Hyundai
86
178,785
Ausa Taurulift T306H T307H Operation Manual
Brand: Ausa
Type of Machine: Taurulift
Type of Manual: Operation Manual, Electric and Hydraulic Diagrams
Model: Ausa T306H T307H Taurulift
above chassis number 33268001
Number of Pages: 154 Pages
1 General Information
1.1 How to identify your machine​
1.1.1 Machine directions​
1.1.2 Warning plates and labels on the machine​
1.1.3 Symbols used on the machine​
1.2 How to identify the machine​
1.2.1 Model and type​
1.2.2 Manufacturer​
1.2.3 Identification plates​
1.2.4 Ec marking​
1.2.5 Frame number​
1.2.6 Engine serial number​
1.3 Acceptable use​
1.3.1 Acceptable use​
1.3.2 Unacceptable use​
1.3.3 Operator risks​
1.3.4 Applicable standards​
1.3.5 Safety devices​
1.4 General description​
1.4.1 Main parts​
1.4.2 Description of the main parts​
1.4.3 Optional accessories​
1.5 Technical data​
1.5.1 Diesel engine​
1.5.2 Transmission​
1.5.3 Steering​
1.5.4 Brakes​
1.5.5 Standard tyres​
1.5.6 Service temperature​
1.5.7 Hydraulic circuit​
1.5.8 Capacity/dimensions​
1.5.9 Forks​
1.5.10 Electrical equipment​
1.5.11 Vibration and noise levels​
1.5.12 Forklift measurements​
1.6 Duration of use​
1.7 Accessories included​
1.7.1 Documentation provided​
2 Special safety messages
2.1 General information​
2.2 Prerequisites for personnel​
2.2.1 Prerequisites for operators​
2.2.2 Prerequisites for personnel in charge of maintenance​
2.2.3 Work and maintenance clothing​
2.2.4 Personal protection equipment​
2.3 Safety standards​
2.3.1 Working area​
2.3.2 Prior preparation​
2.3.3 During work and maintenance​
2.3.4 Parking the forklift and stopping the engine​
2.4 Safety devices​
2.5 Overload system​
3 Operating instructions
3.1 Before entering the machine​
3.2 Accessing the machine​
3.2.1 Accessing the cab​
3.2.1.1 Exiting the cab in an emergency situation (if fitted)​
3.2.2 Adjusting the seat​
3.2.3 Adjusting the seat belt​
3.2.4 Adjusting the rear view mirrors​
3.2.5 Use of the courtesy light (if fitted)​
3.3 Control panel​
3.3.1 Controls​
3.3.2 Engine controls​
3.3.2.1 Starter switch​
3.3.2.2 Forward/reverse selector​
3.3.2.3 Back-up alarm and speed selector​
3.3.2.4 Brakes​
3.3.2.5 Throttle​
3.3.2.6 Turning system​
3.3.2.7 Road - job site switch​
3.3.2.8 Auxiliary driving controls​
3.3.2.8.1 Rotating beacon​
3.3.2.8.2 Hazard warning lights (if fitted)​
3.3.2.8.3 Job lights (if fitted)​
3.3.2.8.4 Continuous and high flow switch (if fitted)​
3.3.2.8.5 Fan speed regulator (if fitted)​
3.3.2.8.6 Hot air temperature regulator (if fitted)​
3.3.2.8.7 Air conditioning (if fitted)​
3.3.3 Gauges and indicators​
3.3.3.1 Gauges​
3.3.3.2 Indicators​
3.3.4 Joystick​
3.3.4.1 Selection of movements​
3.3.4.1.1 Standard machine​
3.3.4.1.2 Inverse controls (optional)​
3.3.4.2 Emergency stop​
3.3.4.2.1 Deactivation of the overload system​
3.3.4.3 lifting/lowering of the extending arm​
3.3.4.4 Forward/back tilt of the fork carriage​
3.3.4.4.1 Standard machine​
3.3.4.4.2 Inverse controls (optional)​
3.3.4.5 Extension/retraction of the extending arm​
3.3.4.5.1 Standard machine​
3.3.4.5.2 Inverse controls (optional)​
3.3.4.6 Auxiliaries hydraulic take-off (if fitted)​
3.3.4.6.1 4th valve​
3.3.4.6.2 5th valve (if fitted)​
3.3.4.7 Attachment of tools​
3.4 Start-up​
3.4.1 Before starting the engine​
3.4.1.1 Machine start-up check list​
3.4.2 Start-up​
3.4.3 Start the engine using an external source​
3.4.4 Start up at low temperatures​
3.4.5 Disconnecting the battery​
3.4.6 Start-up of the machine​
3.4.7 Parking the forklift and cutting the engine​
3.5 Use of the forklift​
3.5.1 Machine nominal load​
3.5.1.1 Load Centre (fig. 1)​
3.5.1.2 Load Capacity​
3.5.2 Use of the load chart​
3.5.2.1 Load charts (except USA and Australia)​
3.5.2.2 Load charts (USA market)​
3.5.2.3 Load charts (Australian market)​
3.5.3 Overload system​
3.5.3.1 Overload system calibration procedure.​
3.5.3.1.1 Standard machines​
3.5.3.1.2 Standard for Australian market (optional)​
3.5.3.2 Usage​
3.5.3.2.1 Standard machines​
3.5.3.2.2 Standard for Australian market (optional)​
3.5.4 Handling loads​
3.5.4.1 Adjustment of forks​
3.5.4.2 Working phases​
3.5.5 Replacement of tools​
3.5.6 Transporting towed loads​
3.6 Transporting the machine​
3.6.1 Towing a damaged machine​
3.6.2 Transfer by road and jobs​
3.6.3 Loading the machine with a crane​
3.6.4 Transport on another vehicle​
3.6.5 Parking and non-operational machines​
3.6.5.1 Short stops​
3.6.5.2 Extended stops​
3.6.6 Cleaning and washing the machine​
3.6.6.1 Cleaning instructions​
3.6.6.2 Washing the machine​
3.6.7 Elimination​
3.6.7.1 Elimination of batteries​
4 Periodic maintenance operations
4.1 Lubricants, Safety and Hygiene standards​
4.2 Scheduled maintenance​
4.2.1 Lubrication and maintenance chart​
4.3 Maintenance operations​
4.3.1 Disconnecting the battery​
4.3.2 Access to engine, cab and tank compartments​
4.3.3 Supply circuit​
4.3.4 Grease​
4.3.5 Tyres and wheels​
4.3.6 Brakes​
4.3.6.1 Brake oil level​
4.3.7 Engine air filter​
4.3.8 Cab air filter​
4.3.9 Engine coolant circuit​
4.3.10 Tank oil level​
4.3.10.1 Replacing hydraulic fluid​
4.3.10.2 Suction oil filter​
4.3.11 Replacement of the hydrostatic transmission filter element​
4.3.11.1 Hydrostatic transmission filter​
4.3.11.2 Regulation of the pressure regulation valves in the hydraulic circuit (fig. 1, 2)​
4.3.11.3 Hydraulic hoses​
4.3.12 Transfer box and differential oil level​
4.3.12.1 Front and rear differential​
4.3.12.2 Transfer box​
4.3.13 Reduction gear oil level (front and rear)​
4.3.14 Re-adjustment of the longitudinal axis of the wheels​
4.3.15 Regulation of clearance for the arm section guides​
4.3.16 Checking safety devices​
4.3.17 Engine oil​
4.3.17.1 Engine oil level​
4.3.17.2 Changing the oil and the oil filter​
4.3.18 Alternator belt​
4.4 Electric installation​
4.4.1 Battery​
4.4.2 Fuses - relays​
4.4.3 12 v supply lamps​
4.5 Liquids and lubricants​
4.5.1 Refuelling​
4.5.2 Product details​
4.5.2.1 Engine oil​
4.5.2.2 Lubricants, oils and filter cartridges​
4.5.2.3 Fuel​
4.5.2.4 Greases​
4.5.2.5 Brakes & Inching​
5 Diagrams
and charts
5.1 Screw torques​
5.2 Forklift actuation hydraulic diagram​
5.2.1 Standard machines and Inverse controls machines (optional)​
5.2.2 Continuous and high flow machines​
5.3 Extending arm hydraulic diagram​
5.4 Transmission hydraulic diagram​
5.4.1 T306H 2 speeds​
5.4.2 T306H / T307H 1 speed​
5.5 Wiring diagram​
5.6 Identification of failures in hydrostatic transmissions​
6 Ec certificate of conformity
