Bell Backhoe Loader 315SL MKII Parts Manual 874111
Brand: Bell
Model: Bell 315SL MKII Backhoe Loader
VIN: AEBF877JX02000964
Part Number: 874111
Publication Date: 2010
Number of Pages: 594 Pages
Location Of Operations
Users Comments
Content Overview
Page Layout
List Of Abbreviations
Ordering Of Parts
Bulletins
Machine Dimension
Serial Number Plates
Service Kits (Changes Done On 03/08/2010)
Pin Identification
Group 0100 Wheels
Rear Drive Wheel - 0110
Front Wheel (4x4) - 0110
Front Wheel (4x2) - 0110
Wheel Spanner (4x4) - 0110
Wheel Spanner (4x2) - 0110
Group 0200 Axles, Diffs And Suspensions
Complete Rear Axle And Differential Assembly - 0201
Differential And Rear Axle Housings - 0201
Rear Axle Planetary Drive Pinion Carrier - 0201
Spiral Bevel Input Pinion And Ring Gear Set - 0210
Differential Case And Gears - 0210
Differential Lock Plumbing - 0210
Standard Front Axle (W/O Mfwd) - 0230
Standard Front Axle Housing (W/O Mfwd) - 0230
Swivel Housings & Steering Cylinder (W/O Mfwd) - 0230
Wheel Hub (W/O Mfwd) - 0230
Front Axle (W/Mfwd) - 0250
Front Axle Housing And Tie Rods (W/Mfwd) - 0250
Frt Axle Hsing Hubs, Shafts & Univ Joints (W/Mfwd)- 0250
Planetary Drive (W/Mfwd) - 0250
Limited Slip Differential (W/Mfwd) - 0250
Fr Spiral Bevel Input Pinion & Ring Gear (W/Mfwd) - 0250
Drive Shaft (W/Mfwd) - 0250
Group 0300 Transmission
Transmission Control Lever - 0315
Rear Driveshaft - 0325
Transmission Rear Housing And Oil Fill Tube - 0341
Transm Fr Housing & Torque Converter Cover - 0341
Transmission, Dipstick And Tube - 0341
Transmission Guard - 0341
Transmission Rear Mounting Support - 0342
Torque Converter - 0350
Transmission Input Shaft And Clutch Disk - 0350
Low Range Forward Clutch Assembly - 0350
High Range Forward Clutch Assembly - 0350
First Speed Clutch Assembly - 0350
Second Speed Clutch Assembly - 0350
Third Speed Clutch Assembly - 0350
Mechanical Front Wheel Drive Clutch Assembly - 0350
Transmission Output Shaft - 0350
Transmission Charge Pump - 0360
Transmission Oil Filter - 0360
Transmission Shift Control Solenoids - 0360
Group 0400 Engine
Camshaft - 0400
Crankshaft / Bearings - 0400
Rocker Arm / Shaft / Tappet / Push Rod - 0400
Rocker Arm Cover - 0400
Timing Gear Cover, Water Pump - 0400
Piston / Connecting Rod / Cylinder Liner - 0400
Front Plate - 0400
Cylinder Block - 0400
Oil Filler Neck - 0400
Engine Oil Dipstick - 0400
Oil Pan - 0400
Oil Filter - 0400
Oil Pump - 0400
Ventilating System - 0400
Cylinder Head - 0400
Exhaust Manifold - 0400
Fuel Injection Nozzles And Lines - 0400
Fuel Filter 2000 - 0420 (Changes Done On 03/08/2010)
Fuel Injection Pump, Lines And Engine Controller - 0400
Fuel Injection Pump - 0400
Water Pump Pulley - 0400
Water Pump Kit - 0400
Thermostat / Cover - 0400
Fuel Filter - 0400
Fuel Lines - 0400
Fuel Transfer Pump - 0400
Starting Motor - 0400
Guide, Starting Motor - 0400
Alternator Brackets - 0400
Flywheel - 0400
Turbocharger - 0400
Turbocharger Oil Lines - 0400
Engine Overhaul Kit - 0400
Engine Gasket Kit - 0400
Group 0500 Engine Auxiliary System
Radiator, Hoses, Fan Shroud And Guard - 0510
A/C Fan Package And Basic Fan Package - 0510
Electrical Accelerator - 0515
Air Cleaner And Mounting Brackets - 0520
Pre Cleaner - 0520
Exhaust Extension And Muffler (W/ Turbo) - 0530
Engine Mounting Supports - 0540
Fuel Tank And Fuel Tank Hoses - 0560
Group 0900 Steering System
Steering Cylinder And Repair Kit (W/Mfwd) - 0960
Steering Wheel And Tilt Column - 0960
Steering Column Standard- 0960
Steering Hydraulics Valve - 0960
Steering Hydraulics Plumbing (W/ Mfwd) - 0960
Steering Hydraulics Plumbing (W/O Mfwd) - 0960
Group 1000 Service Brakes
Service Brake Clutch Disc And Disc Carrier - 1011
Brake Valve And Pedals - 1060
Brake Valve Assembly - 1060
Service Brake Hydraulics - 1060
Brake Valve Boost Plumbing (Cab) - 1060
Parking Brake Plumbing - 1111
Parking Brake Housing And Clutch Disc - 1111
Group 1300 Miscellaneous Vehicle
Loader Arm Service Lock - 1313
License Plate Lamp And Rear Lights - 1314
Trademarks And Labels (4x2) - 1320
Trademarks And Labels (4x4) - 1320
Group 1600 Vehicle Electrical Systems
Single Battery Installation - 1671
Dual Battery Installation - 1671(Optional)
Master Battery Disconnect - 1671
Alternator - 1672
Rotating Beacon - 1673
Roof With Standard Lighting Option - 1673
Roof With Deluxe Lighting Option - 1673
Head Lights And Mirror - 1674(Up To Vin 1054)
Head Lights W/O Mirror - 1674(From Vin 1055)
Side Console Harness - 1674
Side Console Wiring Harnesses - 1674
Side Console Switches - 1674
Instrument Panel Side Console - 1674
Pump Control Relay - 1674
Loader Coupler Electrical And Anti-Theft - 1675
Group 1700 Frame, Chassis Or Supporting Structure
Main Frame With Stabilizer - 1740
Main Frame Guards - 1740
Front Counterweight - 1749
Bumper - 1747
Bumper - 1747
Group 1800 Operator’s Station
Rops Canopy Headliner And Mounting Isolators - 1811
Cab Frame, Headliner & Cab Mounting Isolators - 1811
Floor Mats - 1812
Doors And Side Windows For Cab - 1814
Windshield Glass For Cab - 1814
Sliding Rear Windows And Corner Windowpanes - 1814
Front Windshield Wiper System - 1814
Front Windshield Washer Reservoir And Pump - 1814
Rear Windshield Wiper System - 1814
Backhoe Control Console (Two Lever) - 1816
Steering Column Covers - 1816
Front Console (Cab Or Canopy) - 1816
Side Instrum Panel Hsing & Stabilizer Cntl Cover - 1816(Canopy)
Side Instrum Panel Hsing & Stabilizer Cntl Cover - 1816(Cab)
Seat / Armrest - 1821
Seat Slide And Adjuster Control Levers - 1821
Seat Swivel And Swivel Latch - 1821
Seat Suspension - 1821
Seat Belt - 1821
Air Suspension Seat And Shock Absorber - 1821
Suspension Seat - 1821
Heater Plumbing (Engine Tt094) - 1830
Cab Heater And Air Conditioning Ducting - 1830
Heater And Air Conditioning With Pressurizer - 1830 (Changes Done On 24/01/2011)
Air Conditioning Hardware & Hoses - 1830
Heat And Noise Barrier - 1834
Group 1900 Sheet Metal And Styling
Hood And Side Panels - 1910
Battery Enclosure And Tool Box - 1913
Grille Frame Bumpers - 1921
Operator Station Fenders And Skirts - 1927
Group 2000 Safety, Convenience And Miscellaneous
External Mirror - 2002(From Vin 1055)
Interior Front View Mirror (Rear Mounted) - 2002
Interior Rear View Mirror (Front Mounted) - 2002
Fire Extinguiser - 2003
Back-Up Alarm System - 2004
Horn - 2004
Sun Visor - 2007
Group 2100 Vehicle Main Hydraulic System
Main Hydraulic Pump - 2160
Hydraulic Oil Cooler And Hoses - 2160
Hydraulic Oil Filter - 2160 (Up To Vin 1297)
Hydraulic Oil Filter - 2160 (From Vin 1298
Main Hydraulic System Reservoir - 2160
Main Hydraulic System - 2160 (Up To Vin 1297)
Main Hydraulic System (Up To Vin 1297) - 2160
Main Hydraulic System (From Vin 1298) - 2160
Ride Control Kit - 2160
Group 3100 Loader
Multi-Purpose Bucket Cylinder And Repair Kit - 3102
Multi-Purpose Bucket - 3102
Multi-Purpose Bucket, Cylinder & Hydr Oil Lines - 3102
Loader Bucket And Cutting Edge - 3102
Quick Coupler Forks And Frame - 3102
Hydraulic Front Coupler - 3102
Front Coupler Cylinder - 3104
Bucket Leveling And Return-To-Dig Linkage - 3115
Loader Control Valve Linkage - 3115
Third Function Loader Control Valve Linkage - 3115
Loader Lift Arm - 3143
Loader Bucket Linkage - 3143
Loader Control Valve - 3162
Boom Section (Loader/Stabilizer Valve) - 3162
Bucket Section (Loader Valve) - 3162
Auxiliary Section (Loader/Stabilizer Valve) - 3162
Stabilizer/Loader Valve - 3162
Loader Boom Lift Cylinder Hydraulics - 3163
Loader Bucket Cylinder & Third Function Hydr - 3163
Loader Bucket Cylinder & Repair Kits - 3165
Boom Lift Cylinder And Repair Kits- 3165
Boom Lift Cylinder Hardware- 3165
Hydraulic Front Coupler - 3163
Hydraulic Front Coupler Valve - 3163
Group 3300 Backhoe
Quick Coupler (Universal) - 3302
Backhoe Buckets - 3302
Buckets Pins And Bushes - 3302
Trenching Buckets - 3302
Ditch Cleaning Bucket - 3302
Stabilizer Valve Linkage - 3315
Two Lever Control Lever Valve Conversion Kit - 3315
Fifth Function Pedal - 3315
Backhoe Boom Lock Control Lever And Linkage - 3315
Backhoe Valve Mounting Plate - 3360
Sliding Frame Plate And Component - 3360
Hose Routing - 3360
Sliding Frame Plate And Fitting - 3360
Sliding Frame - 3342 (Changes Done On 24/01/2011)
Cylinder Lock Assembly - 3342
Swing Frame And Pins - 3343
Backhoe Boom - 3344
Boom Protection Plate - 3344
Backhoe Bucket Links - 3345
Standard Dipperstick - 3346
Extendible Arm And Locking Pin - 3346
Backhoe Control Valve - 3362
Priority Inlet Section - 3362
Boom Section - 3362
Bucket Section - 3362
Crowd Section - 3362
Swing Section - 3362
Extendible Section - 3362
Selective Flow Section - 3362
Auxiliary Section - 3362
Locking Control Valve - 3362
Lock Hydraulics And Hose - 3362
Backhoe Boom Lock Control Lever & Linkage - 3315
Fifth Function Manual Valve Kit - 3362
Sixth Function Manual And Pilot Control Kit - 3362
Stabilizer Cylinder Hydraulics - 3363
Boom Cylinder, Hydraulic Hoses And Fittings - 3363
Bucket Cylinder Hydraulic Hoses, Lines & Fittings - 3363(Standard Dipperstick)
Crowd Cylinder Hydraulic Hoses And Fittings - 3363
Swing Cylinder Hydraulic Hoses And Fittings - 3363
Auxiliary Equipment Hydraulic Hoses And Fittings - 3363(Standard Dipperstick)
Auxiliary Equipment Hydraulic Hoses And Fittings - 3363(Extendible Dipperstick)
Attachment Plumbing Kit - 3363
Bucket Cylinder And Repair Kit (Heavy Duty) - 3365
Bucket Cylinder And Repair Kit - 3365
Crowd Cylinder And Repair Kit - 3365
Crowd Cylinder And Repair Kit - 3365 (From Vin 1438) (Only Used On Std Dippers) (Pg Added On 01/09/2010)
Swing Cylinder And Repair Kit - 3365
Stabilizer Cylinder & Repair Kit - 3365(Standard Stabilizer)
Group 9000 General Backhoe
Low Noise Package - 9006
Brand: Bell
Part Number: 874111
Users Comments
Content Overview
Page Layout
Ordering Of Parts
Bulletins
Machine Dimension
Pin Identification
Group 0100 Wheels
Group 0400 Engine
Camshaft - 0400
Front Plate - 0400
Oil Pan - 0400
Oil Filter - 0400
Oil Pump - 0400
Fuel Filter - 0400
Fuel Lines - 0400
Flywheel - 0400
Turbocharger - 0400
Pre Cleaner - 0520
Alternator - 1672
Bumper - 1747
Bumper - 1747
Floor Mats - 1812
Seat Belt - 1821
Horn - 2004
Sun Visor - 2007
Group 3100 Loader
Group 3300 Backhoe
Hose Routing - 3360
Backhoe Boom - 3344
Boom Section - 3362
- Bell Equipment B35D & B40D Repair manual Dumptruck ( Articulated )
- Bell Articulated Dump Truck B25D B30D 6x6 Repair Manual
- Bell Equipment B35D & B40D operation test manual Dumptruck ( Articulated )
- Bell Articulated Dump Truck B30E PIN A830E11 Parts Manual
- Bell Dumptruck Parts Manual B40D 6X6,ADT - 413840 B35D 6X6,OBW,ADT - 413835 B35D 6X6,OBW,WDB,ADT - 4
- Bell Equipment B30D MkVI ADT - A830D60 Parts Manual
- Bell DUMPTRUCK Operators manual
- Bell equipment
- Bell Equipment B25D Mk7.2 ADT - EA825D72 872335 Parts Manual
- Bell Equipment ARTICULATED DUMP TRUCK B25E PIN A825E22 Parts Manual
- Bell Articulated Dump Truck B25D & B30D 6x6 Repair Manual
- Bell Equipment B50D 6X6 SS ADT MK VI - A850D60 872241 Parts Manual
- BELL E-SERIES B18E B30E Articulated Dump Truck Operator's Manual 872353 REV A
- BELL E-SERIES B18E B30E Articulated Dump Truck Service Manual 872352 REV A
- Bell Equipment AH350D-400D Technical Manual
