Bell Backhoe Loader 315SL Parts Manual BN054491
Brand: Bell
Model: Bell 315SL Pin 1.2 Backhoe Loader
VIN: AEBF877JX02000964
Part Number: BN054491
Publication Date: 2019
Number of Pages: 893 Pages
Bell Pages Layout - Left
Bell Pages Layout - Right
List Of Abbreviations
Other Abbreviations
Ordering Of Parts
Bulletins
Machine Dimensions
Serial Number Plates
Service Kits
Pin Identification
Group 0100 Wheels
0110 Wheel Set, Tlb 4x4 Industrial 267717
0110 Wheel Set, Tlb 4x4 Industrial 267716
0110 Wheel Set, Tlb 4x4 Heavy Duty 267688
0110 Wheel Set, Tlb 4x4 Heavy Duty 264308
0110 Wheel Set, Tlb 4x4 Industrial Bn039141
0110 Wheel Set, Tlb 4x4 Industrial Bn038753
0110 Front Wheel (4x2)
Axles, Diffs And Suspension Systems
Complete Rear Axle And Differential Assembly ( - 329327)
Complete Rear Axle And Differential Assembly (329328 - )
Differential And Rear Axle Housings
Rear Axle Cooling System Kit - 0200
Rear Axle Planetary Drive Pinion Carrier
Rear Spiral Bevel Input Pinion And Ring Gear Set
Differential Case And Gears (329328 - )
Differential Lock Control Switch
Front Axle Without Mfwd
Standard Front Axle Housing Without Mfwd
Swivel Housing And Steering Cylinder Without Mfwd
Front Wheel Hub Without Mfwd
Front Axle With Mfwd And Limited Slip Differential
Front Axle Housing With Mfwd
Differential, Front Axle
Limited Slip Differential, Front Axle
Front Axle With Mfwd And Open Differential
Front Axle Housing Hubs, Shafts, And Universal Joints With Mfwd
Front Axle Planetary Drive - 0240
Open Differential With Mfwd
Spiral Bevel Input Pinion And Ring Gear, Front Differential
Axle Mounting Hardware
Differential Lock Plumbing (303524 - )
Transmission Control Lever With Multi-Function
Mfwd Switch
Front Drive Shaft (303524 - )
Rear Drive Shaft (303524 - )
Transmission, Dipstick And Tube
Transmission Rear Housing And Oil Fill Tube
Transmission Front Housing And Torque Converter Cover
Torque Converter
Reverse Clutch And Input Shaft (Kr)
Low Range Forward Clutch Assembly (Kv)
First Speed Clutch Assembly (K1)
Second Speed Clutch Assembly (K2)
Third Speed Clutch Assembly (K3)
High Range Forward Clutch Assembly (K4)
Mechanical Front Wheel Drive Clutch Assembly
Transmission Output Shaft, Rear
Transmission Guard
Transmission Charge Pump
Transmission Oil Filter
Transmission Shift Control Solenoids
Transmission Speed Sensor
Transmission Mounting And Hardware
1118 Valve Cover
1229 Oil Filler Neck
1302 Crankshaft Pulley
1428 Flywheel Housing
1502 Flywheel
16ey Fuel Injection Pump
17dz Air Intake
1903 Oil Pan
2001 Water Pump Pulley
2101 Thermostat Cover
2201 Engine Thermostat
2698 Engine Coolant Heater Fittings
2816 Exhaust Manifold
2901 Vent System
30at Starter Motor
35eq Final Fuel Filter
3618 Front Plate
3701 Fuel Transfer Pump
4002 Engine Oil Dipstick
4429 Timing Gear Cover And Water Pump
4502 Balancer Shaft
4614 Cylinder Block
4706 Crankshaft And Bearings
4823 Connecting Rods And Pistons
4901 Valve Actuating Mechanism
5001 Engine Oil Pump
5102 Cylinder Head With Valves
5738 Water Pump Inlet
5954 Engine Oil Cooler
6282 Alternator Mounting
63aa Low Pressure Fuel Lines
65b7 Turbocharger
6698 Temperature Switch Plug
6710 Engine Sensors
7699 Oil Pressure Switch - Plug
8702 Belt Tensioner
8822 Engine Oil Filter
9801 Lift Straps
9901 Replacement Engine
9901 Short Block Assembly
Engine Auxiliary System
Engine Block Coolant Heater (220 Volt)
Cooling Package (Engine 4045tt096-Re545793) (303524 - )
Fan Shroud And Hoses (Engine 4045tt096-Re545793) (303524 - )
Oil Coolers And Plumbing (Engine 4045tt096-Re545793) (303524 - )
Cooling Package, Canopy And 1/4 Cab (329328 - )
Fan Package Without Air Conditioning (Engine 4045tt096-Re545793)
Fan Package With Air Conditioning (Engine 4045tt096-Re545793)
Foot Throttle Control
Air Intake System (Engine 4045tt096-Re545793)
Air Intake System
Exhaust System With Black Stack (Engine 4045tt096-Re545793)
Engine Mounting Hardware
Fuel System (329328 - )
Fuel Filter And Lines (329328 - )
Severe Duty Fuel Filter And Lines With Preheater (329328 - )
Engine Control Unit And Mounting (Engine 4045tt096-Re545793)
0910 Fixed Steering Column
Steering Hydraulic Valve With 9.7 Cubic Inch Displacement (329328 - )
Steering Hydraulic Valve With 7.3 Cubic Inch Displacement (329328 - )
Steering Hydraulics Without Mechanical Front Wheel Drive (329328 - )
Steering Hydraulics With Mechanical Front Wheel Drive, Mfwd (329328 - )
Steering Cylinder And Repair Kit With Mfwd
Service Brakes
Service Brake Clutch Disc And Disc Carrier
Brake Valve And Pedals (Xxxxxx - )
Brake Valve Assembly ( - Xxxxxx)
Service Brake Hydraulics (329328 - )
Brake Plumbing Clamps
Brake Valve Boost Hydraulics (329328 - )
Parking Brakes
Parking Brake Housing And Clutch Disc
Parking Brake Hydraulics (303524 - )
Miscellaneous Vehicle
1322 Decals
Vehicle Electrical Systems
Single Battery With Fuse (303524 - )
Single Battery Positive Cable
Jump Start Cover And Buss Bar
Single Battery Disconnect
Alternator 130a
Drive And Turn Signal Lights
Rear Tail Lights
1673 Rotating Beacon Kit
Beacon Pivot Bracket
Operators Station Wiring, Routing Hardware
Harness Mounting Bracket, Cab (303524 - )
Cab Wiring Harness Hardware (329328 - )
Cab Wiring Harness (329328 - )
Cab Fuse Box (329328 - )
Main Wiring Harness Hardware (329328 - )
Fron Wiring Harness (329328 - )
Front Wiring Harness (329328 - )
Transmission Wiring Harness Hardware
Ride Control Harness
Selective Flow Wiring Harness
Return To Dig Wiring
Horn Switch
Single Lever Loader Control Wiring Harness
Connector Cap Assemblies, Without Pilot Enable Harness
Multifunction Lever, Cab
Switch Plug Without Horn
Auxiliary Wiring Harness, Loader And Backhoe
High Beam Indicator
Backhoe Boom Lock Wiring
Anti-Theft Decal Kit
Flow Control Switch
Switch Plug Without Air Seat
Switch Plug Without Mechanical Front Wheel Drive
Switch Plug Without Start Aid
1600 Fleetmatic Option - Antenna
1600 Fleetmatic Option - Module
Auxiliary Valve Controller, Avc (329328 - )
Standard Display Monitor (Sdm)
Vehicle Control Unit, Vcu (329328 - )
Frame Chassis Or Supporting Structure
Main Frame (329328 - )
Full Mfwd Drive Shaft Guard
Counterweight Bolts, 204 Kg (450 Lbs)
Counterweight Bolts, 454 Kg (1000 Lbs)
Front Counterweight Kit, 204 Kg (450 Lbs.) ( - 303523)
Front Counterweight Kit, 454 Kg (1000 Lbs.) ( - 303523)
Stabilizer Cylinder And Repair Kit
Operator's Station
Front Console Seal
Roof With Lights
Roof With Wiring Harness And Led Lights
Operator Enclosure Isolators
Led Flood Light Kit
Led Spot Light Kit
Cab Rops
Cab Door, Right Hand
Cab Door, Left Hand
Headliner With Standard Radio
Headliner With Premium Radio
Headliner Without Radio
Cab Glass
Rear Cab Windows (303524 - )
Windshield Wiper Assembly
Windshield Washer Nozzle
Windshield Washer Reservoir
Rear Windshield Wiper System
Floor Covers And Mats, Cab With Manual Controls
Floor Covers And Premium Mats, Cab With Pilot Controls
Cab Right Hand Console Covers
Stabilizer Cover With Pilot Control - Cab (329328 - )
Console, Lh
Console And Loader Control Covers, Cab
1816 Steering Column Covers
Instrument Panel Console Cab
Backhoe Console
Backhoe Console, 2-Lever With Extended Dipperstick And Auxiliary
Mechanical Suspension Seat, Cloth (329328 - )
Seat Belt
Air Conditioning Harness And Switch
Defrost Control Switch (303524 - )
Heater Plumbing
Heater Components And Pressurizer
Defrost Control Switch ( - 303523)
Air Conditioning Compressor And Lines (Engine 4045tt096-Re545793) (329328 - )
Air Conditioning Compressor And Lines (329328 - )
Heating And Air Conditioning Ducts (303524 - )
Heater And Air Conditioning With Pressurizer (303524 - )
Air Conditioning Dryer And Lines (329328 - )
Air Conditioning Condenser And Lines (Engine 4045tt096-) (329328 - )
Cab Seals, Pilot Controls
Sheet Metal And Styling
Hood And Side Panels (319056 - )
Guard, Finger
Battery Enclosure And Tool Box (303524 - )
Grille Frame ( - 329327)
Rubber Bumper For Grille Frame Kit
Operator Station Fenders, Extended
Safety, Convenience And Miscellaneous
2002 Exterior Mirror
Interior Rear View Mirror, Front Mounted
Interior Front View Mirror, Rear Mounted
Fire Extinguisher Mounting Kit
Back-Up Alarm (320055 - )
Horn (303524 - )
Sun Visor
Sun Visor Kit
Loader Arm Service Lock Kit
Vehicle Main Hydraulic System
2161 Axle Cooling Pump
Main Hydraulic Plumbing (303524 - )
Power Beyond Hose For Manual Controls
Auto Idle Pressure Sensor
Steering Load Sense Hydraulics Without Loader Auxiliary (304845 - )
Hydraulic Oil Filter (289786 - )
Hydraulic Reservoir (289786 - )
Loader
3102 Multi-Purpose Bucket Cylinder And Repair Kit
3102 Multi-Purpose Bucket, Cylinder & Hydr Oil Lines
3102 Fork Assembly
3102 Loader Bucket And Cutting Edge
3102 Loader Bucket Pins
3102 Quick Coupler Forks And Frame
Loader Control, Single Lever With Auxiliary
Loader Control, Single Lever Without Auxiliary
Loader Control, Single Lever Kit
Loader Lift Arm
Loader Bucket Linkage
Loader Valve Linkage, Fourth Function
Loader Valve Linkage, Fifth Function
Loader Valve Linkage, Fifth Function With Electrohydraulic Auxiliary
Loader Valve, Fourth Function ( - 292973)
Loader Valve, Fourth Function (292974 - )
Loader Valve, Fifth Function With Electrohydraulic Auxiliary (292974 - )
Stabilizer Valve Circuit, Loader Valve (292974 - )
Boom Valve Circuit, Loader Valve
Bucket Valve Circuit, Loader Valve
Auxiliary Manual Valve Circuit, Loader Valve
Auxiliary Electrohydraulic Valve Circuit, Loader Valve
Loader And Stabilizer System Relief Valve Plug
Ride Control (303524 - )
Ride Control Plumbing Kit
Ride Control Valve
Manual Ride Control Valve Kit
Loader Auxiliary Control Kit, Single Lever (292975 - )
Loader Plumbing, Left Side Second And Third Function (303524 - )
Loader Plumbing, 2-Function Right Side
Loader Plumbing, 3-Function Right Side
Single Lever Loader Control Plumbing, Manual
Loader Auxiliary Plugs
Loader Boom Cylinders And Pins
Loader Bucket Cylinder
Multi-Purpose Loader Bucket Cylinder
Loader Bucket Leveling Linkage
Backhoe
3302 Backhoe Bucket (450mm, 0.14m3)
3302 Backhoe Bucket (610mm, 0.21m3)
3302 Buckets Pins And Bushes
3302 Trenching Buckets
3302 Ditch Cleaning Bucket
Two Lever Backhoe Control Valve Linkage
Fifth Function Pedal, 2-Lever
Backhoe Control Levers, Sae
Stabilizer Control (292974 - )
Swing Lock Pin
Swing Frame And Pins (303524 - )
Sliding Frame
Boom Lock Switch
Backhoe Boom Lock
Backhoe Boom
Boom Protection Plate Kit
Backhoe Bucket Links (304845 - )
Standard Dipperstick
Extendable Arm And Locking Pin ( - 303523)
Stabilizer Dirt Feet
4-Function Backhoe Control Valve (232970 - )
6-Function Backhoe Valve
Priority Inlet Section
Boom Control Valve Section
Bucket Control Valve Section
Crowd Section
Swing Section, Manual Backhoe Valve
Extendable Control Valve Section
Selective Flow Section
Side Shift Locking Valve
Auxiliary Selective Flow Valve Kit
Accu-Swing Valve Kit
Pilot Enable Pattern Select Valve (Peps) (329328 - )
Standard Dipperstick Hydraulics, Upper Section
Standard Dipperstick Hydraulics, Lower Section
Standard Dipperstick And Auxiliary Hydraulics, Upper Section
Standard Dipperstick And Auxiliary Hydraulics, Lower Section
Extendable Dipperstick Plumbing With Auxiliary Hydraulics, Upper Section
Extendable Dipperstick Plumbing With Auxiliary Hydraulics, Lower Section
Swing Cylinder Hydraulic Hoses And Fittings (304845 - )
Stabilizer Cylinder Hydraulics
Pilot Control Hydraulics (303524 - )
Pilot Enable Pattern Select Valve Hydraulics (329328 - )
Port Plugs, Six Function Backhoe Valve
Boom And Slide Lock Hydraulic, Pilot Controls (329328 - )
Boom And Slide Lock Hydraulic, Manual Controls (329328 - )
Auxiliary Equipment Hydraulics Kit, Standard Dipperstick
Auxiliary Equipment Hydraulics Kit, Extendable Dipperstick
Replacement Boom Cylinder
Standard Duty Bucket Cylinder, Shims, And Fitting
Heavy Duty Bucket Cylinder, Shims, And Fitting
Crowd Cylinder, Standard Dipperstick
Crowd Cylinder, Extendable Dipperstick
Swing Cylinders And Trunnion Block (304845 - )
Swing Cylinder (304845 - )
Stabilizer Cylinder
Extendable Dipperstick Cylinder
Brand: Bell
Other Abbreviations
Ordering Of Parts
Bulletins
Machine Dimensions
Service Kits
Pin Identification
Group 0100 Wheels
Mfwd Switch
Torque Converter
Transmission Guard
1118 Valve Cover
1502 Flywheel
17dz Air Intake
1903 Oil Pan
2901 Vent System
30at Starter Motor
3618 Front Plate
4502 Balancer Shaft
4614 Cylinder Block
65b7 Turbocharger
6710 Engine Sensors
8702 Belt Tensioner
9801 Lift Straps
Air Intake System
Service Brakes
Parking Brakes
1322 Decals
Alternator 130a
Rear Tail Lights
Horn Switch
High Beam Indicator
Flow Control Switch
Operator's Station
Front Console Seal
Roof With Lights
Led Flood Light Kit
Led Spot Light Kit
Cab Rops
Cab Door, Left Hand
Cab Glass
Console, Lh
Backhoe Console
Seat Belt
Heater Plumbing
Guard, Finger
Horn (303524 - )
Sun Visor
Sun Visor Kit
Loader
3102 Fork Assembly
Loader Lift Arm
Ride Control Valve
Backhoe
Swing Lock Pin
Sliding Frame
Boom Lock Switch
Backhoe Boom Lock
Backhoe Boom
Crowd Section
Stabilizer Cylinder
- Bell Equipment B35D & B40D Repair manual Dumptruck ( Articulated )
- Bell Articulated Dump Truck B25D B30D 6x6 Repair Manual
- Bell Equipment B35D & B40D operation test manual Dumptruck ( Articulated )
- Bell Articulated Dump Truck B30E PIN A830E11 Parts Manual
- Bell Dumptruck Parts Manual B40D 6X6,ADT - 413840 B35D 6X6,OBW,ADT - 413835 B35D 6X6,OBW,WDB,ADT - 4
- Bell Equipment B30D MkVI ADT - A830D60 Parts Manual
- Bell DUMPTRUCK Operators manual
- Bell equipment
- Bell Equipment B25D Mk7.2 ADT - EA825D72 872335 Parts Manual
- Bell Equipment ARTICULATED DUMP TRUCK B25E PIN A825E22 Parts Manual
- Bell Articulated Dump Truck B25D & B30D 6x6 Repair Manual
- Bell Equipment B50D 6X6 SS ADT MK VI - A850D60 872241 Parts Manual
- BELL E-SERIES B18E B30E Articulated Dump Truck Operator's Manual 872353 REV A
- BELL E-SERIES B18E B30E Articulated Dump Truck Service Manual 872352 REV A
- Bell Equipment AH350D-400D Technical Manual
