Bell Backhoe Loader 315SJ MKII Parts Manual 874111
Brand: Bell
Model: Bell 315SJ MKII Backhoe Loader
VIN: AEBF877JX02000964
Part Number: 874111
Publication Date: 2010
Number of Pages: 594 Pages
Location Of Operations
Users Comments
Content Over View
Table Of Contents
Page Layout
List Of Abbreviations
Ordering Of Parts
Bulletins
Machine Dimension
Serial Number Plates
Service Kits
Pin Identification
Group 0100 Wheels
Rear Drive Wheel - 0110
Front Wheel (4x4) - 0110
Front Wheel (4x2) - 0110
Wheel Spanner (4x4) - 0110
Wheel Spanner (4x2) - 0110
Group 0200 Axles, Diffs And Suspensions
Complete Rear Axle And Differential Assembly - 0201
Differential And Rear Axle Housings - 0201
Rear Axle Planetary Drive Pinion Carrier - 0201
Spiral Bevel Input Pinion And Ring Gear Set - 0210
Spiral Bevel Input Pinion And Ring Gear Set (Cont) - 0210
Differential Case And Gears - 0210
Differential Lock Plumbing - 0210
Standard Front Axle (W/O Mfwd) - 0230
Standard Front Axle Housing (W/O Mfwd) - 0230
Swivel Housings & Steering Cylinder (W/O Mfwd) - 0230
Wheel Hub (W/O Mfwd) - 0230
Front Axle (W/Mfwd) - 0250
Front Axle Housing And Tie Rods (W/Mfwd) - 0250
Frt Axle Hsing Hubs, Shafts & Univ Joints (W/Mfwd)- 0250
Planetary Drive (W/Mfwd) - 0250
Limited Slip Differential (W/Mfwd) - 0250
Fr Spiral Bevel Input Pinion & Ring Gear (W/Mfwd) - 0250
Drive Shaft (W/Mfwd) - 0250
Group 0300 Transmission
Transmission Control Lever - 0315
Rear Driveshaft - 0325
Transmission Rear Housing And Oil Fill Tube - 0341
Transm Fr Housing & Torque Converter Cover - 0341
Transmission, Dipstick And Tube - 0341
Transmission Guard - 0341
Transmission Rear Mounting Support - 0342
Torque Converter - 0350
Transmission Input Shaft And Clutch Disk - 0350
Low Range Forward Clutch Assembly - 0350
High Range Forward Clutch Assembly - 0350
First Speed Clutch Assembly - 0350
Second Speed Clutch Assembly - 0350
Third Speed Clutch Assembly - 0350
Mechanical Front Wheel Drive Clutch Assembly - 0350
Transmission Output Shaft - 0350
Transmission Charge Pump - 0360
Transmission Oil Filter - 0360
Transmission Shift Control Solenoids - 0360
Group 0400 Engine
Camshaft - 0400
Crankshaft / Bearings - 0400
Rocker Arm / Shaft / Tappet / Push Rod - 0400
Rocker Arm Cover - 0400
Timing Gear Cover, Water Pump - 0400
Piston / Connecting Rod / Cylinder Liner - 0400
Front Plate - 0400
Cylinder Block - 0400
Oil Filler Neck - 0400
Engine Oil Dipstick - 0400
Oil Pan - 0400
Oil Filter - 0400
Oil Pump - 0400
Ventilating System - 0400
Cylinder Head - 0400
Exhaust Manifold - 0400
Fuel Injection Nozzles And Lines - 0400
Fuel Filter 2000 - 0420
Fuel Injection Pump, Lines And Engine Controller - 0400
Fuel Injection Pump - 0400
Water Pump Pulley - 0400
Water Pump Kit - 0400
Thermostat / Cover - 0400
Fuel Filter - 0400
Fuel Lines - 0400
Fuel Transfer Pump - 0400
Starting Motor - 0400
Guide, Starting Motor - 0400
Alternator Brackets - 0400
Flywheel - 0400
Turbocharger - 0400
Turbocharger Oil Lines - 0400
Engine Overhaul Kit - 0400
Engine Gasket Kit - 0400
Group 0500 Engine Auxiliary System
Radiator, Hoses, Fan Shroud And Guard - 0510(Engine Tt094)
A/C Fan Package And Basic Fan Package - 0510
Electrical Accelerator - 0515
Air Cleaner And Mounting Brackets - 0520
Pre Cleaner - 0520
Exhaust Extension And Muffler (W/ Turbo) - 0530
Engine Mounting Supports - 0540
Fuel Tank And Fuel Tank Hoses - 0560
Group 0900 Steering System
Steering Cylinder And Repair Kit (W/Mfwd) - 0960
Steering Wheel And Tilt Column - 0960
Steering Column Standard- 0960
Steering Hydraulics Valve - 0960
Steering Hydraulics Plumbing (W/ Mfwd) - 0960(Engine Tt094)
Steering Hydraulics Plumbing (W/O Mfwd) - 0960(Engine Tt094)
Group 1000 Service Brakes
Service Brake Clutch Disc And Disc Carrier - 1011
Brake Valve And Pedals - 1060
Brake Valve Assembly - 1060
Service Brake Hydraulics - 1060
Brake Valve Boost Plumbing (Cab) - 1060
Parking Brake Plumbing - 1111
Parking Brake Housing And Clutch Disc - 1111
Group 1300 Miscellaneous Vehicle
Loader Arm Service Lock - 1313
License Plate Lamp And Rear Lights - 1314
Trademarks And Labels (4x2) - 1320
Trademarks And Labels (4x4) - 1320
Group 1600 Vehicle Electrical Systems
Single Battery Installation - 1671
Dual Battery Installation - 1671(Optional)
Master Battery Disconnect - 1671
Alternator - 1672
Rotating Beacon - 1673
Roof With Standard Lighting Option - 1673
Roof With Deluxe Lighting Option - 1673
Head Lights And Mirror - 1674(Up To Vin 1054)
Head Lights W/O Mirror - 1674(From Vin 1055)
Side Console Harness - 1674
Side Console Wiring Harnesses - 1674
Side Console Switches - 1674
Instrument Panel Side Console - 1674
Pump Control Relay - 1674
Loader Coupler Electrical And Anti-Theft - 1675
Group 1700 Frame, Chassis Or Supporting Structure
Main Frame With Stabilizer - 1740
Main Frame Guards - 1740
Front Counterweight - 1749
Bumper - 1747
Bumper - 1747
Group 1800 Operator’s Station
Rops Canopy Headliner And Mounting Isolators - 1811
Cab Frame, Headliner & Cab Mounting Isolators - 1811
Floor Mats - 1812
Doors And Side Windows For Cab - 1814
Windshield Glass For Cab - 1814
Sliding Rear Windows And Corner Windowpanes - 1814
Front Windshield Wiper System - 1814
Front Windshield Washer Reservoir And Pump - 1814
Rear Windshield Wiper System - 1814
Backhoe Control Console (Two Lever) - 1816
Steering Column Covers - 1816
Front Console (Cab Or Canopy) - 1816
Side Instrum Panel Hsing & Stabilizer Cntl Cover - 1816(Canopy)
Side Instrum Panel Hsing & Stabilizer Cntl Cover - 1816(Cab)
Seat / Armrest - 1821
Seat Slide And Adjuster Control Levers - 1821
Seat Swivel And Swivel Latch - 1821
Seat Suspension - 1821
Seat Belt - 1821
Air Suspension Seat And Shock Absorber - 1821
Suspension Seat - 1821
Heater Plumbing (Engine Tt094) - 1830
Cab Heater And Air Conditioning Ducting - 1830
Heater And Air Conditioning With Pressurizer - 1830
Air Conditioning Hardware & Hoses - 1830
Heat And Noise Barrier - 1834
Group 1900 Sheet Metal And Styling
Hood And Side Panels - 1910
Battery Enclosure And Tool Box - 1913
Grille Frame Bumpers - 1921
Operator Station Fenders And Skirts - 1927
Group 2000 Safety, Convenience And Miscellaneous
External Mirror - 2002(From Vin 1055)
Interior Front View Mirror (Rear Mounted) - 2002
Interior Rear View Mirror (Front Mounted) - 2002
Fire Extinguiser - 2003
Back-Up Alarm System - 2004
Horn - 2004
Sun Visor - 2007
Group 2100 Vehicle Main Hydraulic System
Main Hydraulic Pump - 2160
Hydraulic Oil Cooler And Hoses - 2160
Hydraulic Oil Filter - 2160 (Up To Vin 1297)
Hydraulic Oil Filter - 2160 (From Vin 1298)
Main Hydraulic System Reservoir - 2160
Main Hydraulic System - 2160 (Up To Vin 1297)
Main Hydraulic System (Up To Vin 1297) - 2160
Main Hydraulic System (From Vin 1298) - 2160
Ride Control Kit - 2160
Group 3100 Loader
Multi-Purpose Bucket Cylinder And Repair Kit - 3102
Multi-Purpose Bucket - 3102
Multi-Purpose Bucket, Cylinder & Hydr Oil Lines - 3102
Loader Bucket And Cutting Edge - 3102
Quick Coupler Forks And Frame - 3102
Hydraulic Front Coupler - 3102
Front Coupler Cylinder - 3104
Bucket Leveling And Return-To-Dig Linkage - 3115
Loader Control Valve Linkage - 3115
Third Function Loader Control Valve Linkage - 3115
Loader Lift Arm - 3143
Loader Bucket Linkage - 3143
Loader Control Valve - 3162
Boom Section (Loader/Stabilizer Valve) - 3162
Bucket Section (Loader Valve) - 3162
Auxiliary Section (Loader/Stabilizer Valve) - 3162
Stabilizer/Loader Valve - 3162
Loader Boom Lift Cylinder Hydraulics - 3163
Loader Bucket Cylinder & Third Function Hydr - 3163
Loader Bucket Cylinder & Repair Kits - 3165
Boom Lift Cylinder And Repair Kits- 3165
Boom Lift Cylinder Hardware- 3165
Hydraulic Front Coupler - 3163
Hydraulic Front Coupler Valve - 3163
Group 3300 Backhoe
Quick Coupler (Universal) - 3302
Backhoe Buckets - 3302
Buckets Pins And Bushes - 3302
Trenching Buckets - 3302
Ditch Cleaning Bucket - 3302
Stabilizer Valve Linkage - 3315
Two Lever Control Lever Valve Conversion Kit - 3315
Fifth Function Pedal - 3315
Backhoe Boom Lock Control Lever And Linkage - 3315
Backhoe Valve Mounting Plate - 3360
Sliding Frame Plate And Component - 3360
Hose Routing - 3360
Sliding Frame Plate And Fitting - 3360
Sliding Frame - 3342
Cylinder Lock Assembly - 3342
Swing Frame And Pins - 3343
Backhoe Boom - 3344
Boom Protection Plate - 3344
Backhoe Bucket Links - 3345
Standard Dipperstick - 3346
Extendible Arm And Locking Pin - 3346
Backhoe Control Valve - 3362
Priority Inlet Section - 3362
Boom Section - 3362
Bucket Section - 3362
Crowd Section - 3362
Swing Section - 3362
Extendible Section - 3362
Selective Flow Section - 3362
Auxiliary Section - 3362
Locking Control Valve - 3362
Lock Hydraulics And Hose - 3362
Backhoe Boom Lock Control Lever & Linkage - 3315
Fifth Function Manual Valve Kit - 3362
Sixth Function Manual And Pilot Control Kit - 3362
Stabilizer Cylinder Hydraulics - 3363
Boom Cylinder, Hydraulic Hoses And Fittings - 3363
Bucket Cylinder Hydraulic Hoses, Lines & Fittings - 3363(Standard Dipperstick)
Crowd Cylinder Hydraulic Hoses And Fittings - 3363
Swing Cylinder Hydraulic Hoses And Fittings - 3363
Auxiliary Equipment Hydraulic Hoses And Fittings - 3363(Standard Dipperstick)
Auxiliary Equipment Hydraulic Hoses And Fittings - 3363(Extendible Dipperstick)
Attachment Plumbing Kit - 3363
Bucket Cylinder And Repair Kit (Heavy Duty) - 3365
Bucket Cylinder And Repair Kit - 3365
Crowd Cylinder And Repair Kit - 3365
Crowd Cylinder And Repair Kit - 3365 (From Vin 1438)(Only Used On Std Dippers)
Swing Cylinder And Repair Kit - 3365
Stabilizer Cylinder & Repair Kit - 3365(Standard Stabilizer)
Group 9000 General Backhoe
Low Noise Package - 9006
Brand: Bell
Part Number: 874111
Users Comments
Content Over View
Table Of Contents
Page Layout
Ordering Of Parts
Bulletins
Machine Dimension
Service Kits
Pin Identification
Group 0100 Wheels
Group 0400 Engine
Camshaft - 0400
Front Plate - 0400
Oil Pan - 0400
Oil Filter - 0400
Oil Pump - 0400
Fuel Filter - 0400
Fuel Lines - 0400
Flywheel - 0400
Turbocharger - 0400
Pre Cleaner - 0520
Alternator - 1672
Bumper - 1747
Bumper - 1747
Floor Mats - 1812
Seat Belt - 1821
Horn - 2004
Sun Visor - 2007
Group 3100 Loader
Group 3300 Backhoe
Hose Routing - 3360
Backhoe Boom - 3344
Boom Section - 3362
- Bell Equipment B35D & B40D Repair manual Dumptruck ( Articulated )
- Bell Articulated Dump Truck B25D B30D 6x6 Repair Manual
- Bell Equipment B35D & B40D operation test manual Dumptruck ( Articulated )
- Bell Articulated Dump Truck B30E PIN A830E11 Parts Manual
- Bell Dumptruck Parts Manual B40D 6X6,ADT - 413840 B35D 6X6,OBW,ADT - 413835 B35D 6X6,OBW,WDB,ADT - 4
- Bell Equipment B30D MkVI ADT - A830D60 Parts Manual
- Bell DUMPTRUCK Operators manual
- Bell equipment
- Bell Equipment B25D Mk7.2 ADT - EA825D72 872335 Parts Manual
- Bell Equipment ARTICULATED DUMP TRUCK B25E PIN A825E22 Parts Manual
- Bell Articulated Dump Truck B25D & B30D 6x6 Repair Manual
- Bell Equipment B50D 6X6 SS ADT MK VI - A850D60 872241 Parts Manual
- BELL E-SERIES B18E B30E Articulated Dump Truck Operator's Manual 872353 REV A
- BELL E-SERIES B18E B30E Articulated Dump Truck Service Manual 872352 REV A
- Bell Equipment AH350D-400D Technical Manual
