop switch
Removing and installing replacing starter motor (N55)
Removing and installing replacing steering column
Removing and installing replacing steering wheel module (M sports steering wheel)
Removing and installing replacing striker for tailgate lock
Removing and installing replacing support for front bumper panel
Removing and installing replacing support for front lower bumper panel
Removing and installing replacing support for left or right outer door handle with lock barrel
Removing and installing replacing support for left or right outer door handle without lock barrel
Removing and installing replacing support for outer door handle on left or right rear door
Removing and installing replacing support for rear bumper panel
Removing and installing replacing switch cover on left or right front door trim panel
Removing and installing replacing switch for hazard warning flashers central locking
Removing and installing replacing switch for lumbar support
Removing and installing replacing switch for unlocking tailgate
Removing and installing replacing tailgate lock
Removing and installing replacing tank cover on the left
Removing and installing replacing tank cover on the right
Removing and installing replacing the cover for the rear window frame at top
Removing and installing replacing the shift paddles for the transmission (M sports steering wheel)
Removing and installing replacing the thermostat housing N55
Removing and installing replacing top cover on tail panel
Removing and installing replacing trailing link on spring strut dome
Removing and installing replacing transmission bearing block
Removing and installing replacing trim cover on front door window frame, left or right
Removing and installing replacing trim panel for pedal mechanism
Removing and installing replacing trim panel for storage shelf
Removing and installing replacing trim strip on roof frame at left or right
Removing and installing replacing tweeter in rear
Removing and installing replacing ultrasound sensor for parking assistant
Removing and installing replacing USB audio interface connecting socket
Removing and installing replacing vacuum pump (N55)
Removing and installing replacing vibration absorbe1
Removing and installing replacing vibration absorber
Removing and installing replacing vibration damper (N55)
Removing and installing replacing V-support
Removing and installing replacing washer pump for headlight cleaning system
Removing and installing replacing wave trap
Removing and installing replacing weather strip on inside rear door
Removing and installing replacing weather strip on outside of rear door
Removing and installing replacing wind deflector for glass slide tilt sunroof
Removing and installing replacing windscreen rubber surround
Removing and installing replacing windscreen washer pump
Removing and installing replacing wiper arm on rear window
Removing and installing roof switch cluster (front)
Removing and installing sealing cylinder head cover (N55)
Removing and installing sealing throttle body (N55)
Removing and installing tailgate
Removing and installing three-hole flange
Removing and installing transmission (GS6-45BZ) N55
Removing and installing windscreen
Removing and installing, sealing or replacing oil sump (N55)
Removing and refitting replacing both rear seat backrests
Removing and refitting replacing lock for centre rear seat backrest
Removing installing ball sockets with clip
Removing installing replacing left hinge for tailgate (tailgate removed)
Removing or installing replacing the sound insulation of the upper part of the bulkhead
Removing replacing knock sensors (N55)
Removing replacing zero gear sensor
Removing weather strip with special tool 00 9 324 at front or rear
Removing windows with a Spider
Removing windows with an oscillating knife
Repair instructions for bonded seals
Repair of corrosion damage
Repairing airbag cables 1
Repairing plastic components
Repairing runflat tyres
Replace A-pillar, outer left
Replace B-pillar with reinforcement on left
Replace control panel for heater air conditioning system 1
Replace controller chrome ring
Replace cover bowl
Replace decorative strip on instrument panel at right
Replace electrical steering box (EPS)
Replace front intake pipe (N55)
Replace heating elements for front seat (sport manual) left or right
Replace LED module for left daytime driving lights
Replace outer left B-pillar.
Replace roof outer skin with slide tilt sunroof
Replace seat cover for left or right front seat (normal electric)
Replace sills, left.
Replace the actuator drive for the ventilation flap, right (High AC system)
Replace the A-pillar on the outside left in the area of the windscreen
Replace the decorative strip on the dashboard, left.
Replace the fuel filler neck breather pipe (petrol)
Replace the retaining ring for the left (or right) brake pads
Replace windscreen
Replacing (removing and installing) left or right track rod
Replacing a ball joint in lower steering stub wheel carrier
Replacing a brake pad sensor (front)
Replacing a brake pad sensor (rear)
Replacing a control arm
Replacing a rear pulse sensor
Replacing a run-flat tyre version or UHP tyres
Replacing a wheel carrier
Replacing actuator drive for left blending flap
Replacing actuator drive for left ventilation flap (High AC system)
Replacing actuator drive for rear compartment flap
Replacing actuator drive for right stratification flap
Replacing air conditioning system compressor (N55)
Replacing air filter element (N55)
Replacing all brake pipes
Replacing all connecting rod bearing shells (N55)
Replacing all crankshaft main bearing (N55)
Replacing all rubber mounts for rear axle final drive mounting at front
Replacing all valve springs (N55)
Replacing all valve stem seals (N55)
Replacing alternator belt pulley (with overrunning clutch)
Replacing and installing (replacing) the solar rain light sensor and condensation sensor
Replacing anti-roll bar link for anti-roll bar bar on left or right
Replacing A-pillar with reinforcement on left 1
Replacing ashtray insert
Replacing audio unit 1
Replacing backrest cover for front seat
Replacing backrest cover for left or right front seat
Replacing backrest cover for left rear seat (basic seat)
Replacing backrest cover for left rear seat (through-loading facility)
Replacing backrest cover for rear seat, centre
Replacing backrest cover for right rear seat
Replacing backrest width adjustment with valve on left or right
Replacing ball socket for gearshift lever
Replacing base plate for number license plate
Replacing bearing bushes for gearshift arm
Replacing bearing for front wheel
Replacing blind rivets 1
Replacing Bluetooth cable aerial
Replacing both cushions for backrest width adjustment on left or right front seat
Replacing both rubber mounts for anti-roll bar mounting
Replacing both windscreen wiper blades
Replacing brake light switch
Replacing bulb for daytime driving lights, left
Replacing bulb for front interior roof light
Replacing bulb for front left turn indicator (with xenon headlight)
Replacing bulb for glove box light
Replacing bulb for interior roof light (rear)
Replacing bulb for side lights, front left
Replacing bulb for turn indicator, front left
Replacing bulkhead new part preparation
Replacing centre front panel
Replacing centre mount gaiter 1
Replacing complete gearshift lever
Replacing complete propeller shaft centre bearing
Replacing condensation water drain hose of heating and air conditioning system
Replacing control unit (DME) (N55)
Replacing control unit for left xenon headlight
Replacing controller for heating and air conditioning system blower
Replacing coolant temperature sensor (N55)
Replacing crankshaft (N55)
Replacing crankshaft pulse sensor (N55)
Replacing cylinder head gasket (N55)
Replacing design cover for M sports steering wheel
Replacing door detent (lock striker), front left or right
Replacing door detent (lock striker), rear left or right
Replacing drive belt for alternator (N55)
Replacing drive flange on left right rear axle shaft
Replacing electric auxiliary heater -front-
Replacing electric motor with gearbox (front) for operation of slide tilt sunroof
Replacing emergency battery for Telematic Communication Box (TCB)
Replacing engine support front left side frame connection (front left wheel arch removed).
Replacing engine support in front of bulkhead, left
Replacing engine support in front of wheel arch, left
Replacing engine support with front left wheel arch in front of bulkhead
Replacing evaporator temperature sensor
Replacing flexible disc for front propeller shaft
Replacing fluid in brake system (M sport brake)
Replacing front axle support
Replacing front crankshaft seal (N55)
Replacing front left or right brake hose
Replacing front left or right coil spring
Replacing front left or right rubber guide for left or right door window
Replacing front left or right side wall holder
Replacing front left or right spring strut (adaptive M suspension)
Replacing front left or right spring strut shock absorber
Replacing front left or right spring strut support bearing
Replacing front left wheel arch
Replacing front ride height sensor
Replacing front silencer (N55)
Replacing gaiter (shift lever cover) for shift lever
Replacing gaiter for steering box on left or right
Replacing gearshift arm for gearshift lever mount
Replacing gearshift lever knob
Replacing gearshift rod
Replacing grooved ball bearing in propeller shaft centre bearing
Replacing guide sleeve for clutch operator (GS6-45BZ DZ)
Replacing guide sleeves for front left or right head restraint
Replacing halogen bulb for headlight on left
Replacing halogen bulb for high beam headlight on left
Replacing halogen bulb for left fog light
Replacing halogen bulb for right fog light
Replacing handle for handbrake lever
Replacing heat exchanger
Replacing ignition coils (N55)
Replacing ignition unit for left xenon headlight
Replacing instrument panel trim
Replacing LED for front inside door opener (left or right)
Replacing LED for rear inside door opener (left or right)
Replacing left right swivel bearing
Replacing left engine mount (N55) 1
Replacing left engine support arm (N55)
Replacing left engine support arm (N55)1
Replacing left or right fixed door window in rear window frame
Replacing left or right gaiter for glass slide tilt sunroof
Replacing left or right rear axle support compression strut
Replacing left or right track rod end
Replacing left or right trailing arm
Replacing left or right wheel bearing on rear axle shaft
Replacing left or right wheel speed accelerator sensor
Replacing light bulb for footwell light
Replacing light bulb for luggage compartment lighting
Replacing luggage compartment floor and side member on left (left side wall and tail panel removed)
Replacing luggage compartment floor, left section (rear side panel and tail panel removed)
Replacing microfilter for interior ventilation 1
Replacing middle luggage compartment floor (tail panel has been removed)
Replacing mirror glass
Replacing model name plate, rear
Replacing monitoring sensor (N55)
Replacing negative battery lead
Replacing one front pulse sensor
Replacing one upper wishbone
Replacing operating unit for seat adjustment
Replacing oxygen control sensor (N55)
Replacing piston rings on all pistons (N55)
Replacing positive battery cable (from battery to luggage compartment cable connector)
Replacing positive battery cable between starter motor, alternator and positive battery connection point (N55)
Replacing power distribution module (N20, N26, N55)
Replacing pressure sensor on charge air duct (N55)
Replacing pressure sensor on intake plenum (N55)
Replacing pulse sensor on exhaust camshaft (N55)
Replacing pulse sensor on intake camshaft (N55)
Replacing radial crankshaft seal on transmission side (N55)
Replacing radial shaft seal for drive flange on rear axle final drive
Replacing radial shaft seal for drive shaft
Replacing radial shaft seal for gearshift shaft (GS6-45BZ DZ)
Replacing radial shaft seal for output flange
Replacing radial shaft seal for output shaft at rear axle differential, left or right
Replacing rear axle support
Replacing rear bumper panel trim strip
Replacing rear cover gasket on rear axle final drive
Replacing rear left or right brake hose
Replacing rear left or right bumper (adaptive M suspension)
Replacing rear left or right door window
Replacing rear left or right side shock absorber
Replacing rear left or right support bearing for spring strut shock absorber
Replacing rear left outer wheel arch section (rear side panel removed)
Replacing rear left outer wheel arch section with reinforcement (rear side panel removed)
Replacing rear left side panel
Replacing rear luggage compartment floor (tail panel removed)
Replacing rear ride height sensor
Replacing rear silencer (N55)
Replacing rear window (rear window broken)
Replacing retaining ring for condensation drain hose
Replacing right engine mount (N55) 1
Replacing right engine support arm (N55) 1
Replacing rocker switch for side window operation (rear)
Replacing roller bearing for dual-mass flywheel (N55)
Replacing roof switch cluster (front)
Replacing rubber mount for gearbox mounting (N13)
Replacing rubber mount for trailing arm in wheel carrier
Replacing rubber mount in left or right trailing link
Replacing safety battery terminal (SBK)
Replacing safety pressure switch
Replacing seal for glass slide tilt sunroof panel
Replacing sealing cap for vacuum pump (N55)
Replacing seat cover for front seat
Replacing seat cover for rear seat
Replacing seat cover on left or right front seat (normal manual)
Replacing sensor mat for front passenger seat occupancy detector 1
Replacing slide sunroof frame
Replacing solenoid switch
Replacing spring for brake pedal
Replacing spring for clutch pedal
Replacing steering column adjustment lever
Replacing steering shaft sleeve
Replacing switch for reversing light
Replacing tail panel
Replacing tank vent valve (N55)
Replacing tensioning device for alternator drive belt (N55)
Replacing the additional brake light
Replacing the carrier support before the wheel arch on the left
Replacing the front BMW badge
Replacing the rubber mounts for the rear axle final drive suspension at rear
Replacing timing chain (N55)
Replacing top timing chain (N47D C K
Replacing two rubber mounts (front) for rear axle support
Replacing two rubber mounts (rear) for rear axle support
Replacing U-type bellows
Replacing vacuum hose for brake booster (N43)
Replacing vacuum hose for brake booster (N63)
Replacing voltage regulator
Replacing washer fluid reservoir for windscreen washer system
Replacing wheel arch trim on front left or right side panel (Japanese national-market version)
Replacing wheel arch trim on rear left or right side panel (Japanese national-market version) 1
Replacing wiring harness for front bumper
Replacing wiring harness in left or right front door
Replacing wiring harness in left or right rear door
Replacing wiring harness section for engine (N55)
Replacing wiring harness section for ignition and injectors (N55)
Resurfacing cylinder head lower face (N55)
Safety at work
Safety information for working on vehicles with automatic engine start-stop function (MSA) 1
Safety information for working on vehicles with automatic engine start-stop function (MSA) 2
Safety informations for handling refrigerant oil
Safety informations for handling tetrafluorethane refrigerant R134a
Safety instructions for handling magnets
Safety instructions for handling oil
Safety instructions for handling vehicle battery
Safety instructions for working on cars with airbag systems
Safety precautions and general information
Safety regulations for handling components with gas generators 1
Sealing crankcase lower section (N55)
Sealing installation
Secure engine in installation position
Separating cut determination with a template
Service - engine oil (N55)
Service position of engine compartment lid
Setting blind rivet nuts and bolts
Socket housing (radio connector), Hybrid System
Socket housing 42-, 43-pin, Hybrid System
Socket housings, 2x21-, 2x27-pin, Hybrid Systems
Socket housings, 5-pin, 8-pin, System
Soldering steel components
Special tools for wiring harness repairs
Spot-weld bonding steel components
Spray gun for cavity sealant
Stamping vehicle identification number (needle stamping unit)
Start-up of ICM control unit
Stationary wheel balancing
Steering components Check for play, damage and, if nec., tightness
Straightening aluminium component on the outer skin
Straightening aluminium components in structure
Straightening steel components in the structure
Straightening steel components on the outer skin
Stripping operations - Replace roof outer skin with slide tilt sunroof
Stripping operations - Replace the left side member and luggage compartment floor (removed left side wall and tail panel)
Stripping operations - replacing carrier support in front of left wheel arch
Stripping operations - Replacing complete left carrier support
Stripping operations - replacing engine support in front of left wheel arch
Stripping operations - Replacing front left wheel arch
Stripping operations - Replacing front right wheel arch
Stripping operations - Replacing left luggage compartment floor (rear side wall and tail panel removed)
Stripping operations - Replacing luggage compartment floor, middle (tail panel removed)
Stripping operations - Replacing luggage compartment floor, rear (tail panel removed)
Stripping operations - Replacing rear side panel, left
Stripping operations - Replacing rear side panel, right
Stripping operations - Replacing roof outer skin
Stripping operations - Replacing tail panel
Symbols used and information in repair instructions
Teaching in end stop software for electric steering gear (EPS)
Test requirements for headlights vertical aim adjustment
Testing battery with battery tester
Tightening torques
Touching up paintwork damage
Transmission designations
Transmission difficult to shift diagnostic aid
Transparent screens of different headlight types (halogen, xenon, LED)
Treating cables and optical fibres
Unlocking and disconnecting different plug connections
Unlocking locking airbag plug connections
Use of materials in outer skin
Vacuum supply
Vehicle identification number, general
Venting and filling cooling system with vacuum filling unit
Venting cooling system and checking for watertightness (N55)
Warnings for the removal of injectors (N55)
Welding in reinforcement plate (sheet steel)
Welding steel components
Wheel Alignment F20 REAR WHEEL Rough road package with height adjustment
Window glass removal with wire pull handle
Window glue
Windscreen wipers making noises
Working with 2-component PU cavity foam
Workshop equipment (BMW and MINI vehicles)
