BigBoss1
106
307,104
Bell Articulated Dump Truck B25E EURO Parts Manual BN037020
Brand: Bell
Type of Machine: Articulated Dump Truck
Model: Bell B25E EURO Articulated Dump Truck
PIN: A625E20
Part Number: BN037020
Publication Date: 2015
Number of Pages: 890 Pages
Parts Manual
Location Of Operations
Bulletins
Feedback Form
Introduction
Introduction
Parts Manual Overview
Machine Dimensions
Serial Number Plates
Pin Configuration
List Of Abbreviations
0100 Wheels And Tyres And Tracks
0110 Choice Wheel Set Assy
0200 Axles, Differentials And Suspension Systems
0200 Front Axle
0200 Front Axle Breather Kit
0200 Middle Axle Assy
0200 Rear Axle Assy
0200 Rear Axle Breather Kit
0200 Differential Housing Assy
0200 Housing Assy,Lsd
0200 Final Drive Assy
0200 Differential
0200 Limited Slip Diff Assy
0200 Middle Differential
0200 Rear Differential Assy
0200 Shim Kit
0200 Shim,Pack
0200 Shim Pack
0200 Front Axle Propshaft Assy
0200 Propshaft Breakdown
0200 Middle Axle Propshaft Assy
0200 Thru Drive Assy
0200 Middle Propshaft Breakdown
0200 Propshaft
0200 Rear Axle Propshaft Assy
0200 Propshaft
0200 T/Mission Propshaft Breakdown
0200 Front Suspension Mounting Assy
0200 Front Draglink
0200 Rear Suspension Mounting Assy
0200 Rear Draglink
0200 Pan Hard,Assy
0200 Std Rear Suspension,Kit (Choice)
0200 Comfort Ride Rear Suspension Kit (Choice)
0200 Comfort Ride Rear Suspension Assy
0200 Comfort Ride Walking Beam
0200 Std Suspension Strut Kit
0200 Front Suspension Strut Kit
0200 Suspension Strut Assy
0300 Transmission
0300 Transmission
0300 Transmission Micellaneous Parts
0300 Transmission, Flange
0300 Transmission, Torque Converter
0300 Transmission, P3 Planetary And Rear Cover
0300 Transmission, Main Housing
0300 Transmission, Converter Housing
0300 Transmission, P1 Planetary
0300 Transmission, Main Shaft
0300 Transmission, Rotating Clutch
0300 Transmission Pto
0300 Transmission, Front Support And Oil Pump
0300 Transmission, Control Valve(Part 1)
0300 Transmission, Control Valve (Part 2)
0300 Transmission, Fill Tube
0300 Transmission, Oil Cooler
0300 Transmission Breather Kit
0300 Transmission Cooling Assy
0400 Engine
0400 Engine Assy
0400 Engine,Miscellaneous
0400 Engine, Crankcase
0400 Engine, Flywheel Housing
0400 Engine, Oil Pan And Dipstick
0400 Engine, Cylinder Head & Valves
0400 Engine, Cylinder Head Rocker Arms
0400 Engine, Cylinder Head Cover
0400 Engine, Crankshaft & Flywheel
0400 Engine, Connecting Rods & Pistons
0400 Engine, Camshaft & Timing Parts
0400 Engine, Fuel Pump
0400 Engine, Fuel Lines
0400 Engine, Fuel Filter
0400 Engine, Turbocharger
0400 Engine, Air Compressor
0400 Engine, Air Compressor Attachments
0400 Engine, Inlet Manifold
0400 Engine, Exhaust Manifold
0400 Engine, Exhaust Gas Cooler
0400 Engine, Fuel Metering Device
0400 Engine, Electrical Harness
0400 Engine, Electrical Harness Connectors
0400 Engine, Electrical Harness Sensors
0400 Engine, Starter
0400 Engine, Alternator
0400 Engine, Oil Pump
0400 Engine, Oil Filter & Oil Cooler
0400 Engine, Oil Lines
0400 Engine, Water Pump
0400 Engine, Fan
0400 Engine, Brackets
0400 Engine, Airconditioner Compressor
0400 Engine, Exhaust Sensors
0500 Engine Auxiliary System
0500 Radiator Assembly
0500 Cooling Assembly
0500 Engine Cooler Shroud Assy
0500 Charge Air Cooler Assy
0500 Air Cleaner Assy
0500 Air Cleaner Breakdown
0500 Exhaust Mounting Assembly
0500 Adblue Assembly
0500 Adblue Tank
0500 Engine, Adblue Preheating
0500 Exhaust System Assy
0500 Engine, Adblue Metering Unit
0500 Adblue Pump Module
0500 Exhaust Heatshield Assy
0500 Engine, Catalyst
0500 Engine, Exhaust Control Unit
0500 Bin Heating Assy
0500 Non-Bin Heating Assy
0500 Engine Mounting Assembly
0500 Engine, Mountings
0500 Fuel System Assy
0500 Fuel Filter
0500 Fuel Heater Assy
0500 Fuel Sender Unit Assy
0500 Engine, Flamestart System
0500 Engine, Fuel Lines
0500 Fuel Tank Breather Assy
0500 Fuel Tank Assy
0500 Tank Fuel Assy
0800 Transfer Drive (Includes Splitters)
0800 Transfer Case,Assy
0800 Transfer Case Mounting Assy
0800 Transfer Case, Output Main Assy
0800 Transfer Case, Idler Assy
0800 Transfer Case, Input Assy
0800 Transfer Case, Housing Assy
0800 Transfer Case, Clutch Assy
0800 Transfer Case, Clutch Housing Assy
0800 T/Case, Output Gear And Clutch Assy (Part 1)
0800 T/Case, Output Gear And Clutch Assy (Part 2)
0800 Transfer Case, Planet Carrier Assy
0800 Transfer Case, Rear Output Assy
0800 Transfer Case, Bearing Housing Rear Assy
0800 Transfer Case, Flanges
0800 Transfer Case, Idler Shaft
0800 Transfer Case, Idler Insert
0800 Transfer Case, Pto Idler Insert
0800 Transfer Case, Rear Input Insert
0800 Transfer Case, Input Gear
0800 Transfer Case, Front Input Insert
0800 Transfer Case Breather Assy
0800 Top Mount Assy
0900 Steering System
0900 Emergency Steering Pump Assy(Choice)
0900 Emergency Steering Pump Breakdown
0900 Hose Hyd E-Steering Assy
0900 Cab Steering Column
0900 Steering Column Adt
0900 Steering Column Orbitol Mounting
0900 Steering Cylinder Assy
1000 Service Brakes
1000 Brake Pedal Mounting
1000 Manifold Brake Charge
1000 Brake Pedal Assy
1000 Brake Pedal
1000 Rear Brake Hose Kit
1000 Wdb Front Hose Kit
1000 Accumulator Assy
1000 Brake Caliper
1000 Park Brake Caliper
1000 Park Brake Caliper Breakdown
1300 Miscellaneous Vehicle
1300 Service Kits
1300 Recommended Adhesives
1300 Engine Service Tools (Sheet 1 Of 2)
1300 Engine Service Tools (Sheet 2 Of 2)
1300 Engine Repair Tools
1300 Transfer Case Tools
1300 Axles, Diffs And Final Drives Tools
1300 Suspension Tools
1300 Hydraulics Tools
1300 Frame And Oscillation Tools
1300 Driveline Diagnostic Tools
1300 Tyre Inflation Kit
1300 Recommended Paints And Procedures
1300 Decals And Serial Plates (Sheet 1 Of 5)
1300 Decals And Serial Plates (Sheet 2 Of 5)
1300 Decals And Serial Plates (Sheet 3 Of 5)
1300 Decals And Serial Plates (Sheet 4 Of 5)
1300 Decals And Serial Plates (Sheet 5 Of 5)
1300 Foreign Decals - German (Sheet 1 Of 8)
1300 Foreign Decals - Russian (Sheet 2 Of 8)
1300 Foreign Decals - French (Sheet 3 Of 8)
1300 Foreign Decals - Danish (Sheet 4 Of 8)
1300 Foreign Decals - Spanish (Sheet 5 Of 8)
1300 Foreign Decal - Polish (Sheet 6 Of 8)
1300 Foreign Decal - Swedish (Sheet 7 Of 8)
1300 Foreign Decal - English (Sheet 8 Of 8)
1300 Recommended Lubricants
1300 Manual Grease System W/O Tailgate(Choice)
1300 Manual Grease W/O Tailgate(Choice)
1300 Tailgate Greasing Assy(Choice)
1300 Auto Grease System W/O Tailgate
1300 Auto Greasing With Tailgate(Choice)
1300 Auto Grease System (Choice)
1300 Auto Greasing Pump Kit
1300 Twin Pump Auto Greasing
1300 Base Manual Greasing With Tailgate(Choice)
1300 Manual Grease Assy
1300 Base Manual Greasing(Choice)
1300 Bin Manual Grease System
1300 Bin Manual Greasing
1300 Bin Manual Greasing Breakdown
1300 Greasing Port 1
1300 Greasing Port 2
1300 Greasing Port 3
1600 Vehicle Electrical Systems
1600 Jump Start Cab Isolator Electrical Assy
1600 Chassis Isolator Elec Assy
1600 Jump Start Remote Cab Isolator Elect Breakdown
1600 Jump Start No Remote Elec Assy
1600 Electrical Isolator Assy
1600 Cab Isolator Elec Assy
1600 Cab Battery Box Electrical Assy
1600 Battery Box Elec Assy
1600 Battery Clamp Assy
1600 E-Module Dc/Dc Converter
1600 Artic Lights
1600 Bonnet Elec Assy
1600 Headlights
1600 Headlight Elect Assy
1600 Cab Worklight
1600 Cab Beacon, Elect Assy (Option)
1600 Cab Electric Assy
1600 E-Module Adm3
1600 Rear Electrical Assy
1600 Reverse Electrical Assy
1600 Artic Electric Assy
1600 E-Module Transmission
1600 Cab Load Lights(Option)
1600 Transmission Electrical Assy
1600 Engine Electrical Assy
1600 Scr Electric Assy
1600 Nosebox Elec Assy
1600 Cab Module Mounting Assy
1600 Cab Memory Module Elec Assy
1600 Walking Beam Active Strain Gauge
1600 Walking Beam Active Strain Gauge Kit
1600 Mid Chassis Active Strain Gauge Kit
1600 Rear Chassis Active Strain Gauge Kit
1600 Reverse Camera Elec Assy
1600 Reverse Camera Kit
1600 Hydraulic Sensors Electrical Assy
1600 Electrical Assy Artic Sensor
1600 Pneumatic Sensors Elec Assy
1600 Electrical Connector (Part 1)
1600 Electrical Connectors (Part 2)
1600 Electrical Connector (Part 3)
1600 Electrical Connectors (Part 4)
1600 Electrical Connector (Part 5)
1600 Electrical Connector (Part 6)
1700 Frame, Chassis Or Supporting Structure
1700 Front Chassis Assy
1700 Artic Joint
1700 Oscillation Chassis Assy
1700 Rear Chassis Assy
1700 Chassis Steering Lock
1700 Articulation Stopper Assy
1700 Front Belly Cover Assy
1700 Rear Cover Belly
1800 Operator's Station
1800 Cab Mounting Assy
1800 Interior Trim
1800 Cooler Box
1800 Cab Frame
1800 Cab Headlining
1800 Cab Mounting Brackets
1800 Cab Mount Lock
1800 Heat Shield
1800 Windows
1800 Button Window Kit
1800 Battery Box Cover
1800 Radio Assy Option
1800 Mirror Mountings
1800 Wide Mirrors
1800 Mirror Assembly Euro
1800 Cab Fire Extinguisher
1800 Sun Visor Assy
1800 Emergency Brake,Elec Assy
1800 Rear Cab Guard Assy
1800 External Cab Panel Assy
1800 Roof Assy
1800 Door Assy
1800 Delux Wiper Kit
1800 Wiper System
1800 Wiper Washer Bottle
1800 Window Washer Bottle
1800 Dashboard Panel
1800 Control Panel Console
1800 Trainer Seat Assy
1800 Euro Seat Assy
1800 Euro Seat Breakdown
1800 Step Assy
1800 Handrail Assy
1800 Handrail Assy(Option)
1800 Airconditioner Unit Assy
1800 Airconditioner Breakdown
1800 Airconditioner Kit
1800 Airconditioner Cab Ducting
1800 Airconditioner Receiver Drier
1900 Sheet Metal And Styling
1900 Nosebox,Lhs,Assy
1900 Bumper,Corner,Rhs,Assy
1900 Bumper Corner Lhs
1900 Bonnet Seals
1900 Bonnet Shell
1900 Bonnet Grille
1900 Bonnet Striker Pin Mounting Assy
1900 Bonnet Attachments
1900 Bonnet Stay Assy
1900 Bonnet Sound Absorption Kit
1900 Mudguard Assy
1900 Mudguard,Rhs
1900 Mudguard,Lhs
1900 Mudflap Assy
2100 Vehicle Main Hydraulic System
2100 Hydraulic Tank Assy
2100 Return Filter Assy
2100 Pressure Filter Assy(Choice)
2100 Filter Pressure Mounting
2100 Hydraulic Hose Assy
2100 Engine, High Pressure Oil Filter(Choice)
2100 Hydraulic Cab Tilt Pump
2100 Main Hydraulic Pump Assy
2100 Hydraulic Pump Breakdown
2100 Main Hydraulic Valve
2100 Hydraulic Valve Breakdown
2100 Bin Tip Valve Section
2100 Hydraulic Bridge Assy
2100 Hydraulic Suction & Return Hose
2100 Ls & Test Hose Assy
2100 Hydraulic Clamp Mountings
2100 Steering Control Valve
2100 Hydraulic Cab Tilt Hose Assy
2100 Steering Control Valve Assy
2100 Steering Control Valve Hose Assy
2100 Hydraulic Cooler Assy
2100 Hydraulic Hose Assy(Choice)
2100 Hyd Tank Assy
2100 Hydraulic Tank Cover
2100 Cab Lift Cylinder Kit
2100 Cab Tilt Lift Cylinder
2100 Hyd Bin Tip Front Hose Assy
2100 Hydraulic Bin Tip Assy
2100 Bin Tip Cylinder Assy
2100 Tip Cylinder
2200 Vehicle Pneumatic System
2200 Front Chassis Pneumatic Hose Assembly
2200 Rear Chassis Pneumatic Hose Assembly
2200 Pneumatic Valve Assy
2200 Pneumatic Scr Assy
2200 Pneumatic Cooling Coil Assy
2200 Pneumatic Air Drier Assy
2200 Pneumatic Air Dryer Kit
2200 Pneumatic 30lt Reservoir
3500 Haulage Device (Scraper And Adt)
3500 Bin Pole Assy
3500 Bin-Up Lock
3500 Bin Assy
3500 Bin Liner
3500 Bin Tailgate
3500 Greedy Board
3500 Bin Mudflaps
Functional Groups
Index
