Bell Backhoe Loader 315SK Parts Manual 873089
Brand: Bell
Model: Bell 315SK Backhoe Loader
VIN: AEBF877JX02000964
Part Number: 873089
Publication Date: 2012
Number of Pages: 686 Pages
Page Layout (Left)
Page Layout (Right)
List Of Abbreviations
Ordering Of Parts
Bulletins
Machine Dimensions
Serial Number Plates
Service Kits
Pin Identification
Group 0100 Wheels
Front Wheel (4x4) - 0110 (267717 W/Set Industrial)
Rear Drive Wheel (4x4) - 0110
Front Wheel (4x4) - 0110 (267716 W/Set Industrial)
Front Wheel (4x4) - 0110 (267688 W/Set Heavy Duty, L4)
Front Wheel (4x4) - 0110 (264308 W/Set Heavy Duty, L3)
Front Wheel (4x4) - 0110 (264309 W/Set Industrial)
Front Wheel (4x4) - 0110 (264307 W/Set Agriculture)
Front Wheel (4x2) - 0110
Wheel Spanner (4x4) - 0110
Wheel Spanner (4x2) - 0110
Group 0200 Axles, Diffs And Suspensions
Complete Rear Axle And Differential Assembly - 0201
Differential And Rear Axle Housings - 0201
Rear Axle Planetary Drive Pinion Carrier - 0201
Rear Axle Cooling System Kit - 0200
Spiral Bevel Input Pinion And Ring Gear Set - 0210
Differential Case And Gears - 0210
Differential Lock Plumbing - 0210
Driveshaft (Mfwd) - 0225
Standard Front Axle (W/O Mfwd) - 0230
Standard Front Axle Housing (W/O Mfwd) - 0230
Swivel Housings & Steering Cylinder (W/O Mfwd) - 0230
Wheel Hub (W/O Mfwd) - 0230
Front Axle (W/Mfwd) - 0250
Front Axle Housing And Tie Rods (W/Mfwd) - 0250
Frt Axle Hsing Hubs, Shafts & Univ Joints (W/Mfwd)- 0250
Planetary Drive (W/Mfwd) - 0250
Limited Slip Differential (W/Mfwd) - 0250
Fr Spiral Bevel Input Pinion & Ring Gear (W/Mfwd) - 0250
Group 0300 Transmission
Side Console Switches - 0315
Transmission Control Lever - 0315
Rear Driveshaft - 0325
Transmission Rear Housing And Oil Fill Tube - 0341
Transm Fr Housing & Torque Converter Cover - 0341
Transmission, Dipstick And Tube - 0341
Transmission Guard - 0341
Engine Mounting Support - 0341
Torque Converter - 0341
Transmission Input Shaft And Clutch Disk - 0341
Low Range Forward Clutch Assembly - 0341
High Range Forward Clutch Assembly - 0341
First Speed Clutch Assembly - 0341
Second Speed Clutch Assembly - 0341
Third Speed Clutch Assembly - 0341
Mechanical Front Wheel Drive Clutch Assembly - 0341
Transmission Output Shaft - 0341
Transmission Charge Pump - 0341
Transmission Oil Filter - 0341
Transmission Speed Sensor - 0341
Transmission Shift Control Solenoids - 0341
Transmission Rear Mounting Support - 0342
Group 0400 Engine
4706 Crankshaft / Bearings - 0400
1302 Crankshaft Pulley - 0400
4901 Rocker Arm / Shaft / Tappet / Push Rod - 0400
1118 Rocker Arm Cover - 0400
4429 Timing Gear Cover, Water Pump - 0400
4823 Pistons / Connecting Rod - 0400
3618 Front Plate - 0400
4502 Balancer Shaft - 0400
4614 Cylinder Block - 0400
1229 Oil Filler Neck - 0400
4002 Engine Oil Dipstick - 0400
5954 Oil Cooler - 0400
1903 Oil Pan - 0400
8822 Oil Filter - 0400
5001 Oil Pump - 0400
7699 Oil Pressure Switch (Plug) - 0400
8702 Belt Tensioner - 0400
2901 Ventilating System - 0400
5102 Cylinder Head & Valves - 0400
2816 Exhaust Manifold - 0400
16ey Fuel Injection Pump - 0400
17dz Air Intake - 0400
2001 Water Pump Pulley - 0400
5738 Water Pump Inlet - 0400
6698 Water Temperature Sensor Plug - 0400
6710 Tachometer Switch And Wiring - 0400
2201 Thermostat - 0400
2101 Thermostat Cover - 0400
6282 Alternator Mounting - 0400
9801 Lift Straps - 0400
2698 Engine Coolant Heater - 0400
35eq Fuel Filter - 0400
63aa Fuel Lines - 0400
3701 Fuel Transfer Pump - 0400
30 At Starting Motor - 0400
1502 Flywheel - 0400
1428 Flywheel Housing - 0400
65b7 Turbocharger - 0400
Group 0500 Engine Auxiliary System
Cooling Package - 0510
Oil Coolers And Plumbing - 0510
Fan Shroud And Hoses - 0510
Fan Drive Assembly - 0512
Fan Package W/O Air Conditioning - 0512
Fan Package W/ Air Conditioning - 0512
Electrical Accelerator - 0515
Air Intake System - 0520
Exhaust System With Black Stack - 0530
Fuel Filter And Lines - 0560
Fuel System - 0560
Group 0900 Steering System
Tilt Steering Column - 0962
Steering Hydraulics Valve - 0962
Steering Valve - 0962
Steering Hydraulics Plumbing (W/ Mfwd) - 0960
Steering Hydraulics Plumbing (W/O Mfwd) - 0960
Steering Cylinder And Repair Kit (W/ Mfwd) - 0965
Group 1000 Service Brakes
Brake Valve And Pedals - 1062
Brake Valve Assembly - 1062
Service Brake Hydraulics - 1063
Brake Valve Boost Plumbing (Cab) - 1063
Parking Brake Housing And Clutch Disc - 1111
Parking Brake Plumbing - 1163
Group 1300 Miscellaneous Vehicle
Loader Arm Service Lock - 1313
License Plate Lamp And Rear Lights - 1314
Environmental Drain Kit - 1369
Labels And Decals (4 X 2) - 1322
Labels And Decals (4 X 4) - 1322
Labels And Decals (Cab) - 1322
Group 1600 Vehicle Electrical Systems
Single Battery W/ Fuse - 1671
Single Battery Negative Cable - 1671
Jump Start Kit - 1671
Disconnect Hardware - 1671
Single Battery Disconnect - 1671
Dual Battery Disconnect - 1671
Alternator - 1672
Drive Lights - 1673
Rotating Beacon - 1673
Operator's Station Wiring, Routing Hardware - 1674
Cab Wiring Harness - 1674
Cab Wiring Harness Hardware - 1674
Cab Fuse Box - 1674
Engine Wiring Harness - 1674
Engine Wiring Harness Hardware - 1674
Transmission Wiring Harness - 1674
Loader, Auxiliary Controls - 1674
Backhoe Boom Lock Wiring - 1674
Vehicle Controller - 1675
Engine Controller - 1675
Differential Lock Control Switch - 1675
Return-To-Dig Wiring - 1675
Switch Plug W/O Air Seat - 1675
Switch Plug W/O Mfwd - 1675
Switch Plug W/O Start Aid - 1675
Plug,Beacon - 1675
Standard Display Monitor - 1676
Group 1700 Frame, Chassis Or Supporting Structure
Main Frame - 1741
Front Bumper - 1747
Counterweight Bolts - 1749
Counterweight Kit - 1749
Group 1800 Operator’s Station
Front Console Seal - 1807
Cab Headliner W/O Radio - 1810
Roof With Lights - 1810
Operator Enclosure Isolators - 1810
Cab Seals - 1810
Cab Seals, Manual Controls - 1810
Cab (Manual Controls) - 1811
Cab Glass - 1811
Door Lh (Cab) - 1811
Door Rh (Cab) - 1811
Cab Floor Covers And Mats - 1812
Rear Cab Windows - 1813
Windshield Wiper Assembly - 1814
Windshield Washer Nozzle - 1814
Windshield Washer Reservoir - 1814
Rear Windshield Wiper System - 1814
Instrument Panel Console, Cab - 1816
Cab Console With A/C - 1816
Cab Right-Hand Console Covers - 1816
Tilt Steering Column Covers - 1816
Console, Backhoe - 1816
Console, Backhoe, 2 Lever, Ext Dipperstick, Aux - 1816
Mechanical Suspension Seat, Cloth - 1821
Seat Belt - 1821
Air Conditioning Harness And Switch - 1830
Heater Components And Pressurizer - 1831
Heater Plumbing - 1831
Defrost Control Switch - 1831
Air Conditioning System - 1832
Air Conditioning Unit - 1832
Heating & Air Conditioning Ducts - 1833
Heater & Air Conditioning W/ Pressurizer - 1833
Group 1900 Sheet Metal And Styling
Hood And Side Panels - 1910
Battery Enclosure And Toolbox - 1913
Fan Guard W/O Battery Disconnect - 1921
Grille Frame - 1921
Grille Support & Fan Guard With A/C - 1921
Operator Station Fenders - 1927
Group 2000 Safety, Convenience And Miscellaneous
External Mirror - 2002
Interior Rear View Mirror (Front Mounted) - 2002
Fire Extinguiser Mounting Kit - 2003
Back-Up Alarm System - 2004
Horn - 2004
Sun Visor - 2007
Group 2100 Vehicle Main Hydraulic System
Main Hydraulic Pump - 2160
Main Hydraulic Plumbing - 2163
Steering Hydraulics - 2163
Auto Idle Pressure Sensor - 2163
Hydraulic Reservoir - 2164
Hydraulic Oil Filter - 2164
Group 3100 Loader
Multi-Purpose Bucket Cylinder And Repair Kit - 3102
Multi-Purpose Bucket - 3102
Multi-Purpose Bucket, Cylinder & Hydr Oil Lines - 3102
Loader Bucket And Cutting Edge - 3102
Loader Bucket Pins - 3102
Quick Coupler Forks And Frame - 3102
Hydraulic Front Coupler - 3102
Front Coupler Cylinder - 3104
Bucket Leveling And Return-To-Dig Linkage - 3115
Loader Control Valve Linkage - 3115
Third Function Loader Control Valve Linkage - 3115
Loader Controls, 3-Function Pilot - 3115
Loader Lift Arm - 3143
Loader Bucket Linkage - 3143
Ride Control Kit - 3162
Loader Control Valve - 3162
Boom Section (Loader/Stabilizer Valve) - 3162
Bucket Section (Loader Valve) - 3162
Auxiliary Section (Loader/Stabilizer Valve) - 3162
Stabilizer/Loader Valve - 3162
Loader Boom Lift Cylinder Hydraulics - 3163(2-Function)
Loader Bucket Cylinder & Third Function Hydr - 3163
Ride Control Accumulator Mounting Hardware - 3163
Loader Bucket Cylinder (20292
- 3165
Boom Lift Cylinder- 3165
Boom Lift Cylinder Hardware- 3165
Hydraulic Front Coupler - 3163
Hydraulic Front Coupler Valve - 3163
Group 3300 Backhoe
Quick Coupler (Universal) - 3302
Backhoe Bucket (450mm, 0.14m3) - 3302
Backhoe Bucket (610mm, 0.21m3) - 3302
Buckets Pins And Bushes - 3302
Trenching Buckets - 3302
Ditch Cleaning Bucket - 3302
Stabilizer Valve Linkage - 3315
Two Lever Control Lever Valve Conversion Kit - 3315
Fifth Function Pedal - 3315
Backhoe Boom Lock Control Lever And Linkage - 3315
Backhoe Valve Mounting Plate - 3360
Hose Routing - 3360
Sliding Frame Plate And Fitting - 3360
Sliding Frame - 3342
Cylinder Lock Assembly - 3342
Swing Frame And Pins - 3343
Backhoe Boom - 3344
Boom Protection Plate - 3344
Backhoe Bucket Links - 3345
Standard Dipperstick - 3346
Extendible Arm And Locking Pin - 3346
Backhoe Control Valve - 3362
Priority Inlet Section - 3362
Boom Section - 3362
Bucket Section - 3362
Crowd Section - 3362
Swing Section - 3362
Extendible Section - 3362
Selective Flow Section - 3362
Auxiliary Section - 3362
Locking Control Valve - 3362
Lock Hydraulics And Hoses - 3362
Side Shift Lock Hydraulics - 3363
Backhoe Boom Lock Control Lever & Linkage - 3315
Fifth Function Manual Valve Kit - 3362
Sixth Function Manual And Pilot Control Kit - 3362
Stabilizer Cylinder Hydraulics - 3363
Boom Cylinder, Hydraulic Hoses And Fittings - 3363
Bucket Cylinder Hydraulic Hoses, Lines & Fittings - 3363(Standard Dipperstick)
Crowd Cylinder Hydraulic Hoses And Fittings - 3363
Swing Cylinder Hydraulic Hoses And Fittings - 3363
Auxiliary Equipment Hydraulic Hoses And Fittings - 3363(Standard Dipperstick)
Auxiliary Equipment Hydraulic Hoses And Fittings - 3363(Extendible Dipperstick)
Attachment Plumbing Kit - 3363
Bucket Cylinder And Repair Kit (Heavy Duty) - 3365
Bucket Cylinder And Repair Kit - 3365
Crowd Cylinder And Repair Kit - 3365
Crowd Cylinder And Repair Kit - 3365(Only Used On Std Dippers)
Swing Cylinder And Repair Kit - 3365
Stabilizer Cylinder & Repair Kit - 3365(Standard Stabilizer)
Group 9000 General Backhoe
Low Noise Package - 9006
Brand: Bell
Part Number: 873089
Page Layout (Left)
Page Layout (Right)
Ordering Of Parts
Bulletins
Machine Dimensions
Service Kits
Pin Identification
Group 0100 Wheels
Group 0400 Engine
1903 Oil Pan - 0400
Fuel System - 0560
Alternator - 1672
Drive Lights - 1673
Cab Fuse Box - 1674
Plug,Beacon - 1675
Main Frame - 1741
Front Bumper - 1747
Cab Seals - 1810
Cab Glass - 1811
Seat Belt - 1821
Grille Frame - 1921
Horn - 2004
Sun Visor - 2007
Group 3100 Loader
Group 3300 Backhoe
Hose Routing - 3360
Backhoe Boom - 3344
Boom Section - 3362
- Bell Equipment B35D & B40D Repair manual Dumptruck ( Articulated )
- Bell Articulated Dump Truck B25D B30D 6x6 Repair Manual
- Bell Equipment B35D & B40D operation test manual Dumptruck ( Articulated )
- Bell Articulated Dump Truck B30E PIN A830E11 Parts Manual
- Bell Dumptruck Parts Manual B40D 6X6,ADT - 413840 B35D 6X6,OBW,ADT - 413835 B35D 6X6,OBW,WDB,ADT - 4
- Bell Equipment B30D MkVI ADT - A830D60 Parts Manual
- Bell DUMPTRUCK Operators manual
- Bell equipment
- Bell Equipment B25D Mk7.2 ADT - EA825D72 872335 Parts Manual
- Bell Equipment ARTICULATED DUMP TRUCK B25E PIN A825E22 Parts Manual
- Bell Articulated Dump Truck B25D & B30D 6x6 Repair Manual
- Bell Equipment B50D 6X6 SS ADT MK VI - A850D60 872241 Parts Manual
- BELL E-SERIES B18E B30E Articulated Dump Truck Operator's Manual 872353 REV A
- BELL E-SERIES B18E B30E Articulated Dump Truck Service Manual 872352 REV A
- Bell Equipment AH350D-400D Technical Manual
