Martin Welker
104
230,310
Bell Dump Truck B40D B35D PIN 7.3 Tier 3B IT4 Parts Manual 872386
Brand: Bell
Type of Machine: Dump Truck
Model: Bell Dump Truck
B40D ADT PIN 7.3 TIER 3B - EA640D73
B35D ADT PIN 7.3 TIER 3B - EA636D73
B40D ADT PIN 7.3 IT4 - EA340D73
B35D ADT PIN 7.3 IT4 - EA336D73
Part Number: 872386
Publication Date: 2014
Number of Pages: 828 Pages
Section 1: General Information
Page Layout
Bulletins
List Of Abbreviations
Ordering Of Parts
Machine Dimensions B40d 6x6 Adt
Machine Dimensions B35d 6x6 Adt
Serial Number Plates
Engine Control Unit (Pld) - Ordering Details
Pin Identification
Section 2: Engine
Engine & Misc Components - B35d It4
Engine & Misc Components - B40d It4
Engine & Misc Components - B35d Tier 3b
Engine & Misc Components - B40d Tier 3b
Engine Crankcase
Timing Case
Oil Pan & Dipstick
Cylinder Head (Continued)
Decompression Valve Pipe
Crankshaft And Flywheel - B40d
Crankshaft And Flywheel - B35d
Connecting Rods And Pistons
Camshaft
Fuel Lines
Turbocharger
Air Compressor
Intake Manifold & Flame Start
Exhaust Manifold
Exhaust Brake Manifold
Adblue Metering Unit
Adblue Pump Module
Starter Motor
Alternator - B40d
Alternator - B35d
Alternator Support
Electrical Equipment
Oil Pump
Oil Filter & Oil Cooler
Oil Lines
Fan
Belt Tensioner & Belt - B40d
Belt Tensioner & Belt - B35d
Engine Support
Adblue Preheating
P.T.O
Air Conditioner Compressor
Catalyst
Engine Cooling System, B40d - Detail A
Engine Cooling System, B40d - Detail B
Engine Cooling System, Radiator, B40d
Engine Cooling System, B35d - Detail A
Engine Cooling System, B35d - Detail B
Engine Cooling System, Radiator, B35d
Engine Fuel System Kit
Handlift Pump & Pre-Filter
Fuel-Water Filter Unit
Filter 2000 (Optional)
Depth Fuel Filter
Exhaust- After Treatment System - Detail A
Exhaust - After Treatment System - Detail B
Exhaust - After Treatment System - Detail C
Exhaust - After Treatment System - Detail D
Bin Heating Kit (Optional)
Kit, Exhaust Stand
Air Intake Kit
Air Cleaner & Pre-Cleaner Assembly
Section 3: Drivetrain
Transmission Kit - Detail A
Transmission Kit - Detail B
Transmission, Main Housing
Transmission, Fill Tube
Transmission, Main Shaft
Transmission, Flange
Transmission, Front Support & Oil Pump
Transmission, P1 Planetary
Transmission, P2 Planetary
Transmission, Control Valve (Part 1)
Transmission, Control Valve (Part1) (Contd)
Transmission, Control Valve (Part 2)
Transmission, Control Valve (Part 2) (Contd)
Transmission, Oil Cooler
Transmission, Torque Converter
Transmission, Rotating Clutch
Transmission, Converter Housing
Transmission, P3 Planetary & Rear Cover
Transmission, Cooler Box
Transmission Cooler, Fan Assembly
Transmission Cooler, Cooler Assembly
Cooler, T/Mission, Hyd
Transfer Case - Drop Box & Mountings
Drop Box, Output Main Assy
Drop Box, Idler Assy
Drop Box, Input Assy
Drop Box, Housing Assy
Drop Box, Clutch Assy
Drop Box, Clutch Housing Assy
Drop Box, Output Gear & Clutch Assy
Drop Box, Output Gear Assy
Drop Box, Planet Carrier Assy
Drop Box, Rear Output Assy
Drop Box, Bearing Housing Rear Assy
Drop Box, Flanges
Drop Box, Idler Shaft
Drop Box, Front & Rear Idler Inserts
Drop Box, Rear Input Insert
Drop Box, Input Gear
Drop Box, Front Input Insert
Drop Box, Filtration System
Driveline Kit
Propshafts
Coupling, Pto
Thru Drive Kit
Kit, Park Brake Mounting
Park Brake Assembly
Actuator Assembly
Axle, Front (Wdb)
Axle, Middle, B40d (Wdb)
Axle, Rear, (Wdb)
Axle Drain & Filler Plugs
Axle, Middle, Caliper
Axle, Rear, Caliper
Final Drive Kit For Rear Axles, B40d
Final Drive Kit For Caliper Axles, B35d
Final Drive Kit For Wdb Axles, B35d
Caliper Hyd Component Kit, B35d - Detail A
Caliper Hyd Component Kit, B35d - Detail B
Disc Brake Kit, Front Axle, B35d
Disc Brake Kit, Rear & Mid Axle, B35d
Middle & Rear Axle Guards Kit, B35d
Front Axle Guards Kit, B35d
Kit, Hydraulic Component, Caliper, B35d
Wet Disc Brake Kit, Middle Axle, B40d
Axle, Rear, Caliper
Wet Disc Brake Kit, Front Axle, B35d
Wet Disc Brake Kit, Middle Axle, B35d
Wet Disc Brake Kit, Rear Axle
Kit, Axle Guards, B40d
Brake, Wdb, B40d
Wet Disc Brake Pump
Disc Brake Caliper Location, B35d
Disc Brake Caliper Breakdown
Front/Rear Differential Assembly
Front/Rear Differential Assembly (Contd)
Middle Differential Assembly
Middle Differential Assembly (Contd)
Wet Disc Brake Assy, Rh Front & Lh Mid Axles
Wet Disc Brake Assy, Lh Front & Rh Mid Axles
Wet Disc Brake Assembly, B35d
Wheel Sets Options, B40d
Wheel Set Options, B40d (Contd)
Wheel Set Options, B35d
Wheel Set Options, B35d (Contd)
Section 4: Hydraulics
Valve, Hydraulic, Assembly
Hydraulic Block - Valve Positions
Hydraulic Block - Valves
Hydraulic Block - Tip Section
Kit, Hydraulic Mounting / Cover
Pipe, Accumulator, Supply, Hydraulic, Assy
Cooler, Hydraulic Assembly
Kit, Front Hydraulic Cooler
Fan Motor - Rexroth
Fan Motor - Parker
Fan Motor Breakdown
Fan Motor (Alternative) Breakdown
Pump, Hydraulic Assembly
Pipe, Return, Hydraulic Assy
Hose, Hydraulic Artic Assembly
Hydraulic Pump, Main (Rexroth)
Hydraulic Pump, Alternative (Parker)
High Presure Filter Assy
Hydraulic Pump Breakdown
Hyd Pump (Alternative) Breakdown - Front
Hyd Pump (Alternative) Breakdown - Rear
Check Valve Manifold
Emergency Steering Pump, Rexroth
E/Steering Pump, Parker (Alternative)
Emergency Steering Pump Breakdown
E/Steering Pump (Alternative) Breakdown
Emergency Steering Pump Check Valve
Kit, Bi-Dir, E/Steering Pump
Pump, Emergency Steering
Kit, Bi-Dir, E/Steering Pump (Alternative)
Damper, Hydraulic Assembly
Damper
Steering, Hydraulic Assembly
Steering Cylinder
Front Susp, Comfort Ride - Detail A (Choice)
Front Susp, Comfort Ride - Detail B (Choice)
Suspension Struts, Comfort Ride (Choice)
Damping Valve, F/Susp, Comfort Ride
Suspension Manifold, F/Susp, Comfort Ride
Front Chassis, Kit, Hyd Component, Wdb
Rear Chassis, Kit, Hyd Component, Wdb
Kit, Filtration, Wdb, B40d
Accumulator Kit, B40d - Europe
Accumulator Kit, B35d - Europe
Hydraulic Kit, Cab - Detail A
Hydraulic Kit, Cab - Detail B
Steering Control Valve, Eaton
Brake Pedal
Ext Brake Pedal Kit
Hydraulic Kit, Cab Tilt System
Hydraulic, Cab Tilt Cylinder Breakdown
Pump, Cab Tilt
Hydraulic Kit, Rear Chassis
Tip Cylinder Breakdown
Section 5: Pneumatics
Pneumatic Kit, Front Chassis - Detail A
Pneumatic Kit, Front Chassis - Detail B
Pneumatic, Scr Assembly
Fan Purging Kit
Purge Tank Valve
Reservoir Kit
Air Dryer Kit
Air Dryer Repair Kit
Pneumatic Kit, Rear Chassis
Pneumatic Kit, Cab Assembly
Pneumatic Valve Assembly
Air Horn (Optional)
Section 6: Electrical
Cab Harness - Detail A
Cab Harness - Detail B
Cab Harness - Detail C
Cab, Fuse And Relay Panel Components
Cab, Windscreen Wiper Kit
Option, Rear Wiper
Kit, Wiper System, Rear, B40d
Cab, Transmission Harness
Cab, Rear View Mirror Kit
Rear View Mirrors
Cab, Load Lights (Optional)
, Electrical, Air Horn
Cab, Beacon (Optional)
Cab, Work Lights (Optional)
Cab, Reverse Lights (Optional)
Cab, Memory Module
Cab, Radio (Optional)
Cab, Reverse Monitor
Cab, Emergency Brake (Optional)
Engine Harness
Electrical System, Artic
Electrical Assembly - Blu@Vantage Only
Kit, Grill, Head Lights (Optional)
Option, Cold Start
Light Breakdowns
Artic Harness
Battery Box
Fuel Heater (Optional)
Suspension System (Optional)
Rear Harness
Obw
Strain Gauge Kit
Connectors (Sheet 1 Of 9)
Connectors (Sheet 2 Of 9)
Connectors (Sheet 3 Of 9)
Connectors (Sheet 4 Of 9)
Connectors (Sheet 5 Of 9)
Connectors (Sheet 6 Of 9)
Connectors (Sheet 7 Of 9)
Connectors (Sheet 8 Of 9)
Connectors (Sheet 9 Of 9)
Section 7: Frame And Body
Bonnet Kit - Detail A
Bonnet Kit - Detail B
Cab Complete
Cab Shell
Cab Door Assembly
Window Guard, Handrails & Cab Mountings
Cab Windows
Rear View Mirror Brackets
Door, Hvac System
Cab Front Insulation Parts
Cab Bottom Seals
Window Catches
Cab, Roof Interior Liners
Cab, Floor Mat & Pillar Covers
Operator & Trainer Seat Installation
Cab Interior Misc. Parts - Detail A
Cab Interior Misc. Parts - Detail B
Steering Column, Misc. Parts
Steering Column
Cab Sound Foam
Trainer Seat Mounting
Seat Installation, Sears Low Back
Seat Installation, Sears High Back
Seat Assembly, Base, Sears
Cab Air Ducting, Hvac System
Aircon Drier Unit & Piping
Aircon Unit
Aircon System, Front Chassis
Kit, Voac Mounting & Cover: B40
Kit, Voac Mounting & Cover: B35
Grill Kit - B35d
Grill Kit - B40d
Belly Plate Kit
Front Chassis Kit - B35d
Front Chassis Kit - B40d
Cab Clamps Kit
Front Chassis Clamps - Detail A
Front Chassis Clamps - Detail B
Rear Chassis Clamps
Full Handrails (Option)
Cap, Diesel Filler
Mudguard Kit, Lh - Detail A
Mudguard Kit, Lh - Detail B
Mudguard Kit, Rh - Detail A
Mudguard Kit, Rh - Detail B
Hydraulic Tank & Battery Box Kit - Detail A
Hydraulic Tank & Battery Box Kit - Detail B
Hydraulic Tank Filter Assembly
Front Suspension, Standard (Choice)
Link, Panhard, F/Susp, Standard
Suspension Struts, Standard (Choice)
Oscillation Joint Kit
Artic Joint
Rear Chassis Kit
Bin Pivot
Bin, Miscellaneous Parts
Rear Suspension, Standard (Choice)
Rear Suspension, Cride
Walking Beam, Obw, Standard (Choice)
Wet Disc Brake Tank
Wet Disc Brake Filter Assembly
Tailgate Kit
Bin Liner Kit
Front Chassis Grease Kit
Rear Chassis Grease Kit
Manual Greasing Kit
Tailgate Grease Kit
Decals (Sheet 1 Of 4)
Decals (Sheet 2 Of 4)
Decals (Sheet 3 Of 4)
Decals (Sheet 4 Of 4)
Section 8: Service Kits
Service Kits
Service Kits (Contd)
Section 9: Lubricants, Adhesivesand Paints
Lubricants
Adhesives
Paints And Procedures
Section 10: Special Tools
Engine - Om 501 Service Tools, Kit 262126
Engine - Om 501 Service Tools, Kit 262130
Engine - Om 501 Service Tools, Kit 262131
Engine - Om 501 Service Tools, Kit 262132
Allison Transmission
Gear Ratio 17000 Transfer Case
Axles, Diffs & Final Drives, Repair & Overhaul
Suspension, Repair & Overhaul
Hydraulics, Repair & Overhaul
Frame & Oscillation Tools
Diagnostic Tools (Driveline)
Tyre Inflation Kit (Optional)
Section 11: Automatic Greasingsystem
Kit, Auto Greasing (Optional)
Greasing System Hoses Layout
Greasing Installation Main Lines
Front Twin Distribution Port Block
Middle Twin Distribution Port Block
Rear Twin Distribution Port Block
Gina Programming Kit
Twin Pump Components
Section 12 : Numerical Index
