Bell Backhoe Loader 315SG Parts Manual 874800
Brand: Bell
Model: Bell 315SG Backhoe Loader
VIN: AEBF877JX02000964
Part Number: 874800
Publication Date: 2007
Number of Pages: 674 Pages
Location Of Operations
Users Comments
Content Overview
Table Of Contents
Page Layout
List Of Abbreviations
Ordering Of Parts
Bulletins
Machine Dimensions
Serial Number Plates
Service Kits
Pin Identification
Group 0100 Wheels
Rear Drive Wheel - 0110
Front Drive Wheel - 0110
Front Wheel (W/O Mfwd) - 0120
Group 0200 Axles, Diffs And Suspensions
Differential Housing, Axle Housing And Shaft - 0201
Planetary Pinion Carrier - 0210
Differential Assembly With Lock - 0210
Spiral Bevel Input Pinion And Ring Gear Set - 0210
Differential Lock Plumbing - 0210
Tie Rod Assembly (W/O Mfwd) - 0230 (Sn -911131)
Front Axle, Spindle & Knuckle Assy (W/O Mfwd) - 0230 (Sn -911131)
Front Wheel Hub (W/O Mfwd) - 0230 (Sn -911131)
Standard Front Axle (W/O Mfwd) - 0230 (Sn 911132- )
Standard Front Axle Housing (W/O Mfwd) - 0230( Sn 911132- )
Swivel Housings & Steering Cylinder (W/O Mfwd) - 0230 (Sn 911132- )
Wheel Hub (W/O Mfwd) - 0230 (Sn 911132- )
Drive Shaft (W/O Mfwd) - 0230
Front Axle (W/ Mfwd) - 0250
Front Axle Housing And Tie Rods (W/ Mfwd) - 0250
Front Axle Housings, Hubs & Universal Joints - 0250 (W /Mfwd)
Planetary Drive (W/ Mfwd) - 0250 (Sn 962374-)
Limited Slip Differential (W/ Mfwd) - 0250
Fr Spiral Bevel Input Pinion & Ring Gear (W/Mfwd) - 0250
Spiral Bevel Gear And Input Flange (W/ Mfwd) - 0250
Group 0300 Transmission
Shift Forks And Shift Rails (Synchshuttle) - 0315
Transm Shifter Lever & Housing (Synchshuttle) - 0315
Transmission Control Lever - 0315
Transmission Shifter Levers (Std & Isolated) - 0315
Rear Driveshaft And Universal Joints - 0325
Transmission Housing (Synchshuttle) - 0341
Transmission Housing (Power Shift) - 0341
Transmission, Dipstick And Tube - 0341
Torque Converter - 0350
Forward Clutch Assembly (Synchshuttle) - 0350
Reverse Clutch Assembly (Synchshuttle) - 0350
Input Shafts (Synchshuttle) - 0350
Mfwd Idler Shaft (Synchshuttle) - 0350
Mfwd Output Shaft (Synchshuttle) - 0350
Output Shaft Group (Synchshuttle) - 0350
Intermediate Shaft Group (Synchshuttle) - 0350
Transmission Input Shaft (Power Shift) - 0350
First Gear Clutch Assembly (Power Shift) - 0350
Second Gear Clutch Assembly (Power Shift) - 0350
Third Gear Clutch Assembly (Power Shift) - 0350
Fourth Gear Clutch Assembly (Power Shift) - 0350
Forward Clutch Assembly (Power Shift) - 0350
Reverse Clutch Assembly (Power Shift) - 0350
Transmission Output Shaft (Power Shift)(W/Mfwd) - 0350
Transm Control Valve Group (Synchshuttle) - 0360
Transm Control Valve Group (Continued) - 0360 (Synchshuttle)
Transm Interm Plate & Gasket (Synchshuttle) - 0360
Transmission Charge Pump - 0360
Transmission Control Valve Group (Power Shift) - 0360
Range Shift Valve Group (Power Shift) - 0360
Group 0400 Engine
Crankshaft And Main Bearings (Turbo) - 0401
Camshaft - 0402
Rocker Arm / Shaft / Push Rod - 0402
Rocker Arm Cover And Gasket- 0402
Timing Gear Cover And Gasket - 0402
Piston / Connecting Rod / Cylinder Liner - 0403
Front Plate - 0404
Cylinder Block And Main Bearing Cap - 0404
Engine Short Block - 0404
Oil Filler Neck - 0407
Engine Oil Dipstick - 0407
Engine Oil Pan And Gasket - 0407
Engine Oil Filter And Housing - 0407
Engine Oil Pump And Intake - 0407
Engine Ventilating System - 0408
Cylinder Head And Valves - 0409
Exhaust Manifold And Gasket - 0410
Exhaust Elbow - 0410
Fuel Injection Nozzles - 0413
Fuel Injection Pump, Lines And Engine Controller - 0413
Fuel Injection Pump Stanadyne De10 Service Kits - 0413(With Turbocharger)
Air Intake System (Turbo) - 0414
Engine Balancer Shaft (Turbo) - 0415
Turbocharger - 0416
Turbocharger Oil Lines - 0416
Water Pump Inlet And Pulley - 0417
Water Pump And Repair Kit - 0417
Thermostat And Cover - 0418
Engine Oil Cooler And Adapter - 0419
Fuel Filter 2000 - 0420
Fuel Filter (Turbo) - 0420
Fuel Filter Lines (Turbo) - 0420
Fuel Transfer Pump - 0421
Starting Motor And Attaching Parts - 0422(Iskra)
Starting Motor (Denso) - 0422
Starting Motor Adaptor Kit - 0422(To Convert Iskra Starter To Denso Starter)
Alternator Mounting Brackets - 0423
Fan Drive And Belt (Turbo) - 0429
Flywheel - 0433
Flywheel Housing - 0433
Engine Overhaul Kit - 0450
Engine Major Overhaul Gasket Kit - 0452
Engine Gasket Kit - 0452
Group 0500 Engine Auxiliary System
Engine Coolant Heater - 0505
Cold Weather Starting Aid - 0505
Radiator, Hoses, Fan Shroud And Guard - 0510
Engine Speed Control Linkage - 0515
Air Cleaner And Mounting Brackets - 0520
Pre-Cleaner - 0520
Exhaust Extension And Muffler (W/ Turbo) - 0530
Engine Mounts And Isolators - 0540
Fuel Tank And Fuel Tank Hoses - 0560
(Replacement) Fuel Tank And Fuel Tank Hoses - 0560
Group 0900 Steering System
Steering Wheel And Column - 0960
Steering Wheel And Tilt Column - 0960
Power Steering Valve Seal Repair Kit - 0960
Steering Hydraulics (W/ Mfwd) - 0960
Steering Hydraulics (W/O Mfwd) - 0960
Steering Cylinder (Mfwd) - 0960
Group 1000 Service Brakes
Service Brake Assembly - 1011
Brake Valve And Pedals - 1060
Brake Valve Assembly - 1060
Service Brake Hydraulics - 1060
Brake Valve Boost Plumbing (Rops & Cab) - 1060
Parking Brake - 1111
Group 1300 Miscellaneous Vehicle
Loader Arm Service Lock - 1313
License Plate Lamp And Rear Lights - 1314
Trademarks And Labels (4x2) - 1320
Trademarks And Labels (4x4) - 1320
Loctite Service Kit - 1330
Environmental Drain Package - 1369
O-Ring Kit - 1369
Group 1600 Vehicle Electrical Systems
Single Battery Installation - 1671
Dual Battery Installation - 1671
Master Battery Disconnect - 1671
Remote Start Post - 1671
Alternator - 1672
Rotating Beacon (From Vin 306) - 1673
Standard Lights, Deluxe Lights & Roof Harness - 1673(To Vin 234)
Standard Lights, Deluxe Lights & Roof Harness - 1673(From Vin 235)
Roof With Bell Lighting Option - 1673
Head Lights And Mirror- 1674
Head Light - 1674
Side Console Wiring Harnesses - 1674
Front Console Wiring Harnesses - 1674
Hydraulic Front Coupler Harness - 1674
Monitor Panel With Monitor, Switches And Labels - 1674
Differential Lock Switch - 1674
Return-To-Dig Switch - 1674
Engine Wiring Harness - 1674
Engine Front Harness - 1674
Select Flow Control & Pump Control Wire Harn - 1674
Wire Lead Kit - 1674
Weatherpack Terminals And Connectors - 1674
Suppl Terminals, Connectors & Repair Conduit - 1674
Deutsch Terminals - 1674
Group 1700 Frame, Chassis Or Supporting Structure
Main Frame With Stabilizer - 1740
Bottom Guard - 1746
Bumper - 1747
Front Counterweight - 1749
Group 1800 Operator’s Station
Rops Canopy Headliner And Mounting Isolators - 1811
Headliner & Cab Mounting Isolators (Cab Frame) - 1811
Roof (Cab, Quarter Cab Or Rops) - 1811
Floor Mats - 1812
Doors And Side Windows For Cab - 1814
Windshield Glass For Cab - 1814
Sliding Rear Windows And Corner Windowpanes - 1814
Front Windshield Wiper System - 1814
Front Windshield Washer Reservoir And Pump - 1814
Rear Windshield Wiper System - 1814
Backhoe Control Console (Two Lever) - 1816
Steering Column Covers - 1816
Front Console (Cab Or Canopy) - 1816
Side Instrum Panel Hsg & Stabilizer Cntl Cover - 1816(Canopy)
Side Instrum Panel Hsg & Stabilizer Cntl Cover - 1816(Cab)
Seat / Seat Belts / Armrest - 1821
Seat Slide And Adjuster Control Levers - 1821
Seat Swivel And Swivel Latch - 1821
Seat Suspension And Shock Absorber - 1821
Seat Base And Tether Belt - 1821
Seat Base And Height Adjuster - 1821
Air Suspension Seat Base - 1821
Suspension Seat - 1821
Cab Heater And Air Conditioning Ducting - 1830(Page 1 Of 2)
Cab Heater And Air Conditioning Ducting - 1830(Page 2 Of 2)
Heater And Air Conditioning With Pressurizer - 1830
Canopy Heater, Hoses & Control - 1830
Cab Heater (20,000 Btu) - 1830
Air Conditioning, Hardware And Hoses - 1830
Heat And Noise Barrier - 1834
Group 1900 Sheet Metal And Styling
Bonnet & Miscellaneous Parts - 1910
Battery Enclosure And Tool Box - 1913
Loader Plumbing Shield - 1913
Grille And Grille Housing - 1921
Extended Grille Housing - 1921
Operator Station Fenders And Skirts - 1927
Group 2000 Safety, Convenience And Miscellaneous
External Mirror - 2002
Interior Rear View Mirror - 2002
Back-Up Alarm System - 2004
Horn - 2004
Sun Visor - 2007
Group 2100 Vehicle Main Hydraulic System
Main Hydraulic Pump - 2160
Main Hydraulic System (Page 1 Of 2) - 2160
Main Hydraulic System (Page 2 Of 2) - 2160
Main Hydraulic System Reservoir - 2160
Hydraulic Oil Filter - 2160
Hydraulic Oil Cooler And Hoses - 2160
Hydraulic Oil Cooler And Hoses (Hi-Ambient) - 2160
Ride Control Kit - 2160
Group 3100 Loader
Multi-Purpose Bucket Cylinder And Repair Kit - 3102
Multi-Purpose Bucket - 3102
Multi-Purpose Bucket, Cylinder & Hyd Oil Lines - 3102
Loader Bucket And Cutting Edge - 3102
Loader Bucket Pins - 3102
Quick Coupler Forks And Frame - 3102
Hydraulic Front Coupler - 3102
Front Coupler Cylinder - 3104
Bucket Leveling And Return-To-Dig Linkage - 3115
Loader Control Valve Linkage - 3115
Third Function Loader Control Valve Linkage - 3115
Loader Lift Arm - 3143
Loader Bucket Linkage (To Vin 356) - 3143
Loader Bucket Linkage (From Vin 357) - 3143
Loader / Stabilizer Control Valve - 3162
Boom Section (Loader / Stabilizer Valve) - 3162
Bucket Section (Loader Valve) - 3162
Auxiliary Section (Loader / Stabilizer Valve) - 3162
Stabilizer / Loader Valve (Husco) - 3162
Hydraulic Front Coupler Valve - 3162
Loader Boom Lift Cylinder Hydraulics - 3163
Loader Bucket Cylinder & Third Function Hyd - 3163 (To Vin 383)
Loader Bucket Cylinder & Third Function Hyd - 3163 (From Vin 384)
Hydraulic Front Coupler - 3163
Boom Cylinder And Repair Kits - 3165
Loader Bucket Cylinder & Repair Kits - 3165
Group 3300 Backhoe
Backhoe Buckets - 3302 (Page 1 Of 2)
Backhoe Buckets - 3302 (Page 2 Of 2)
Ditch Cleaning Buckets - 3302
Buckets Pins And Bushes - 3302
Trenching Buckets - 3302
Backhoe Valve Mounting Plate - 3315
Stabilizer Valve Linkage - 3315
Two Lever Control Lever Valve Conversion Kit - 3315
Fifth Function Pedal - 3315
Backhoe Boom Lock Control Lever And Linkage - 3315
Sliding Frame - 3342
Swing Frame And Pins - 3343 (To Vin 448)
Swing Frame And Pins - 3343 (From Vin 449)
Backhoe Boom - 3344
Backhoe Boom Protection Plate - 3344
Backhoe Bucket Links - 3345 (To Vin 234)
Backhoe Bucket Links - 3345 (From Vin 235)
Standard Dipperstick - 3346
Extendible Dipperstick And Locking Pin - 3346
Protection And Grip Kit - 3346 (Extendible Dipperstick)
Backhoe Control Valve (Husco) - 3362
Priority Inlet Section - 3362
Boom Section - 3362
Bucket Section - 3362
Crowd Section - 3362
Swing Section - 3362
Extendible Section - 3362
Selective Flow Section - 3362
Auxiliary Section - 3362
Fifth Function Manual Valve Kit - 3362
Hydraulic Remote Kit - 3362
Locking Control Valve - 3362
Stabilizer Cylinder Hydraulics - 3363
Boom Cylinder, Hydraulic Hoses And Fittings - 3363
Bucket Cylinder Hydraulic Hoses, Lines & Fittings - 3363 (Standard Dipperstick)
Bucket Cylinder Hydraulic Hoses, Lines & Fittings - 3363 (Extendible Dipperstick)
Crowd Cylinder Hydraulic Hoses And Fittings - 3363
Swing Cylinder Hydraulic Hoses And Fittings - 3363
Extension Cylinder Hydraulic Hoses And Fittings - 3363 (Extendible Dipperstick)
Auxiliary Equipment Hydraulic Hoses And Fittings - 3363 (Standard Dipperstick)
Auxiliary Equipment Hydraulic Hoses And Fittings - 3363 (Extendible Dipperstick)
Side Shift Lock Hydraulics - 3363
Backhoe Boom Lock Valve Hydraulics - 3363
Backhoe Cylinder Hydraulics - 3363
Boom Cylinder - 3365
Bucket Cylinder And Repair Kit (Heavy Duty) - 3365
Bucket Cylinder And Repair Kit - 3365
Crowd Cylinder And Repair Kit - 3365
Stabilizer Cylinder And Repair Kit - 3365
Swing Cylinder And Repair Kit - 3365
Extendible Dipperstick Cylinder - 3365
Brand: Bell
Part Number: 874800
Users Comments
Content Overview
Table Of Contents
Page Layout
Ordering Of Parts
Bulletins
Machine Dimensions
Service Kits
Pin Identification
Group 0100 Wheels
Group 0400 Engine
Camshaft - 0402
Front Plate - 0404
Turbocharger - 0416
Flywheel - 0433
Pre-Cleaner - 0520
O-Ring Kit - 1369
Alternator - 1672
Head Light - 1674
Bottom Guard - 1746
Bumper - 1747
Floor Mats - 1812
Horn - 2004
Sun Visor - 2007
Group 3100 Loader
Group 3300 Backhoe
Backhoe Boom - 3344
Boom Section - 3362
- Bell Equipment B35D & B40D Repair manual Dumptruck ( Articulated )
- Bell Articulated Dump Truck B25D B30D 6x6 Repair Manual
- Bell Equipment B35D & B40D operation test manual Dumptruck ( Articulated )
- Bell Articulated Dump Truck B30E PIN A830E11 Parts Manual
- Bell Dumptruck Parts Manual B40D 6X6,ADT - 413840 B35D 6X6,OBW,ADT - 413835 B35D 6X6,OBW,WDB,ADT - 4
- Bell Equipment B30D MkVI ADT - A830D60 Parts Manual
- Bell DUMPTRUCK Operators manual
- Bell equipment
- Bell Equipment B25D Mk7.2 ADT - EA825D72 872335 Parts Manual
- Bell Equipment ARTICULATED DUMP TRUCK B25E PIN A825E22 Parts Manual
- Bell Articulated Dump Truck B25D & B30D 6x6 Repair Manual
- Bell Equipment B50D 6X6 SS ADT MK VI - A850D60 872241 Parts Manual
- BELL E-SERIES B18E B30E Articulated Dump Truck Operator's Manual 872353 REV A
- BELL E-SERIES B18E B30E Articulated Dump Truck Service Manual 872352 REV A
- Bell Equipment AH350D-400D Technical Manual
