Bell Articulated Dump Truck B35D ADT B40D ADT B35D WDB ADT Parts Manual 872362
Brand: Bell
Type of Machine: Articulated Dump Truck
Model: Bell B35D ADT, B40D ADT, B35D WDB ADT Articulated Dump Truck
PIN:
B40D ADT: 7.2 Blu@dvantage - A340D72
B35D ADT: 7.2 Blu@dvantage - A335D72
B35D WDB ADT: 7.2 - A336D72
Part Number: 872362
Publication Date: 2013
Number of Pages: 804 Pages
Start Of Manual
Location Of Operations
Important
Table Of Contents
Section 1: General Information
Page Layout
Bulletins
List Of Abbreviations
Ordering Of Parts
Machine Dimensions B40d 6x6 Ad
Machine Dimensions B35d 6x6 Adt
Serial Number Plates
Engine Control Unit (Pld) - Ordering Details
Pin Identification
Section 2: Engine Tier 3b
Engine & Miscellaneous Components - B35d
Engine & Miscellaneous Components - B40
Engine Crankcase
Timing Case
Oil Pan & Dipstick
Cylinder Head (Continue
Decompression Valve Pipe
Crankshaft And Flywheel - B40d
Crankshaft And Flywheel - B35d
Connecting Rods And Pistons
Camshaft
Fuel Lines
Turbocharger
Air Compressor
Intake Manifold & Flame Start
Exhaust Manifold
Exhaust Brake Manifo
Adblue Metering Unit
Adblue Pump Module
Starter Motor
Alternator - B40
Alternator - B35d
Alternator Support
Electrical Equipment
Oil Pump
Oil Filter & Oil Cooler
Oil Lines
Fan
Belt Tensioner & Belt - B40d
Belt Tensioner & Belt - B35d
Engine Support
Adblue Preheating
P.T.O
Air Conditioner Compressor
Catalyst
Engine Cooling System - Detail A
Engine Cooling System - Detail B
Engine Cooling System, Radiator
Engine Fuel System Kit
Handlift Pump & Pre-Filter
Fuel-Water Filter Unit
Filter 2000 (Optional)
Depth Fuel Filter
Exhaust- After Treatment System - Detail A
Exhaust - After Treatment System - Detail B
Exhaust - After Treatment System - Detail C
Exhaust - After Treatment System - Detail D
Bin Heating Kit (Optional)
Kit, Exhaust Stand
Air Intake Kit
Air Cleaner & Pre-Cleaner Assembly
Section 3: Drivetrain
Transmission Kit - Detail A
Transmission Kit - Detail B
Transmission, Main Housing
Transmission, Fill Tube
Transmission, Main Sha
Transmission, Flange
Transmission, Front Support & Oil Pump
Transmission, P1 Planetary
Transmission, P2 Planetary
Transmission, Control Valve (Part 1)
Transmission, Control Valve (Part1) (Contd)
Transmission, Control Valve (Part 2)
Transmission, Control Valve (Part 2) (Contd)
Transmission, Oil Cooler
Transmission, Torque Converter
Transmission, Rotating Clutch
Transmission, Converter Housing
Transmission, P3 Planetary & Rear Cover
Transmission, Cooler Box
Transmission Cooler, Fan Assembly
Transmission Cooler, Cooler Assembly-B35d
Transmission Cooler, Cooler Assembly-B40d
Drop Box & Mountings
Drop Box, Casing
Drop Box, Input Shaft Assembly
Drop Box, Idler Shaft Assembly
Drop Box, Rear Output Shaft Assembly
Drop Box, Front Output Diff Assembly
Drop Box Filtration System
Driveline Kit
Propshafts
Coupling, Pto
Thru Drive Kit
Kit, Park Brake Mounting
Park Brake Assembly
Actuator Assembly
Axle, Front
Axle, Middle
Axle, Rear, B40d (Wdb)
Axle, Rear, B35d (Wdb)
Axle Drain & Filler Plugs
Alxe, Middle, Caliper
Axle, Rear, Caliper
Final Drive Kit For Rear Axles, B40d
Final Drive Kit For Caliper Axles, B35d
Final Drive Kit For Wdb Axles, B35d
Caliper Hyd Component Kit, B35d - Detail A
Caliper Hyd Component Kit, B35d - Detail B
Disc Brake Kit, Front Axle, B35d
Disc Brake Kit, Rear & Mid Axle, B35d
Middle & Rear Axle Guards Kit, B35d
Front Axle Guards Kit, B35d
Kit, Hydraulic Component, Caliper, B35d
Wet Disc Brake Kit, Middle Axle, B40d
Wet Disc Brake Kit, Front Axle, B35d
Wet Disc Brake Kit, Middle Axle, B35d
Wet Disc Brake Kit, Rear Axle
Kit, Axle Guards
Brake, Wdb, Plate
Wet Disc Brake Pump
Kit, Cooler, Wdb, Cooling
Disc Brake Caliper Location
Disc Brake Caliper Breakdown
Front/Rear Differential Assembly
Front/Rear Differential Assembly (Contd)
Middle Differential Assembly
Middle Differential Assembly (Contd)
Wet Disc Brake Assy, Rh Front & Lh Mid Axles
Wet Disc Brake Assy, Lh Front & Rh Mid Axles
Wet Disc Brake Assembly, B35d
Wheel Sets Options, B40d
Wheel Set Options, B40d (Contd)
Wheel Set Options, B35d
Wheel Set Options, B35d (Contd)
Section 4: Hydraulics
Valve, Hydraulic, Assembly
Hydraulic Block - Valve Positions
Hydraulic Block - Valves
Hydraulic Block - Tip Section
Kit, Hydraulic Mounting/Cover
Pipe, Accumulator, Supply, Hydraulic, Assy
Cooler, Hydraulic Assembly
Kit, Front Hydraulic Cooler
Fan Motor
Fan Motor (Alternative)
Fan Motor Breakdown
Fan Motor (Alternative) Breakdown
Hose, Hydraulic, Artic, Assy
Pipe, Return, Hydraulic, Assy
Pump, Hydraulic Assembly
Hydraulic Pump (Alternative)
Kit, Main Pump
Hydraulic Pump Breakdown
Hyd Pump (Alternative) Breakdown - Front
Hyd Pump (Alternative) Breakdown - Rear
Check Valve Manifold
Emergency Steering Pump
Emergency Steering Pump (Alternative)
Emergency Steering Pump Breakdown
Emergency Pump (Alternative) Breakdown
Emergency Steering Pump Check Valve
Damper, Hydraulic Assembly
Damper
Steering, Hydraulic Assembly
Steering Cylinder
Front Susp, Comfort Ride - Detail A (Choice)
Front Susp, Comfort Ride - Detail B (Choice)
Suspension Struts, Comfort Ride (Choice)
Damping Valve, F/Susp, Comfort Ride
Suspension Manifold, F/Susp, Comfort Ride
Front Chassis, Kit, Hyd Component, Wdb
Rear Chassis, Kit, Hyd Component, Wdb
Kit, Filtration, Wdb, B40d
Wdb Hyd Component Kit - Detail A
Wdb Hyd Component Kit, B40d - Detail A (Contd)
Wdb Hyd Component Kit - Detail B
Wdb Hyd Component Kit - Detail C
Accumulator Kit, B40d - Europe
Accumulator Kit, B35d - Europe
Hydraulic Kit, Cab - Detail A
Hydraulic Kit, Cab - Detail B
Steering Control Valve, Eaton
Brake Pedal
Hydraulic Kit, Cab Tilt Syst
Hydraulic, Cab Tilt Cylinder Breakdown
Pump, Cab Tilt
Hydraulic Kit, Rear Chassis
Tip Cylinder Breakdown
Section 5: Pneumatics
Pneumatic Kit, Front Chassis - Detail A
Pneumatic Kit, Front Chassis - Detail B
Pneumatic, Scr Assembly
Fan Purging Kit
Purge Tank Valve
Reservoir Kit
Air Dryer Kit
Air Dryer Repair Kit
Pneumatic Kit, Rear Chassis
Pneumatic Kit, Cab Assembly
Pneumatic Valve Asse
Air Horn
Section 6: Electrical
Cab Harness - Detail A
Cab Harness - Detail B
Cab Harness - Detail C
Cab, Fuse And Relay Panel Components
Cab, Windscreen Wiper Kit
Option, Rear Wiper
Kit, Wiper System, Rear, B40d
Cab, Transmission Harness
Cab, Rear View Mirror K
Cab, Rear View Mirrors
Cab, Load Lights (Optional)
Electrical, Air Horn
Cab, Beacon (Optional)
Cab, Work Lights (Optional)
Cab, Reverse Light (Optional)
Cab, Memory Module
Cab, Radio (Optional)
Cab, Reverse Monitor
Cab, Emergency Brake (Optional)
Engine Harness
Electrical System, Artic
Electrical Assembly - Blu@Vantage Only
Kit, Grill, Head Lights
Option, Cold Start
Light Breakdowns
Artic Harness
Battery Box
Fuel Heater (Optional)
Suspension System (Optional)
Rear Harness
Obw
Strain Gauge Kit
Connectors (Sheet 1 Of 9)
Connectors (Sheet 2 Of 9)
Connectors (Sheet 3 Of 9)
Connectors (Sheet 4 Of 9
Connectors (Sheet 5 Of 9)
Connectors (Sheet 6 Of 9)
Connectors (Sheet 7 Of 9)
Connectors (Sheet 8 Of 9)
Connectors - (Sheet 9 Of 9)
Section 7: Frame And Body
Bonnet Kit - Detail A
Bonnet Kit - Detail B
Cab Complete
Cab Shell
Cab Front Insulation Parts
Cab Bottom Seals
Window Guard, Handrails & Cab Mountings
Rear View Mirror Brackets
Cab Door Assem
Cab Windows
Window Catches
Cab, Roller Blind
Door, Hvac System
Cab Interior Miscellaneous Parts - Detail A
Cab Interior Miscellaneous Parts - Detail B
Cab Floor Mat & Pillar Covers
Roof Interior Liners
Cab Sound Foam
Steering Column Miscellaneous Parts
Steering Column
Operator & Trainer Seat Intallation
Trainer Seat Mounting
Seat Installation, Sears Low Back
Seat Installation, Sears High Back
Seat Assembly, Base, Sears
Cab Air Ducting, Hvac System
Aircon Drier Unit & Piping
Aircon Unit
Aircon System, Front Chassis
Voac Mtg & Cover Kit
Grill Kit - B35d
Grill Kit - B40d
Belly Plate Kit
Front Chassis Kit - B35d
Front Chassis Kit - B40d
Cab Clamps Kit
Front Chassis Clamps - Detail A
Front Chassis Clamps - Detail B
Rear Chassis Clamps
Rhs Mudguard - B40d - Detail A
Rhs Mudguard - B40d - Detail B
Adblue Tank, Scr, Hse
Adblue Tank, Scr, Non-Hse
Cap, Diesel Filler
Lhs Mudguard - B40d - Detail A
Lhs Mudguard - B40d - Detail B
Kit Mudguard, Rh, B35d - Detail A
Kit, Mudguard, Rh, B35d - Detail B
Kit, Mudguard, Lh, B35d - Detail A
Kit, Mudguard, Lh, B35d - Detail B
Hydraulic Tank & Battery Box Kit - Detail A
Hydraulic Tank & Battery Box Kit - Detail B
Kit, Miscellaneous Parts
Hydraulic Tank Filter Assembly
Front Suspension, Standard (Choice)
Link, Panhard, F/Susp, Standard
Suspension Struts, Standard (Choice)
Oscillation Joint Kit
Artic Joint
Rear Chassis Kit
Bin Pivot
Bin, Miscellaneous Parts
Rear Suspension, Standard (Choice)
Rear Suspension, Cride
Walking Beam, Owb, Standard (Choice)
Rear Suspension, Comfort Ride (Choice)
Walking Beam, Owb, Comfort Ride (Choice)
Wet Disc Brake Ta
Wet Disc Brake Filter Assembly
Tailgate Kit
Bin Liner Kit
Front Chassis Grease Ki
Rear Chassis Grease Kit
Manual Greasing Kit
Tailgate Grease Kit
Decals (Sheet 1 Of 3)
Decals (Sheet 2 Of 3)
Decals (Sheet 3 Of 3)
Section 8: Service Kits
Service Kits (Contd)
Service Kit (Contd)
Service Kit (Contd)
Service Kits
Section 9: Lubricants, Adhesivesand Paints
Lubricants
Adhesives
Paints And Procedures
Section 10: Special Tools
Engine - Om 501 Service Tools, Kit 262126
Engine - Om 501 Service Tools, Kit 262130
Engine - Om 501 Service Tools, Kit 262131
Engine - Om 501 Service Tools, Kit 262132
Allison Transmission
Gear Ratio 17000 Transfer Case
Axles, Diffs & Final Drives, Repair & Ove
Suspension, Repair & Overhaul
Hydraulics, Repair & Overhaul
Frame & Oscillation Tools
Diagnostic Tools (Driveline)
Tyre Inflation Kit (Optional)
Section 11: Automatic Greasingsystem
Kit, Auto Greasing (Optional)
Greasing System Hoses Layout
Greasing Installation Main Lines
Front Twin Distribution Port Block
Middle Twin Distribution Port Blo
Rear Twin Distribution Port Block
Gina Programming Kit
Twin Pump Components
Section 12: Numerical Index
Brand: Bell
PIN:
Part Number: 872362
Start Of Manual
Important
Table Of Contents
Page Layout
Bulletins
Ordering Of Parts
Pin Identification
Engine Crankcase
Timing Case
Oil Pan & Dipstick
Camshaft
Fuel Lines
Turbocharger
Air Compressor
Exhaust Manifold
Adblue Pump Module
Starter Motor
Alternator - B40
Alternator - B35d
Alternator Support
Oil Pump
Oil Lines
Fan
Engine Support
Adblue Preheating
P.T.O
Catalyst
Depth Fuel Filter
Kit, Exhaust Stand
Air Intake Kit
Drop Box, Casing
Driveline Kit
Propshafts
Coupling, Pto
Thru Drive Kit
Park Brake Assembly
Actuator Assembly
Axle, Front
Axle, Middle
Axle, Rear, Caliper
Kit, Axle Guards
Brake, Wdb, Plate
Wet Disc Brake Pump
Fan Motor
Fan Motor Breakdown
Kit, Main Pump
Damper
Steering Cylinder
Brake Pedal
Pump, Cab Tilt
Fan Purging Kit
Purge Tank Valve
Reservoir Kit
Air Dryer Kit
Air Horn
Option, Rear Wiper
Cab, Memory Module
Engine Harness
Option, Cold Start
Light Breakdowns
Artic Harness
Battery Box
Rear Harness
Obw
Strain Gauge Kit
Cab Complete
Cab Shell
Cab Bottom Seals
Cab Door Assem
Cab Windows
Window Catches
Cab, Roller Blind
Door, Hvac System
Cab Sound Foam
Steering Column
Aircon Unit
Grill Kit - B35d
Grill Kit - B40d
Belly Plate Kit
Cab Clamps Kit
Rear Chassis Clamps
Cap, Diesel Filler
Artic Joint
Rear Chassis Kit
Bin Pivot
Wet Disc Brake Ta
Tailgate Kit
Bin Liner Kit
Manual Greasing Kit
Tailgate Grease Kit
Service Kit (Contd)
Service Kit (Contd)
Service Kits
Lubricants
Adhesives
- Bell Equipment B35D & B40D Repair manual Dumptruck ( Articulated )
- Bell Articulated Dump Truck B25D B30D 6x6 Repair Manual
- Bell Equipment B35D & B40D operation test manual Dumptruck ( Articulated )
- Bell Articulated Dump Truck B30E PIN A830E11 Parts Manual
- Bell Dumptruck Parts Manual B40D 6X6,ADT - 413840 B35D 6X6,OBW,ADT - 413835 B35D 6X6,OBW,WDB,ADT - 4
- Bell Equipment B30D MkVI ADT - A830D60 Parts Manual
- Bell DUMPTRUCK Operators manual
- Bell equipment
- Bell Equipment B25D Mk7.2 ADT - EA825D72 872335 Parts Manual
- Bell Equipment ARTICULATED DUMP TRUCK B25E PIN A825E22 Parts Manual
- Bell Articulated Dump Truck B25D & B30D 6x6 Repair Manual
- Bell Equipment B50D 6X6 SS ADT MK VI - A850D60 872241 Parts Manual
- BELL E-SERIES B18E B30E Articulated Dump Truck Operator's Manual 872353 REV A
- BELL E-SERIES B18E B30E Articulated Dump Truck Service Manual 872352 REV A
- Bell Equipment AH350D-400D Technical Manual
