BigBoss1
106
307,104
Bell Articulated Dump Truck B40E Parts Manual BN043124
Brand: Bell
Type of Machine: Articulated Dump Truck
Model: Bell B40E Articulated Dump Truck
PIN: A640E11
Part Number: BN043124
Publication Date: 2016
Number of Pages: 962 Pages
Parts Manual
Location Of Operations
Bulletins
Feedback Form
Introduction
Introduction
Parts Manual Overview
Machine Dimensions
Serial Number Plates
Pin Configuration
List Of Abbreviations
0100 Wheels And Tyres And Tracks
Wheelset Choice Assy
0200 Axles, Differentials And Suspension Systems
Axle Front
Front Axle Breather Kit
Front Axle Pipes Brakes Kit
Axle Middle
Middle Axle Pipes Brakes Kit
Axle Rear
Middle & Rear Axle Breather Kit
Front & Middle Axle Final Drive Kit
Rear Final Drive Kit
Guard Kit
Front & Rear Differential Assembly
Middle Differential Assembly
Propshaft F-Axle Assy
Front Propshaft Breakdown
Propshaft M-Axle Assy
Middle Propshaft Breakdown
Rear Axle Propshaft Assy
Rear Propshaft Breakdown
Thru Drive Assy
Thru Drive Yoke
Yoke
Front Suspension Mounting Assy
Rear Suspension Mounting Assy
Draglink Assy
Straight Draglink Assy
Std Front Suspension Strut Kit (Choice)
Front Suspension Comfort Ride (Choice)
Suspension Strut Lhs
Suspension Strut Rhs
Front Adaptive Suspension
Front Suspension Damping Valve Assy
Front Suspension Comfort Ride Strut Assy
Comfort Ride Suspension Strut Lhs
Comfort Ride Suspension Strut Rhs
Neckbush Strut Assy
Piston Assembly
Piston Assembly
Suspension Elec Assy
Std Rear Suspension(Choice)
Comfort Ride Rear Suspension(Choice)
Walking Beam
Walking Beam Lhs
Walking Beam Rhs
Walking Beam Active Strain Gauge Kit
0300 Transmission
Transmission Assy
Transmission Assy
Transmission Main Housing
Transmission Fill Tube
Transmission Main Shaft
Transmission Flange
Transmission Front Support And Oil Pump
Transmission P1 Planetary
Transmission P2 Planetary
Transmission Control Valve Part 1
Transmission Control Valve Part 2
Transmission Oil Cooler
Transmission Torque Converter
Transmission Flexplate & Adapter
Transmission Rotating Clutch
Transmission Converter Housing
Transmission P3 Planetary & Rear Cover Pg 1
Transmission P3 Planetary & Rear Cover Pg2
Remote Filter (Choice)
Transmission Cooling Purge Fan Brackets
Transmission Cooler Assy
Transmission Breather Assy
0400 Engine
Engine Assy
Propshaft Breakdown
Engine Miscellaneous Brackets
Engine, Crankcase
Engine, Timing Case
Engine, Oil Pan & Dipstick
Engine, Cylinder Head & Gasket Kit
Engine, Cylinder Head Cover
Engine, Crankshaft & Flywheel
Engine, Connecting Rod & Pistons
Engine, Camshaft & Timing Parts
Engine, High Pressure Pump
Engine, Fuel Lines
Engine, Fuel Filter
Engine, Turbo Charger
Engine, Air Compressor
Engine, Compressor Connection
Engine, Intake Manifold
Engine, Exhaust Manifold
Engine, Exhaust Gas Recirculation
Engine, Electrical Equipment (Part1)
Engine, Electrical Equipment(Part2)
Engine, Starting Motor
Engine, Alternator
Engine, Attachment Parts For Alternator
Engine, Oil Pump
Engine, Oil Filter & Oil Cooler
Engine, Oil Lines
Engine, Water Pump
Engine, Fan
Engine Supports & Attachment Parts
Engine, Pto
Engine, Airconditioner Compressor
Engine, Exhaust Gas Aftertreatment
Engine Purge Fan Brackets
0500 Engine Auxiliary System
Radiator Assy
Engine Mounting Assy
Cooler Cac Assy
Tank Surge Assy
Cab And Cooler Heat Shield
Engine Cooler Shroud Assy
Cooler Charge Air Assy
Air Cleaner Assy
Air Cleaner Breakdown
Exhaust Mounting Assy
Adblue Assy
Adblue Tank
Exhaust System Assy
Exhaust Heatshield Assy
Bin Heating Assy (Option)
Non Bin Heating Assy (Option)
Fuel System Assy
Fuel Water Filter Unit
Fuel System Breather Assy
Tank Fuel Assy
Tank Fuel Assy
Lid Tank Fuel Assy
Drain Remote (Option)
Standard Oil Drain (Option)
0800 Transfer Drive (Includes Splitters)
Transfer Case Assy
Transfer Case Cooling
Cooler Box
Transfer Case Breather Assy
Transfer Case Mounting Assy
Transfer Case With Mounts
Transfer Case Front Input Insert
Transfer Case Rear Input Insert
Transfer Case Input Stage
Transfer Case Pto Idler Insert
Transfer Case Pump Insert
Transfer Case Idler Shaft
Transfer Case Flanges
Transfer Case Bearing Housing Rear Assy
Transfer Case Rear Output Assy
Transfer Case Planet Carrier Assy
Transfer Case Output Gear Assy
Transfer Case Clutch Housing Assy
Transfer Case Front Output Assy
Transfer Case Housing Assy
Transfer Case Input Assy
Transfer Case Front Side
Transfer Case Filtration System
Pto Propshaft
0900 Steering System
Emergency Steering Pump Assy
Emergency Steering Pump Breakdown
Emergency Steering Pump Hose Assy
Steering Column Cab Assy
Steering Column Breakdown
Steering Isolator Kit
Steering Hose Assy
Steering Cylinder Attachment
Steering Cylinder
Steering Control Valve Assy
Steering Control Valve Breakdown
1000 Service Brakes
Wdb Pedal Assy
Brake Pedal
Wdb Manifold
Wdb Brake Charge Valve Assy
Valve Wdb Brake Charge
Wdb Front Hose Assy
Rear Brake Hose Kit
Wdb Pump Assembly
Single Stage Wdb Pump
Two Stage Wdb Pump
Wdb Hydraulic Tank Assy
Return Filter
Wdb Rear Hydraulic Hose Assy
Brake Hose Kit Front
Wet Disk Brake Kit
Brake Wear Indicator
Wet Disk Brake Piston Assy
Rear Relay Valve Assy
Relay Valve Filter Bracket
Wdb Charge Filter
Front Accumulator Kit
Rear Accumulator Kit
Park Brake Caliper
Park Brake Caliper Breakdown
1300 Miscellaneous Vehicle
Service Kits
Engine Service Tools (Sheet 1 Of 2)
Engine Service Tools (Sheet 2 Of 2)
Engine Repair Tools
Transfer Case Tools
Axles Diffs And Final Drives Tools
Suspension Tools
Hydraulics Tools
Frame And Oscillation Tools
Driveline Diagnostic Tools
Tyre Inflation Kit
Recommended Paints And Procedures
Decals And Serial Plates
Decal And Serial Plates
Foreign Decal - German (Sheet 1 Of 8)
Foreign Decal - Russian (Sheet 2 Of 8)
Foreign Decal - French (Sheet 3 Of 8)
Foreign Decal - Danish (Sheet 4 Of 8)
Foreign Decal - Spanish (Sheet 5 Of 8)
Foreign Decal - Polish (Sheet 6 Of 8)
Foreign Decal - Swedish (Sheet 7 Of 8)
Foreign Decal - English (Sheet 8 Of 8)
Recommended Lubricants
Recommended Adhesives
Grease Assy Base
Grease Assy Bin
Auto Grease Assy (Choice)
Manual Grease Assy Without Tailgate (Choice)
Auto Grease With Tailgate (Choice)
Manual Grease With Tailgate (Choice)
Manual Grease Assy
Tail Gate Greasing Assy
Groeneveld Kit
Twin Pump Auto Greasing
Block 1 Complete
Block 2 Complete
Block 3 Complete
1600 Vehicle Electrical Systems
Bonnet Electrical Assy
Headlights
Headlight Sa Elec Assy
Headlight Eu Elec Assy
Nosebox Electrical Assy
Isolator Electrical Assy (Choice)
Cab Isolator Elec Assy
Chassis Isolator Electrical Assy
Cab Battery Box Elec Assy (Choice)
Cab Battery Box Electrical Assy
E-Module Dc Dc Converter
Artic Lights
Cab Worklight Elec Assy
Cab Electrical Assy
Brake Emergency Elec Assy (Option)
Emergency Brake Switch
Artic Electrical Assy
Artic Sensor Electrical Assy
E-Module Adm3
Memory Module Electrical Assy
Memory Module Elec Assy Breakdown
Engine Electrical Assy
Pneumatic Sensors Electrical Assy
Scr Electrical Assy
Rear Electrical Assy
Reverse Camera Electrical Assy
Reverse Camera Kit
Cab Beacon Elec Assy
Cab Beacon Elect Assy Breakdown
Cab Loadlights Elec Assy Option
Cab Loadlights Elec Assy Breakdown
Hydraulic Sensors Elec Assy
E-Module Transmission
Transmission Electrical Assy
Mid Chassis Active Strain Gauge Kit
Rear Chassis Active Strain Gauge Kit
Fuel Heater Electrical Assy (Option)
Chassis Engine Elec Assy
Fuel Sender Unit Assy
Electrical Connector (Part 1)
Electrical Connectors (Part 2)
Electrical Connector (Part 3)
Electrical Connectors (Part 4)
Electrical Connector (Part 5)
1700 Frame, Chassis Or Supporting Structure
Front Chassis Assy
Front Belly Cover Assy
Assembly Oscillation Male
Oscillation Male With Active Strain Gauge Kit
Artic Joint
Chassis Steering Lock
Stop Articulation Assy
Rear Chassis Assy
1800 Operator's Station
Cab Frame
Cab Mounting Assy
Support Device Cab Kit
Support Device Cab
Cab Headlining
Trim Cab Assy Interior
Trim Cab Assy External
Control Panel Console
Dashboard Panel
Electrical Cab Assy Mounting
Mounting E-Modules Adt
Radio Assembly
Cooler Box
Door Cab Assy Operator
Handle Door Cab Kit
Windows
Window Safety Punch
Sun Visor Assy
Shield Cab Assy Heat
Euro Seat Assy
Euro Seat Breakdown
Trainer Seat Assy
Panel Cab Assy External
Roof Assy
Guard Cab Assy Rear
Delux Wiper Kit Breakdown
Wiper System
Cab Assy Wiper Cover
Cab Wiper Common Parts
Window Washer Bottle
Mirror Assembly Adt
Side Mirror Assembly
Mirror Cab Assy Mounting
Cab Fire Extinguisher
Airconditioner Cab Ducting
Hvac Cab Unit
Hvac Breakdown
Hvac Adt Kit
Airconditioner Receiver Drier
Battery Clamp Assy
Door Assy Battery Box
1900 Sheet Metal And Styling
Lhs Nosebox Assy
Front Lid Top Nosebox
Rear Lid Top Nosebox
Bumper Corner Lhs Assy
Bumper Corner Rhs Assy
Bonnet
Bonnet Grille
Bonnet Attachments
Mudguard Assy
Mudguard Assy Lhs
Mudguard Assy Rhs
Mudflap Assy
Step Assy Rhs
Step Assy Lhs
Handrail Assy
Handrail Assy
2100 Vehicle Main Hydraulic System
Hydraulic Tank Assy
Hydraulic Filter Return
Filter Hp With Hose Assy (Choice)
High Pressure Filter Assy
High Pressure Oil Filter Unit
High Pressure Filter Hose Assy
Hydraulic Supply Hose Assy (Choice)
Hydraulic Cab Tilt Pump
Cab Lift Cylinder Kit
Cab Tilt Lift Cylinder
Hydraulic Cab Tilt Hose Assy
Main Hyd Pump Assy
Hydraulic Pump Breakdown
Main Hyd Valve Assy
Hydraulic Valve Breakdown
Main Hydraulic Valve Mounting
Bin Tip Valve Section
Hydraulic Bridge Assy
Hydraulic Suction & Return Hose Assy
Test Hose Assy
Hydraulic Clamp Mountings
Hydraulic Bin Tip Front Hose Assy
Hydraulic Bin Tip Rear Hose Assy
Tip Cylinder Attachment
Tip Cylinder
Hyd Fan Motor Assy
Hose Hyd Fan Assy
2200 Vehicle Pneumatic System
Pneumatic Valve Assy
Pneumatic Cool Coil Assy
Rear Chassis Pneumatic Hose Assy
Front Chassis Pneumatic Hose Assy
Pneumatic Air Drier Assy
Pneumatic Air Dryer Kit
Rear Pneum Reservoir Assy
Reservoir
3500 Haulage Device (Scraper And Adt)
Bin Pole Assy
Bin Up Lock
Bin Liner
Bin Assy
Tailgate
Bin Tailgate
Greedy Board
Bin Mudflap
Functional Groups
Index
