Bell Articulated Dump Truck B16B 6X2 Parts Manual 870150
Brand: Bell
Type of Machine: Articulated Dump Truck
Type of Manual: Parts Manual, ELectrical Schematic
Model: Bell B16B 6X2 Articulated Dump Truck
VIN: AEB 404821 TRO 00189 to 00522 ; AEB 404821 VRO 00474 to 00813
Part Number: 870150
Publication Date: 1997
Number of Pages: 285 Pages
Section 1 General Information
Bulletins
List Of Abbreviations
Ordering Of Parts
Machine Dimension
Serial Number Plates
Service Kits
Section 2 Engine
Engine And Miscellaneous Parts
Engine Coupling (Kuzel K030)
Air Cleaner System (Ade 366t)
Air Cleaner (12 Inch)
Pre Cleaner (127 Mm Outlet)
Exhaust System
Fuel System (Ade 366ti)
Throttle Assembly (Upto 09.12.95)
Throttle Assembly (From 10.12.95)
Stop Cable Assembly
Baffle Rubbers (Cooling System)
Section 3 Power Train
Transmission And Miscellaneous Parts
Mechanical C Clamp Brake Assembly
Oil Cooler Assembly
Propshaft Layout
Propshaft Assembly
Propshaft Assembly
Front Axle And Miscellaneous Parts
Axle Assembly (Dual - 1350 Crs)
Front Axle Assembly (2.84x4.82)
Differential Assembly (2,84:1)
Brake Caliper
Brake Assembly (Drum)
Wheel Assembly (14.00x20)
Wheel Assembly (15.00x20)
Section 4a Hydraulic System
Hydraulic System Front
Hydraulic System Rear
Hydraulic Tank
Hydraulic Filter/ Breather Assembly
Control Valve (One Bank)
Priority Valve
Steering Valve (From 02.09.94)
Steering Valve
Hydraulic Filter Assembly
Tip Cylinder
Steering Cylinder
Special Tools
Section 4b Pneumatic System
Pneumatic System Front (Upto 31.08.95)
Pneumatic System Front (From 01.10.96)
Pneumatic System Rear
Retarder System
Air Spring Assembly
Push Button Valve
Park Brake Spring Actuator
Brake Actuator Assembly(Spring- Type 2430)
Relay Emergency Valve
Park Brake Valve
Pressure Protection Valve
Quick Release Valve
Check Valve
Levelling Valve
Unloader Valve With Integral Air Drier Assembly
Brake Valve
Control Valve
Brake Valve Adaptor
Unloader Valve
Section 4c Electrical System
Electrical Circuit - Starting/Charging
Electrical Circuit - Lighting
Electrical Circuit - Stop Light/ Horn
Electrical Circuit - Reverse And Exhaust Brake
Electrical Circuit - Gauges And Warning Lights
Electrical Circuit - Indicator / Hazard
Electrical Circuit - Blower And Wiper
Electrical Circuit - Aircon And Wiper
Est 17 Transmission (Cab)
Est 17 Transmission (Exterior)
Est 25 Transmission (Cab)
Est 25 Transmission (Exterior)
Connectors 1 & 2
Connectors 3,4,5 & 6
Connectors 7,8,9 & 10
Electronic Speedo And Other Accessories
Instrument Panel Assembly
Cold Start Instrument Panel
Distribution Box
Battery,Clamps And Cables
Windscreen Wiper Assembly
Headlight (Upto 05 Sept 93)
Indicator
Horn Assembly
Special Tools
Section 5 Frame And Body
Cab And Cowlings
Bonnet Latch
Cab Exterior Fittings (Up To Tba)
Cab Exterior Fittings (From Tba)
Cab Interior Fittings
Door Handle Assembly
Seat Assembly (From Oct 1993)
Steering Column Assembly (Upto 01/07/96)
Steering Column Assembly(From 01/07/96)
Blower Assembly
Air Conditioner Assembly(Reddot)
Air Conditioner Assembly(Sanden)
Front Frame
Rear Frame
Articulation And Oscillation Assembly
Steering Cylinder Mountings
Tip Cylinder Mountings
Bin Prop / Support Extension Assembly
Reverse Warning Buzzer Mounting Assembly
Bin (9m³)
Decals Left Hand Side
Decals Right Hand Side
Special Tools
Brand: Bell
Part Number: 870150
Bulletins
Ordering Of Parts
Machine Dimension
Service Kits
Section 2 Engine
Exhaust System
Stop Cable Assembly
Oil Cooler Assembly
Propshaft Layout
Propshaft Assembly
Propshaft Assembly
Brake Caliper
Hydraulic Tank
Priority Valve
Steering Valve
Tip Cylinder
Steering Cylinder
Special Tools
Retarder System
Air Spring Assembly
Push Button Valve
Park Brake Valve
Quick Release Valve
Check Valve
Levelling Valve
Brake Valve
Control Valve
Brake Valve Adaptor
Unloader Valve
Connectors 1 & 2
Distribution Box
Indicator
Horn Assembly
Special Tools
Cab And Cowlings
Bonnet Latch
Blower Assembly
Front Frame
Rear Frame
Bin (9m³)
Special Tools
- Bell Equipment B35D & B40D Repair manual Dumptruck ( Articulated )
- Bell Articulated Dump Truck B25D B30D 6x6 Repair Manual
- Bell Equipment B35D & B40D operation test manual Dumptruck ( Articulated )
- Bell Articulated Dump Truck B30E PIN A830E11 Parts Manual
- Bell Dumptruck Parts Manual B40D 6X6,ADT - 413840 B35D 6X6,OBW,ADT - 413835 B35D 6X6,OBW,WDB,ADT - 4
- Bell Equipment B30D MkVI ADT - A830D60 Parts Manual
- Bell DUMPTRUCK Operators manual
- Bell equipment
- Bell Equipment B25D Mk7.2 ADT - EA825D72 872335 Parts Manual
- Bell Equipment ARTICULATED DUMP TRUCK B25E PIN A825E22 Parts Manual
- Bell Articulated Dump Truck B25D & B30D 6x6 Repair Manual
- Bell Equipment B50D 6X6 SS ADT MK VI - A850D60 872241 Parts Manual
- BELL E-SERIES B18E B30E Articulated Dump Truck Operator's Manual 872353 REV A
- BELL E-SERIES B18E B30E Articulated Dump Truck Service Manual 872352 REV A
- Bell Equipment AH350D-400D Technical Manual
