Momed80
150
35,046
Baudouin Engine 12M26 Series Service Manual
Brand: Baudouin
Model: Baudouin 12M26 Series Diesel Engine for Land Power Generators
Number of Pages: 145 Pages
Chapter I General Information
1.1 External View of the Diesel Engine
1.2 Model Meaning of Diesel Engine
1.3 Basic parameters of diesel engine
1.4 Operation Notice for New Diesel Engine
1.5 Hoisting of Diesel Engine
1.6 Unpacking of Diesel Engine
1.7 Preparations before Start
1.8 Startup of Diesel Engine
1.9 Running of Diesel Engine
1.10 Stop of Diesel Engine
Chapter II Maintenance Guide
2.1 Fuel, Lubricating Oil, Coolant, and Auxiliary Materials for Diesel Engine
2.1.1 Fuel
2.1.2 Engine lubricating oil
2.1.3 Engine coolant
2.1.4 Auxiliary materials
2.2 Daily maintenance
2.2.1 Daily service
2.2.2 Daily Maintenance
2.3 Level-specific maintenance
2.4 Maintenance for Long-Term Storage of Diesel Engine
Chapter III Typical Malfunctions and Troubleshooting of Diesel Engine
3.1 Diagnostic method
3.2 General malfunction causes and troubleshooting of diesel engine
3.2.1 Start failure of diesel engine
3.2.2 Stop of engine shortly after start
3.2.3 Low power
3.2.4 Excessive fuel consumption
3.2.5 Black exhaust gas
3.2.6 White or blue exhaust gas
3.2.7 Deposit of engine oil at air inlet port and air inlet pipe of turbocharger
3.2.8 Unstable speed
3.2.9 Engine oil pressure too low
3.2.10 High coolant temperature
3.2.11 Excessive wear of parts
3.2.12 Excessive noise
3.2.13 Working failure of starter motor
3.2.14 Weak starter motor
Chapter IV Dismantling and Assembling of Engine
4.1 Overview
4.1.1 Danger signs
4.1.2 Safety signs
4.1.3 Tools
4.1.4 Precautions for health protection
4.1.5 Environmental protection measures
4.1.6 Precautions for dismantling and assembling of diesel engine
4.2 Cylinder head subassembly
4.2.1 Cylinder head
4.2.2 Dismantling procedures
4.2.3 Assembling procedures
4.2.4 Disassembling, checking, repair, and assembling essentials
4.3 Engine Block Group
4.3.1 Flywheel cover
4.3.2 Cylinder block
4.3.3 Oil sump and piston cooling nozzle parts
4.4 Crank Connecting Rod Mechanism
4.4.1 Crankshaft and flywheel subassembly
4.4.2 Piston and connecting rod
4.5 Valve mechanism
4.5.1 Rocker arm
4.5.2 Camshaft
4.5.3 Timing gear
4.6 Intake and exhaust system
4.6.1 Intake and Exhaust Systems
4.6.2 Turbocharging system
4.6.3 Turbocharger
4.7 Fuel system
4.7.1 Fuel System
4.7.2 Fuel filter
4.7.3 Fuel pump
4.8 Cooling System
4.8.1 Cooling circuit
4.8.2 Thermostat
4.8.3 Water pump
4.8.4 Fan
4.9 Lubrication System
4.9.1 Lubrication System
4.9.2 Oil cooler
4.10 Startup system
4.10.1 Start-up system
4.10.2 Starter
4.10.3 Malfunction diagnosis and troubleshooting of charging system
4.10.4 Generator
Annex A Recommended Torque for Standard Bolts
Annex B Recommended Torque for Hollow Bolts
Appendix C Fit Clearances for Main Parts of Diesel Engine
