Bell Logger 220A MKIII 225A MKIII Parts Manual 874192
Brand: Bell
Type of Machine: Logger
Model: Bell 220A MKIII 225A MKIII Logger
Serial Number:
220A: 424220
225A: 424225
Part Number: 874192
Publication Date: 2015
Number of Pages: 279 Pages
Section 1 - General Information
Introduction
User’s Comment Form
Amendment Record Sheet
List Of Abbreviations
Ordering Of Parts
Service Kits
Machine Dimension - 225a
Machine Dimension - 220a
Serial Number Plates
Section 2 - Engine
Engine And Miscellaneous Parts
Spray Nozzle
Breather
Blanking Parts
Fastenings
Cover
Crankcase
Tensioning Pulley
Deflector Plate
Guide
Oil Filler Cap
Dipstick
Timing Cover
Timing Cover Fasteners
Idler Bearing
Oil Pan
Cylinder Liner
Flywheel
Vibration Damper
Dynamic Balancer
V-Belt Pulley
Connecting Rod
Piston
Cylinder Head Bolts
Cylinder Head Cover
Camshaft
Valve Drive
Pushrod Tube
Oil Pump
Oil Filter
Oil Pressure Pipe
Oil Suction Pipe
Fuel Injection Pump
Fuel Line Fittings
Fuel Lines
Overflow Line
Injector Pipes
Leak Off Line
Intake Manifold
Fittings
Cooling Fan
V-Belt - Cooling Fan
Air Duct Wall
Guide Rail
Air Duct Wall Rear
Cooling Air Baffle
Air Cowling Base
Cool Air Feed Duct
Exhaust Manifold
Alternator Brackets
Alternator Fan And Pulley
V-Belt - Alternator
Starter
Flywheel Housing
Shutdown Device
Hydraulic Pump Driving Parts
Gasket Sets
Air Cleaner System
Air Cleaner
Pre Cleaner
Exhaust System
Fuel System
Throttle And Cut Out Control
Section 3 - Powertrain
Transmission Pump Miscellaneous Parts
Transmission Pump
Transmission Pump (Continued)
Wheel Drive (Series 29)
Wheel Drive (Series 29) (Continued)
Hydraulic Motor - 560cc
Brake Release Valve
Control Linkage Assembly
Tail Wheel Fork Assembly
Tail Wheel Axle
Wheelset Option (23.1x26 - 18.0x15.5)
Rear Wheel Assembly Option (18.0x15.5)
Front Wheel Assembly Option (23.1x26)
Wheelset Option (18.4x30 - 400x15.5)
Rear Wheel Assembly Option (400x15.5)
Front Wheel Assembly Option (18.4/15x30)
Special Tools
Section 4 - Hydraulic System
Hydraulic System - Driveline
Hydraulic System - Driveline (Continued)
Hydraulic System - Filter & Pump Supply
Hydraulic System - Drain
Hydraulic Filter Assembly (Single Port)
Hydraulic Filter Assembly (Double Port)
Control Valve (One Bank)
Control Valve (One Bank) (Continued)
Control Valve (Two Bank)
Control Valve (Two Bank) (Continued)
Handle Assembly
Hydraulic Pump - 16cc
Cylinder Assembly (Lift)
Cylinder Assembly (Telescopic Extension)
Cylinder Assy (Grapple)
Rotator Assembly
Rotator Assembly (Continued)
Section 5 - Electrical System
Electrical System (Sheet 1 Of 2)
Electrical System (Sheet 2 Of 2)
Instrument Panel Assembly
Battery And Clamps
Lighting Kit (5 Lights)
Section 6 - Frame And Body
Frame And Body
Frame And Body (Continued)
Cab Assembly
Seat Assembly
Crank Boom - 225a
Telescopic Boom - 220a
Telescopic Boom - 220a (Continued)
Grapple Assy, Mt360 / Mt420 (With Damper)
Decal Layout
Brand: Bell
Serial Number:
220A: 424220
225A: 424225
Part Number: 874192
Introduction
User’s Comment Form
Ordering Of Parts
Service Kits
Section 2 - Engine
Spray Nozzle
Breather
Blanking Parts
Fastenings
Cover
Crankcase
Tensioning Pulley
Deflector Plate
Guide
Oil Filler Cap
Dipstick
Timing Cover
Idler Bearing
Oil Pan
Cylinder Liner
Flywheel
Vibration Damper
Dynamic Balancer
V-Belt Pulley
Connecting Rod
Piston
Cylinder Head Bolts
Cylinder Head Cover
Camshaft
Valve Drive
Pushrod Tube
Oil Pump
Oil Filter
Oil Pressure Pipe
Oil Suction Pipe
Fuel Injection Pump
Fuel Line Fittings
Fuel Lines
Overflow Line
Injector Pipes
Leak Off Line
Intake Manifold
Fittings
Cooling Fan
Air Duct Wall
Guide Rail
Air Duct Wall Rear
Cooling Air Baffle
Air Cowling Base
Cool Air Feed Duct
Exhaust Manifold
Alternator Brackets
V-Belt - Alternator
Starter
Flywheel Housing
Shutdown Device
Gasket Sets
Air Cleaner System
Air Cleaner
Pre Cleaner
Exhaust System
Fuel System
Transmission Pump
Brake Release Valve
Tail Wheel Axle
Special Tools
Handle Assembly
Rotator Assembly
Battery And Clamps
Frame And Body
Cab Assembly
Seat Assembly
Crank Boom - 225a
Decal Layout
- Bell Equipment B35D & B40D Repair manual Dumptruck ( Articulated )
- Bell Articulated Dump Truck B25D B30D 6x6 Repair Manual
- Bell Equipment B35D & B40D operation test manual Dumptruck ( Articulated )
- Bell Articulated Dump Truck B30E PIN A830E11 Parts Manual
- Bell Dumptruck Parts Manual B40D 6X6,ADT - 413840 B35D 6X6,OBW,ADT - 413835 B35D 6X6,OBW,WDB,ADT - 4
- Bell Equipment B30D MkVI ADT - A830D60 Parts Manual
- Bell DUMPTRUCK Operators manual
- Bell equipment
- Bell Equipment B25D Mk7.2 ADT - EA825D72 872335 Parts Manual
- Bell Equipment ARTICULATED DUMP TRUCK B25E PIN A825E22 Parts Manual
- Bell Articulated Dump Truck B25D & B30D 6x6 Repair Manual
- Bell Equipment B50D 6X6 SS ADT MK VI - A850D60 872241 Parts Manual
- BELL E-SERIES B18E B30E Articulated Dump Truck Operator's Manual 872353 REV A
- BELL E-SERIES B18E B30E Articulated Dump Truck Service Manual 872352 REV A
- Bell Equipment AH350D-400D Technical Manual
